root/radiance/src/gen/xform.c
Revision: 2.16
Committed: Thu Jun 3 14:15:01 1999 UTC (26 years, 4 months ago) by gwlarson
Changes since 2.15: +88 -3 lines
added -f option to read transform arguments from a file
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * xform.c - program to transform object files.
9 * Transformations must preserve aspect ratio.
10 *
11 * 10/19/85
12 * 11/6/86 Finally added error checking!
13 */
14
15 #include "standard.h"
16
17 #include "paths.h"
18
19 #include <ctype.h>
20
21 #include "object.h"
22
23 #include "otypes.h"
24
25 int xac; /* global xform argument count */
26 char **xav; /* global xform argument pointer */
27 int xfa; /* start of xf arguments */
28
29 XF tot; /* total transformation */
30 int reverse; /* boolean true if scene mirrored */
31
32 int invert = 0; /* boolean true to invert surfaces */
33
34 int expand = 1; /* boolean true to expand commands */
35
36 char *newmod = NULL; /* new modifier for surfaces */
37
38 char *idprefix = NULL; /* prefix for object identifiers */
39
40 #define ALIAS NUMOTYPE /* put alias at end of array */
41
42 #define NUMTYPES (NUMOTYPE+1) /* total number of object types */
43
44 FUN ofun[NUMTYPES] = INIT_OTYPE; /* default types and actions */
45
46 short tinvers[NUMOTYPE]; /* inverse types for surfaces */
47
48 int nrept = 1; /* number of array repetitions */
49
50 extern char *malloc(), *fgets(), *fgetword();
51
52 char mainfn[MAXPATH]; /* main file name */
53 FILE *mainfp = NULL; /* main file pointer */
54
55 #define progname (xav[0])
56
57
58 main(argc, argv) /* get transform options and transform file */
59 int argc;
60 char *argv[];
61 {
62 char *fname;
63 int a;
64 /* check for argument list file */
65 for (a = 1; a < argc; a++)
66 if (!strcmp(argv[a], "-f"))
67 return(doargf(argc, argv, a));
68 /* check for regular array */
69 for (a = 1; a < argc; a++)
70 if (!strcmp(argv[a], "-a"))
71 return(doarray(argc, argv, a));
72
73 initotypes();
74
75 for (a = 1; a < argc; a++) {
76 if (argv[a][0] == '-')
77 switch (argv[a][1]) {
78 case 'm':
79 if (argv[a][2] || a+1 >= argc)
80 break;
81 newmod = argv[++a];
82 continue;
83 case 'n':
84 if (argv[a][2] || a+1 >= argc)
85 break;
86 idprefix = argv[++a];
87 continue;
88 case 'c':
89 if (argv[a][2])
90 break;
91 expand = 0;
92 continue;
93 case 'e':
94 if (argv[a][2])
95 break;
96 expand = 1;
97 continue;
98 case 'I':
99 if (argv[a][2])
100 break;
101 invert = 1;
102 continue;
103 }
104 break;
105 }
106
107 xav = argv;
108 xfa = a;
109
110 a += xf(&tot, argc-a, argv+a);
111
112 if (reverse = tot.sca < 0.0)
113 tot.sca = -tot.sca;
114 if (invert)
115 reverse = !reverse;
116
117 if (a < argc && argv[a][0] == '-') {
118 fprintf(stderr, "%s: command line error at '%s'\n",
119 argv[0], argv[a]);
120 exit(1);
121 }
122
123 xac = a;
124 /* simple header */
125 putchar('#');
126 for (a = 0; a < xac; a++)
127 printf(" %s", xav[a]);
128 putchar('\n');
129 /* transform input */
130 if (xac == argc) {
131 openmain(NULL);
132 xform(mainfn, mainfp);
133 } else
134 for (a = xac; a < argc; a++) {
135 openmain(argv[a]);
136 xform(mainfn, mainfp);
137 }
138
139 return(0);
140 }
141
142
143 doargf(ac, av, fi) /* take argument list from file */
144 char **av;
145 int ac, fi;
146 {
147 char *newav[256], **avp;
148 char argbuf[2048];
149 char newid[128];
150 char *oldid;
151 register char *cp;
152 FILE *argfp;
153 int n, i, k, newac, err;
154
155 if (fi >= ac-1 || av[fi+1][0] == '-') {
156 fprintf(stderr, "%s: missing file for -f option\n", av[0]);
157 exit(1);
158 }
159 if ((argfp = fopen(av[fi+1], "r")) == NULL) {
160 fprintf(stderr, "%s: cannot open argument file \"%s\"\n",
161 av[0], av[fi+1]);
162 exit(1);
163 }
164 n = 0; /* count number of lines in file */
165 while (fgets(argbuf, sizeof(argbuf), argfp) != NULL)
166 n++;
167 if (!n) {
168 fprintf(stderr, "%s: empty argument file \"%s\"\n",
169 av[0], av[fi+1]);
170 exit(1);
171 }
172 rewind(argfp);
173 nrept *= n;
174 err = 0; /* read each arg list and call main */
175 for (k = 0; k < n; k++) {
176 fgets(argbuf, sizeof(argbuf), argfp);
177 avp = newav+2;
178 avp[0] = av[0];
179 for (i = 1; i < fi; i++)
180 avp[i] = av[i];
181 newac = i;
182 cp = argbuf; /* parse new words */
183 for ( ; ; ) {
184 while (isspace(*cp)) /* nullify spaces */
185 *cp++ = '\0';
186 if (!*cp) /* all done? */
187 break;
188 avp[newac++] = cp; /* add argument to list */
189 while (*++cp && !isspace(*cp))
190 ;
191 }
192 for (i = fi+2; i < ac; i++)
193 avp[newac++] = av[i];
194 avp[newac] = NULL;
195 oldid = NULL;
196 for (i = 2; i < newac; i++)
197 if (!strcmp(avp[i-1], "-n")) {
198 oldid = avp[i];
199 avp[i] = newid;
200 break;
201 }
202 if (oldid == NULL) {
203 newav[0] = av[0];
204 newav[1] = "-n";
205 newav[2] = newid;
206 avp = newav;
207 newac += 2;
208 }
209 if (oldid == NULL)
210 sprintf(newid, "i%d", k);
211 else
212 sprintf(newid, "%s.%d", oldid, k);
213 err |= main(newac, avp);
214 }
215 fclose(argfp);
216 return(err);
217 }
218
219
220 doarray(ac, av, ai) /* make array */
221 char **av;
222 int ac, ai;
223 {
224 char *newav[256], **avp;
225 char newid[128], repts[32];
226 char *oldid = NULL;
227 int n, i, err;
228
229 if (ai >= ac-1 || (n = atoi(av[ai+1])) <= 0) {
230 fprintf(stderr, "%s: missing count for -a option\n", av[0]);
231 exit(1);
232 }
233 nrept *= n;
234 avp = newav+2;
235 avp[0] = av[0];
236 for (i = 1; i < ac; i++)
237 if (!strcmp(av[i-1], "-n")) {
238 oldid = av[i];
239 avp[i] = newid;
240 } else
241 avp[i] = av[i];
242 avp[ai] = "-i";
243 avp[ai+1] = repts;
244 avp[i] = NULL;
245 if (oldid == NULL) {
246 newav[0] = av[0];
247 newav[1] = "-n";
248 newav[2] = newid;
249 avp = newav;
250 ac += 2;
251 }
252 err = 0;
253 for (i = 0; i < n; i++) {
254 if (oldid == NULL)
255 sprintf(newid, "a%d", i);
256 else
257 sprintf(newid, "%s.%d", oldid, i);
258 sprintf(repts, "%d", i);
259 err |= main(ac, avp);
260 }
261 return(err);
262 }
263
264
265 xform(name, fin) /* transform stream by tot.xfm */
266 char *name;
267 register FILE *fin;
268 {
269 int nobjs = 0;
270 register int c;
271
272 while ((c = getc(fin)) != EOF) {
273 if (isspace(c)) /* blank */
274 continue;
275 if (c == '#') { /* comment */
276 putchar(c);
277 do {
278 if ((c = getc(fin)) == EOF)
279 return;
280 putchar(c);
281 } while (c != '\n');
282 } else if (c == '!') { /* command */
283 ungetc(c, fin);
284 xfcomm(name, fin);
285 nobjs++;
286 } else { /* object */
287 ungetc(c, fin);
288 xfobject(name, fin);
289 nobjs++;
290 }
291 }
292 if (nobjs == 0)
293 fprintf(stderr, "%s: (%s): warning - empty file\n",
294 progname, name);
295 }
296
297
298 xfcomm(fname, fin) /* transform a command */
299 char *fname;
300 FILE *fin;
301 {
302 extern FILE *popen();
303 extern char *fgetline();
304 FILE *pin;
305 char buf[512];
306 int i;
307
308 fgetline(buf, sizeof(buf), fin);
309 if (expand) {
310 if ((pin = popen(buf+1, "r")) == NULL) {
311 fprintf(stderr, "%s: (%s): cannot execute \"%s\"\n",
312 progname, fname, buf);
313 exit(1);
314 }
315 xform(buf, pin);
316 pclose(pin);
317 } else {
318 printf("\n%s", buf);
319 if (xac > 1) {
320 printf(" | %s", xav[0]);
321 for (i = 1; i < xac; i++)
322 printf(" %s", xav[i]);
323 }
324 putchar('\n');
325 }
326 }
327
328
329 xfobject(fname, fin) /* transform an object */
330 char *fname;
331 FILE *fin;
332 {
333 extern char *strcpy();
334 char typ[16], nam[MAXSTR];
335 int fn;
336 /* modifier and type */
337 strcpy(typ, "EOF");
338 fgetword(nam, sizeof(nam), fin);
339 fgetword(typ, sizeof(typ), fin);
340 if ((fn = otype(typ)) < 0) {
341 fprintf(stderr, "%s: (%s): unknown object type \"%s\"\n",
342 progname, fname, typ);
343 exit(1);
344 }
345 if (ismodifier(fn))
346 printf("\n%s %s ", nam, typ);
347 else
348 printf("\n%s %s ", newmod != NULL ? newmod : nam,
349 invert ? ofun[tinvers[fn]].funame : typ);
350 /* object name */
351 fgetword(nam, sizeof(nam), fin);
352 if (idprefix == NULL || ismodifier(fn))
353 printf("%s\n", nam);
354 else
355 printf("%s.%s\n", idprefix, nam);
356 /* transform arguments */
357 if ((*ofun[fn].funp)(fin) < 0) {
358 fprintf(stderr, "%s: (%s): bad %s \"%s\"\n",
359 progname, fname, ofun[fn].funame, nam);
360 exit(1);
361 }
362 }
363
364
365 o_default(fin) /* pass on arguments unchanged */
366 FILE *fin;
367 {
368 register int i;
369 FUNARGS fa;
370
371 if (readfargs(&fa, fin) != 1)
372 return(-1);
373 /* string arguments */
374 printf("%d", fa.nsargs);
375 for (i = 0; i < fa.nsargs; i++)
376 printf(" %s", fa.sarg[i]);
377 printf("\n");
378 #ifdef IARGS
379 /* integer arguments */
380 printf("%d", fa.niargs);
381 for (i = 0; i < fa.niargs; i++)
382 printf(" %d", fa.iarg[i]);
383 printf("\n");
384 #else
385 printf("0\n");
386 #endif
387 /* float arguments */
388 printf("%d", fa.nfargs);
389 for (i = 0; i < fa.nfargs; i++)
390 printf(" %18.12g", fa.farg[i]);
391 printf("\n");
392 freefargs(&fa);
393 return(0);
394 }
395
396
397 addxform(fin) /* add xf arguments to strings */
398 FILE *fin;
399 {
400 register int i;
401 int resetarr = 0;
402 FUNARGS fa;
403
404 if (readfargs(&fa, fin) != 1)
405 return(-1);
406 /* string arguments */
407 if (xac > xfa && strcmp(xav[xfa], "-i"))
408 resetarr = 2;
409 printf("%d", fa.nsargs + resetarr + xac-xfa);
410 for (i = 0; i < fa.nsargs; i++)
411 printf(" %s", fa.sarg[i]);
412 if (resetarr)
413 printf(" -i 1");
414 for (i = xfa; i < xac; i++) /* add xf arguments */
415 printf(" %s", xav[i]);
416 printf("\n");
417 #ifdef IARGS
418 /* integer arguments */
419 printf("%d", fa.niargs);
420 for (i = 0; i < fa.niargs; i++)
421 printf(" %d", fa.iarg[i]);
422 printf("\n");
423 #else
424 printf("0\n");
425 #endif
426 /* float arguments */
427 printf("%d", fa.nfargs);
428 for (i = 0; i < fa.nfargs; i++)
429 printf(" %18.12g", fa.farg[i]);
430 printf("\n");
431 freefargs(&fa);
432 return(0);
433 }
434
435
436 int
437 otype(ofname) /* get object function number from its name */
438 register char *ofname;
439 {
440 register int i;
441
442 for (i = 0; i < NUMTYPES; i++)
443 if (!strcmp(ofun[i].funame, ofname))
444 return(i);
445
446 return(-1); /* not found */
447 }
448
449
450 alias(fin) /* transfer alias */
451 FILE *fin;
452 {
453 char aliasnm[MAXSTR];
454
455 if (fgetword(aliasnm, MAXSTR, fin) == NULL)
456 return(-1);
457 printf("\t%s\n", aliasnm);
458 return(0);
459 }
460
461
462 m_glow(fin) /* transform arguments for proximity light */
463 FILE *fin;
464 {
465 FUNARGS fa;
466
467 if (readfargs(&fa, fin) != 1)
468 return(-1);
469 if (fa.nsargs != 0 || fa.nfargs != 4)
470 return(-1);
471 printf("0\n0\n4");
472 printf(" %18.12g %18.12g %18.12g",
473 fa.farg[0], fa.farg[1], fa.farg[2]);
474 printf(" %18.12g\n", fa.farg[3] * tot.sca);
475 freefargs(&fa);
476 return(0);
477 }
478
479
480 m_spot(fin) /* transform arguments for spotlight */
481 FILE *fin;
482 {
483 FVECT v;
484 FUNARGS fa;
485
486 if (readfargs(&fa, fin) != 1)
487 return(-1);
488 if (fa.nsargs != 0 || fa.nfargs != 7)
489 return(-1);
490 printf("0\n0\n7");
491 printf(" %18.12g %18.12g %18.12g %18.12g\n",
492 fa.farg[0], fa.farg[1], fa.farg[2], fa.farg[3]);
493 multv3(v, fa.farg+4, tot.xfm);
494 printf("\t%18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
495 freefargs(&fa);
496 return(0);
497 }
498
499
500 m_mist(fin) /* transform arguments for mist */
501 FILE *fin;
502 {
503 FUNARGS fa;
504 int i;
505
506 if (readfargs(&fa, fin) != 1)
507 return(-1);
508 if (fa.nfargs > 7)
509 return(-1);
510 printf("%d", fa.nsargs);
511 if (idprefix == NULL)
512 for (i = 0; i < fa.nsargs; i++)
513 printf(" %s", fa.sarg[i]);
514 else
515 for (i = 0; i < fa.nsargs; i++) {
516 char sname[256], *sp;
517 register char *cp1, *cp2 = sname;
518 /* add idprefix */
519 for (sp = fa.sarg[i]; *sp; sp = cp1) {
520 for (cp1 = idprefix; *cp1; )
521 *cp2++ = *cp1++;
522 *cp2++ = '.';
523 for (cp1 = sp; *cp1 &&
524 (*cp2++ = *cp1++) != '>'; )
525 ;
526 }
527 *cp2 = '\0';
528 printf(" %s", sname);
529 }
530 printf("\n0\n%d", fa.nfargs);
531 if (fa.nfargs > 2)
532 printf(" %12.6g %12.6g %12.6g", fa.farg[0]/tot.sca,
533 fa.farg[1]/tot.sca, fa.farg[2]/tot.sca);
534 for (i = 3; i < fa.nfargs; i++)
535 printf(" %12.6g", fa.farg[i]);
536 printf("\n");
537 freefargs(&fa);
538 return(0);
539 }
540
541
542 m_dielectric(fin) /* transform arguments for dielectric */
543 FILE *fin;
544 {
545 FUNARGS fa;
546
547 if (readfargs(&fa, fin) != 1)
548 return(-1);
549 if (fa.nsargs != 0 || fa.nfargs != 5)
550 return(-1);
551 printf("0\n0\n5");
552 printf(" %12.6g %12.6g %12.6g",
553 pow(fa.farg[0], 1.0/tot.sca),
554 pow(fa.farg[1], 1.0/tot.sca),
555 pow(fa.farg[2], 1.0/tot.sca));
556 printf(" %12.6g %12.6g\n", fa.farg[3], fa.farg[4]);
557 freefargs(&fa);
558 return(0);
559 }
560
561
562 m_interface(fin) /* transform arguments for interface */
563 FILE *fin;
564 {
565 FUNARGS fa;
566
567 if (readfargs(&fa, fin) != 1)
568 return(-1);
569 if (fa.nsargs != 0 || fa.nfargs != 8)
570 return(-1);
571 printf("0\n0\n8\n");
572 printf("%12.6g %12.6g %12.6g",
573 pow(fa.farg[0], 1.0/tot.sca),
574 pow(fa.farg[1], 1.0/tot.sca),
575 pow(fa.farg[2], 1.0/tot.sca));
576 printf(" %12.6g\n", fa.farg[3]);
577 printf("%12.6g %12.6g %12.6g",
578 pow(fa.farg[4], 1.0/tot.sca),
579 pow(fa.farg[5], 1.0/tot.sca),
580 pow(fa.farg[6], 1.0/tot.sca));
581 printf(" %12.6g\n", fa.farg[7]);
582 freefargs(&fa);
583 return(0);
584 }
585
586
587 text(fin) /* transform text arguments */
588 FILE *fin;
589 {
590 int i;
591 FVECT v;
592 FUNARGS fa;
593
594 if (readfargs(&fa, fin) != 1)
595 return(-1);
596 if (fa.nfargs < 9)
597 return(-1);
598 /* string arguments */
599 printf("%d", fa.nsargs);
600 for (i = 0; i < fa.nsargs; i++)
601 printf(" %s", fa.sarg[i]);
602 printf("\n0\n%d\n", fa.nfargs);
603 /* anchor point */
604 multp3(v, fa.farg, tot.xfm);
605 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
606 /* right vector */
607 multv3(v, fa.farg+3, tot.xfm);
608 printf(" %18.12g %18.12g %18.12g\n", v[0], v[1], v[2]);
609 /* down vector */
610 multv3(v, fa.farg+6, tot.xfm);
611 printf(" %18.12g %18.12g %18.12g", v[0], v[1], v[2]);
612 /* remaining arguments */
613 for (i = 9; i < fa.nfargs; i++) {
614 if (i%3 == 0)
615 putchar('\n');
616 printf(" %18.12g", fa.farg[i]);
617 }
618 putchar('\n');
619 freefargs(&fa);
620 return(0);
621 }
622
623
624 o_source(fin) /* transform source arguments */
625 FILE *fin;
626 {
627 FVECT dv;
628 FUNARGS fa;
629
630 if (readfargs(&fa, fin) != 1)
631 return(-1);
632 if (fa.nsargs != 0 || fa.nfargs != 4)
633 return(-1);
634 /* transform direction vector */
635 multv3(dv, fa.farg, tot.xfm);
636 /* output */
637 printf("0\n0\n4");
638 printf(" %18.12g %18.12g %18.12g %18.12g\n",
639 dv[0], dv[1], dv[2], fa.farg[3]);
640 freefargs(&fa);
641 return(0);
642 }
643
644
645 o_sphere(fin) /* transform sphere arguments */
646 FILE *fin;
647 {
648 FVECT cent;
649 double rad;
650 FUNARGS fa;
651
652 if (readfargs(&fa, fin) != 1)
653 return(-1);
654 if (fa.nsargs != 0 || fa.nfargs != 4)
655 return(-1);
656
657 multp3(cent, fa.farg, tot.xfm); /* transform center */
658
659 rad = fa.farg[3] * tot.sca; /* scale radius */
660
661 printf("0\n0\n4");
662 printf(" %18.12g %18.12g %18.12g %18.12g\n",
663 cent[0], cent[1], cent[2], rad);
664 freefargs(&fa);
665 return(0);
666 }
667
668
669 o_face(fin) /* transform face arguments */
670 FILE *fin;
671 {
672 FVECT p;
673 register int i;
674 FUNARGS fa;
675
676 if (readfargs(&fa, fin) != 1)
677 return(-1);
678 if (fa.nsargs != 0 || fa.nfargs % 3)
679 return(-1);
680
681 printf("0\n0\n%d\n", fa.nfargs);
682
683 for (i = 0; i < fa.nfargs; i += 3) {
684 if (reverse)
685 multp3(p, fa.farg+(fa.nfargs-i-3), tot.xfm);
686 else
687 multp3(p, fa.farg+i, tot.xfm);
688 printf(" %18.12g %18.12g %18.12g\n", p[0], p[1], p[2]);
689 }
690 freefargs(&fa);
691 return(0);
692 }
693
694
695 o_cone(fin) /* transform cone and cup arguments */
696 FILE *fin;
697 {
698 FVECT p0, p1;
699 double r0, r1;
700 FUNARGS fa;
701
702 if (readfargs(&fa, fin) != 1)
703 return(-1);
704 if (fa.nsargs != 0 || fa.nfargs != 8)
705 return(-1);
706
707 printf("0\n0\n8\n");
708
709 multp3(p0, fa.farg, tot.xfm);
710 multp3(p1, fa.farg+3, tot.xfm);
711 r0 = fa.farg[6] * tot.sca;
712 r1 = fa.farg[7] * tot.sca;
713 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
714 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
715 printf(" %18.12g %18.12g\n", r0, r1);
716
717 freefargs(&fa);
718 return(0);
719 }
720
721
722 o_cylinder(fin) /* transform cylinder and tube arguments */
723 FILE *fin;
724 {
725 FVECT p0, p1;
726 double rad;
727 FUNARGS fa;
728
729 if (readfargs(&fa, fin) != 1)
730 return(-1);
731 if (fa.nsargs != 0 || fa.nfargs != 7)
732 return(-1);
733
734 printf("0\n0\n7\n");
735
736 multp3(p0, fa.farg, tot.xfm);
737 multp3(p1, fa.farg+3, tot.xfm);
738 rad = fa.farg[6] * tot.sca;
739 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
740 printf(" %18.12g %18.12g %18.12g\n", p1[0], p1[1], p1[2]);
741 printf(" %18.12g\n", rad);
742 freefargs(&fa);
743 return(0);
744 }
745
746
747 o_ring(fin) /* transform ring arguments */
748 FILE *fin;
749 {
750 FVECT p0, pd;
751 double r0, r1;
752 FUNARGS fa;
753
754 if (readfargs(&fa, fin) != 1)
755 return(-1);
756 if (fa.nsargs != 0 || fa.nfargs != 8)
757 return(-1);
758
759 printf("0\n0\n8\n");
760
761 multp3(p0, fa.farg, tot.xfm);
762 multv3(pd, fa.farg+3, tot.xfm);
763 if (invert) {
764 pd[0] = -pd[0];
765 pd[1] = -pd[1];
766 pd[2] = -pd[2];
767 }
768 r0 = fa.farg[6] * tot.sca;
769 r1 = fa.farg[7] * tot.sca;
770 printf(" %18.12g %18.12g %18.12g\n", p0[0], p0[1], p0[2]);
771 printf(" %18.12g %18.12g %18.12g\n", pd[0], pd[1], pd[2]);
772 printf(" %18.12g %18.12g\n", r0, r1);
773 freefargs(&fa);
774 return(0);
775 }
776
777
778 initotypes() /* initialize ofun[] array */
779 {
780 register int i;
781
782 if (ofun[OBJ_SOURCE].funp == o_source)
783 return; /* done already */
784 /* alias is additional */
785 ofun[ALIAS].funame = ALIASID;
786 ofun[ALIAS].flags = 0;
787 /* functions get new transform */
788 for (i = 0; i < NUMTYPES; i++)
789 if (hasfunc(i))
790 ofun[i].funp = addxform;
791 /* special cases */
792 ofun[OBJ_SOURCE].funp = o_source;
793 ofun[OBJ_SPHERE].funp =
794 ofun[OBJ_BUBBLE].funp = o_sphere;
795 ofun[OBJ_FACE].funp = o_face;
796 ofun[OBJ_CONE].funp =
797 ofun[OBJ_CUP].funp = o_cone;
798 ofun[OBJ_CYLINDER].funp =
799 ofun[OBJ_TUBE].funp = o_cylinder;
800 ofun[OBJ_RING].funp = o_ring;
801 ofun[OBJ_INSTANCE].funp = addxform;
802 ofun[MAT_GLOW].funp = m_glow;
803 ofun[MAT_SPOT].funp = m_spot;
804 ofun[MAT_DIELECTRIC].funp = m_dielectric;
805 ofun[MAT_INTERFACE].funp = m_interface;
806 ofun[MAT_MIST].funp = m_mist;
807 ofun[PAT_CTEXT].funp =
808 ofun[PAT_BTEXT].funp =
809 ofun[MIX_TEXT].funp = text;
810 ofun[ALIAS].funp = alias;
811 /* surface inverses */
812 tinvers[OBJ_FACE] = OBJ_FACE;
813 tinvers[OBJ_SOURCE] = OBJ_SOURCE;
814 tinvers[OBJ_CONE] = OBJ_CUP;
815 tinvers[OBJ_CUP] = OBJ_CONE;
816 tinvers[OBJ_SPHERE] = OBJ_BUBBLE;
817 tinvers[OBJ_BUBBLE] = OBJ_SPHERE;
818 tinvers[OBJ_RING] = OBJ_RING;
819 tinvers[OBJ_CYLINDER] = OBJ_TUBE;
820 tinvers[OBJ_TUBE] = OBJ_CYLINDER;
821 tinvers[OBJ_INSTANCE] = OBJ_INSTANCE; /* oh, well */
822 }
823
824
825 #ifdef OLDXFORM
826 openmain(fname)
827 char *fname;
828 {
829 if (fname == NULL) {
830 strcpy(mainfn, "standard input");
831 mainfp = stdin;
832 return;
833 }
834 if (mainfp != NULL) {
835 if (!strcmp(fname, mainfn)) {
836 rewind(mainfp);
837 return;
838 }
839 fclose(mainfp);
840 }
841 if ((mainfp = fopen(fname, "r")) == NULL) {
842 fprintf(stderr, "%s: cannot open file \"%s\"\n",
843 progname, fname);
844 exit(1);
845 }
846 strcpy(mainfn, fname);
847 }
848 #else
849 openmain(fname) /* open fname for input, changing to its directory */
850 char *fname;
851 {
852 extern FILE *tmpfile();
853 extern char *getlibpath(), *getpath();
854 static char origdir[MAXPATH];
855 static char curfn[MAXPATH];
856 static int diffdir;
857 register char *fpath;
858
859 if (fname == NULL) { /* standard input */
860 if (mainfp == NULL) {
861 register int c;
862 strcpy(mainfn, "standard input");
863 if (nrept <= 1) {
864 mainfp = stdin;
865 return; /* just read once */
866 }
867 /* else copy */
868 if ((mainfp = tmpfile()) == NULL) {
869 fprintf(stderr,
870 "%s: cannot create temporary file\n",
871 progname);
872 exit(1);
873 }
874 while ((c = getc(stdin)) != EOF)
875 putc(c, mainfp);
876 fclose(stdin);
877 }
878 rewind(mainfp); /* rewind copy */
879 return;
880 }
881 if (mainfp == NULL) { /* first call, initialize */
882 getwd(origdir);
883 } else if (!strcmp(fname, curfn)) { /* just need to rewind? */
884 rewind(mainfp);
885 return;
886 } else { /* else close old stream */
887 fclose(mainfp);
888 if (diffdir) {
889 chdir(origdir);
890 diffdir = 0;
891 }
892 }
893 strcpy(curfn, fname); /* remember file name */
894 /* get full path */
895 if ((fpath = getpath(fname, getlibpath(), R_OK)) == NULL) {
896 fprintf(stderr, "%s: cannot find file \"%s\"\n",
897 progname, fname);
898 exit(1);
899 }
900 if (fpath[0] == '.' && ISDIRSEP(fpath[1])) /* remove leading ./ */
901 fpath += 2;
902 /* record path name */
903 strcpy(mainfn, fpath);
904 if (expand) { /* change to local directory */
905 register char *cp = fpath + strlen(fpath); /* get dir. */
906 while (cp > fpath) {
907 cp--;
908 if (ISDIRSEP(*cp)) {
909 if (cp == fpath)
910 cp++; /* root special case */
911 break;
912 }
913 }
914 *cp = '\0';
915 if (fpath[0]) { /* change to new directory? */
916 if (chdir(fpath) < 0) {
917 fprintf(stderr,
918 "%s: cannot change directory to \"%s\"\n",
919 progname, fpath);
920 exit(1);
921 }
922 diffdir++;
923 }
924 /* get final path component */
925 for (fpath = fname+strlen(fname);
926 fpath > fname && !ISDIRSEP(fpath[-1]); fpath--)
927 ;
928 }
929 /* open the file */
930 if ((mainfp = fopen(fpath, "r")) == NULL) {
931 fprintf(stderr, "%s: cannot open file \"%s\"\n",
932 progname, mainfn);
933 exit(1);
934 }
935 }
936 #endif
