| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: replmarks.c,v 2.19 2025/04/22 04:45:25 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* Replace markers in Radiance scene description with objects or instances. |
| 6 |
| 7 |
* Created: 17 Feb 1991 Greg Ward |
| 8 |
| 9 |
| 10 |
#include <stdlib.h> |
| 11 |
#include <ctype.h> |
| 12 |
#include <math.h> |
| 13 |
#include <stdio.h> |
| 14 |
| 15 |
#include "platform.h" |
| 16 |
#include "rtio.h" |
| 17 |
#include "paths.h" |
| 18 |
#include "fvect.h" |
| 19 |
| 20 |
#ifdef M_PI |
| 21 |
#define PI ((double)M_PI) |
| 22 |
#else |
| 23 |
#define PI 3.14159265358979323846 |
| 24 |
#endif |
| 25 |
| 26 |
#define MAXVERT 6 /* maximum number of vertices for markers */ |
| 27 |
#define MAXMARK 128 /* maximum number of markers */ |
| 28 |
| 29 |
#define USE_XFORM 1 /* use !xform inline command */ |
| 30 |
#define USE_INSTANCE 2 /* use instance primitive */ |
| 31 |
#define USE_MESH 3 /* use mesh primitive */ |
| 32 |
| 33 |
typedef struct { |
| 34 |
short beg, end; /* beginning and ending vertex */ |
| 35 |
float len2; /* length squared */ |
| 36 |
} EDGE; /* a marker edge */ |
| 37 |
| 38 |
struct mrkr { |
| 39 |
char *modout; /* output modifier */ |
| 40 |
double mscale; /* scale by this to get unit */ |
| 41 |
char *modin; /* input modifier indicating marker */ |
| 42 |
char *objname; /* output object file or octree */ |
| 43 |
int usetype; /* one of USE_* above */ |
| 44 |
} marker[MAXMARK+1]; /* array of markers */ |
| 45 |
int nmarkers = 0; /* number of markers */ |
| 46 |
| 47 |
int expand; /* expand commands? */ |
| 48 |
| 49 |
char *progname; |
| 50 |
| 51 |
static void convert(char *name, FILE *fin); |
| 52 |
static void cvcomm(char *fname, FILE *fin); |
| 53 |
static void cvobject(char *fname, FILE *fin); |
| 54 |
static void replace(char *fname, struct mrkr *m, char *mark, FILE *fin); |
| 55 |
static int edgecmp(const void *e1, const void *e2); |
| 56 |
static int buildxf(char *xf, double markscale, FILE *fin); |
| 57 |
static int addrot(char *xf, FVECT xp, FVECT yp, FVECT zp); |
| 58 |
| 59 |
| 60 |
int |
| 61 |
main( |
| 62 |
int argc, |
| 63 |
char *argv[] |
| 64 |
| 65 |
| 66 |
FILE *fp; |
| 67 |
int i, j; |
| 68 |
| 69 |
progname = argv[0]; |
| 70 |
i = 1; |
| 71 |
while (i < argc && argv[i][0] == '-') { |
| 72 |
do { |
| 73 |
switch (argv[i][1]) { |
| 74 |
case 'i': |
| 75 |
marker[nmarkers].usetype = USE_INSTANCE; |
| 76 |
marker[nmarkers].objname = argv[++i]; |
| 77 |
break; |
| 78 |
case 'I': |
| 79 |
marker[nmarkers].usetype = USE_MESH; |
| 80 |
| 81 |
break; |
| 82 |
case 'x': |
| 83 |
marker[nmarkers].usetype = USE_XFORM; |
| 84 |
| 85 |
break; |
| 86 |
case 'e': |
| 87 |
expand = 1; |
| 88 |
break; |
| 89 |
case 'm': |
| 90 |
marker[nmarkers].modout = argv[++i]; |
| 91 |
break; |
| 92 |
case 's': |
| 93 |
marker[nmarkers].mscale = atof(argv[++i]); |
| 94 |
break; |
| 95 |
default: |
| 96 |
goto userr; |
| 97 |
| 98 |
if (++i >= argc) |
| 99 |
goto userr; |
| 100 |
} while (argv[i][0] == '-'); |
| 101 |
if (marker[nmarkers].objname == NULL) |
| 102 |
goto userr; |
| 103 |
if (nmarkers >= MAXMARK) { |
| 104 |
fprintf(stderr, "%s: too many markers\n", progname); |
| 105 |
return 1; |
| 106 |
| 107 |
marker[nmarkers++].modin = argv[i++]; |
| 108 |
marker[nmarkers].mscale = marker[nmarkers-1].mscale; |
| 109 |
| 110 |
if (nmarkers == 0) |
| 111 |
goto userr; |
| 112 |
/* simple header */ |
| 113 |
putchar('#'); |
| 114 |
for (j = 0; j < i; j++) { |
| 115 |
putchar(' '); |
| 116 |
fputs(argv[j], stdout); |
| 117 |
| 118 |
putchar('\n'); |
| 119 |
if (i == argc) |
| 120 |
convert("<stdin>", stdin); |
| 121 |
else |
| 122 |
for ( ; i < argc; i++) { |
| 123 |
if ((fp = fopen(argv[i], "r")) == NULL) { |
| 124 |
perror(argv[i]); |
| 125 |
exit(1); |
| 126 |
| 127 |
convert(argv[i], fp); |
| 128 |
fclose(fp); |
| 129 |
| 130 |
return 0; |
| 131 |
userr: |
| 132 |
fprintf(stderr, |
| 133 |
"Usage: %s [-e][-s size][-m modout] {-x objfile|-i octree|-I mesh} modname .. [file ..]\n", |
| 134 |
progname); |
| 135 |
return 1; |
| 136 |
| 137 |
| 138 |
| 139 |
void |
| 140 |
convert( /* replace marks in a stream */ |
| 141 |
char *name, |
| 142 |
register FILE *fin |
| 143 |
| 144 |
| 145 |
register int c; |
| 146 |
| 147 |
while ((c = getc(fin)) != EOF) { |
| 148 |
if (isspace(c)) /* blank */ |
| 149 |
continue; |
| 150 |
if (c == '#') { /* comment */ |
| 151 |
putchar(c); |
| 152 |
do { |
| 153 |
if ((c = getc(fin)) == EOF) |
| 154 |
return; |
| 155 |
putchar(c); |
| 156 |
} while (c != '\n'); |
| 157 |
} else if (c == '!') { /* command */ |
| 158 |
ungetc(c, fin); |
| 159 |
cvcomm(name, fin); |
| 160 |
} else { /* object */ |
| 161 |
ungetc(c, fin); |
| 162 |
cvobject(name, fin); |
| 163 |
| 164 |
| 165 |
| 166 |
| 167 |
| 168 |
void |
| 169 |
cvcomm( /* convert a command */ |
| 170 |
char *fname, |
| 171 |
FILE *fin |
| 172 |
| 173 |
| 174 |
FILE *pin; |
| 175 |
char buf[512], *fgetline(); |
| 176 |
| 177 |
fgetline(buf, sizeof(buf), fin); |
| 178 |
if (expand) { |
| 179 |
if ((pin = popen(buf+1, "r")) == NULL) { |
| 180 |
fprintf(stderr, |
| 181 |
"%s: (%s): cannot execute \"%s\"\n", |
| 182 |
progname, fname, buf); |
| 183 |
exit(1); |
| 184 |
| 185 |
convert(buf, pin); |
| 186 |
if (pclose(pin) != 0) |
| 187 |
fprintf(stderr, |
| 188 |
"%s: (%s): warning - bad status from \"%s\"\n", |
| 189 |
| 190 |
} else |
| 191 |
printf("\n%s\n", buf); |
| 192 |
| 193 |
| 194 |
| 195 |
void |
| 196 |
cvobject( /* convert an object */ |
| 197 |
char *fname, |
| 198 |
FILE *fin |
| 199 |
| 200 |
| 201 |
extern char *fgetword(); |
| 202 |
char buf[128], typ[16], nam[128]; |
| 203 |
int i, n; |
| 204 |
register int j; |
| 205 |
| 206 |
if (fgetword(buf, sizeof(buf), fin) == NULL || |
| 207 |
fgetword(typ, sizeof(typ), fin) == NULL || |
| 208 |
fgetword(nam, sizeof(nam), fin) == NULL) |
| 209 |
goto readerr; |
| 210 |
if (!strcmp(typ, "polygon")) |
| 211 |
for (j = 0; j < nmarkers; j++) |
| 212 |
if (!strcmp(buf, marker[j].modin)) { |
| 213 |
replace(fname, &marker[j], nam, fin); |
| 214 |
return; |
| 215 |
| 216 |
putchar('\n'); fputword(buf, stdout); |
| 217 |
printf(" %s ", typ); |
| 218 |
fputword(nam, stdout); putchar('\n'); |
| 219 |
if (!strcmp(typ, "alias")) { /* alias special case */ |
| 220 |
if (fgetword(buf, sizeof(buf), fin) == NULL) |
| 221 |
goto readerr; |
| 222 |
putchar('\t'); fputword(buf, stdout); putchar('\n'); |
| 223 |
return; |
| 224 |
| 225 |
for (i = 0; i < 3; i++) { /* pass along arguments */ |
| 226 |
if (fscanf(fin, "%d", &n) != 1) |
| 227 |
goto readerr; |
| 228 |
printf("%d", n); |
| 229 |
for (j = 0; j < n; j++) { |
| 230 |
| 231 |
goto readerr; |
| 232 |
if (j%3 == 0) |
| 233 |
putchar('\n'); |
| 234 |
putchar('\t'); |
| 235 |
| 236 |
| 237 |
putchar('\n'); |
| 238 |
| 239 |
return; |
| 240 |
readerr: |
| 241 |
fprintf(stderr, "%s: (%s): read error for %s \"%s\"\n", |
| 242 |
progname, fname, typ, nam); |
| 243 |
| 244 |
| 245 |
| 246 |
void |
| 247 |
replace( /* replace marker */ |
| 248 |
char *fname, |
| 249 |
register struct mrkr *m, |
| 250 |
char *mark, |
| 251 |
FILE *fin |
| 252 |
| 253 |
| 254 |
int n; |
| 255 |
char buf[256]; |
| 256 |
| 257 |
buf[0] = '\0'; /* bug fix thanks to schorsch */ |
| 258 |
if (m->usetype == USE_XFORM) { |
| 259 |
sprintf(buf, "xform -n %s", mark); |
| 260 |
if (m->modout != NULL) |
| 261 |
sprintf(buf+strlen(buf), " -m %s", m->modout); |
| 262 |
if (buildxf(buf+strlen(buf), m->mscale, fin) < 0) |
| 263 |
goto badxf; |
| 264 |
sprintf(buf+strlen(buf), " %s", m->objname); |
| 265 |
if (expand) { |
| 266 |
fflush(stdout); |
| 267 |
system(buf); |
| 268 |
} else |
| 269 |
printf("\n!%s\n", buf); |
| 270 |
} else { |
| 271 |
if ((n = buildxf(buf, m->mscale, fin)) < 0) |
| 272 |
goto badxf; |
| 273 |
printf("\n%s %s %s\n", |
| 274 |
m->modout==NULL?"void":m->modout, |
| 275 |
m->usetype==USE_INSTANCE?"instance":"mesh", |
| 276 |
mark); |
| 277 |
printf("%d %s%s\n0\n0\n", n+1, m->objname, buf); |
| 278 |
| 279 |
return; |
| 280 |
badxf: |
| 281 |
fprintf(stderr, "%s: (%s): bad arguments for marker \"%s\"\n", |
| 282 |
progname, fname, mark); |
| 283 |
exit(1); |
| 284 |
| 285 |
| 286 |
| 287 |
int |
| 288 |
edgecmp( /* compare two edges, descending order */ |
| 289 |
const void *e1, |
| 290 |
const void *e2 |
| 291 |
| 292 |
| 293 |
if (((EDGE*)e1)->len2 > ((EDGE*)e2)->len2) |
| 294 |
return(-1); |
| 295 |
if (((EDGE*)e1)->len2 < ((EDGE*)e2)->len2) |
| 296 |
return(1); |
| 297 |
return(0); |
| 298 |
| 299 |
| 300 |
| 301 |
int |
| 302 |
buildxf( /* build transform for marker */ |
| 303 |
register char *xf, |
| 304 |
double markscale, |
| 305 |
FILE *fin |
| 306 |
| 307 |
| 308 |
static FVECT vlist[MAXVERT]; |
| 309 |
static EDGE elist[MAXVERT]; |
| 310 |
FVECT xvec, yvec, zvec; |
| 311 |
double xlen; |
| 312 |
int n; |
| 313 |
register int i; |
| 314 |
| 315 |
* Read and sort vectors: longest is hypotenuse, |
| 316 |
* second longest is x' axis, |
| 317 |
* third longest is y' axis (approximate), |
| 318 |
* other vectors are ignored. |
| 319 |
* It is an error if the x' and y' axes do |
| 320 |
* not share a common vertex (their origin). |
| 321 |
| 322 |
if (fscanf(fin, "%*d %*d %d", &n) != 1) |
| 323 |
return(-1); |
| 324 |
if (n%3 != 0) |
| 325 |
return(-1); |
| 326 |
n /= 3; |
| 327 |
if (n < 3 || n > MAXVERT) |
| 328 |
return(-1); |
| 329 |
/* sort edges in descending order */ |
| 330 |
for (i = 0; i < n; i++) { |
| 331 |
if (fscanf(fin, "%lf %lf %lf", &vlist[i][0], |
| 332 |
&vlist[i][1], &vlist[i][2]) != 3) |
| 333 |
return(-1); |
| 334 |
if (i) { |
| 335 |
elist[i].beg = i-1; |
| 336 |
elist[i].end = i; |
| 337 |
elist[i].len2 = dist2(vlist[i-1],vlist[i]); |
| 338 |
| 339 |
| 340 |
elist[0].beg = n-1; |
| 341 |
elist[0].end = 0; |
| 342 |
elist[0].len2 = dist2(vlist[n-1],vlist[0]); |
| 343 |
qsort(elist, n, sizeof(EDGE), edgecmp); |
| 344 |
/* find x' and y' */ |
| 345 |
if (elist[1].end == elist[2].beg || elist[1].end == elist[2].end) { |
| 346 |
i = elist[1].beg; |
| 347 |
elist[1].beg = elist[1].end; |
| 348 |
elist[1].end = i; |
| 349 |
| 350 |
if (elist[2].end == elist[1].beg) { |
| 351 |
i = elist[2].beg; |
| 352 |
elist[2].beg = elist[2].end; |
| 353 |
elist[2].end = i; |
| 354 |
| 355 |
if (elist[1].beg != elist[2].beg) |
| 356 |
return(-1); /* x' and y' not connected! */ |
| 357 |
for (i = 0; i < 3; i++) { |
| 358 |
xvec[i] = vlist[elist[1].end][i] - vlist[elist[1].beg][i]; |
| 359 |
yvec[i] = vlist[elist[2].end][i] - vlist[elist[2].beg][i]; |
| 360 |
| 361 |
if ((xlen = normalize(xvec)) == 0.0) |
| 362 |
return(-1); |
| 363 |
fcross(zvec, xvec, yvec); |
| 364 |
if (normalize(zvec) == 0.0) |
| 365 |
return(-1); |
| 366 |
fcross(yvec, zvec, xvec); |
| 367 |
n = 0; /* start transformation... */ |
| 368 |
if (markscale > 0.0) { /* add scale factor */ |
| 369 |
sprintf(xf, " -s %f", xlen*markscale); |
| 370 |
n += 2; |
| 371 |
while (*xf) ++xf; |
| 372 |
| 373 |
/* add rotation */ |
| 374 |
n += addrot(xf, xvec, yvec, zvec); |
| 375 |
while (*xf) ++xf; |
| 376 |
/* add translation */ |
| 377 |
n += 4; |
| 378 |
sprintf(xf, " -t %f %f %f", vlist[elist[1].beg][0], |
| 379 |
vlist[elist[1].beg][1], vlist[elist[1].beg][2]); |
| 380 |
return(n); /* all done */ |
| 381 |
| 382 |
| 383 |
| 384 |
int |
| 385 |
addrot( /* compute rotation (x,y,z) => (xp,yp,zp) */ |
| 386 |
| 387 |
FVECT xp, |
| 388 |
FVECT yp, |
| 389 |
FVECT zp |
| 390 |
| 391 |
| 392 |
int n; |
| 393 |
double theta; |
| 394 |
| 395 |
if (yp[2]*yp[2] + zp[2]*zp[2] < 2.*FTINY*FTINY) { |
| 396 |
/* Special case for X' along Z-axis */ |
| 397 |
theta = -atan2(yp[0], yp[1]); |
| 398 |
sprintf(xf, " -ry %f -rz %f", |
| 399 |
xp[2] < 0.0 ? 90.0 : -90.0, |
| 400 |
theta*(180./PI)); |
| 401 |
return(4); |
| 402 |
| 403 |
n = 0; |
| 404 |
theta = atan2(yp[2], zp[2]); |
| 405 |
if (!FABSEQ(theta,0.0)) { |
| 406 |
sprintf(xf, " -rx %f", theta*(180./PI)); |
| 407 |
while (*xf) ++xf; |
| 408 |
n += 2; |
| 409 |
| 410 |
theta = Asin(-xp[2]); |
| 411 |
| 412 |
sprintf(xf, " -ry %f", theta*(180./PI)); |
| 413 |
while (*xf) ++xf; |
| 414 |
n += 2; |
| 415 |
| 416 |
theta = atan2(xp[1], xp[0]); |
| 417 |
| 418 |
sprintf(xf, " -rz %f", theta*(180./PI)); |
| 419 |
/* while (*xf) ++xf; */ |
| 420 |
n += 2; |
| 421 |
| 422 |
return(n); |
| 423 |
