root/radiance/src/gen/sun.c
Fri Aug 9 16:51:15 2013 UTC (12 years, 2 months ago) by greg
Added header file for solar position calculations
Sat Jun 6 20:18:32 2009 UTC (16 years, 4 months ago) by greg
CVS Tags: rad4R0, rad4R1
Changes since 2.4: +6 -2 lines
Sun Nov 16 10:29:38 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.3: +19 -11 lines
Sat Feb 22 02:07:24 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.2: +1 -4 lines
Fri Oct 2 16:12:29 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.1: +2 -8 lines
Diff to previous 2.1
Tue Nov 12 17:04:42 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.2
Sun Sep 10 16:45:19 1989 UTC (36 years, 1 month ago) by greg
Diff to previous 1.1
fixed location of SCCSid
Thu Feb 2 11:16:32 1989 UTC (36 years, 9 months ago) by greg
