root/radiance/src/hd/holo.h
Thu Sep 9 01:06:19 2004 UTC (21 years, 1 month ago) by greg
Diff to previous 3.24
Thu Jan 1 11:21:55 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 3.23: +32 -1 lines
Diff to previous 3.23
Ansification and prototypes.
Mon Jul 14 22:24:00 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.22: +14 -1 lines
Diff to previous 3.22
Fri Jun 20 00:25:49 2003 UTC (22 years, 4 months ago) by greg
Changes since 3.21: +6 -6 lines
Diff to previous 3.21
Thu May 29 16:26:21 2003 UTC (22 years, 4 months ago) by greg
Diff to previous 3.20
Sat Feb 22 02:07:24 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.19: +1 -4 lines
Diff to previous 3.19
Thu Jan 7 22:04:48 1999 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.18: +8 -1 lines
Diff to previous 3.18
Fri Dec 4 11:37:47 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.17: +0 -1 lines
Diff to previous 3.17
got rid of unnecessary constants in HOLO struct
Mon Nov 9 17:10:53 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.16: +8 -1 lines
Diff to previous 3.16
changed section directory code to write in segments
Thu Nov 5 09:09:32 1998 UTC (26 years, 11 months ago) by gwlarson
Diff to previous 3.15
fixed hdflush() and hdclobber() macros
Wed Aug 12 17:54:15 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.14: +4 -10 lines
Diff to previous 3.14
moved int2 and int4 definitions to standard.h
Wed Jan 7 21:27:29 1998 UTC (27 years, 9 months ago) by gregl
Changes since 3.13: +2 -1 lines
Diff to previous 3.13
added declaration of hdfilord()
Tue Jan 6 15:08:50 1998 UTC (27 years, 9 months ago) by gregl
Changes since 3.12: +5 -3 lines
Diff to previous 3.12
Sun Jan 4 12:32:52 1998 UTC (27 years, 9 months ago) by gregl
Changes since 3.11: +1 -1 lines
Diff to previous 3.11
took fragment resource management out of hdsyncbeam()
Thu Jan 1 10:12:24 1998 UTC (27 years, 9 months ago) by gregl
Changes since 3.10: +1 -1 lines
Diff to previous 3.10
changed magic number to incorporate sizeof(long)
Wed Dec 24 10:52:44 1997 UTC (27 years, 9 months ago) by gregl
Diff to previous 3.9
changed default int4 from long to int
Thu Dec 18 14:45:59 1997 UTC (27 years, 10 months ago) by gregl
Changes since 3.8: +8 -2 lines
Diff to previous 3.8
Tue Dec 16 15:01:25 1997 UTC (27 years, 10 months ago) by gregl
Changes since 3.7: +1 -1 lines
Diff to previous 3.7
added declaration for hdfilen()
Fri Dec 12 19:52:31 1997 UTC (27 years, 10 months ago) by gregl
Diff to previous 3.6
modified hdsync() to optionally sync all unflushed beams
Thu Dec 11 11:47:57 1997 UTC (27 years, 10 months ago) by gregl
Changes since 3.5: +3 -2 lines
Diff to previous 3.5
added function to delete beams and clobber holodecks
Tue Nov 11 16:59:34 1997 UTC (27 years, 11 months ago) by gregl
Diff to previous 3.4
simplified intersection code
added hdgrid() routine to compute grid coordinates
Tue Nov 11 15:13:33 1997 UTC (27 years, 11 months ago) by gregl
Diff to previous 3.3
added declaration for hdalloc()
Mon Nov 10 18:04:05 1997 UTC (27 years, 11 months ago) by gregl
Changes since 3.2: +1 -1 lines
fixed macro
Thu Nov 6 16:37:45 1997 UTC (27 years, 11 months ago) by gregl
changed BCOORD to GCOORD[2]
Fri Oct 31 10:23:29 1997 UTC (27 years, 11 months ago) by gregl
