root/radiance/src/gen/mkillum2.c
Revision: 2.30
Committed: Thu May 28 18:38:52 2009 UTC (16 years, 4 months ago) by greg
Changes since 2.29: +2 -1 lines
Bug fix in source sampling
2 static const char RCSid[] = "$Id: mkillum2.c,v 2.29 2009/03/04 00:12:25 greg Exp $";
5 * Routines to do the actual calculation for mkillum
6 */
7
8 #include <string.h>
9
10 #include "mkillum.h"
11 #include "face.h"
12 #include "cone.h"
13 #include "source.h"
14
15
16 COLORV * distarr = NULL; /* distribution array */
17 int distsiz = 0;
18 COLORV * direct_discount = NULL; /* amount to take off direct */
19
20 void
21 newdist( /* allocate & clear distribution array */
22 int siz
23 )
24 {
25 if (siz <= 0) {
26 if (distsiz > 0)
27 free((void *)distarr);
28 distarr = NULL;
29 distsiz = 0;
30 return;
31 }
32 if (distsiz < siz) {
33 if (distsiz > 0)
34 free((void *)distarr);
35 distarr = (COLORV *)malloc(sizeof(COLOR)*siz);
36 if (distarr == NULL)
37 error(SYSTEM, "out of memory in newdist");
38 distsiz = siz;
39 }
40 memset(distarr, '\0', sizeof(COLOR)*siz);
41 }
42
43
44 static void
45 new_discount() /* allocate space for direct contrib. record */
46 {
47 if (distsiz <= 0)
48 return;
49 direct_discount = (COLORV *)calloc(distsiz, sizeof(COLOR));
50 if (direct_discount == NULL)
51 error(SYSTEM, "out of memory in new_discount");
52 }
53
54
55 static void
56 done_discount() /* clear off direct contrib. record */
57 {
58 if (direct_discount == NULL)
59 return;
60 free((void *)direct_discount);
61 direct_discount = NULL;
62 }
63
64
65 int
66 process_ray( /* process a ray result or report error */
67 RAY *r,
68 int rv
69 )
70 {
71 COLORV *colp;
72
73 if (rv == 0) /* no result ready */
74 return(0);
75 if (rv < 0)
76 error(USER, "ray tracing process died");
77 if (r->rno >= distsiz)
78 error(INTERNAL, "bad returned index in process_ray");
79 multcolor(r->rcol, r->rcoef); /* in case it's a source ray */
80 colp = &distarr[r->rno * 3];
81 addcolor(colp, r->rcol);
82 if (r->rsrc >= 0 && /* remember source contrib. */
83 direct_discount != NULL) {
84 colp = &direct_discount[r->rno * 3];
85 addcolor(colp, r->rcol);
86 }
87 return(1);
88 }
89
90
91 void
92 raysamp( /* queue a ray sample */
93 int ndx,
94 FVECT org,
95 FVECT dir
96 )
97 {
98 RAY myRay;
99 int rv;
100
101 if ((ndx < 0) | (ndx >= distsiz))
102 error(INTERNAL, "bad index in raysamp");
103 VCOPY(myRay.rorg, org);
104 VCOPY(myRay.rdir, dir);
105 myRay.rmax = .0;
106 rayorigin(&myRay, PRIMARY, NULL, NULL);
107 myRay.rno = ndx;
108 /* queue ray, check result */
109 process_ray(&myRay, ray_pqueue(&myRay));
110 }
111
112
113 void
114 srcsamps( /* sample sources from this surface position */
115 struct illum_args *il,
116 FVECT org,
117 FVECT nrm,
118 MAT4 ixfm
119 )
120 {
121 int nalt, nazi;
122 SRCINDEX si;
123 RAY sr;
124 FVECT v;
125 double d;
126 int i, j;
127 /* get sampling density */
128 if (il->sampdens <= 0) {
129 nalt = nazi = 1;
130 } else {
131 i = PI * il->sampdens;
132 nalt = sqrt(i/PI) + .5;
133 nazi = PI*nalt + .5;
134 }
135 initsrcindex(&si); /* loop over (sub)sources */
136 for ( ; ; ) {
137 VCOPY(sr.rorg, org); /* pick side to shoot from */
138 if (il->sd != NULL) {
139 int sn = si.sn;
140 if (si.sp+1 >= si.np) ++sn;
141 if (sn >= nsources) break;
142 if (source[sn].sflags & SDISTANT)
143 d = DOT(source[sn].sloc, nrm);
144 else {
145 VSUB(v, source[sn].sloc, org);
146 d = DOT(v, nrm);
147 }
148 } else
149 d = 1.0; /* only transmission */
150 if (d < 0.0)
151 d = -1.0001*il->thick - 5.*FTINY;
152 else
153 d = 5.*FTINY;
154 for (i = 3; i--; )
155 sr.rorg[i] += d*nrm[i];
156 samplendx++; /* increment sample counter */
157 if (!srcray(&sr, NULL, &si))
158 break; /* end of sources */
159 /* index direction */
160 if (ixfm != NULL)
161 multv3(v, sr.rdir, ixfm);
162 else
163 VCOPY(v, sr.rdir);
164 if (il->sd != NULL) {
165 i = getBSDF_incndx(il->sd, v);
166 if (i < 0)
167 continue; /* must not be important */
168 sr.rno = i;
169 d = 1.0/getBSDF_incohm(il->sd, i);
170 } else {
171 if (v[2] >= -FTINY)
172 continue; /* only sample transmission */
173 v[0] = -v[0]; v[1] = -v[1]; v[2] = -v[2];
174 sr.rno = flatindex(v, nalt, nazi);
175 d = nalt*nazi*(1./PI) * v[2];
176 }
177 d *= si.dom; /* solid angle correction */
178 scalecolor(sr.rcoef, d);
179 process_ray(&sr, ray_pqueue(&sr));
180 }
181 }
182
183
184 void
185 rayclean() /* finish all pending rays */
186 {
187 RAY myRay;
188
189 while (process_ray(&myRay, ray_presult(&myRay, 0)))
190 ;
191 }
192
193
194 static void
195 mkaxes( /* compute u and v to go with n */
196 FVECT u,
197 FVECT v,
198 FVECT n
199 )
200 {
201 register int i;
202
203 v[0] = v[1] = v[2] = 0.0;
204 for (i = 0; i < 3; i++)
205 if (n[i] < 0.6 && n[i] > -0.6)
206 break;
207 v[i] = 1.0;
208 fcross(u, v, n);
209 normalize(u);
210 fcross(v, n, u);
211 }
212
213
214 static void
215 rounddir( /* compute uniform spherical direction */
216 register FVECT dv,
217 double alt,
218 double azi
219 )
220 {
221 double d1, d2;
222
223 dv[2] = 1. - 2.*alt;
224 d1 = sqrt(1. - dv[2]*dv[2]);
225 d2 = 2.*PI * azi;
226 dv[0] = d1*cos(d2);
227 dv[1] = d1*sin(d2);
228 }
229
230
231 void
232 flatdir( /* compute uniform hemispherical direction */
233 FVECT dv,
234 double alt,
235 double azi
236 )
237 {
238 double d1, d2;
239
240 d1 = sqrt(alt);
241 d2 = 2.*PI * azi;
242 dv[0] = d1*cos(d2);
243 dv[1] = d1*sin(d2);
244 dv[2] = sqrt(1. - alt);
245 }
246
247 int
248 flatindex( /* compute index for hemispherical direction */
249 FVECT dv,
250 int nalt,
251 int nazi
252 )
253 {
254 double d;
255 int i, j;
256
257 d = 1.0 - dv[2]*dv[2];
258 i = d*nalt;
259 d = atan2(dv[1], dv[0]) * (0.5/PI);
260 if (d < 0.0) d += 1.0;
261 j = d*nazi + 0.5;
262 if (j >= nazi) j = 0;
263 return(i*nazi + j);
264 }
265
266
267 int
268 my_default( /* default illum action */
269 OBJREC *ob,
270 struct illum_args *il,
271 char *nm
272 )
273 {
274 sprintf(errmsg, "(%s): cannot make illum for %s \"%s\"",
275 nm, ofun[ob->otype].funame, ob->oname);
276 error(WARNING, errmsg);
277 printobj(il->altmat, ob);
278 return(1);
279 }
280
281
282 int
283 my_face( /* make an illum face */
284 OBJREC *ob,
285 struct illum_args *il,
286 char *nm
287 )
288 {
289 int dim[2];
290 int n, nalt, nazi, alti;
291 double sp[2], r1, r2;
292 int h;
293 FVECT dn, org, dir;
294 FVECT u, v;
295 double ur[2], vr[2];
296 MAT4 xfm;
297 int nallow;
298 FACE *fa;
299 int i, j;
300 /* get/check arguments */
301 fa = getface(ob);
302 if (fa->area == 0.0) {
303 freeface(ob);
304 return(my_default(ob, il, nm));
305 }
306 /* set up sampling */
307 if (il->sd != NULL) {
308 if (!getBSDF_xfm(xfm, fa->norm, il->udir)) {
309 objerror(ob, WARNING, "illegal up direction");
310 freeface(ob);
311 return(my_default(ob, il, nm));
312 }
313 n = il->sd->ninc;
314 } else {
315 if (il->sampdens <= 0) {
316 nalt = nazi = 1; /* diffuse assumption */
317 } else {
318 n = PI * il->sampdens;
319 nalt = sqrt(n/PI) + .5;
320 nazi = PI*nalt + .5;
321 }
322 n = nazi*nalt;
323 }
324 newdist(n);
325 /* take first edge >= sqrt(area) */
326 for (j = fa->nv-1, i = 0; i < fa->nv; j = i++) {
327 u[0] = VERTEX(fa,i)[0] - VERTEX(fa,j)[0];
328 u[1] = VERTEX(fa,i)[1] - VERTEX(fa,j)[1];
329 u[2] = VERTEX(fa,i)[2] - VERTEX(fa,j)[2];
330 if ((r1 = DOT(u,u)) >= fa->area-FTINY)
331 break;
332 }
333 if (i < fa->nv) { /* got one! -- let's align our axes */
334 r2 = 1.0/sqrt(r1);
335 u[0] *= r2; u[1] *= r2; u[2] *= r2;
336 fcross(v, fa->norm, u);
337 } else /* oh well, we'll just have to wing it */
338 mkaxes(u, v, fa->norm);
339 /* now, find limits in (u,v) coordinates */
340 ur[0] = vr[0] = FHUGE;
341 ur[1] = vr[1] = -FHUGE;
342 for (i = 0; i < fa->nv; i++) {
343 r1 = DOT(VERTEX(fa,i),u);
344 if (r1 < ur[0]) ur[0] = r1;
345 if (r1 > ur[1]) ur[1] = r1;
346 r2 = DOT(VERTEX(fa,i),v);
347 if (r2 < vr[0]) vr[0] = r2;
348 if (r2 > vr[1]) vr[1] = r2;
349 }
350 dim[0] = random();
351 /* sample polygon */
352 nallow = 5*n*il->nsamps;
353 for (dim[1] = 0; dim[1] < n; dim[1]++)
354 for (i = 0; i < il->nsamps; i++) {
355 /* randomize direction */
356 h = ilhash(dim, 2) + i;
357 if (il->sd != NULL) {
358 r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm);
359 } else {
360 multisamp(sp, 2, urand(h));
361 alti = dim[1]/nazi;
362 r1 = (alti + sp[0])/nalt;
363 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
364 flatdir(dn, r1, r2);
365 for (j = 0; j < 3; j++)
366 dir[j] = -dn[0]*u[j] - dn[1]*v[j] -
367 dn[2]*fa->norm[j];
368 }
369 /* randomize location */
370 do {
371 multisamp(sp, 2, urand(h+4862+nallow));
372 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
373 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
374 for (j = 0; j < 3; j++)
375 org[j] = r1*u[j] + r2*v[j]
376 + fa->offset*fa->norm[j];
377 } while (!inface(org, fa) && nallow-- > 0);
378 if (nallow < 0) {
379 objerror(ob, WARNING, "bad aspect");
380 rayclean();
381 freeface(ob);
382 return(my_default(ob, il, nm));
383 }
384 if (il->sd != NULL && DOT(dir, fa->norm) < -FTINY)
385 r1 = -1.0001*il->thick - 5.*FTINY;
386 else
387 r1 = 5.*FTINY;
388 for (j = 0; j < 3; j++)
389 org[j] += r1*fa->norm[j];
390 /* send sample */
391 raysamp(dim[1], org, dir);
392 }
393 /* add in direct component? */
394 if (!directvis && (il->flags & IL_LIGHT || il->sd != NULL)) {
395 MAT4 ixfm;
396 if (il->sd == NULL) {
397 for (i = 3; i--; ) {
398 ixfm[i][0] = u[i];
399 ixfm[i][1] = v[i];
400 ixfm[i][2] = fa->norm[i];
401 ixfm[i][3] = 0.;
402 }
403 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
404 ixfm[3][3] = 1.;
405 } else {
406 if (!invmat4(ixfm, xfm))
407 objerror(ob, INTERNAL,
408 "cannot invert BSDF transform");
409 if (!(il->flags & IL_LIGHT))
410 new_discount();
411 }
412 dim[0] = random();
413 nallow = 10*il->nsamps;
414 for (i = 0; i < il->nsamps; i++) {
415 /* randomize location */
416 h = dim[0] + samplendx++;
417 do {
418 multisamp(sp, 2, urand(h+nallow));
419 r1 = ur[0] + (ur[1]-ur[0]) * sp[0];
420 r2 = vr[0] + (vr[1]-vr[0]) * sp[1];
421 for (j = 0; j < 3; j++)
422 org[j] = r1*u[j] + r2*v[j]
423 + fa->offset*fa->norm[j];
424 } while (!inface(org, fa) && nallow-- > 0);
425 if (nallow < 0) {
426 objerror(ob, WARNING, "bad aspect");
427 rayclean();
428 freeface(ob);
429 return(my_default(ob, il, nm));
430 }
431 /* sample source rays */
432 srcsamps(il, org, fa->norm, ixfm);
433 }
434 }
435 /* wait for all rays to finish */
436 rayclean();
437 if (il->sd != NULL) { /* run distribution through BSDF */
438 nalt = sqrt(il->sd->nout/PI) + .5;
439 nazi = PI*nalt + .5;
440 redistribute(il->sd, nalt, nazi, u, v, fa->norm, xfm);
441 done_discount();
442 if (!il->sampdens)
443 il->sampdens = nalt*nazi/PI + .999;
444 }
445 /* write out the face and its distribution */
446 if (average(il, distarr, n)) {
447 if (il->sampdens > 0)
448 flatout(il, distarr, nalt, nazi, u, v, fa->norm);
449 illumout(il, ob);
450 } else
451 printobj(il->altmat, ob);
452 /* clean up */
453 freeface(ob);
454 return(0);
455 }
456
457
458 int
459 my_sphere( /* make an illum sphere */
460 register OBJREC *ob,
461 struct illum_args *il,
462 char *nm
463 )
464 {
465 int dim[3];
466 int n, nalt, nazi;
467 double sp[4], r1, r2, r3;
468 FVECT org, dir;
469 FVECT u, v;
470 register int i, j;
471 /* check arguments */
472 if (ob->oargs.nfargs != 4)
473 objerror(ob, USER, "bad # of arguments");
474 /* set up sampling */
475 if (il->sampdens <= 0)
476 nalt = nazi = 1;
477 else {
478 n = 4.*PI * il->sampdens;
479 nalt = sqrt(2./PI*n) + .5;
480 nazi = PI/2.*nalt + .5;
481 }
482 if (il->sd != NULL)
483 objerror(ob, WARNING, "BSDF ignored");
484 n = nalt*nazi;
485 newdist(n);
486 dim[0] = random();
487 /* sample sphere */
488 for (dim[1] = 0; dim[1] < nalt; dim[1]++)
489 for (dim[2] = 0; dim[2] < nazi; dim[2]++)
490 for (i = 0; i < il->nsamps; i++) {
491 /* next sample point */
492 multisamp(sp, 4, urand(ilhash(dim,3)+i));
493 /* random direction */
494 r1 = (dim[1] + sp[0])/nalt;
495 r2 = (dim[2] + sp[1] - .5)/nazi;
496 rounddir(dir, r1, r2);
497 /* random location */
498 mkaxes(u, v, dir); /* yuck! */
499 r3 = sqrt(sp[2]);
500 r2 = 2.*PI*sp[3];
501 r1 = r3*ob->oargs.farg[3]*cos(r2);
502 r2 = r3*ob->oargs.farg[3]*sin(r2);
503 r3 = ob->oargs.farg[3]*sqrt(1.01-r3*r3);
504 for (j = 0; j < 3; j++) {
505 org[j] = ob->oargs.farg[j] + r1*u[j] + r2*v[j] +
506 r3*dir[j];
507 dir[j] = -dir[j];
508 }
509 /* send sample */
510 raysamp(dim[1]*nazi+dim[2], org, dir);
511 }
512 /* wait for all rays to finish */
513 rayclean();
514 /* write out the sphere and its distribution */
515 if (average(il, distarr, n)) {
516 if (il->sampdens > 0)
517 roundout(il, distarr, nalt, nazi);
518 else
519 objerror(ob, WARNING, "diffuse distribution");
520 illumout(il, ob);
521 } else
522 printobj(il->altmat, ob);
523 /* clean up */
524 return(1);
525 }
526
527
528 int
529 my_ring( /* make an illum ring */
530 OBJREC *ob,
531 struct illum_args *il,
532 char *nm
533 )
534 {
535 int dim[2];
536 int n, nalt, nazi, alti;
537 double sp[2], r1, r2, r3;
538 int h;
539 FVECT dn, org, dir;
540 FVECT u, v;
541 MAT4 xfm;
542 CONE *co;
543 int i, j;
544 /* get/check arguments */
545 co = getcone(ob, 0);
546 /* set up sampling */
547 if (il->sd != NULL) {
548 if (!getBSDF_xfm(xfm, co->ad, il->udir)) {
549 objerror(ob, WARNING, "illegal up direction");
550 freecone(ob);
551 return(my_default(ob, il, nm));
552 }
553 n = il->sd->ninc;
554 } else {
555 if (il->sampdens <= 0) {
556 nalt = nazi = 1; /* diffuse assumption */
557 } else {
558 n = PI * il->sampdens;
559 nalt = sqrt(n/PI) + .5;
560 nazi = PI*nalt + .5;
561 }
562 n = nazi*nalt;
563 }
564 newdist(n);
565 mkaxes(u, v, co->ad);
566 dim[0] = random();
567 /* sample disk */
568 for (dim[1] = 0; dim[1] < n; dim[1]++)
569 for (i = 0; i < il->nsamps; i++) {
570 /* next sample point */
571 h = ilhash(dim,2) + i;
572 /* randomize direction */
573 if (il->sd != NULL) {
574 r_BSDF_incvec(dir, il->sd, dim[1], urand(h), xfm);
575 } else {
576 multisamp(sp, 2, urand(h));
577 alti = dim[1]/nazi;
578 r1 = (alti + sp[0])/nalt;
579 r2 = (dim[1] - alti*nazi + sp[1] - .5)/nazi;
580 flatdir(dn, r1, r2);
581 for (j = 0; j < 3; j++)
582 dir[j] = -dn[0]*u[j] - dn[1]*v[j] - dn[2]*co->ad[j];
583 }
584 /* randomize location */
585 multisamp(sp, 2, urand(h+8371));
586 r3 = sqrt(CO_R0(co)*CO_R0(co) +
587 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
588 r2 = 2.*PI*sp[1];
589 r1 = r3*cos(r2);
590 r2 = r3*sin(r2);
591 if (il->sd != NULL && DOT(dir, co->ad) < -FTINY)
592 r3 = -1.0001*il->thick - 5.*FTINY;
593 else
594 r3 = 5.*FTINY;
595 for (j = 0; j < 3; j++)
596 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j] +
597 r3*co->ad[j];
598 /* send sample */
599 raysamp(dim[1], org, dir);
600 }
601 /* add in direct component? */
602 if (!directvis && (il->flags & IL_LIGHT || il->sd != NULL)) {
603 MAT4 ixfm;
604 if (il->sd == NULL) {
605 for (i = 3; i--; ) {
606 ixfm[i][0] = u[i];
607 ixfm[i][1] = v[i];
608 ixfm[i][2] = co->ad[i];
609 ixfm[i][3] = 0.;
610 }
611 ixfm[3][0] = ixfm[3][1] = ixfm[3][2] = 0.;
612 ixfm[3][3] = 1.;
613 } else {
614 if (!invmat4(ixfm, xfm))
615 objerror(ob, INTERNAL,
616 "cannot invert BSDF transform");
617 if (!(il->flags & IL_LIGHT))
618 new_discount();
619 }
620 dim[0] = random();
621 for (i = 0; i < il->nsamps; i++) {
622 /* randomize location */
623 h = dim[0] + samplendx++;
624 multisamp(sp, 2, urand(h));
625 r3 = sqrt(CO_R0(co)*CO_R0(co) +
626 sp[0]*(CO_R1(co)*CO_R1(co) - CO_R0(co)*CO_R0(co)));
627 r2 = 2.*PI*sp[1];
628 r1 = r3*cos(r2);
629 r2 = r3*sin(r2);
630 for (j = 0; j < 3; j++)
631 org[j] = CO_P0(co)[j] + r1*u[j] + r2*v[j];
632 /* sample source rays */
633 srcsamps(il, org, co->ad, ixfm);
634 }
635 }
636 /* wait for all rays to finish */
637 rayclean();
638 if (il->sd != NULL) { /* run distribution through BSDF */
639 nalt = sqrt(il->sd->nout/PI) + .5;
640 nazi = PI*nalt + .5;
641 redistribute(il->sd, nalt, nazi, u, v, co->ad, xfm);
642 done_discount();
643 if (!il->sampdens)
644 il->sampdens = nalt*nazi/PI + .999;
645 }
646 /* write out the ring and its distribution */
647 if (average(il, distarr, n)) {
648 if (il->sampdens > 0)
649 flatout(il, distarr, nalt, nazi, u, v, co->ad);
650 illumout(il, ob);
651 } else
652 printobj(il->altmat, ob);
653 /* clean up */
654 freecone(ob);
655 return(1);
656 }
