root/radiance/src/gen/xform.c
Revision: 2.26
Committed: Sun Jun 8 12:03:10 2003 UTC (22 years, 4 months ago) by schorsch
2 static const char RCSid[] = "$Id: xform.c,v 2.25 2003/05/13 17:58:32 greg Exp $";
5 * xform.c - program to transform object files.
6 * Transformations must preserve aspect ratio.
7 *
8 * 10/19/85
9 * 11/6/86 Finally added error checking!
10 */
11
12 #include <ctype.h>
13 #include <stdio.h>
14
15 #include "standard.h"
16 #include "platform.h"
17 #include "paths.h"
18 #include "object.h"
19 #include "otypes.h"
20
21 int xac; /* global xform argument count */
22 char **xav; /* global xform argument pointer */
23 int xfa; /* start of xf arguments */
24
25 XF tot; /* total transformation */
26 int reverse; /* boolean true if scene mirrored */
27
28 int invert; /* boolean true to invert surfaces */
29
30 int expand; /* boolean true to expand commands */
31
32 char *newmod; /* new modifier for surfaces */
33
34 char *idprefix; /* prefix for object identifiers */
35
36 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* default types and actions */
37
38 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
39
40 int nrept = 1; /* number of array repetitions */
41
42 int stdinused = 0; /* stdin has been used by -f option? */
43
44 char mainfn[MAXPATH]; /* main file name */
45 FILE *mainfp = NULL; /* main file pointer */
46
47 #define progname (xav[0])
48
49
50 main(argc, argv) /* get transform options and transform file */
51 int argc;
52 char *argv[];
53 {
54 int mal_prefix = 0;
55 char *fname;
56 int a;
57 /* check for argument list file */
58 for (a = 1; a < argc; a++)
59 if (!strcmp(argv[a], "-f"))
60 return(doargf(argc, argv, a));
61 /* check for regular array */
62 for (a = 1; a < argc; a++)
63 if (!strcmp(argv[a], "-a"))
64 return(doarray(argc, argv, a));
65
66 initotypes(); /* initialize */
67 invert = 0;
68 expand = 1;
69 newmod = NULL;
70 idprefix = NULL;
71
72 for (a = 1; a < argc; a++) {
73 if (argv[a][0] == '-')
74 switch (argv[a][1]) {
75 case 'm':
76 if (argv[a][2] | a+1 >= argc)
77 break;
78 a++;
79 if (newmod == NULL)
80 newmod = argv[a];
81 continue;
82 case 'n':
83 if (argv[a][2] | a+1 >= argc)
84 break;
85 a++;
86 if (idprefix == NULL)
87 idprefix = argv[a];
88 else {
89 register char *newp;
90 newp = (char *)malloc(strlen(idprefix)+
91 strlen(argv[a])+2);
92 if (newp == NULL)
93 exit(2);
94 sprintf(newp, "%s.%s",
95 idprefix, argv[a]);
96 if (mal_prefix++)
97 free((void *)idprefix);
98 idprefix = newp;
99 }
100 continue;
101 case 'c':
102 if (argv[a][2])
103 break;
104 expand = 0;
105 continue;
106 case 'e':
107 if (argv[a][2])
108 break;
109 expand = 1;
110 continue;
111 case 'I':
112 if (argv[a][2])
113 break;
114 invert = !invert;
115 continue;
116 }
117 break;
118 }
119
120 xav = argv;
121 xfa = a;
122
123 a += xf(&tot, argc-a, argv+a);
124
125 if (reverse = tot.sca < 0.0)
126 tot.sca = -tot.sca;
127 if (invert)
128 reverse = !reverse;
129
130 if (a < argc && argv[a][0] == '-') {
131 fprintf(stderr, "%s: command line error at '%s'\n",
132 argv[0], argv[a]);
133 exit(1);
134 }
135
136 xac = a;
137 /* simple header */
138 putchar('#');
139 for (a = 0; a < xac; a++)
140 printf(" %s", xav[a]);
141 putchar('\n');
142 /* transform input */
143 if (xac == argc) {
144 if (stdinused) {
145 fprintf(stderr, "%s: cannot use stdin more than once\n",
146 argv[0]);
147 exit(1);
148 }
149 openmain(NULL);
150 xform(mainfn, mainfp);
151 } else
152 for (a = xac; a < argc; a++) {
153 openmain(argv[a]);
154 xform(mainfn, mainfp);
155 }
156
157 if (mal_prefix)
158 free((void *)idprefix);
159 return(0);
160 }
161
162
163 doargf(ac, av, fi) /* take argument list from file */
164 char **av;
165 int ac, fi;
166 {
167 int inquote;
168 char *newav[256], **avp;
169 char argbuf[1024];
170 char newid[128];
171 char *oldid;
172 register char *cp;
173 FILE *argfp;
174 int n, i, k, newac, err;
175
176 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
177 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
178 exit(1);
179 }
180 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
181 if (stdinused++) {
182 fprintf(stderr,
183 "%s: cannot use stdin more than once\n",
184 av[0]);
185 exit(1);
186 }
187 argfp = stdin;
188 n = 100; /* we just don't know! */
189 } else {
190 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
191 fprintf(stderr,
192 "%s: cannot open argument file \"%s\"\n",
193 av[0], av[fi+1]);
194 exit(1);
195 }
196 n = 0; /* count number of lines in file */
197 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL)
198 n += argbuf[0] && argbuf[0] != '#';
199 if (!n) {
200 fprintf(stderr, "%s: empty argument file \"%s\"\n",
201 av[0], av[fi+1]);
202 exit(1);
203 }
204 nrept *= n;
205 rewind(argfp);
206 }
207 err = 0; k = 0; /* read each arg list and call main */
208 while (fgetline(argbuf,sizeof(argbuf),argfp) != NULL) {
209 if (!argbuf[0] || argbuf[0] == '#')
210 continue;
211 avp = newav+2;
212 avp[0] = av[0];
213 for (i = 1; i < fi; i++)
214 avp[i] = av[i];
215 newac = i;
216 cp = argbuf; /* parse new words */
217 if (*cp == '!') cp++;
218 if (!strncmp(cp, "xform ", 6)) cp += 6;
219 inquote = 0;
220 for ( ; ; ) {
221 skipspaces:
222 while (isspace(*cp)) /* nullify spaces */
223 *cp++ = '\0';
224 if ((*cp == '"' | *cp == '\''))
225 inquote = *cp++;
226 if (!*cp) /* all done? */
227 break;
228 if (cp[0] == '\\' && cp[1])
229 if (*++cp == '\n')
230 goto skipspaces;
231 avp[newac++] = cp; /* add argument to list */
232 if (inquote) {
233 while (*++cp)
234 if (*cp == inquote) {
235 *cp++ = '\0';
236 break;
237 }
238 } else {
239 while (*++cp && !isspace(*cp))
240 ;
241 }
242 }
243 for (i = fi+2; i < ac; i++)
244 avp[newac++] = av[i];
245 avp[newac] = NULL;
246 oldid = NULL;
247 for (i = 2; i < newac; i++)
248 if (!strcmp(avp[i-1], "-n")) {
249 oldid = avp[i];
250 avp[i] = newid;
251 break;
252 }
253 if (oldid == NULL) {
254 newav[0] = av[0];
255 newav[1] = "-n";
256 newav[2] = newid;
257 avp = newav;
258 newac += 2;
259 }
260 if (oldid == NULL)
261 sprintf(newid, "i%d", k);
262 else
263 sprintf(newid, "%s.%d", oldid, k);
264 err |= main(newac, avp);
265 k++;
266 }
267 fclose(argfp);
268 return(err);
269 }
270
271
272 doarray(ac, av, ai) /* make array */
273 char **av;
274 int ac, ai;
275 {
276 char *newav[256], **avp;
277 char newid[128], repts[32];
278 char *oldid = NULL;
279 int n, i, err;
280
281 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
282 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
283 exit(1);
284 }
285 nrept *= n;
286 avp = newav+2;
287 avp[0] = av[0];
288 for (i = 1; i < ac; i++)
289 if (!strcmp(av[i-1], "-n")) {
290 oldid = av[i];
291 avp[i] = newid;
292 } else
293 avp[i] = av[i];
294 avp[ai] = "-i";
295 avp[ai+1] = repts;
296 avp[i] = NULL;
297 if (oldid == NULL) {
298 newav[0] = av[0];
299 newav[1] = "-n";
300 newav[2] = newid;
301 avp = newav;
302 ac += 2;
303 }
304 err = 0;
305 for (i = 0; i < n; i++) {
306 if (oldid == NULL)
307 sprintf(newid, "a%d", i);
308 else
309 sprintf(newid, "%s.%d", oldid, i);
310 sprintf(repts, "%d", i);
311 err |= main(ac, avp);
312 }
313 return(err);
314 }
315
316
317 xform(name, fin) /* transform stream by tot.xfm */
318 char *name;
319 register FILE *fin;
320 {
321 int nobjs = 0;
322 register int c;
323
324 while ((c = getc(fin)) != EOF) {
325 if (isspace(c)) /* blank */
326 continue;
327 if (c == '#') { /* comment */
328 putchar(c);
329 do {
330 if ((c = getc(fin)) == EOF)
331 return;
332 putchar(c);
333 } while (c != '\n');
334 } else if (c == '!') { /* command */
335 ungetc(c, fin);
336 xfcomm(name, fin);
337 nobjs++;
338 } else { /* object */
339 ungetc(c, fin);
340 xfobject(name, fin);
341 nobjs++;
342 }
343 }
344 if (nobjs == 0)
345 fprintf(stderr, "%s: (%s): warning - empty file\n",
346 progname, name);
347 }
348
349
350 xfcomm(fname, fin) /* transform a command */
351 char *fname;
352 FILE *fin;
353 {
354 FILE *pin;
355 char buf[512];
356 int i;
357
358 fgetline(buf, sizeof(buf), fin);
359 if (expand) {
360 if ((pin = popen(buf+1, "r")) == NULL) {
361 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
362 progname, fname, buf);
363 exit(1);
364 }
365 xform(buf, pin);
366 pclose(pin);
367 } else {
368 printf("\n%s", buf);
369 if (xac > 1) {
370 printf(" | %s -e", xav[0]); /* expand next time */
371 for (i = 1; i < xac; i++)
372 if (i >= xfa || strcmp(xav[i], "-c"))
373 printf(" %s", xav[i]);
374 }
375 putchar('\n');
376 }
377 }
378
379
380 xfobject(fname, fin) /* transform an object */
381 char *fname;
382 FILE *fin;
383 {
384 char typ[16], nam[MAXSTR];
385 int fn;
386 /* modifier and type */
387 strcpy(typ, "EOF");
388 fgetword(nam, sizeof(nam), fin);
389 fgetword(typ, sizeof(typ), fin);
390 if ((fn = otype(typ)) < 0) {
391 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
392 progname, fname, typ);
393 exit(1);
394 }
395 if (ismodifier(fn))
396 printf("\n%s %s ", nam, typ);
397 else
398 printf("\n%s %s ", newmod != NULL ? newmod : nam,
399 invert ? ofun[tinvers[fn]].funame : typ);
400 /* object name */
401 fgetword(nam, sizeof(nam), fin);
402 if (idprefix == NULL || ismodifier(fn))
403 printf("%s\n", nam);
404 else
405 printf("%s.%s\n", idprefix, nam);
406 /* transform arguments */
407 if ((*ofun[fn].funp)(fin) < 0) {
408 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
409 progname, fname, ofun[fn].funame, nam);
410 exit(1);
411 }
412 }
413
414
415 o_default(fin) /* pass on arguments unchanged */
416 FILE *fin;
417 {
418 register int i;
419 FUNARGS fa;
420
421 if (readfargs(&fa, fin) != 1)
422 return(-1);
423 /* string arguments */
424 printf("%d", fa.nsargs);
425 for (i = 0; i < fa.nsargs; i++) {
426 fputc(' ', stdout);
427 fputword(fa.sarg[i], stdout);
428 }
429 printf("\n");
430 #ifdef IARGS
431 /* integer arguments */
432 printf("%d", fa.niargs);
433 for (i = 0; i < fa.niargs; i++)
434 printf(" %d", fa.iarg[i]);
435 printf("\n");
436 #else
437 printf("0\n");
438 #endif
439 /* float arguments */
440 printf("%d", fa.nfargs);
441 for (i = 0; i < fa.nfargs; i++)
442 printf(" %18.12g", fa.farg[i]);
443 printf("\n");
444 freefargs(&fa);
445 return(0);
446 }
447
448
449 addxform(fin) /* add xf arguments to strings */
450 FILE *fin;
451 {
452 register int i;
453 int resetarr = 0;
454 FUNARGS fa;
455
456 if (readfargs(&fa, fin) != 1)
457 return(-1);
458 /* string arguments */
459 if (xac > xfa && strcmp(xav[xfa], "-i"))
460 resetarr = 2;
461 printf("%d", fa.nsargs + resetarr + xac-xfa);
462 for (i = 0; i < fa.nsargs; i++) {
463 fputc(' ', stdout);
464 fputword(fa.sarg[i], stdout);
465 }
466 if (resetarr)
467 printf(" -i 1");
468 for (i = xfa; i < xac; i++) /* add xf arguments */
469 printf(" %s", xav[i]);
470 printf("\n");
471 #ifdef IARGS
472 /* integer arguments */
473 printf("%d", fa.niargs);
474 for (i = 0; i < fa.niargs; i++)
475 printf(" %d", fa.iarg[i]);
476 printf("\n");
477 #else
478 printf("0\n");
479 #endif
480 /* float arguments */
481 printf("%d", fa.nfargs);
482 for (i = 0; i < fa.nfargs; i++)
483 printf(" %18.12g", fa.farg[i]);
484 printf("\n");
485 freefargs(&fa);
486 return(0);
487 }
488
489
490 alias(fin) /* transfer alias */
491 FILE *fin;
492 {
493 char aliasnm[MAXSTR];
494
495 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
496 return(-1);
497 printf("\t%s\n", aliasnm);
498 return(0);
499 }
500
501
502 m_glow(fin) /* transform arguments for proximity light */
503 FILE *fin;
504 {
505 FUNARGS fa;
506
507 if (readfargs(&fa, fin) != 1)
508 return(-1);
509 if (fa.nsargs != 0 || fa.nfargs != 4)
510 return(-1);
511 printf("0\n0\n4");
512 printf(" %18.12g %18.12g %18.12g",
513 fa.farg[0], fa.farg[1], fa.farg[2]);
514 printf(" %18.12g\n", fa.farg[3] * tot.sca);
515 freefargs(&fa);
516 return(0);
517 }
518
519
520 m_spot(fin) /* transform arguments for spotlight */
521 FILE *fin;
522 {
523 FVECT v;
524 FUNARGS fa;
525
526 if (readfargs(&fa, fin) != 1)
527 return(-1);
528 if (fa.nsargs != 0 || fa.nfargs != 7)
529 return(-1);
530 printf("0\n0\n7");
531 printf(" %18.12g %18.12g %18.12g %18.12g\n",
532 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
533 multv3(v, fa.farg+4, tot.xfm);
534 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
535 freefargs(&fa);
536 return(0);
537 }
538
539
540 m_mist(fin) /* transform arguments for mist */
541 FILE *fin;
542 {
543 FUNARGS fa;
544 int i;
545
546 if (readfargs(&fa, fin) != 1)
547 return(-1);
548 if (fa.nfargs > 7)
549 return(-1);
550 printf("%d", fa.nsargs);
551 if (idprefix == NULL)
552 for (i = 0; i < fa.nsargs; i++)
553 printf(" %s", fa.sarg[i]);
554 else
555 for (i = 0; i < fa.nsargs; i++) {
556 char sname[256], *sp;
557 register char *cp1, *cp2 = sname;
558 /* add idprefix */
559 for (sp = fa.sarg[i]; *sp; sp = cp1) {
560 for (cp1 = idprefix; *cp1; )
561 *cp2++ = *cp1++;
562 *cp2++ = '.';
563 for (cp1 = sp; *cp1 &&
564 (*cp2++ = *cp1++) != '>'; )
565 ;
566 }
567 *cp2 = '\0';
568 printf(" %s", sname);
569 }
570 printf("\n0\n%d", fa.nfargs);
571 if (fa.nfargs > 2)
572 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
573 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
574 for (i = 3; i < fa.nfargs; i++)
575 printf(" %12.6g", fa.farg[i]);
576 printf("\n");
577 freefargs(&fa);
578 return(0);
579 }
580
581
582 m_dielectric(fin) /* transform arguments for dielectric */
583 FILE *fin;
584 {
585 FUNARGS fa;
586
587 if (readfargs(&fa, fin) != 1)
588 return(-1);
589 if (fa.nsargs != 0 || fa.nfargs != 5)
590 return(-1);
591 printf("0\n0\n5");
592 printf(" %12.6g %12.6g %12.6g",
593 pow(fa.farg[0], 1.0/tot.sca),
594 pow(fa.farg[1], 1.0/tot.sca),
595 pow(fa.farg[2], 1.0/tot.sca));
596 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
597 freefargs(&fa);
598 return(0);
599 }
600
601
602 m_interface(fin) /* transform arguments for interface */
603 FILE *fin;
604 {
605 FUNARGS fa;
606
607 if (readfargs(&fa, fin) != 1)
608 return(-1);
609 if (fa.nsargs != 0 || fa.nfargs != 8)
610 return(-1);
611 printf("0\n0\n8\n");
612 printf("%12.6g %12.6g %12.6g",
613 pow(fa.farg[0], 1.0/tot.sca),
614 pow(fa.farg[1], 1.0/tot.sca),
615 pow(fa.farg[2], 1.0/tot.sca));
616 printf(" %12.6g\n", fa.farg[3]);
617 printf("%12.6g %12.6g %12.6g",
618 pow(fa.farg[4], 1.0/tot.sca),
619 pow(fa.farg[5], 1.0/tot.sca),
620 pow(fa.farg[6], 1.0/tot.sca));
621 printf(" %12.6g\n", fa.farg[7]);
622 freefargs(&fa);
623 return(0);
624 }
625
626
627 text(fin) /* transform text arguments */
628 FILE *fin;
629 {
630 int i;
631 FVECT v;
632 FUNARGS fa;
633
634 if (readfargs(&fa, fin) != 1)
635 return(-1);
636 if (fa.nfargs < 9)
637 return(-1);
638 /* string arguments */
639 printf("%d", fa.nsargs);
640 for (i = 0; i < fa.nsargs; i++) {
641 fputc(' ', stdout);
642 fputword(fa.sarg[i], stdout);
643 }
644 printf("\n0\n%d\n", fa.nfargs);
645 /* anchor point */
646 multp3(v, fa.farg, tot.xfm);
647 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
648 /* right vector */
649 multv3(v, fa.farg+3, tot.xfm);
650 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
651 /* down vector */
652 multv3(v, fa.farg+6, tot.xfm);
653 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
654 /* remaining arguments */
655 for (i = 9; i < fa.nfargs; i++) {
656 if (i%3 == 0)
657 putchar('\n');
658 printf(" %18.12g", fa.farg[i]);
659 }
660 putchar('\n');
661 freefargs(&fa);
662 return(0);
663 }
664
665
666 o_source(fin) /* transform source arguments */
667 FILE *fin;
668 {
669 FVECT dv;
670 FUNARGS fa;
671
672 if (readfargs(&fa, fin) != 1)
673 return(-1);
674 if (fa.nsargs != 0 || fa.nfargs != 4)
675 return(-1);
676 /* transform direction vector */
677 multv3(dv, fa.farg, tot.xfm);
678 /* output */
679 printf("0\n0\n4");
680 printf(" %18.12g %18.12g %18.12g %18.12g\n",
681 dv[0], dv[1], dv[2], fa.farg[3]);
682 freefargs(&fa);
683 return(0);
684 }
685
686
687 o_sphere(fin) /* transform sphere arguments */
688 FILE *fin;
689 {
690 FVECT cent;
691 double rad;
692 FUNARGS fa;
693
694 if (readfargs(&fa, fin) != 1)
695 return(-1);
696 if (fa.nsargs != 0 || fa.nfargs != 4)
697 return(-1);
698
699 multp3(cent, fa.farg, tot.xfm); /* transform center */
700
701 rad = fa.farg[3] * tot.sca; /* scale radius */
702
703 printf("0\n0\n4");
704 printf(" %18.12g %18.12g %18.12g %18.12g\n",
705 cent[0], cent[1], cent[2], rad);
706 freefargs(&fa);
707 return(0);
708 }
709
710
711 o_face(fin) /* transform face arguments */
712 FILE *fin;
713 {
714 FVECT p;
715 register int i;
716 FUNARGS fa;
717
718 if (readfargs(&fa, fin) != 1)
719 return(-1);
720 if (fa.nsargs != 0 || fa.nfargs % 3)
721 return(-1);
722
723 printf("0\n0\n%d\n", fa.nfargs);
724
725 for (i = 0; i < fa.nfargs; i += 3) {
726 if (reverse)
727 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
728 else
729 multp3(p, fa.farg+i, tot.xfm);
730 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
731 }
732 freefargs(&fa);
733 return(0);
734 }
735
736
737 o_cone(fin) /* transform cone and cup arguments */
738 FILE *fin;
739 {
740 FVECT p0, p1;
741 double r0, r1;
742 FUNARGS fa;
743
744 if (readfargs(&fa, fin) != 1)
745 return(-1);
746 if (fa.nsargs != 0 || fa.nfargs != 8)
747 return(-1);
748
749 printf("0\n0\n8\n");
750
751 multp3(p0, fa.farg, tot.xfm);
752 multp3(p1, fa.farg+3, tot.xfm);
753 r0 = fa.farg[6] * tot.sca;
754 r1 = fa.farg[7] * tot.sca;
755 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
756 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
757 printf(" %18.12g %18.12g\n", r0, r1);
758
759 freefargs(&fa);
760 return(0);
761 }
762
763
764 o_cylinder(fin) /* transform cylinder and tube arguments */
765 FILE *fin;
766 {
767 FVECT p0, p1;
768 double rad;
769 FUNARGS fa;
770
771 if (readfargs(&fa, fin) != 1)
772 return(-1);
773 if (fa.nsargs != 0 || fa.nfargs != 7)
774 return(-1);
775
776 printf("0\n0\n7\n");
777
778 multp3(p0, fa.farg, tot.xfm);
779 multp3(p1, fa.farg+3, tot.xfm);
780 rad = fa.farg[6] * tot.sca;
781 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
782 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
783 printf(" %18.12g\n", rad);
784 freefargs(&fa);
785 return(0);
786 }
787
788
789 o_ring(fin) /* transform ring arguments */
790 FILE *fin;
791 {
792 FVECT p0, pd;
793 double r0, r1;
794 FUNARGS fa;
795
796 if (readfargs(&fa, fin) != 1)
797 return(-1);
798 if (fa.nsargs != 0 || fa.nfargs != 8)
799 return(-1);
800
801 printf("0\n0\n8\n");
802
803 multp3(p0, fa.farg, tot.xfm);
804 multv3(pd, fa.farg+3, tot.xfm);
805 if (invert) {
806 pd[0] = -pd[0];
807 pd[1] = -pd[1];
808 pd[2] = -pd[2];
809 }
810 r0 = fa.farg[6] * tot.sca;
811 r1 = fa.farg[7] * tot.sca;
812 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
813 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
814 printf(" %18.12g %18.12g\n", r0, r1);
815 freefargs(&fa);
816 return(0);
817 }
818
819
820 initotypes() /* initialize ofun[] array */
821 {
822 register int i;
823
824 if (ofun[OBJ_SOURCE].funp == o_source)
825 return; /* done already */
826 /* functions get new transform */
827 for (i = 0; i < NUMOTYPE; i++)
828 if (hasfunc(i))
829 ofun[i].funp = addxform;
830 /* special cases */
831 ofun[OBJ_SOURCE].funp = o_source;
832 ofun[OBJ_SPHERE].funp =
833 ofun[OBJ_BUBBLE].funp = o_sphere;
834 ofun[OBJ_FACE].funp = o_face;
835 ofun[OBJ_CONE].funp =
836 ofun[OBJ_CUP].funp = o_cone;
837 ofun[OBJ_CYLINDER].funp =
838 ofun[OBJ_TUBE].funp = o_cylinder;
839 ofun[OBJ_RING].funp = o_ring;
840 ofun[OBJ_INSTANCE].funp = addxform;
841 ofun[MAT_GLOW].funp = m_glow;
842 ofun[MAT_SPOT].funp = m_spot;
843 ofun[MAT_DIELECTRIC].funp = m_dielectric;
844 ofun[MAT_INTERFACE].funp = m_interface;
845 ofun[MAT_MIST].funp = m_mist;
846 ofun[PAT_CTEXT].funp =
847 ofun[PAT_BTEXT].funp =
848 ofun[MIX_TEXT].funp = text;
849 ofun[MOD_ALIAS].funp = alias;
850 /* surface inverses */
851 tinvers[OBJ_FACE] = OBJ_FACE;
852 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
853 tinvers[OBJ_CONE] = OBJ_CUP;
854 tinvers[OBJ_CUP] = OBJ_CONE;
855 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
856 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
857 tinvers[OBJ_RING] = OBJ_RING;
858 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
859 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
860 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
861 }
862
863
864 #ifdef OLDXFORM
865 openmain(fname)
866 char *fname;
867 {
868 if (fname == NULL) {
869 strcpy(mainfn, "standard input");
870 mainfp = stdin;
871 return;
872 }
873 if (mainfp != NULL) {
874 if (!strcmp(fname, mainfn)) {
875 rewind(mainfp);
876 return;
877 }
878 fclose(mainfp);
879 }
880 if ((mainfp = fopen(fname, "r")) == NULL) {
881 fprintf(stderr, "%s: cannot open file \"%s\"\n",
882 progname, fname);
883 exit(1);
884 }
885 strcpy(mainfn, fname);
886 }
887 #else
888 openmain(iname) /* open input, changing directory for file */
889 char *iname;
890 {
891 static char origdir[MAXPATH];
892 static char curfn[MAXPATH];
893 static int diffdir;
894 register char *fpath;
895
896 if (iname == NULL) { /* standard input */
897 if (mainfp == NULL) {
898 register int c;
899 strcpy(mainfn, "standard input");
900 if (nrept <= 1) {
901 mainfp = stdin;
902 return; /* just read once */
903 }
904 /* else copy */
905 if ((mainfp = tmpfile()) == NULL) {
906 fprintf(stderr,
907 "%s: cannot create temporary file\n",
908 progname);
909 exit(1);
910 }
911 while ((c = getc(stdin)) != EOF)
912 putc(c, mainfp);
913 }
914 rewind(mainfp); /* rewind copy */
915 return;
916 }
917 if (mainfp == NULL) { /* first call, initialize */
918 getwd(origdir);
919 } else if (!strcmp(iname, curfn)) { /* just need to rewind? */
920 rewind(mainfp);
921 return;
922 } else { /* else close old stream */
923 fclose(mainfp);
924 mainfp = NULL;
925 if (diffdir) { /* return to our directory */
926 chdir(origdir);
927 diffdir = 0;
928 }
929 }
930 strcpy(curfn, iname); /* remember input name */
931 /* get full path for file */
932 if ((fpath = getpath(iname, getrlibpath(), R_OK)) == NULL) {
933 fprintf(stderr, "%s: cannot find file \"%s\"\n",
934 progname, iname);
935 exit(1);
936 }
937 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
938 fpath += 2;
939 /* record path name */
940 strcpy(mainfn, fpath);
941 if (expand) { /* change to local directory */
942 register char *cp = fpath + strlen(fpath); /* get dir. */
943 while (cp > fpath) {
944 cp--;
945 if (ISDIRSEP(*cp)) {
946 if (cp == fpath)
947 cp++; /* root special case */
948 break;
949 }
950 }
951 *cp = '\0';
952 if (fpath[0]) { /* change to new directory? */
953 if (chdir(fpath) < 0) {
954 fprintf(stderr,
955 "%s: cannot change directory to \"%s\"\n",
956 progname, fpath);
957 exit(1);
958 }
959 diffdir++;
960 }
961 /* get final path component */
962 for (fpath = iname+strlen(iname);
963 fpath > iname && !ISDIRSEP(fpath[-1]); fpath--)
964 ;
965 }
966 /* finally, open the file */
967 if ((mainfp = fopen(fpath, "r")) == NULL) {
968 fprintf(stderr, "%s: cannot open file \"%s\"\n",
969 progname, mainfn);
970 exit(1);
971 }
972 }
973 #endif
