root/radiance/src/gen/mkillum.c
Revision: 2.15
Committed: Fri Jun 27 22:27:45 2003 UTC (22 years, 3 months ago) by greg
2 static const char RCSid[] = "$Id: mkillum.c,v 2.14 2003/06/26 00:58:09 schorsch Exp $";
5 * Make illum sources for optimizing rendering process
6 */
7
8 #include <signal.h>
9 #include <ctype.h>
10
11 #include "mkillum.h"
12 #include "platform.h"
13
14 /* default parameters */
15 #define SAMPDENS 48 /* points per projected steradian */
16 #define NSAMPS 32 /* samples per point */
17 #define DFLMAT "illum_mat" /* material name */
18 #define DFLDAT "illum" /* data file name */
19 /* selection options */
20 #define S_NONE 0 /* select none */
21 #define S_ELEM 1 /* select specified element */
22 #define S_COMPL 2 /* select all but element */
23 #define S_ALL 3 /* select all */
24
25 /* rtrace command and defaults */
26 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-dv-",
27 "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", };
28 int rtargc = 14;
29 /* overriding rtrace options */
30 char *myrtopts[] = { "-I-", "-i-", "-ld-", "-ov", "-h-",
31 "-fff", "-y", "0", NULL };
32
33 struct rtproc rt; /* our rtrace process */
34
35 struct illum_args thisillum = { /* our illum and default values */
36 0,
37 DFLMAT,
38 DFLDAT,
39 0,
40 VOIDID,
41 SAMPDENS,
42 NSAMPS,
43 0.,
44 };
45
46 char matcheck[MAXSTR]; /* current material to include or exclude */
47 int matselect = S_ALL; /* selection criterion */
48
49 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
50
51 int gargc; /* global argc */
52 char **gargv; /* global argv */
53 #define progname gargv[0]
54
55 int doneheader = 0; /* printed header yet? */
56 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
57
58 int warnings = 1; /* print warnings? */
59
60
61 main(argc, argv) /* compute illum distributions using rtrace */
62 int argc;
63 char *argv[];
64 {
65 char *rtpath;
66 FILE *fp;
67 register int i;
68 /* set global arguments */
69 gargv = argv;
70 /* set up rtrace command */
71 for (i = 1; i < argc; i++) {
72 if (argv[i][0] == '<' && argv[i][1] == '\0')
73 break;
74 rtargv[rtargc++] = argv[i];
75 if (argv[i][0] == '-' && argv[i][1] == 'w')
76 switch (argv[i][2]) {
77 case '\0':
78 warnings = !warnings;
79 break;
80 case '+':
81 case 'T': case 't':
82 case 'Y': case 'y':
83 case '1':
84 warnings = 1;
85 break;
86 case '-':
87 case 'F': case 'f':
88 case 'N': case 'n':
89 case '0':
90 warnings = 0;
91 break;
92 }
93 }
94 gargc = i;
95 rtargc--;
96 for (i = 0; myrtopts[i] != NULL; i++)
97 rtargv[rtargc++] = myrtopts[i];
98 rtargv[rtargc++] = argv[gargc-1];
99 rtargv[rtargc] = NULL;
100 /* just asking for defaults? */
101 if (!strcmp(argv[gargc-1], "-defaults")) {
102 printopts(); fflush(stdout);
103 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
104 if (rtpath == NULL) {
105 eputs(rtargv[0]);
106 eputs(": command not found\n");
107 exit(1);
108 }
109 execv(rtpath, rtargv);
110 perror(rtpath);
111 exit(1);
112 }
113 if (gargc < 2 || argv[gargc-1][0] == '-')
114 error(USER, "missing octree argument");
115 /* else initialize and run our calculation */
116 init();
117 if (gargc+1 < argc)
118 for (i = gargc+1; i < argc; i++) {
119 if ((fp = fopen(argv[i], "r")) == NULL) {
120 sprintf(errmsg,
121 "cannot open scene file \"%s\"", argv[i]);
122 error(SYSTEM, errmsg);
123 }
124 filter(fp, argv[i]);
125 fclose(fp);
126 }
127 else
128 filter(stdin, "standard input");
129 quit(0);
130 }
131
132
133 void
134 quit(status) /* exit with status */
135 int status;
136 {
137 int rtstat;
138
139 rtstat = close_process(&(rt.pd));
140 if (status == 0)
141 if (rtstat < 0)
142 error(WARNING,
143 "unknown return status from rtrace process");
144 else
145 status = rtstat;
146 exit(status);
147 }
148
149
150 init() /* start rtrace and set up buffers */
151 {
152 extern int o_face(), o_sphere(), o_ring();
153 int maxbytes;
154 /* set up object functions */
155 ofun[OBJ_FACE].funp = o_face;
156 ofun[OBJ_SPHERE].funp = o_sphere;
157 ofun[OBJ_RING].funp = o_ring;
158 /* set up signal handling */
159 #ifdef SIGPIPE /* not present on Windows */
160 signal(SIGPIPE, quit);
161 #endif
162 /* start rtrace process */
163 errno = 0;
164 maxbytes = open_process(&(rt.pd), rtargv);
165 if (maxbytes == 0) {
166 eputs(rtargv[0]);
167 eputs(": command not found\n");
168 exit(1);
169 }
170 if (maxbytes < 0)
171 error(SYSTEM, "cannot start rtrace process");
172 rt.bsiz = maxbytes/(6*sizeof(float));
173 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
174 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
175 if (rt.buf == NULL || rt.dest == NULL)
176 error(SYSTEM, "out of memory in init");
177 rt.nrays = 0;
178 /* set up urand */
179 initurand(16384);
180 }
181
182
183 void
184 eputs(s) /* put string to stderr */
185 register char *s;
186 {
187 static int midline = 0;
188
189 if (!*s) return;
190 if (!midline) {
191 fputs(progname, stderr);
192 fputs(": ", stderr);
193 }
194 fputs(s, stderr);
195 midline = s[strlen(s)-1] != '\n';
196 }
197
198
199 void
200 wputs(s) /* print warning if enabled */
201 char *s;
202 {
203 if (warnings)
204 eputs(s);
205 }
206
207
208 filter(infp, name) /* process stream */
209 register FILE *infp;
210 char *name;
211 {
212 char buf[512];
213 FILE *pfp;
214 register int c;
215
216 while ((c = getc(infp)) != EOF) {
217 if (isspace(c))
218 continue;
219 if (c == '#') { /* comment/options */
220 buf[0] = c;
221 fgets(buf+1, sizeof(buf)-1, infp);
222 xoptions(buf, name);
223 } else if (c == '!') { /* command */
224 buf[0] = c;
225 fgetline(buf+1, sizeof(buf)-1, infp);
226 if ((pfp = popen(buf+1, "r")) == NULL) {
227 sprintf(errmsg, "cannot execute \"%s\"", buf);
228 error(SYSTEM, errmsg);
229 }
230 filter(pfp, buf);
231 pclose(pfp);
232 } else { /* object */
233 ungetc(c, infp);
234 xobject(infp, name);
235 }
236 }
237 }
238
239
240 xoptions(s, nm) /* process options in string s */
241 char *s;
242 char *nm;
243 {
244 extern FILE *freopen();
245 char buf[64];
246 int nerrs = 0;
247 register char *cp;
248
249 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
250 fputs(s, stdout); /* not for us */
251 return;
252 }
253 cp = s+10;
254 while (*cp) {
255 switch (*cp) {
256 case ' ':
257 case '\t':
258 case '\n':
259 case '\r':
260 case '\f':
261 cp++;
262 continue;
263 case 'm': /* material name */
264 if (*++cp != '=')
265 break;
266 if (!*++cp || isspace(*cp))
267 break;
268 atos(thisillum.matname, MAXSTR, cp);
269 cp = sskip(cp);
270 if (!(thisillum.flags & IL_DATCLB)) {
271 strcpy(thisillum.datafile, thisillum.matname);
272 thisillum.dfnum = 0;
273 }
274 continue;
275 case 'f': /* data file name */
276 if (*++cp != '=')
277 break;
278 if (!*++cp || isspace(*cp)) {
279 strcpy(thisillum.datafile,thisillum.matname);
280 thisillum.dfnum = 0;
281 thisillum.flags &= ~IL_DATCLB;
282 continue;
283 }
284 atos(thisillum.datafile, MAXSTR, cp);
285 cp = sskip(cp);
286 thisillum.dfnum = 0;
287 thisillum.flags |= IL_DATCLB;
288 continue;
289 case 'i': /* include material */
290 case 'e': /* exclude material */
291 if (cp[1] != '=')
292 break;
293 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
294 cp += 2;
295 atos(matcheck, MAXSTR, cp);
296 cp = sskip(cp);
297 continue;
298 case 'a': /* use everything */
299 cp = sskip(cp);
300 matselect = S_ALL;
301 continue;
302 case 'n': /* use nothing (passive) */
303 cp = sskip(cp);
304 matselect = S_NONE;
305 continue;
306 case 'c': /* color calculation */
307 if (*++cp != '=')
308 break;
309 switch (*++cp) {
310 case 'a': /* average */
311 thisillum.flags = (thisillum.flags|IL_COLAVG)
312 & ~IL_COLDST;
313 break;
314 case 'd': /* distribution */
315 thisillum.flags |= (IL_COLDST|IL_COLAVG);
316 break;
317 case 'n': /* none */
318 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
319 break;
320 default:
321 goto opterr;
322 }
323 cp = sskip(cp);
324 continue;
325 case 'd': /* point sample density */
326 if (*++cp != '=')
327 break;
328 if (!isintd(++cp, " \t\n\r"))
329 break;
330 thisillum.sampdens = atoi(cp);
331 cp = sskip(cp);
332 continue;
333 case 's': /* point super-samples */
334 if (*++cp != '=')
335 break;
336 if (!isintd(++cp, " \t\n\r"))
337 break;
338 thisillum.nsamps = atoi(cp);
339 cp = sskip(cp);
340 continue;
341 case 'l': /* light sources */
342 cp++;
343 if (*cp == '+')
344 thisillum.flags |= IL_LIGHT;
345 else if (*cp == '-')
346 thisillum.flags &= ~IL_LIGHT;
347 else
348 break;
349 cp++;
350 continue;
351 case 'b': /* brightness */
352 if (*++cp != '=')
353 break;
354 if (!isfltd(++cp, " \t\n\r"))
355 break;
356 thisillum.minbrt = atof(cp);
357 if (thisillum.minbrt < 0.)
358 thisillum.minbrt = 0.;
359 cp = sskip(cp);
360 continue;
361 case 'o': /* output file */
362 if (*++cp != '=')
363 break;
364 if (!*++cp || isspace(*cp))
365 break;
366 atos(buf, sizeof(buf), cp);
367 cp = sskip(cp);
368 if (freopen(buf, "w", stdout) == NULL) {
369 sprintf(errmsg,
370 "cannot open output file \"%s\"", buf);
371 error(SYSTEM, errmsg);
372 }
373 doneheader = 0;
374 continue;
375 case '!': /* processed file! */
376 sprintf(errmsg, "(%s): already processed!", nm);
377 error(WARNING, errmsg);
378 matselect = S_NONE;
379 return;
380 }
381 opterr: /* skip faulty option */
382 while (*cp && !isspace(*cp))
383 cp++;
384 nerrs++;
385 }
386 /* print header? */
387 checkhead();
388 /* issue warnings? */
389 if (nerrs) {
390 sprintf(errmsg, "(%s): %d error(s) in option line:",
391 nm, nerrs);
392 error(WARNING, errmsg);
393 wputs(s);
394 printf("# %s: the following option line has %d error(s):\n",
395 progname, nerrs);
396 }
397 /* print pure comment */
398 printf("# %s", s+2);
399 }
400
401
402 printopts() /* print out option default values */
403 {
404 printf("m=%-15s\t\t# material name\n", thisillum.matname);
405 printf("f=%-15s\t\t# data file name\n", thisillum.datafile);
406 if (thisillum.flags & IL_COLAVG)
407 if (thisillum.flags & IL_COLDST)
408 printf("c=d\t\t\t\t# color distribution\n");
409 else
410 printf("c=a\t\t\t\t# color average\n");
411 else
412 printf("c=n\t\t\t\t# color none\n");
413 if (thisillum.flags & IL_LIGHT)
414 printf("l+\t\t\t\t# light type on\n");
415 else
416 printf("l-\t\t\t\t# light type off\n");
417 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
418 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
419 printf("b=%f\t\t\t# minimum average brightness\n", thisillum.minbrt);
420 }
421
422
423 printhead(ac, av) /* print out header */
424 register int ac;
425 register char **av;
426 {
427 putchar('#');
428 while (ac-- > 0) {
429 putchar(' ');
430 fputs(*av++, stdout);
431 }
432 fputs("\n#@mkillum !\n", stdout);
433 }
434
435
436 xobject(fp, nm) /* translate an object from fp */
437 FILE *fp;
438 char *nm;
439 {
440 OBJREC thisobj;
441 char str[MAXSTR];
442 int doit;
443 /* read the object */
444 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
445 goto readerr;
446 if (fgetword(str, MAXSTR, fp) == NULL)
447 goto readerr;
448 /* is it an alias? */
449 if (!strcmp(str, ALIASKEY)) {
450 if (fgetword(str, MAXSTR, fp) == NULL)
451 goto readerr;
452 printf("\n%s %s %s", thisillum.altmat, ALIASKEY, str);
453 if (fgetword(str, MAXSTR, fp) == NULL)
454 goto readerr;
455 printf("\t%s\n", str);
456 return;
457 }
458 thisobj.omod = OVOID; /* unused field */
459 if ((thisobj.otype = otype(str)) < 0) {
460 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
461 error(USER, errmsg);
462 }
463 if (fgetword(str, MAXSTR, fp) == NULL)
464 goto readerr;
465 thisobj.oname = str;
466 if (readfargs(&thisobj.oargs, fp) != 1)
467 goto readerr;
468 thisobj.os = NULL;
469 /* check for translation */
470 switch (matselect) {
471 case S_NONE:
472 doit = 0;
473 break;
474 case S_ALL:
475 doit = 1;
476 break;
477 case S_ELEM:
478 doit = !strcmp(thisillum.altmat, matcheck);
479 break;
480 case S_COMPL:
481 doit = strcmp(thisillum.altmat, matcheck);
482 break;
483 }
484 doit = doit && issurface(thisobj.otype);
485 /* print header? */
486 checkhead();
487 /* process object */
488 if (doit)
489 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
490 else
491 printobj(thisillum.altmat, &thisobj);
492 /* free arguments */
493 freefargs(&thisobj.oargs);
494 return;
495 readerr:
496 sprintf(errmsg, "(%s): error reading scene", nm);
497 error(USER, errmsg);
498 }
