root/radiance/src/hd/Rmakefile
Thu Feb 9 00:18:05 2023 UTC (2 years, 10 months ago) by greg
Changes since 3.37: +4 -2 lines
Diff to previous 3.37
Sat Apr 26 15:59:38 2014 UTC (11 years, 8 months ago) by greg
Diff to previous 3.36
Mon Nov 19 17:40:37 2012 UTC (13 years, 1 month ago) by greg
Changes since 3.35: +5 -9 lines
Diff to previous 3.35
Fixed compile for make -j > 1
Wed Apr 25 22:21:06 2012 UTC (13 years, 8 months ago) by greg
Diff to previous 3.34
Tue Jun 24 02:01:20 2008 UTC (17 years, 6 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 3.33: +2 -2 lines
Diff to previous 3.33
Mon May 12 16:46:46 2008 UTC (17 years, 7 months ago) by greg
Changes since 3.32: +10 -10 lines
Diff to previous 3.32
Repaired last change
Wed May 7 15:53:03 2008 UTC (17 years, 8 months ago) by greg
Changes since 3.31: +12 -10 lines
Diff to previous 3.31
Added $(LN) definition to provide for soft links (Bernd Zeimetz)
Thu May 1 16:42:06 2008 UTC (17 years, 8 months ago) by greg
Changes since 3.30: +5 -5 lines
Diff to previous 3.30
Thu Feb 7 23:02:14 2008 UTC (17 years, 11 months ago) by greg
Changes since 3.29: +3 -3 lines
Diff to previous 3.29
Sat Nov 24 00:37:27 2007 UTC (18 years, 1 month ago) by greg
Changes since 3.28: +14 -12 lines
Diff to previous 3.28
Wed Nov 21 17:52:05 2007 UTC (18 years, 1 month ago) by greg
Changes since 3.27: +3 -3 lines
Diff to previous 3.27
Fri Mar 10 19:40:12 2006 UTC (19 years, 10 months ago) by schorsch
Changes since 3.26: +13 -13 lines
Diff to previous 3.26
Mon Nov 8 17:41:03 2004 UTC (21 years, 2 months ago) by greg
Changes since 3.25: +2 -25 lines
Diff to previous 3.25
Removed more unused files and compiles (genrhenv and glx driver)
Fri Nov 5 03:31:37 2004 UTC (21 years, 2 months ago) by greg
Changes since 3.24: +1 -64 lines
Diff to previous 3.24
Wed Oct 27 23:23:47 2004 UTC (21 years, 2 months ago) by greg
CVS Tags: rad3R6P1
Diff to previous 3.23
Fri Jun 27 06:53:22 2003 UTC (22 years, 6 months ago) by greg
Changes since 3.22: +24 -10 lines
Diff to previous 3.22
Tue Mar 4 05:49:21 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.21: +12 -14 lines
Diff to previous 3.21
Sat Feb 22 02:07:24 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.20: +14 -18 lines
Diff to previous 3.20
Thu Mar 4 10:29:22 1999 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.19: +36 -31 lines
Diff to previous 3.19
Thu Dec 31 16:24:59 1998 UTC (27 years ago) by gwlarson
Changes since 3.18: +5 -3 lines
Diff to previous 3.18
created rhinfo program
Mon Dec 28 18:07:07 1998 UTC (27 years ago) by gwlarson
Changes since 3.17: +12 -12 lines
Diff to previous 3.17
changes to ogl driver
Fri Dec 18 11:58:30 1998 UTC (27 years ago) by simmons
Changes since 3.16: +127 -22 lines
Diff to previous 3.16
Thu Sep 3 10:49:05 1998 UTC (27 years, 4 months ago) by gwlarson
Diff to previous 3.15
Wed Aug 26 12:29:26 1998 UTC (27 years, 4 months ago) by gwlarson
Changes since 3.14: +7 -5 lines
Diff to previous 3.14
added missing dependencies for rhdobj.o
Wed Aug 19 17:45:57 1998 UTC (27 years, 4 months ago) by gwlarson
Changes since 3.13: +103 -11 lines
Diff to previous 3.13
first attempt and Delaunay triangulation driver
Tue Jan 6 17:19:51 1998 UTC (28 years ago) by gregl
Changes since 3.12: +5 -2 lines
Diff to previous 3.12
created genrhgrid program
Tue Jan 6 15:09:24 1998 UTC (28 years ago) by gregl
Changes since 3.11: +5 -2 lines
Diff to previous 3.11
wrote genrhenv program to create holodeck environment maps
Fri Dec 26 13:29:13 1997 UTC (28 years ago) by gregl
Changes since 3.10: +4 -6 lines
Diff to previous 3.10
reverted to using quadtree for GLX driver
Tue Dec 23 18:31:43 1997 UTC (28 years ago) by gregl
Changes since 3.9: +14 -2 lines
Diff to previous 3.9
created GLX driver
Tue Dec 23 09:20:27 1997 UTC (28 years ago) by gregl
Changes since 3.8: +4 -2 lines
Diff to previous 3.8
Mon Dec 22 17:42:02 1997 UTC (28 years ago) by gregl
Changes since 3.7: +6 -6 lines
Diff to previous 3.7
change driver suffix
Thu Dec 18 09:32:33 1997 UTC (28 years ago) by gregl
Changes since 3.6: +9 -2 lines
Diff to previous 3.6
added rhcopy program
Mon Dec 1 16:33:30 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.5: +2 -0 lines
Diff to previous 3.5
made persist file vary with process id so multiple rholo's don't interfere
Tue Nov 25 16:53:10 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.4: +5 -4 lines
Diff to previous 3.4
Mon Nov 24 15:16:24 1997 UTC (28 years, 1 month ago) by gregl
removed device prefix
Thu Nov 20 11:37:53 1997 UTC (28 years, 1 month ago) by gregl
added Version.c
Wed Nov 19 17:05:29 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.1: +29 -4 lines
added compiles for x11 driver
Fri Oct 31 10:23:29 1997 UTC (28 years, 2 months ago) by gregl
