root/radiance/src/gen/xform.c
Revision: 2.19
Committed: Fri Jun 4 16:00:27 1999 UTC (26 years, 4 months ago) by gwlarson
Changes since 2.18: +3 -1 lines
made -f option ignore leading '!' and "xform" on each line
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * xform.c - program to transform object files.
9 * Transformations must preserve aspect ratio.
10 *
11 * 10/19/85
12 * 11/6/86 Finally added error checking!
13 */
14
15 #include "standard.h"
16
17 #include "paths.h"
18
19 #include <ctype.h>
20
21 #include "object.h"
22
23 #include "otypes.h"
24
25 int xac; /* global xform argument count */
26 char **xav; /* global xform argument pointer */
27 int xfa; /* start of xf arguments */
28
29 XF tot; /* total transformation */
30 int reverse; /* boolean true if scene mirrored */
31
32 int invert = 0; /* boolean true to invert surfaces */
33
34 int expand = 1; /* boolean true to expand commands */
35
36 char *newmod = NULL; /* new modifier for surfaces */
37
38 char *idprefix = NULL; /* prefix for object identifiers */
39
40 #define ALIAS NUMOTYPE /* put alias at end of array */
41
42 #define NUMTYPES (NUMOTYPE+1) /* total number of object types */
43
44 FUN ofun[NUMTYPES] = INIT_OTYPE; /* default types and actions */
45
46 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
47
48 int nrept = 1; /* number of array repetitions */
49
50 int stdinused = 0; /* stdin has been used by -f option? */
51
52 extern char *malloc(), *fgets(), *fgetword();
53
54 char mainfn[MAXPATH]; /* main file name */
55 FILE *mainfp = NULL; /* main file pointer */
56
57 #define progname (xav[0])
58
59
60 main(argc, argv) /* get transform options and transform file */
61 int argc;
62 char *argv[];
63 {
64 char *fname;
65 int a;
66 /* check for argument list file */
67 for (a = 1; a < argc; a++)
68 if (!strcmp(argv[a], "-f"))
69 return(doargf(argc, argv, a));
70 /* check for regular array */
71 for (a = 1; a < argc; a++)
72 if (!strcmp(argv[a], "-a"))
73 return(doarray(argc, argv, a));
74
75 initotypes();
76
77 for (a = 1; a < argc; a++) {
78 if (argv[a][0] == '-')
79 switch (argv[a][1]) {
80 case 'm':
81 if (argv[a][2] || a+1 >= argc)
82 break;
83 newmod = argv[++a];
84 continue;
85 case 'n':
86 if (argv[a][2] || a+1 >= argc)
87 break;
88 idprefix = argv[++a];
89 continue;
90 case 'c':
91 if (argv[a][2])
92 break;
93 expand = 0;
94 continue;
95 case 'e':
96 if (argv[a][2])
97 break;
98 expand = 1;
99 continue;
100 case 'I':
101 if (argv[a][2])
102 break;
103 invert = 1;
104 continue;
105 }
106 break;
107 }
108
109 xav = argv;
110 xfa = a;
111
112 a += xf(&tot, argc-a, argv+a);
113
114 if (reverse = tot.sca < 0.0)
115 tot.sca = -tot.sca;
116 if (invert)
117 reverse = !reverse;
118
119 if (a < argc && argv[a][0] == '-') {
120 fprintf(stderr, "%s: command line error at '%s'\n",
121 argv[0], argv[a]);
122 exit(1);
123 }
124
125 xac = a;
126 /* simple header */
127 putchar('#');
128 for (a = 0; a < xac; a++)
129 printf(" %s", xav[a]);
130 putchar('\n');
131 /* transform input */
132 if (xac == argc) {
133 if (stdinused) {
134 fprintf(stderr, "%s: cannot use stdin more than once\n",
135 argv[0]);
136 exit(1);
137 }
138 openmain(NULL);
139 xform(mainfn, mainfp);
140 } else
141 for (a = xac; a < argc; a++) {
142 openmain(argv[a]);
143 xform(mainfn, mainfp);
144 }
145
146 return(0);
147 }
148
149
150 doargf(ac, av, fi) /* take argument list from file */
151 char **av;
152 int ac, fi;
153 {
154 char *newav[256], **avp;
155 char argbuf[2048];
156 char newid[128];
157 char *oldid;
158 register char *cp;
159 FILE *argfp;
160 int n, i, k, newac, err;
161
162 if (fi >= ac-1 || (av[fi+1][0] == '-' && av[fi+1][1] != '\0')) {
163 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
164 exit(1);
165 }
166 if (av[fi+1][0] == '-' && av[fi+1][1] == '\0') {
167 if (stdinused++) {
168 fprintf(stderr, "%s: cannot use stdin more than once\n",
169 av[0]);
170 exit(1);
171 }
172 argfp = stdin;
173 n = 100; /* we just don't know! */
174 } else {
175 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
176 fprintf(stderr, "%s: cannot open argument file \"%s\"\n",
177 av[0], av[fi+1]);
178 exit(1);
179 }
180 n = 0; /* count number of lines in file */
181 while (fgets(argbuf,sizeof(argbuf),argfp) != NULL)
182 n += argbuf[0] != '\n' & argbuf[0] != '#';
183 if (!n) {
184 fprintf(stderr, "%s: empty argument file \"%s\"\n",
185 av[0], av[fi+1]);
186 exit(1);
187 }
188 nrept *= n;
189 rewind(argfp);
190 }
191 err = 0; k = 0; /* read each arg list and call main */
192 while (fgets(argbuf,sizeof(argbuf),argfp) != NULL) {
193 if (argbuf[0] == '\n' | argbuf[0] == '#')
194 continue;
195 avp = newav+2;
196 avp[0] = av[0];
197 for (i = 1; i < fi; i++)
198 avp[i] = av[i];
199 newac = i;
200 cp = argbuf; /* parse new words */
201 if (*cp == '!') cp++;
202 if (!strncmp(cp, "xform ", 6)) cp += 6;
203 for ( ; ; ) {
204 while (isspace(*cp)) /* nullify spaces */
205 *cp++ = '\0';
206 if (!*cp) /* all done? */
207 break;
208 avp[newac++] = cp; /* add argument to list */
209 while (*++cp && !isspace(*cp))
210 ;
211 }
212 for (i = fi+2; i < ac; i++)
213 avp[newac++] = av[i];
214 avp[newac] = NULL;
215 oldid = NULL;
216 for (i = 2; i < newac; i++)
217 if (!strcmp(avp[i-1], "-n")) {
218 oldid = avp[i];
219 avp[i] = newid;
220 break;
221 }
222 if (oldid == NULL) {
223 newav[0] = av[0];
224 newav[1] = "-n";
225 newav[2] = newid;
226 avp = newav;
227 newac += 2;
228 }
229 if (oldid == NULL)
230 sprintf(newid, "i%d", k);
231 else
232 sprintf(newid, "%s.%d", oldid, k);
233 err |= main(newac, avp);
234 k++;
235 }
236 fclose(argfp);
237 return(err);
238 }
239
240
241 doarray(ac, av, ai) /* make array */
242 char **av;
243 int ac, ai;
244 {
245 char *newav[256], **avp;
246 char newid[128], repts[32];
247 char *oldid = NULL;
248 int n, i, err;
249
250 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
251 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
252 exit(1);
253 }
254 nrept *= n;
255 avp = newav+2;
256 avp[0] = av[0];
257 for (i = 1; i < ac; i++)
258 if (!strcmp(av[i-1], "-n")) {
259 oldid = av[i];
260 avp[i] = newid;
261 } else
262 avp[i] = av[i];
263 avp[ai] = "-i";
264 avp[ai+1] = repts;
265 avp[i] = NULL;
266 if (oldid == NULL) {
267 newav[0] = av[0];
268 newav[1] = "-n";
269 newav[2] = newid;
270 avp = newav;
271 ac += 2;
272 }
273 err = 0;
274 for (i = 0; i < n; i++) {
275 if (oldid == NULL)
276 sprintf(newid, "a%d", i);
277 else
278 sprintf(newid, "%s.%d", oldid, i);
279 sprintf(repts, "%d", i);
280 err |= main(ac, avp);
281 }
282 return(err);
283 }
284
285
286 xform(name, fin) /* transform stream by tot.xfm */
287 char *name;
288 register FILE *fin;
289 {
290 int nobjs = 0;
291 register int c;
292
293 while ((c = getc(fin)) != EOF) {
294 if (isspace(c)) /* blank */
295 continue;
296 if (c == '#') { /* comment */
297 putchar(c);
298 do {
299 if ((c = getc(fin)) == EOF)
300 return;
301 putchar(c);
302 } while (c != '\n');
303 } else if (c == '!') { /* command */
304 ungetc(c, fin);
305 xfcomm(name, fin);
306 nobjs++;
307 } else { /* object */
308 ungetc(c, fin);
309 xfobject(name, fin);
310 nobjs++;
311 }
312 }
313 if (nobjs == 0)
314 fprintf(stderr, "%s: (%s): warning - empty file\n",
315 progname, name);
316 }
317
318
319 xfcomm(fname, fin) /* transform a command */
320 char *fname;
321 FILE *fin;
322 {
323 extern FILE *popen();
324 extern char *fgetline();
325 FILE *pin;
326 char buf[512];
327 int i;
328
329 fgetline(buf, sizeof(buf), fin);
330 if (expand) {
331 if ((pin = popen(buf+1, "r")) == NULL) {
332 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
333 progname, fname, buf);
334 exit(1);
335 }
336 xform(buf, pin);
337 pclose(pin);
338 } else {
339 printf("\n%s", buf);
340 if (xac > 1) {
341 printf(" | %s", xav[0]);
342 for (i = 1; i < xac; i++)
343 printf(" %s", xav[i]);
344 }
345 putchar('\n');
346 }
347 }
348
349
350 xfobject(fname, fin) /* transform an object */
351 char *fname;
352 FILE *fin;
353 {
354 extern char *strcpy();
355 char typ[16], nam[MAXSTR];
356 int fn;
357 /* modifier and type */
358 strcpy(typ, "EOF");
359 fgetword(nam, sizeof(nam), fin);
360 fgetword(typ, sizeof(typ), fin);
361 if ((fn = otype(typ)) < 0) {
362 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
363 progname, fname, typ);
364 exit(1);
365 }
366 if (ismodifier(fn))
367 printf("\n%s %s ", nam, typ);
368 else
369 printf("\n%s %s ", newmod != NULL ? newmod : nam,
370 invert ? ofun[tinvers[fn]].funame : typ);
371 /* object name */
372 fgetword(nam, sizeof(nam), fin);
373 if (idprefix == NULL || ismodifier(fn))
374 printf("%s\n", nam);
375 else
376 printf("%s.%s\n", idprefix, nam);
377 /* transform arguments */
378 if ((*ofun[fn].funp)(fin) < 0) {
379 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
380 progname, fname, ofun[fn].funame, nam);
381 exit(1);
382 }
383 }
384
385
386 o_default(fin) /* pass on arguments unchanged */
387 FILE *fin;
388 {
389 register int i;
390 FUNARGS fa;
391
392 if (readfargs(&fa, fin) != 1)
393 return(-1);
394 /* string arguments */
395 printf("%d", fa.nsargs);
396 for (i = 0; i < fa.nsargs; i++)
397 printf(" %s", fa.sarg[i]);
398 printf("\n");
399 #ifdef IARGS
400 /* integer arguments */
401 printf("%d", fa.niargs);
402 for (i = 0; i < fa.niargs; i++)
403 printf(" %d", fa.iarg[i]);
404 printf("\n");
405 #else
406 printf("0\n");
407 #endif
408 /* float arguments */
409 printf("%d", fa.nfargs);
410 for (i = 0; i < fa.nfargs; i++)
411 printf(" %18.12g", fa.farg[i]);
412 printf("\n");
413 freefargs(&fa);
414 return(0);
415 }
416
417
418 addxform(fin) /* add xf arguments to strings */
419 FILE *fin;
420 {
421 register int i;
422 int resetarr = 0;
423 FUNARGS fa;
424
425 if (readfargs(&fa, fin) != 1)
426 return(-1);
427 /* string arguments */
428 if (xac > xfa && strcmp(xav[xfa], "-i"))
429 resetarr = 2;
430 printf("%d", fa.nsargs + resetarr + xac-xfa);
431 for (i = 0; i < fa.nsargs; i++)
432 printf(" %s", fa.sarg[i]);
433 if (resetarr)
434 printf(" -i 1");
435 for (i = xfa; i < xac; i++) /* add xf arguments */
436 printf(" %s", xav[i]);
437 printf("\n");
438 #ifdef IARGS
439 /* integer arguments */
440 printf("%d", fa.niargs);
441 for (i = 0; i < fa.niargs; i++)
442 printf(" %d", fa.iarg[i]);
443 printf("\n");
444 #else
445 printf("0\n");
446 #endif
447 /* float arguments */
448 printf("%d", fa.nfargs);
449 for (i = 0; i < fa.nfargs; i++)
450 printf(" %18.12g", fa.farg[i]);
451 printf("\n");
452 freefargs(&fa);
453 return(0);
454 }
455
456
457 int
458 otype(ofname) /* get object function number from its name */
459 register char *ofname;
460 {
461 register int i;
462
463 for (i = 0; i < NUMTYPES; i++)
464 if (!strcmp(ofun[i].funame, ofname))
465 return(i);
466
467 return(-1); /* not found */
468 }
469
470
471 alias(fin) /* transfer alias */
472 FILE *fin;
473 {
474 char aliasnm[MAXSTR];
475
476 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
477 return(-1);
478 printf("\t%s\n", aliasnm);
479 return(0);
480 }
481
482
483 m_glow(fin) /* transform arguments for proximity light */
484 FILE *fin;
485 {
486 FUNARGS fa;
487
488 if (readfargs(&fa, fin) != 1)
489 return(-1);
490 if (fa.nsargs != 0 || fa.nfargs != 4)
491 return(-1);
492 printf("0\n0\n4");
493 printf(" %18.12g %18.12g %18.12g",
494 fa.farg[0], fa.farg[1], fa.farg[2]);
495 printf(" %18.12g\n", fa.farg[3] * tot.sca);
496 freefargs(&fa);
497 return(0);
498 }
499
500
501 m_spot(fin) /* transform arguments for spotlight */
502 FILE *fin;
503 {
504 FVECT v;
505 FUNARGS fa;
506
507 if (readfargs(&fa, fin) != 1)
508 return(-1);
509 if (fa.nsargs != 0 || fa.nfargs != 7)
510 return(-1);
511 printf("0\n0\n7");
512 printf(" %18.12g %18.12g %18.12g %18.12g\n",
513 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
514 multv3(v, fa.farg+4, tot.xfm);
515 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
516 freefargs(&fa);
517 return(0);
518 }
519
520
521 m_mist(fin) /* transform arguments for mist */
522 FILE *fin;
523 {
524 FUNARGS fa;
525 int i;
526
527 if (readfargs(&fa, fin) != 1)
528 return(-1);
529 if (fa.nfargs > 7)
530 return(-1);
531 printf("%d", fa.nsargs);
532 if (idprefix == NULL)
533 for (i = 0; i < fa.nsargs; i++)
534 printf(" %s", fa.sarg[i]);
535 else
536 for (i = 0; i < fa.nsargs; i++) {
537 char sname[256], *sp;
538 register char *cp1, *cp2 = sname;
539 /* add idprefix */
540 for (sp = fa.sarg[i]; *sp; sp = cp1) {
541 for (cp1 = idprefix; *cp1; )
542 *cp2++ = *cp1++;
543 *cp2++ = '.';
544 for (cp1 = sp; *cp1 &&
545 (*cp2++ = *cp1++) != '>'; )
546 ;
547 }
548 *cp2 = '\0';
549 printf(" %s", sname);
550 }
551 printf("\n0\n%d", fa.nfargs);
552 if (fa.nfargs > 2)
553 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
554 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
555 for (i = 3; i < fa.nfargs; i++)
556 printf(" %12.6g", fa.farg[i]);
557 printf("\n");
558 freefargs(&fa);
559 return(0);
560 }
561
562
563 m_dielectric(fin) /* transform arguments for dielectric */
564 FILE *fin;
565 {
566 FUNARGS fa;
567
568 if (readfargs(&fa, fin) != 1)
569 return(-1);
570 if (fa.nsargs != 0 || fa.nfargs != 5)
571 return(-1);
572 printf("0\n0\n5");
573 printf(" %12.6g %12.6g %12.6g",
574 pow(fa.farg[0], 1.0/tot.sca),
575 pow(fa.farg[1], 1.0/tot.sca),
576 pow(fa.farg[2], 1.0/tot.sca));
577 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
578 freefargs(&fa);
579 return(0);
580 }
581
582
583 m_interface(fin) /* transform arguments for interface */
584 FILE *fin;
585 {
586 FUNARGS fa;
587
588 if (readfargs(&fa, fin) != 1)
589 return(-1);
590 if (fa.nsargs != 0 || fa.nfargs != 8)
591 return(-1);
592 printf("0\n0\n8\n");
593 printf("%12.6g %12.6g %12.6g",
594 pow(fa.farg[0], 1.0/tot.sca),
595 pow(fa.farg[1], 1.0/tot.sca),
596 pow(fa.farg[2], 1.0/tot.sca));
597 printf(" %12.6g\n", fa.farg[3]);
598 printf("%12.6g %12.6g %12.6g",
599 pow(fa.farg[4], 1.0/tot.sca),
600 pow(fa.farg[5], 1.0/tot.sca),
601 pow(fa.farg[6], 1.0/tot.sca));
602 printf(" %12.6g\n", fa.farg[7]);
603 freefargs(&fa);
604 return(0);
605 }
606
607
608 text(fin) /* transform text arguments */
609 FILE *fin;
610 {
611 int i;
612 FVECT v;
613 FUNARGS fa;
614
615 if (readfargs(&fa, fin) != 1)
616 return(-1);
617 if (fa.nfargs < 9)
618 return(-1);
619 /* string arguments */
620 printf("%d", fa.nsargs);
621 for (i = 0; i < fa.nsargs; i++)
622 printf(" %s", fa.sarg[i]);
623 printf("\n0\n%d\n", fa.nfargs);
624 /* anchor point */
625 multp3(v, fa.farg, tot.xfm);
626 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
627 /* right vector */
628 multv3(v, fa.farg+3, tot.xfm);
629 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
630 /* down vector */
631 multv3(v, fa.farg+6, tot.xfm);
632 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
633 /* remaining arguments */
634 for (i = 9; i < fa.nfargs; i++) {
635 if (i%3 == 0)
636 putchar('\n');
637 printf(" %18.12g", fa.farg[i]);
638 }
639 putchar('\n');
640 freefargs(&fa);
641 return(0);
642 }
643
644
645 o_source(fin) /* transform source arguments */
646 FILE *fin;
647 {
648 FVECT dv;
649 FUNARGS fa;
650
651 if (readfargs(&fa, fin) != 1)
652 return(-1);
653 if (fa.nsargs != 0 || fa.nfargs != 4)
654 return(-1);
655 /* transform direction vector */
656 multv3(dv, fa.farg, tot.xfm);
657 /* output */
658 printf("0\n0\n4");
659 printf(" %18.12g %18.12g %18.12g %18.12g\n",
660 dv[0], dv[1], dv[2], fa.farg[3]);
661 freefargs(&fa);
662 return(0);
663 }
664
665
666 o_sphere(fin) /* transform sphere arguments */
667 FILE *fin;
668 {
669 FVECT cent;
670 double rad;
671 FUNARGS fa;
672
673 if (readfargs(&fa, fin) != 1)
674 return(-1);
675 if (fa.nsargs != 0 || fa.nfargs != 4)
676 return(-1);
677
678 multp3(cent, fa.farg, tot.xfm); /* transform center */
679
680 rad = fa.farg[3] * tot.sca; /* scale radius */
681
682 printf("0\n0\n4");
683 printf(" %18.12g %18.12g %18.12g %18.12g\n",
684 cent[0], cent[1], cent[2], rad);
685 freefargs(&fa);
686 return(0);
687 }
688
689
690 o_face(fin) /* transform face arguments */
691 FILE *fin;
692 {
693 FVECT p;
694 register int i;
695 FUNARGS fa;
696
697 if (readfargs(&fa, fin) != 1)
698 return(-1);
699 if (fa.nsargs != 0 || fa.nfargs % 3)
700 return(-1);
701
702 printf("0\n0\n%d\n", fa.nfargs);
703
704 for (i = 0; i < fa.nfargs; i += 3) {
705 if (reverse)
706 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
707 else
708 multp3(p, fa.farg+i, tot.xfm);
709 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
710 }
711 freefargs(&fa);
712 return(0);
713 }
714
715
716 o_cone(fin) /* transform cone and cup arguments */
717 FILE *fin;
718 {
719 FVECT p0, p1;
720 double r0, r1;
721 FUNARGS fa;
722
723 if (readfargs(&fa, fin) != 1)
724 return(-1);
725 if (fa.nsargs != 0 || fa.nfargs != 8)
726 return(-1);
727
728 printf("0\n0\n8\n");
729
730 multp3(p0, fa.farg, tot.xfm);
731 multp3(p1, fa.farg+3, tot.xfm);
732 r0 = fa.farg[6] * tot.sca;
733 r1 = fa.farg[7] * tot.sca;
734 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
735 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
736 printf(" %18.12g %18.12g\n", r0, r1);
737
738 freefargs(&fa);
739 return(0);
740 }
741
742
743 o_cylinder(fin) /* transform cylinder and tube arguments */
744 FILE *fin;
745 {
746 FVECT p0, p1;
747 double rad;
748 FUNARGS fa;
749
750 if (readfargs(&fa, fin) != 1)
751 return(-1);
752 if (fa.nsargs != 0 || fa.nfargs != 7)
753 return(-1);
754
755 printf("0\n0\n7\n");
756
757 multp3(p0, fa.farg, tot.xfm);
758 multp3(p1, fa.farg+3, tot.xfm);
759 rad = fa.farg[6] * tot.sca;
760 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
761 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
762 printf(" %18.12g\n", rad);
763 freefargs(&fa);
764 return(0);
765 }
766
767
768 o_ring(fin) /* transform ring arguments */
769 FILE *fin;
770 {
771 FVECT p0, pd;
772 double r0, r1;
773 FUNARGS fa;
774
775 if (readfargs(&fa, fin) != 1)
776 return(-1);
777 if (fa.nsargs != 0 || fa.nfargs != 8)
778 return(-1);
779
780 printf("0\n0\n8\n");
781
782 multp3(p0, fa.farg, tot.xfm);
783 multv3(pd, fa.farg+3, tot.xfm);
784 if (invert) {
785 pd[0] = -pd[0];
786 pd[1] = -pd[1];
787 pd[2] = -pd[2];
788 }
789 r0 = fa.farg[6] * tot.sca;
790 r1 = fa.farg[7] * tot.sca;
791 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
792 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
793 printf(" %18.12g %18.12g\n", r0, r1);
794 freefargs(&fa);
795 return(0);
796 }
797
798
799 initotypes() /* initialize ofun[] array */
800 {
801 register int i;
802
803 if (ofun[OBJ_SOURCE].funp == o_source)
804 return; /* done already */
805 /* alias is additional */
806 ofun[ALIAS].funame = ALIASID;
807 ofun[ALIAS].flags = 0;
808 /* functions get new transform */
809 for (i = 0; i < NUMTYPES; i++)
810 if (hasfunc(i))
811 ofun[i].funp = addxform;
812 /* special cases */
813 ofun[OBJ_SOURCE].funp = o_source;
814 ofun[OBJ_SPHERE].funp =
815 ofun[OBJ_BUBBLE].funp = o_sphere;
816 ofun[OBJ_FACE].funp = o_face;
817 ofun[OBJ_CONE].funp =
818 ofun[OBJ_CUP].funp = o_cone;
819 ofun[OBJ_CYLINDER].funp =
820 ofun[OBJ_TUBE].funp = o_cylinder;
821 ofun[OBJ_RING].funp = o_ring;
822 ofun[OBJ_INSTANCE].funp = addxform;
823 ofun[MAT_GLOW].funp = m_glow;
824 ofun[MAT_SPOT].funp = m_spot;
825 ofun[MAT_DIELECTRIC].funp = m_dielectric;
826 ofun[MAT_INTERFACE].funp = m_interface;
827 ofun[MAT_MIST].funp = m_mist;
828 ofun[PAT_CTEXT].funp =
829 ofun[PAT_BTEXT].funp =
830 ofun[MIX_TEXT].funp = text;
831 ofun[ALIAS].funp = alias;
832 /* surface inverses */
833 tinvers[OBJ_FACE] = OBJ_FACE;
834 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
835 tinvers[OBJ_CONE] = OBJ_CUP;
836 tinvers[OBJ_CUP] = OBJ_CONE;
837 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
838 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
839 tinvers[OBJ_RING] = OBJ_RING;
840 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
841 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
842 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
843 }
844
845
846 #ifdef OLDXFORM
847 openmain(fname)
848 char *fname;
849 {
850 if (fname == NULL) {
851 strcpy(mainfn, "standard input");
852 mainfp = stdin;
853 return;
854 }
855 if (mainfp != NULL) {
856 if (!strcmp(fname, mainfn)) {
857 rewind(mainfp);
858 return;
859 }
860 fclose(mainfp);
861 }
862 if ((mainfp = fopen(fname, "r")) == NULL) {
863 fprintf(stderr, "%s: cannot open file \"%s\"\n",
864 progname, fname);
865 exit(1);
866 }
867 strcpy(mainfn, fname);
868 }
869 #else
870 openmain(fname) /* open fname for input, changing to its directory */
871 char *fname;
872 {
873 extern FILE *tmpfile();
874 extern char *getlibpath(), *getpath();
875 static char origdir[MAXPATH];
876 static char curfn[MAXPATH];
877 static int diffdir;
878 register char *fpath;
879
880 if (fname == NULL) { /* standard input */
881 if (mainfp == NULL) {
882 register int c;
883 strcpy(mainfn, "standard input");
884 if (nrept <= 1) {
885 mainfp = stdin;
886 return; /* just read once */
887 }
888 /* else copy */
889 if ((mainfp = tmpfile()) == NULL) {
890 fprintf(stderr,
891 "%s: cannot create temporary file\n",
892 progname);
893 exit(1);
894 }
895 while ((c = getc(stdin)) != EOF)
896 putc(c, mainfp);
897 fclose(stdin);
898 }
899 rewind(mainfp); /* rewind copy */
900 return;
901 }
902 if (mainfp == NULL) { /* first call, initialize */
903 getwd(origdir);
904 } else if (!strcmp(fname, curfn)) { /* just need to rewind? */
905 rewind(mainfp);
906 return;
907 } else { /* else close old stream */
908 fclose(mainfp);
909 if (diffdir) {
910 chdir(origdir);
911 diffdir = 0;
912 }
913 }
914 strcpy(curfn, fname); /* remember file name */
915 /* get full path */
916 if ((fpath = getpath(fname, getlibpath(), R_OK)) == NULL) {
917 fprintf(stderr, "%s: cannot find file \"%s\"\n",
918 progname, fname);
919 exit(1);
920 }
921 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
922 fpath += 2;
923 /* record path name */
924 strcpy(mainfn, fpath);
925 if (expand) { /* change to local directory */
926 register char *cp = fpath + strlen(fpath); /* get dir. */
927 while (cp > fpath) {
928 cp--;
929 if (ISDIRSEP(*cp)) {
930 if (cp == fpath)
931 cp++; /* root special case */
932 break;
933 }
934 }
935 *cp = '\0';
936 if (fpath[0]) { /* change to new directory? */
937 if (chdir(fpath) < 0) {
938 fprintf(stderr,
939 "%s: cannot change directory to \"%s\"\n",
940 progname, fpath);
941 exit(1);
942 }
943 diffdir++;
944 }
945 /* get final path component */
946 for (fpath = fname+strlen(fname);
947 fpath > fname && !ISDIRSEP(fpath[-1]); fpath--)
948 ;
949 }
950 /* open the file */
951 if ((mainfp = fopen(fpath, "r")) == NULL) {
952 fprintf(stderr, "%s: cannot open file \"%s\"\n",
953 progname, mainfn);
954 exit(1);
955 }
956 }
957 #endif
