root/radiance/src/gen/mkillum.h
Revision: 2.18
Committed: Fri Sep 3 23:53:50 2010 UTC (15 years, 2 months ago) by greg
Changes since 2.17: +4 -1 lines
# User Rev Content
1 greg 2.18 /* RCSid: $Id: mkillum.h,v 2.17 2009/06/12 17:37:37 greg Exp $ */
2 greg 1.1 /*
3     * Common definitions for mkillum
4     */
5 schorsch 2.3 #ifndef _RAD_MKILLUM_H_
6     #define _RAD_MKILLUM_H_
7 greg 1.2
8 greg 2.8 #include "ray.h"
9     #include "otypes.h"
10 greg 2.17 #include "bsdf.h"
11 greg 2.14 #include "random.h"
12 schorsch 2.4
13     #ifdef __cplusplus
14     extern "C" {
15     #endif
16 greg 1.1 /* illum flags */
17 greg 1.3 #define IL_LIGHT 0x1 /* light rather than illum */
18     #define IL_COLDST 0x2 /* use color distribution */
19     #define IL_COLAVG 0x4 /* use average color */
20     #define IL_DATCLB 0x8 /* OK to clobber data file */
21 greg 1.1
22     struct illum_args {
23     int flags; /* flags from list above */
24 greg 2.10 UpDir udir; /* up direction */
25 greg 2.11 double thick; /* object thickness */
26 greg 1.1 char matname[MAXSTR]; /* illum material name */
27     char datafile[MAXSTR]; /* distribution data file name */
28     int dfnum; /* data file number */
29 greg 1.2 char altmat[MAXSTR]; /* alternate material name */
30 greg 1.3 int sampdens; /* point sample density */
31 greg 1.1 int nsamps; /* # of samples in each direction */
32 greg 2.10 struct BSDF_data
33     *sd; /* scattering data (if set) */
34 greg 1.5 float minbrt; /* minimum average brightness */
35 greg 2.9 COLOR col; /* computed average color */
36 greg 1.1 }; /* illum options */
37
38 greg 2.11 extern void redistribute(struct BSDF_data *b, int nalt, int nazi,
39     FVECT u, FVECT v, FVECT w, MAT4 xm);
40 greg 2.10
41     extern void printobj(char *mod, OBJREC *obj);
42     extern int average(struct illum_args *il, COLORV *da, int n);
43 greg 2.9 extern void flatout(struct illum_args *il, COLORV *da, int n, int m,
44     FVECT u, FVECT v, FVECT w);
45 greg 2.10 extern void illumout(struct illum_args *il, OBJREC *ob);
46 greg 2.9 extern void roundout(struct illum_args *il, COLORV *da, int n, int m);
47 schorsch 2.3
48 greg 2.11 extern void newdist(int siz);
49     extern int process_ray(RAY *r, int rv);
50     extern void raysamp(int ndx, FVECT org, FVECT dir);
51     extern void rayclean(void);
52
53 greg 2.13 extern void flatdir(FVECT dv, double alt, double azi);
54 greg 2.16 extern int flatindex(FVECT dv, int nalt, int nazi);
55 greg 2.13
56 greg 2.18 extern int printgeom(struct BSDF_data *sd, char *xfrot,
57     FVECT ctr, double s1, double s2);
58
59 greg 2.8 extern int my_default(OBJREC *, struct illum_args *, char *);
60     extern int my_face(OBJREC *, struct illum_args *, char *);
61     extern int my_sphere(OBJREC *, struct illum_args *, char *);
62     extern int my_ring(OBJREC *, struct illum_args *, char *);
63 greg 2.7
64 greg 2.11 extern COLORV * distarr; /* distribution array */
65     extern int distsiz;
66 greg 2.16 extern COLORV * direct_discount; /* amount to take off direct */
67 greg 2.11
68 greg 2.8 extern char *progname;
69 greg 2.7
70     #ifdef __cplusplus
71     }
72     #endif
73 greg 2.6
74 schorsch 2.3 #endif /* _RAD_MKILLUM_H_ */
75
