root/radiance/src/hd/SConscript
Revision: 1.10
Committed: Thu Mar 10 21:43:23 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.9: +9 -14 lines
1 import os
2
3 Import('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def radbin(name): return os.path.join('$RAD_BUILDBIN', name)
10 def radlib(name): return os.path.join('$RAD_BUILDLIB', name)
11
12 # common objects
13 viewbeams = env.Object(source='viewbeams.c')
14 holo = env.Object(source='holo.c')
15 holofile = env.Object(source='holofile.c')
16 clumpbeams = env.Object(source='clumpbeams.c')
17
18 # standard targets
19 PROGS = (
20 ('rholo', Split('''rholo.c rholo2.c rholo2l.c rholo3.c rholo4.c''')
21 + [env.version, holofile, holo, viewbeams], ['rtrad'],0),
22 ('rhpict', Split('rhpict.c rhpict2.c')+[env.version, holofile, holo, viewbeams],
23 ['rtrad'],1),
24 ('rhcopy', Split('rhcopy.c') + [clumpbeams, holofile, holo], ['rtrad'],1),
25 ('rhinfo', Split('rhinfo.c') + [holofile, holo], ['rtrad'],1),
26 ('rhoptimize', Split('rhoptimize.c') + [clumpbeams,holofile,holo], ['rtrad'],1),
27 ('genrhgrid', Split('genrhgrid.c') + [holofile, holo], ['rtrad'],1),
28 )
29 if 1:
30 for p in PROGS:
31 print(p[0])
32 if not p[3] and os.name == 'nt': continue
33 prog = env.Program(target=radbin(p[0]),
34 source=p[1], LIBS=p[2] + mlib)
35 Default(prog)
36 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
37
38 # display drivers
39 if env.has_key('X11INCLUDE'):
40 xenv = env.Clone(CPPPATH=[env['X11INCLUDE']] + env['CPPPATH'],
41 LIBPATH=[env['X11LIB']] + env['LIBPATH'],)
42 # common objects
43 rhdisp = xenv.Object(source='rhdisp.c')
44 rhdisp2 = xenv.Object(source='rhdisp2.c')
45 rhd_qtree = env.Object(source='rhd_qtree.c')
46 xcommon = [rhdisp, rhdisp2, holo, viewbeams]
47 # other stuff
48 devdir = os.path.join(xenv['RAD_BUILDBIN'],'dev')
49 idevdir = os.path.join(xenv['RAD_BINDIR'],'dev')
50 ocppflags = xenv.get('CPPFLAGS', [])
51
52 # XXX the .hdi extension will cause problems on Windows
53 xenv['PROGSUFFIX'] = '.hdi'
54
55 dlibs = ['rtrad', 'rtdummy']
56 def make_hdi(p): # build them
57 obj = xenv.Object(target=p[3], source=p[4], CPPFLAGS=ocppflags + p[5])
58 prog = xenv.Program(target=radbin(p[0]),
59 source=[obj] + p[1] + xcommon, LIBS=p[2])
60 Default(prog)
61 inst = xenv.Install(idevdir, prog)
62 # XXX what are the alternative "<driver>h" names good for?
63 insth = xenv.InstallAs(target=radbin(
64 p[0] + 'h' + xenv['PROGSUFFIX']), source=prog)
65 env.Append(RAD_BININSTALL=[inst, insth])
66
67 # (name, sources, libs, obj, objsrc, objflags)
68 XHDI = (('x11', Split('rhd_ctab.c rhd_qtree2r.c') + [rhd_qtree],
69 dlibs + ['X11'] + mlib,
70 'rhd_x11', 'rhd_x11.c', []),
71 )
72 for p in XHDI:
73 make_hdi(p)
74
75 if env.has_key('OGL'):
76 rgllibs = ['rgl','rtrad']
77 ogl_common_s = Split('rhd_odraw.c rhd_geom.c')
78 ogl_common = map(lambda s:xenv.Object(source=s), ogl_common_s)
79 rhdobj = xenv.Object(source='rhdobj.c')
80
81 GLHDI = (
82 # glx1h
83 ('glx1', ['rhd_qtree2c.c', rhd_qtree],
84 dlibs + ['GLU','GL','X11'] + mlib,
85 'rhd_glx1', 'rhd_glx1.c', ['-DNOSTEREO']),
86
87 # oglh
88 ('ogl', ogl_common,
89 rgllibs+dlibs+['GLU','GL','X11'] + mlib,
90 'rhd_ogl0', 'rhd_ogl.c', ['-DNOSTEREO']),
91
92 # ogloh
93 ('oglo', [rhdobj] + ogl_common,
94 rgllibs+['rtrad']+dlibs+['GLU','GL','X11'] + mlib,
95 'rhd_oglo', 'rhd_ogl.c', ['-DDOBJ', '-DNOSTEREO']),
96 )
97 for p in GLHDI:
98 make_hdi(p)
99 if xenv['RAD_STEREO'] == '-DSTEREO':
100
101 GLSHDI = (
102 # oglsh
103 ('ogls', ogl_common,
104 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
105 'rhd_ogls', 'rhd_ogl.c' ['-DSTEREO']),
106
107 # oglsoh
108 ('oglso', [rhdobj] + ogl_common,
109 rgllibs+dlibs+['GLU','GL','X11','Xext'] + mlib,
110 'rhd_oglso', 'rhd_ogl.c' ['-DDOBJ', '-DSTEREO']),
111 )
112 for p in GLHDI:
113 make_hdi(p)
114
115
116
117 # vim: set syntax=python:
