root/radiance/src/gen/xform.c
Revision: 2.21
Committed: Fri Jun 4 17:06:31 1999 UTC (26 years, 4 months ago) by gwlarson
Changes since 2.20: +33 -10 lines
made it so -n option can be given multiple times with desired effect
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * xform.c - program to transform object files.
9 * Transformations must preserve aspect ratio.
10 *
11 * 10/19/85
12 * 11/6/86 Finally added error checking!
13 */
14
15 #include "standard.h"
16
17 #include "paths.h"
18
19 #include <ctype.h>
20
21 #include "object.h"
22
23 #include "otypes.h"
24
25 int xac; /* global xform argument count */
26 char **xav; /* global xform argument pointer */
27 int xfa; /* start of xf arguments */
28
29 XF tot; /* total transformation */
30 int reverse; /* boolean true if scene mirrored */
31
32 int invert; /* boolean true to invert surfaces */
33
34 int expand; /* boolean true to expand commands */
35
36 char *newmod; /* new modifier for surfaces */
37
38 char *idprefix; /* prefix for object identifiers */
39
40 #define ALIAS NUMOTYPE /* put alias at end of array */
41
42 #define NUMTYPES (NUMOTYPE+1) /* total number of object types */
43
44 FUN ofun[NUMTYPES] = INIT_OTYPE; /* default types and actions */
45
46 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
47
48 int nrept = 1; /* number of array repetitions */
49
50 int stdinused = 0; /* stdin has been used by -f option? */
51
52 extern char *malloc(), *fgets(), *fgetword();
53
54 char mainfn[MAXPATH]; /* main file name */
55 FILE *mainfp = NULL; /* main file pointer */
56
57 #define progname (xav[0])
58
59
60 main(argc, argv) /* get transform options and transform file */
61 int argc;
62 char *argv[];
63 {
64 int mal_prefix = 0;
65 char *fname;
66 int a;
67 /* check for argument list file */
68 for (a = 1; a < argc; a++)
69 if (!strcmp(argv[a], "-f"))
70 return(doargf(argc, argv, a));
71 /* check for regular array */
72 for (a = 1; a < argc; a++)
73 if (!strcmp(argv[a], "-a"))
74 return(doarray(argc, argv, a));
75
76 initotypes(); /* initialize */
77 invert = 0;
78 expand = 1;
79 newmod = NULL;
80 idprefix = NULL;
81
82 for (a = 1; a < argc; a++) {
83 if (argv[a][0] == '-')
84 switch (argv[a][1]) {
85 case 'm':
86 if (argv[a][2] | a+1 >= argc)
87 break;
88 a++;
89 if (newmod == NULL)
90 newmod = argv[a];
91 continue;
92 case 'n':
93 if (argv[a][2] | a+1 >= argc)
94 break;
95 a++;
96 if (idprefix == NULL)
97 idprefix = argv[a];
98 else {
99 register char *newp;
100 newp = (char *)malloc(strlen(idprefix)+
101 strlen(argv[a])+2);
102 if (newp == NULL)
103 exit(2);
104 sprintf(newp, "%s.%s",
105 idprefix, argv[a]);
106 if (mal_prefix++)
107 free((char *)idprefix);
108 idprefix = newp;
109 }
110 continue;
111 case 'c':
112 if (argv[a][2])
113 break;
114 expand = 0;
115 continue;
116 case 'e':
117 if (argv[a][2])
118 break;
119 expand = 1;
120 continue;
121 case 'I':
122 if (argv[a][2])
123 break;
124 invert = !invert;
125 continue;
126 }
127 break;
128 }
129
130 xav = argv;
131 xfa = a;
132
133 a += xf(&tot, argc-a, argv+a);
134
135 if (reverse = tot.sca < 0.0)
136 tot.sca = -tot.sca;
137 if (invert)
138 reverse = !reverse;
139
140 if (a < argc && argv[a][0] == '-') {
141 fprintf(stderr, "%s: command line error at '%s'\n",
142 argv[0], argv[a]);
143 exit(1);
144 }
145
146 xac = a;
147 /* simple header */
148 putchar('#');
149 for (a = 0; a < xac; a++)
150 printf(" %s", xav[a]);
151 putchar('\n');
152 /* transform input */
153 if (xac == argc) {
154 if (stdinused) {
155 fprintf(stderr, "%s: cannot use stdin more than once\n",
156 argv[0]);
157 exit(1);
158 }
159 openmain(NULL);
160 xform(mainfn, mainfp);
161 } else
162 for (a = xac; a < argc; a++) {
163 openmain(argv[a]);
164 xform(mainfn, mainfp);
165 }
166
167 if (mal_prefix)
168 free((char *)idprefix);
169 return(0);
170 }
171
172
173 doargf(ac, av, fi) /* take argument list from file */
174 char **av;
175 int ac, fi;
176 {
177 char *newav[256], **avp;
178 char argbuf[1024];
179 char newid[128];
180 char *oldid;
181 register char *cp;
182 FILE *argfp;
183 int n, i, k, newac, err;
184
185 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
186 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
187 exit(1);
188 }
189 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
190 if (stdinused++) {
191 fprintf(stderr, "%s: cannot use stdin more than once\n",
192 av[0]);
193 exit(1);
194 }
195 argfp = stdin;
196 n = 100; /* we just don't know! */
197 } else {
198 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
199 fprintf(stderr, "%s: cannot open argument file \"%s\"\n",
200 av[0], av[fi+1]);
201 exit(1);
202 }
203 n = 0; /* count number of lines in file */
204 while (fgets(argbuf,sizeof(argbuf),argfp) != NULL)
205 n += argbuf[0] != '\n' & argbuf[0] != '#';
206 if (!n) {
207 fprintf(stderr, "%s: empty argument file \"%s\"\n",
208 av[0], av[fi+1]);
209 exit(1);
210 }
211 nrept *= n;
212 rewind(argfp);
213 }
214 err = 0; k = 0; /* read each arg list and call main */
215 while (fgets(argbuf,sizeof(argbuf),argfp) != NULL) {
216 if (argbuf[0] == '\n' | argbuf[0] == '#')
217 continue;
218 avp = newav+2;
219 avp[0] = av[0];
220 for (i = 1; i < fi; i++)
221 avp[i] = av[i];
222 newac = i;
223 cp = argbuf; /* parse new words */
224 if (*cp == '!') cp++;
225 if (!strncmp(cp, "xform ", 6)) cp += 6;
226 for ( ; ; ) {
227 while (isspace(*cp)) /* nullify spaces */
228 *cp++ = '\0';
229 if (!*cp) /* all done? */
230 break;
231 avp[newac++] = cp; /* add argument to list */
232 while (*++cp && !isspace(*cp))
233 ;
234 }
235 for (i = fi+2; i < ac; i++)
236 avp[newac++] = av[i];
237 avp[newac] = NULL;
238 oldid = NULL;
239 for (i = 2; i < newac; i++)
240 if (!strcmp(avp[i-1], "-n")) {
241 oldid = avp[i];
242 avp[i] = newid;
243 break;
244 }
245 if (oldid == NULL) {
246 newav[0] = av[0];
247 newav[1] = "-n";
248 newav[2] = newid;
249 avp = newav;
250 newac += 2;
251 }
252 if (oldid == NULL)
253 sprintf(newid, "i%d", k);
254 else
255 sprintf(newid, "%s.%d", oldid, k);
256 err |= main(newac, avp);
257 k++;
258 }
259 fclose(argfp);
260 return(err);
261 }
262
263
264 doarray(ac, av, ai) /* make array */
265 char **av;
266 int ac, ai;
267 {
268 char *newav[256], **avp;
269 char newid[128], repts[32];
270 char *oldid = NULL;
271 int n, i, err;
272
273 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
274 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
275 exit(1);
276 }
277 nrept *= n;
278 avp = newav+2;
279 avp[0] = av[0];
280 for (i = 1; i < ac; i++)
281 if (!strcmp(av[i-1], "-n")) {
282 oldid = av[i];
283 avp[i] = newid;
284 } else
285 avp[i] = av[i];
286 avp[ai] = "-i";
287 avp[ai+1] = repts;
288 avp[i] = NULL;
289 if (oldid == NULL) {
290 newav[0] = av[0];
291 newav[1] = "-n";
292 newav[2] = newid;
293 avp = newav;
294 ac += 2;
295 }
296 err = 0;
297 for (i = 0; i < n; i++) {
298 if (oldid == NULL)
299 sprintf(newid, "a%d", i);
300 else
301 sprintf(newid, "%s.%d", oldid, i);
302 sprintf(repts, "%d", i);
303 err |= main(ac, avp);
304 }
305 return(err);
306 }
307
308
309 xform(name, fin) /* transform stream by tot.xfm */
310 char *name;
311 register FILE *fin;
312 {
313 int nobjs = 0;
314 register int c;
315
316 while ((c = getc(fin)) != EOF) {
317 if (isspace(c)) /* blank */
318 continue;
319 if (c == '#') { /* comment */
320 putchar(c);
321 do {
322 if ((c = getc(fin)) == EOF)
323 return;
324 putchar(c);
325 } while (c != '\n');
326 } else if (c == '!') { /* command */
327 ungetc(c, fin);
328 xfcomm(name, fin);
329 nobjs++;
330 } else { /* object */
331 ungetc(c, fin);
332 xfobject(name, fin);
333 nobjs++;
334 }
335 }
336 if (nobjs == 0)
337 fprintf(stderr, "%s: (%s): warning - empty file\n",
338 progname, name);
339 }
340
341
342 xfcomm(fname, fin) /* transform a command */
343 char *fname;
344 FILE *fin;
345 {
346 extern FILE *popen();
347 extern char *fgetline();
348 FILE *pin;
349 char buf[512];
350 int i;
351
352 fgetline(buf, sizeof(buf), fin);
353 if (expand) {
354 if ((pin = popen(buf+1, "r")) == NULL) {
355 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
356 progname, fname, buf);
357 exit(1);
358 }
359 xform(buf, pin);
360 pclose(pin);
361 } else {
362 printf("\n%s", buf);
363 if (xac > 1) {
364 printf(" | %s", xav[0]);
365 for (i = 1; i < xac; i++)
366 printf(" %s", xav[i]);
367 }
368 putchar('\n');
369 }
370 }
371
372
373 xfobject(fname, fin) /* transform an object */
374 char *fname;
375 FILE *fin;
376 {
377 extern char *strcpy();
378 char typ[16], nam[MAXSTR];
379 int fn;
380 /* modifier and type */
381 strcpy(typ, "EOF");
382 fgetword(nam, sizeof(nam), fin);
383 fgetword(typ, sizeof(typ), fin);
384 if ((fn = otype(typ)) < 0) {
385 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
386 progname, fname, typ);
387 exit(1);
388 }
389 if (ismodifier(fn))
390 printf("\n%s %s ", nam, typ);
391 else
392 printf("\n%s %s ", newmod != NULL ? newmod : nam,
393 invert ? ofun[tinvers[fn]].funame : typ);
394 /* object name */
395 fgetword(nam, sizeof(nam), fin);
396 if (idprefix == NULL || ismodifier(fn))
397 printf("%s\n", nam);
398 else
399 printf("%s.%s\n", idprefix, nam);
400 /* transform arguments */
401 if ((*ofun[fn].funp)(fin) < 0) {
402 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
403 progname, fname, ofun[fn].funame, nam);
404 exit(1);
405 }
406 }
407
408
409 o_default(fin) /* pass on arguments unchanged */
410 FILE *fin;
411 {
412 register int i;
413 FUNARGS fa;
414
415 if (readfargs(&fa, fin) != 1)
416 return(-1);
417 /* string arguments */
418 printf("%d", fa.nsargs);
419 for (i = 0; i < fa.nsargs; i++)
420 printf(" %s", fa.sarg[i]);
421 printf("\n");
422 #ifdef IARGS
423 /* integer arguments */
424 printf("%d", fa.niargs);
425 for (i = 0; i < fa.niargs; i++)
426 printf(" %d", fa.iarg[i]);
427 printf("\n");
428 #else
429 printf("0\n");
430 #endif
431 /* float arguments */
432 printf("%d", fa.nfargs);
433 for (i = 0; i < fa.nfargs; i++)
434 printf(" %18.12g", fa.farg[i]);
435 printf("\n");
436 freefargs(&fa);
437 return(0);
438 }
439
440
441 addxform(fin) /* add xf arguments to strings */
442 FILE *fin;
443 {
444 register int i;
445 int resetarr = 0;
446 FUNARGS fa;
447
448 if (readfargs(&fa, fin) != 1)
449 return(-1);
450 /* string arguments */
451 if (xac > xfa && strcmp(xav[xfa], "-i"))
452 resetarr = 2;
453 printf("%d", fa.nsargs + resetarr + xac-xfa);
454 for (i = 0; i < fa.nsargs; i++)
455 printf(" %s", fa.sarg[i]);
456 if (resetarr)
457 printf(" -i 1");
458 for (i = xfa; i < xac; i++) /* add xf arguments */
459 printf(" %s", xav[i]);
460 printf("\n");
461 #ifdef IARGS
462 /* integer arguments */
463 printf("%d", fa.niargs);
464 for (i = 0; i < fa.niargs; i++)
465 printf(" %d", fa.iarg[i]);
466 printf("\n");
467 #else
468 printf("0\n");
469 #endif
470 /* float arguments */
471 printf("%d", fa.nfargs);
472 for (i = 0; i < fa.nfargs; i++)
473 printf(" %18.12g", fa.farg[i]);
474 printf("\n");
475 freefargs(&fa);
476 return(0);
477 }
478
479
480 int
481 otype(ofname) /* get object function number from its name */
482 register char *ofname;
483 {
484 register int i;
485
486 for (i = 0; i < NUMTYPES; i++)
487 if (!strcmp(ofun[i].funame, ofname))
488 return(i);
489
490 return(-1); /* not found */
491 }
492
493
494 alias(fin) /* transfer alias */
495 FILE *fin;
496 {
497 char aliasnm[MAXSTR];
498
499 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
500 return(-1);
501 printf("\t%s\n", aliasnm);
502 return(0);
503 }
504
505
506 m_glow(fin) /* transform arguments for proximity light */
507 FILE *fin;
508 {
509 FUNARGS fa;
510
511 if (readfargs(&fa, fin) != 1)
512 return(-1);
513 if (fa.nsargs != 0 || fa.nfargs != 4)
514 return(-1);
515 printf("0\n0\n4");
516 printf(" %18.12g %18.12g %18.12g",
517 fa.farg[0], fa.farg[1], fa.farg[2]);
518 printf(" %18.12g\n", fa.farg[3] * tot.sca);
519 freefargs(&fa);
520 return(0);
521 }
522
523
524 m_spot(fin) /* transform arguments for spotlight */
525 FILE *fin;
526 {
527 FVECT v;
528 FUNARGS fa;
529
530 if (readfargs(&fa, fin) != 1)
531 return(-1);
532 if (fa.nsargs != 0 || fa.nfargs != 7)
533 return(-1);
534 printf("0\n0\n7");
535 printf(" %18.12g %18.12g %18.12g %18.12g\n",
536 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
537 multv3(v, fa.farg+4, tot.xfm);
538 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
539 freefargs(&fa);
540 return(0);
541 }
542
543
544 m_mist(fin) /* transform arguments for mist */
545 FILE *fin;
546 {
547 FUNARGS fa;
548 int i;
549
550 if (readfargs(&fa, fin) != 1)
551 return(-1);
552 if (fa.nfargs > 7)
553 return(-1);
554 printf("%d", fa.nsargs);
555 if (idprefix == NULL)
556 for (i = 0; i < fa.nsargs; i++)
557 printf(" %s", fa.sarg[i]);
558 else
559 for (i = 0; i < fa.nsargs; i++) {
560 char sname[256], *sp;
561 register char *cp1, *cp2 = sname;
562 /* add idprefix */
563 for (sp = fa.sarg[i]; *sp; sp = cp1) {
564 for (cp1 = idprefix; *cp1; )
565 *cp2++ = *cp1++;
566 *cp2++ = '.';
567 for (cp1 = sp; *cp1 &&
568 (*cp2++ = *cp1++) != '>'; )
569 ;
570 }
571 *cp2 = '\0';
572 printf(" %s", sname);
573 }
574 printf("\n0\n%d", fa.nfargs);
575 if (fa.nfargs > 2)
576 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
577 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
578 for (i = 3; i < fa.nfargs; i++)
579 printf(" %12.6g", fa.farg[i]);
580 printf("\n");
581 freefargs(&fa);
582 return(0);
583 }
584
585
586 m_dielectric(fin) /* transform arguments for dielectric */
587 FILE *fin;
588 {
589 FUNARGS fa;
590
591 if (readfargs(&fa, fin) != 1)
592 return(-1);
593 if (fa.nsargs != 0 || fa.nfargs != 5)
594 return(-1);
595 printf("0\n0\n5");
596 printf(" %12.6g %12.6g %12.6g",
597 pow(fa.farg[0], 1.0/tot.sca),
598 pow(fa.farg[1], 1.0/tot.sca),
599 pow(fa.farg[2], 1.0/tot.sca));
600 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
601 freefargs(&fa);
602 return(0);
603 }
604
605
606 m_interface(fin) /* transform arguments for interface */
607 FILE *fin;
608 {
609 FUNARGS fa;
610
611 if (readfargs(&fa, fin) != 1)
612 return(-1);
613 if (fa.nsargs != 0 || fa.nfargs != 8)
614 return(-1);
615 printf("0\n0\n8\n");
616 printf("%12.6g %12.6g %12.6g",
617 pow(fa.farg[0], 1.0/tot.sca),
618 pow(fa.farg[1], 1.0/tot.sca),
619 pow(fa.farg[2], 1.0/tot.sca));
620 printf(" %12.6g\n", fa.farg[3]);
621 printf("%12.6g %12.6g %12.6g",
622 pow(fa.farg[4], 1.0/tot.sca),
623 pow(fa.farg[5], 1.0/tot.sca),
624 pow(fa.farg[6], 1.0/tot.sca));
625 printf(" %12.6g\n", fa.farg[7]);
626 freefargs(&fa);
627 return(0);
628 }
629
630
631 text(fin) /* transform text arguments */
632 FILE *fin;
633 {
634 int i;
635 FVECT v;
636 FUNARGS fa;
637
638 if (readfargs(&fa, fin) != 1)
639 return(-1);
640 if (fa.nfargs < 9)
641 return(-1);
642 /* string arguments */
643 printf("%d", fa.nsargs);
644 for (i = 0; i < fa.nsargs; i++)
645 printf(" %s", fa.sarg[i]);
646 printf("\n0\n%d\n", fa.nfargs);
647 /* anchor point */
648 multp3(v, fa.farg, tot.xfm);
649 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
650 /* right vector */
651 multv3(v, fa.farg+3, tot.xfm);
652 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
653 /* down vector */
654 multv3(v, fa.farg+6, tot.xfm);
655 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
656 /* remaining arguments */
657 for (i = 9; i < fa.nfargs; i++) {
658 if (i%3 == 0)
659 putchar('\n');
660 printf(" %18.12g", fa.farg[i]);
661 }
662 putchar('\n');
663 freefargs(&fa);
664 return(0);
665 }
666
667
668 o_source(fin) /* transform source arguments */
669 FILE *fin;
670 {
671 FVECT dv;
672 FUNARGS fa;
673
674 if (readfargs(&fa, fin) != 1)
675 return(-1);
676 if (fa.nsargs != 0 || fa.nfargs != 4)
677 return(-1);
678 /* transform direction vector */
679 multv3(dv, fa.farg, tot.xfm);
680 /* output */
681 printf("0\n0\n4");
682 printf(" %18.12g %18.12g %18.12g %18.12g\n",
683 dv[0], dv[1], dv[2], fa.farg[3]);
684 freefargs(&fa);
685 return(0);
686 }
687
688
689 o_sphere(fin) /* transform sphere arguments */
690 FILE *fin;
691 {
692 FVECT cent;
693 double rad;
694 FUNARGS fa;
695
696 if (readfargs(&fa, fin) != 1)
697 return(-1);
698 if (fa.nsargs != 0 || fa.nfargs != 4)
699 return(-1);
700
701 multp3(cent, fa.farg, tot.xfm); /* transform center */
702
703 rad = fa.farg[3] * tot.sca; /* scale radius */
704
705 printf("0\n0\n4");
706 printf(" %18.12g %18.12g %18.12g %18.12g\n",
707 cent[0], cent[1], cent[2], rad);
708 freefargs(&fa);
709 return(0);
710 }
711
712
713 o_face(fin) /* transform face arguments */
714 FILE *fin;
715 {
716 FVECT p;
717 register int i;
718 FUNARGS fa;
719
720 if (readfargs(&fa, fin) != 1)
721 return(-1);
722 if (fa.nsargs != 0 || fa.nfargs % 3)
723 return(-1);
724
725 printf("0\n0\n%d\n", fa.nfargs);
726
727 for (i = 0; i < fa.nfargs; i += 3) {
728 if (reverse)
729 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
730 else
731 multp3(p, fa.farg+i, tot.xfm);
732 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
733 }
734 freefargs(&fa);
735 return(0);
736 }
737
738
739 o_cone(fin) /* transform cone and cup arguments */
740 FILE *fin;
741 {
742 FVECT p0, p1;
743 double r0, r1;
744 FUNARGS fa;
745
746 if (readfargs(&fa, fin) != 1)
747 return(-1);
748 if (fa.nsargs != 0 || fa.nfargs != 8)
749 return(-1);
750
751 printf("0\n0\n8\n");
752
753 multp3(p0, fa.farg, tot.xfm);
754 multp3(p1, fa.farg+3, tot.xfm);
755 r0 = fa.farg[6] * tot.sca;
756 r1 = fa.farg[7] * tot.sca;
757 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
758 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
759 printf(" %18.12g %18.12g\n", r0, r1);
760
761 freefargs(&fa);
762 return(0);
763 }
764
765
766 o_cylinder(fin) /* transform cylinder and tube arguments */
767 FILE *fin;
768 {
769 FVECT p0, p1;
770 double rad;
771 FUNARGS fa;
772
773 if (readfargs(&fa, fin) != 1)
774 return(-1);
775 if (fa.nsargs != 0 || fa.nfargs != 7)
776 return(-1);
777
778 printf("0\n0\n7\n");
779
780 multp3(p0, fa.farg, tot.xfm);
781 multp3(p1, fa.farg+3, tot.xfm);
782 rad = fa.farg[6] * tot.sca;
783 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
784 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
785 printf(" %18.12g\n", rad);
786 freefargs(&fa);
787 return(0);
788 }
789
790
791 o_ring(fin) /* transform ring arguments */
792 FILE *fin;
793 {
794 FVECT p0, pd;
795 double r0, r1;
796 FUNARGS fa;
797
798 if (readfargs(&fa, fin) != 1)
799 return(-1);
800 if (fa.nsargs != 0 || fa.nfargs != 8)
801 return(-1);
802
803 printf("0\n0\n8\n");
804
805 multp3(p0, fa.farg, tot.xfm);
806 multv3(pd, fa.farg+3, tot.xfm);
807 if (invert) {
808 pd[0] = -pd[0];
809 pd[1] = -pd[1];
810 pd[2] = -pd[2];
811 }
812 r0 = fa.farg[6] * tot.sca;
813 r1 = fa.farg[7] * tot.sca;
814 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
815 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
816 printf(" %18.12g %18.12g\n", r0, r1);
817 freefargs(&fa);
818 return(0);
819 }
820
821
822 initotypes() /* initialize ofun[] array */
823 {
824 register int i;
825
826 if (ofun[OBJ_SOURCE].funp == o_source)
827 return; /* done already */
828 /* alias is additional */
829 ofun[ALIAS].funame = ALIASID;
830 ofun[ALIAS].flags = 0;
831 /* functions get new transform */
832 for (i = 0; i < NUMTYPES; i++)
833 if (hasfunc(i))
834 ofun[i].funp = addxform;
835 /* special cases */
836 ofun[OBJ_SOURCE].funp = o_source;
837 ofun[OBJ_SPHERE].funp =
838 ofun[OBJ_BUBBLE].funp = o_sphere;
839 ofun[OBJ_FACE].funp = o_face;
840 ofun[OBJ_CONE].funp =
841 ofun[OBJ_CUP].funp = o_cone;
842 ofun[OBJ_CYLINDER].funp =
843 ofun[OBJ_TUBE].funp = o_cylinder;
844 ofun[OBJ_RING].funp = o_ring;
845 ofun[OBJ_INSTANCE].funp = addxform;
846 ofun[MAT_GLOW].funp = m_glow;
847 ofun[MAT_SPOT].funp = m_spot;
848 ofun[MAT_DIELECTRIC].funp = m_dielectric;
849 ofun[MAT_INTERFACE].funp = m_interface;
850 ofun[MAT_MIST].funp = m_mist;
851 ofun[PAT_CTEXT].funp =
852 ofun[PAT_BTEXT].funp =
853 ofun[MIX_TEXT].funp = text;
854 ofun[ALIAS].funp = alias;
855 /* surface inverses */
856 tinvers[OBJ_FACE] = OBJ_FACE;
857 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
858 tinvers[OBJ_CONE] = OBJ_CUP;
859 tinvers[OBJ_CUP] = OBJ_CONE;
860 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
861 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
862 tinvers[OBJ_RING] = OBJ_RING;
863 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
864 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
865 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
866 }
867
868
869 #ifdef OLDXFORM
870 openmain(fname)
871 char *fname;
872 {
873 if (fname == NULL) {
874 strcpy(mainfn, "standard input");
875 mainfp = stdin;
876 return;
877 }
878 if (mainfp != NULL) {
879 if (!strcmp(fname, mainfn)) {
880 rewind(mainfp);
881 return;
882 }
883 fclose(mainfp);
884 }
885 if ((mainfp = fopen(fname, "r")) == NULL) {
886 fprintf(stderr, "%s: cannot open file \"%s\"\n",
887 progname, fname);
888 exit(1);
889 }
890 strcpy(mainfn, fname);
891 }
892 #else
893 openmain(fname) /* open fname for input, changing to its directory */
894 char *fname;
895 {
896 extern FILE *tmpfile();
897 extern char *getlibpath(), *getpath();
898 static char origdir[MAXPATH];
899 static char curfn[MAXPATH];
900 static int diffdir;
901 register char *fpath;
902
903 if (fname == NULL) { /* standard input */
904 if (mainfp == NULL) {
905 register int c;
906 strcpy(mainfn, "standard input");
907 if (nrept <= 1) {
908 mainfp = stdin;
909 return; /* just read once */
910 }
911 /* else copy */
912 if ((mainfp = tmpfile()) == NULL) {
913 fprintf(stderr,
914 "%s: cannot create temporary file\n",
915 progname);
916 exit(1);
917 }
918 while ((c = getc(stdin)) != EOF)
919 putc(c, mainfp);
920 fclose(stdin);
921 }
922 rewind(mainfp); /* rewind copy */
923 return;
924 }
925 if (mainfp == NULL) { /* first call, initialize */
926 getwd(origdir);
927 } else if (!strcmp(fname, curfn)) { /* just need to rewind? */
928 rewind(mainfp);
929 return;
930 } else { /* else close old stream */
931 fclose(mainfp);
932 if (diffdir) {
933 chdir(origdir);
934 diffdir = 0;
935 }
936 }
937 strcpy(curfn, fname); /* remember file name */
938 /* get full path */
939 if ((fpath = getpath(fname, getlibpath(), R_OK)) == NULL) {
940 fprintf(stderr, "%s: cannot find file \"%s\"\n",
941 progname, fname);
942 exit(1);
943 }
944 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
945 fpath += 2;
946 /* record path name */
947 strcpy(mainfn, fpath);
948 if (expand) { /* change to local directory */
949 register char *cp = fpath + strlen(fpath); /* get dir. */
950 while (cp > fpath) {
951 cp--;
952 if (ISDIRSEP(*cp)) {
953 if (cp == fpath)
954 cp++; /* root special case */
955 break;
956 }
957 }
958 *cp = '\0';
959 if (fpath[0]) { /* change to new directory? */
960 if (chdir(fpath) < 0) {
961 fprintf(stderr,
962 "%s: cannot change directory to \"%s\"\n",
963 progname, fpath);
964 exit(1);
965 }
966 diffdir++;
967 }
968 /* get final path component */
969 for (fpath = fname+strlen(fname);
970 fpath > fname && !ISDIRSEP(fpath[-1]); fpath--)
971 ;
972 }
973 /* open the file */
974 if ((mainfp = fopen(fpath, "r")) == NULL) {
975 fprintf(stderr, "%s: cannot open file \"%s\"\n",
976 progname, mainfn);
977 exit(1);
978 }
979 }
980 #endif
