root/radiance/src/gen/mkillum.h
Revision: 2.20
Committed: Sun Aug 11 02:57:49 2013 UTC (12 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad6R0, rad4R2P1, rad4R2P2, HEAD
Changes since 2.19: +1 -2 lines
Removed deprecated thickness setting used for BSDF input
1 /* RCSid: $Id: mkillum.h,v 2.19 2012/10/13 20:15:43 greg Exp $ */
2 /*
3 * Common definitions for mkillum
4 */
5 #ifndef _RAD_MKILLUM_H_
6 #define _RAD_MKILLUM_H_
7
8 #include "ray.h"
9 #include "otypes.h"
10 #include "random.h"
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15 /* illum flags */
16 #define IL_LIGHT 0x1 /* light rather than illum */
17 #define IL_COLDST 0x2 /* use color distribution */
18 #define IL_COLAVG 0x4 /* use average color */
19 #define IL_DATCLB 0x8 /* OK to clobber data file */
20
21 struct illum_args {
22 int flags; /* flags from list above */
23 char matname[MAXSTR]; /* illum material name */
24 char datafile[MAXSTR]; /* distribution data file name */
25 int dfnum; /* data file number */
26 char altmat[MAXSTR]; /* alternate material name */
27 int sampdens; /* point sample density */
28 int nsamps; /* # of samples in each direction */
29 float minbrt; /* minimum average brightness */
30 COLOR col; /* computed average color */
31 }; /* illum options */
32
33 extern void printobj(char *mod, OBJREC *obj);
34 extern int average(struct illum_args *il, COLORV *da, int n);
35 extern void flatout(struct illum_args *il, COLORV *da, int n, int m,
36 FVECT u, FVECT v, FVECT w);
37 extern void illumout(struct illum_args *il, OBJREC *ob);
38 extern void roundout(struct illum_args *il, COLORV *da, int n, int m);
39
40 extern void newdist(int siz);
41 extern int process_ray(RAY *r, int rv);
42 extern void raysamp(int ndx, FVECT org, FVECT dir);
43 extern void rayclean(void);
44
45 extern void flatdir(FVECT dv, double alt, double azi);
46 extern int flatindex(FVECT dv, int nalt, int nazi);
47
48 extern int my_default(OBJREC *, struct illum_args *, char *);
49 extern int my_face(OBJREC *, struct illum_args *, char *);
50 extern int my_sphere(OBJREC *, struct illum_args *, char *);
51 extern int my_ring(OBJREC *, struct illum_args *, char *);
52
53 extern COLORV * distarr; /* distribution array */
54 extern int distsiz;
55
56 extern char *progname;
57
58 #ifdef __cplusplus
59 }
60 #endif
61
62 #endif /* _RAD_MKILLUM_H_ */
63
