| 1 |
/* RCSid: $Id: holo.h,v 3.27 2010/09/30 15:43:30 greg Exp $ */ |
| 2 |
| 3 |
* Header file for holodeck programs |
| 4 |
| 5 |
* 9/29/97 GWLarson |
| 6 |
| 7 |
#ifndef _RAD_HOLO_H_ |
| 8 |
#define _RAD_HOLO_H_ |
| 9 |
| 10 |
#include "standard.h" |
| 11 |
#include "color.h" |
| 12 |
| 13 |
#ifdef __cplusplus |
| 14 |
extern "C" { |
| 15 |
#endif |
| 16 |
| 17 |
#ifndef HDMAX |
| 18 |
#define HDMAX 128 /* maximum active holodeck sections */ |
| 19 |
#endif |
| 20 |
| 21 |
#ifndef MAXDIRSE |
| 22 |
#define MAXDIRSE 32 /* maximum seeks per directory write */ |
| 23 |
#endif |
| 24 |
| 25 |
#define DCINF (unsigned)((1L<<16)-1) /* special value for infinity */ |
| 26 |
#define DCLIN (unsigned)(1L<<11) /* linear depth limit */ |
| 27 |
| 28 |
typedef struct { |
| 29 |
uby8 r[2][2]; /* ray direction index */ |
| 30 |
COLR v; /* color value */ |
| 31 |
uint16 d; /* depth code (from entry wall) */ |
| 32 |
} RAYVAL; /* ray value */ |
| 33 |
| 34 |
| 35 |
* Walls are ordered: X0 X1 X2 WN |
| 36 |
* 0 ? ? 0 |
| 37 |
* 1 ? ? 1 |
| 38 |
* ? 0 ? 2 |
| 39 |
* ? 1 ? 3 |
| 40 |
* ? ? 0 4 |
| 41 |
* ? ? 1 5 |
| 42 |
| 43 |
* Grid on wall WN corresponds to X(WN/2+1)%3 and X(WN/2+2)%3, resp. |
| 44 |
| 45 |
| 46 |
typedef struct { |
| 47 |
short w; /* wall number */ |
| 48 |
short i[2]; /* index on wall grid */ |
| 49 |
} GCOORD; /* grid coordinates (two for beam) */ |
| 50 |
| 51 |
typedef struct { |
| 52 |
uint32 nrd; /* number of beam rays bundled on disk */ |
| 53 |
off_t fo; /* position in file */ |
| 54 |
} BEAMI; /* beam index */ |
| 55 |
| 56 |
typedef struct { |
| 57 |
uint32 nrm; /* number of beam rays bundled in memory */ |
| 58 |
uint32 tick; /* clock tick for LRU replacement */ |
| 59 |
} BEAM; /* followed by nrm RAYVAL's */ |
| 60 |
| 61 |
#define hdbray(bp) ((RAYVAL *)((bp)+1)) |
| 62 |
#define hdbsiz(nr) (sizeof(BEAM)+(nr)*sizeof(RAYVAL)) |
| 63 |
| 64 |
typedef struct { |
| 65 |
FVECT orig; /* prism origin (first) */ |
| 66 |
FVECT xv[3]; /* side vectors (second) */ |
| 67 |
int16 grid[3]; /* grid resolution (third) */ |
| 68 |
} HDGRID; /* holodeck section grid (must match HOLO struct) */ |
| 69 |
| 70 |
typedef struct holo { |
| 71 |
| 72 |
| 73 |
| 74 |
int fd; /* file descriptor */ |
| 75 |
struct { |
| 76 |
int s, n; /* dirty section start, length */ |
| 77 |
} dirseg[MAXDIRSE+1]; /* dirty beam index segments */ |
| 78 |
short dirty; /* number of dirty segments */ |
| 79 |
double tlin; /* linear range for depth encoding */ |
| 80 |
FVECT wg[3]; /* wall grid vectors (derived) */ |
| 81 |
int wi[6]; /* wall super-indices (derived) */ |
| 82 |
char *priv; /* pointer to private client data */ |
| 83 |
BEAM **bl; /* beam pointers (memory cache) */ |
| 84 |
BEAMI bi[1]; /* beam index (extends struct) */ |
| 85 |
} HOLO; /* holodeck section */ |
| 86 |
| 87 |
typedef struct { |
| 88 |
HOLO *h; /* pointer to holodeck */ |
| 89 |
int b; /* beam index */ |
| 90 |
} HDBEAMI; /* holodeck beam index */ |
| 91 |
| 92 |
#define nbeams(hp) (((hp)->wi[5]-1)<<1) |
| 93 |
#define biglob(hp) ((hp)->bi) |
| 94 |
#define blglob(hp) (*(hp)->bl) |
| 95 |
| 96 |
#define bnrays(hp,i) ((hp)->bl[i]!=NULL ? (hp)->bl[i]->nrm : (hp)->bi[i].nrd) |
| 97 |
| 98 |
#define hdflush(hp) (hdfreebeam(hp,0), hdsync(hp,0)) |
| 99 |
#define hdclobber(hp) (hdkillbeam(hp,0), hdsync(hp,0)) |
| 100 |
| 101 |
| 102 |
extern HOLO *hdinit(), *hdalloc(); |
| 103 |
extern BEAM *hdgetbeam(); |
| 104 |
extern RAYVAL *hdnewrays(); |
| 105 |
extern unsigned hdmemuse(); |
| 106 |
extern off_t hdfiluse(), hdfilen(), hdallocfrag(); |
| 107 |
extern double hdray(), hdinter(); |
| 108 |
extern unsigned hdcode(); |
| 109 |
extern int hdfilord(); |
| 110 |
| 111 |
| 112 |
#define FF_NEVER 0 /* never free fragments */ |
| 113 |
#define FF_WRITE 01 /* free fragment on write */ |
| 114 |
#define FF_ALLOC 02 /* free fragment on ray alloc */ |
| 115 |
#define FF_READ 04 /* free fragment on read */ |
| 116 |
#define FF_KILL 010 /* free fragment on beam kill */ |
| 117 |
| 118 |
extern int hdfragflags; /* tells when to free fragments */ |
| 119 |
extern unsigned hdcachesize; /* target cache size (bytes) */ |
| 120 |
extern unsigned long hdclock; /* holodeck system clock */ |
| 121 |
extern HOLO *hdlist[HDMAX+1]; /* holodeck pointers (NULL term.) */ |
| 122 |
| 123 |
extern float hd_depthmap[]; /* depth conversion map */ |
| 124 |
| 125 |
extern int hdwg0[6]; /* wall grid 0 index */ |
| 126 |
extern int hdwg1[6]; /* wall grid 1 index */ |
| 127 |
| 128 |
#define hddepth(hp,dc) ( (dc) >= DCINF ? FHUGE : \ |
| 129 |
(hp)->tlin * ( (dc) >= DCLIN ? \ |
| 130 |
hd_depthmap[(dc)-DCLIN] : \ |
| 131 |
((dc)+.5)/DCLIN ) ) |
| 132 |
| 133 |
#define HOLOFMT "Holodeck" /* file format identifier */ |
| 134 |
#define HOLOVERS 0 /* file format version number */ |
| 135 |
#define HOLOMAGIC (324+sizeof(BEAMI)+16*HOLOVERS) /* file magic number */ |
| 136 |
| 137 |
| 138 |
* A holodeck file consists of an information header terminated by a |
| 139 |
* blank line, with "FORMAT=Holodeck" somewhere in it. |
| 140 |
* The first integer after the information header is the |
| 141 |
* above magic number, which includes the file format version number. |
| 142 |
* The first longword (off_t) after the magic number is a pointer to the |
| 143 |
* pointer just before the SECOND holodeck section, or 0 if there is only one. |
| 144 |
* This longword is immediately followed by the first holodeck |
| 145 |
* section header and directory. |
| 146 |
* Similarly, every holodeck section in the file is preceeded by |
| 147 |
* a pointer to the following section, or 0 for the final section. |
| 148 |
* Since holodeck files consist of directly written C data structures, |
| 149 |
* they are not generally portable between different machine architectures. |
| 150 |
* In particular, different floating point formats or bit/byte ordering |
| 151 |
* will make the data unusable. This is unfortunate, and may be changed |
| 152 |
* in future versions, but we thought this would be best for paging speed |
| 153 |
* in our initial implementation. |
| 154 |
| 155 |
| 156 |
/* clumpbeams.c */ |
| 157 |
extern void clumpbeams(HOLO *hp, int maxcnt, int maxsiz, |
| 158 |
int (*cf)(HOLO *hp, int *bqueue, int bqlen)); |
| 159 |
/* holo.c */ |
| 160 |
extern void hdcompgrid(HOLO *hp); |
| 161 |
extern int hdbcoord(GCOORD gc[2], HOLO *hp, int i); |
| 162 |
extern int hdbindex(HOLO *hp, GCOORD gc[2]); |
| 163 |
extern void hdcell(FVECT cp[4], HOLO *hp, GCOORD *gc); |
| 164 |
extern int hdlseg(int lseg[2][3], HOLO *hp, GCOORD gc[2]); |
| 165 |
extern unsigned int hdcode(HOLO *hp, double d); |
| 166 |
extern void hdgrid( FVECT gp, HOLO *hp, FVECT wp); |
| 167 |
extern void hdworld(FVECT wp, HOLO *hp, FVECT gp); |
| 168 |
extern double hdray(FVECT ro, FVECT rd, HOLO *hp, GCOORD gc[2], uby8 r[2][2]); |
| 169 |
extern double hdinter(GCOORD gc[2], uby8 r[2][2], double *ed, HOLO *hp, |
| 170 |
FVECT ro, FVECT rd); |
| 171 |
/* holofile.c */ |
| 172 |
extern HOLO * hdinit(int fd, HDGRID *hproto); |
| 173 |
extern void hddone(HOLO *hp); |
| 174 |
extern int hdsync(HOLO *hp, int all); |
| 175 |
extern off_t hdfilen(int fd); |
| 176 |
extern off_t hdfiluse(int fd); |
| 177 |
extern RAYVAL * hdnewrays(HOLO *hp, int i, int nr); |
| 178 |
extern BEAM * hdgetbeam(HOLO *hp, int i); |
| 179 |
extern void hdloadbeams(HDBEAMI *hb, int n, void (*bf)(BEAM *bp, HDBEAMI *hb)); |
| 180 |
extern int hdfreebeam(HOLO *hp, int i); |
| 181 |
extern int hdfreefrag(HOLO *hp, int i); |
| 182 |
extern int hdfragOK(int fd, int *listlen, int32 *listsiz); |
| 183 |
extern int hdkillbeam(HOLO *hp, int i); |
| 184 |
| 185 |
| 186 |
| 187 |
| 188 |
#endif |
| 189 |
#endif /* _RAD_HOLO_H_ */ |
| 190 |
