root/radiance/src/gen/mkillum.c
Revision: 1.10
Committed: Tue Jul 30 16:24:42 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.9: +3 -1 lines
small changes in default data file name
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Make illum sources for optimizing rendering process
9 */
10
11 #include "mkillum.h"
12
13 #include <signal.h>
14
15 #include <ctype.h>
16
17 /* default parameters */
18 #define SAMPDENS 48 /* points per projected steradian */
19 #define NSAMPS 32 /* samples per point */
20 #define DFLMAT "illum_mat" /* material name */
21 #define DFLDAT "illum" /* data file name */
22 /* selection options */
23 #define S_NONE 0 /* select none */
24 #define S_ELEM 1 /* select specified element */
25 #define S_COMPL 2 /* select all but element */
26 #define S_ALL 3 /* select all */
27
28 /* rtrace command and defaults */
29 char *rtargv[64] = { "rtrace", "-dj", ".25", "-dr", "3", "-di+",
30 "-ab", "2", "-ad", "256", "-as", "128", "-aa", ".15", };
31 int rtargc = 14;
32 /* overriding rtrace options */
33 char *myrtopts[] = { "-I-", "-i-", "-ov", "-h-", "-fff", NULL };
34
35 struct rtproc rt; /* our rtrace process */
36
37 struct illum_args thisillum = { /* our illum and default values */
38 0,
39 DFLMAT,
40 DFLDAT,
41 0,
42 VOIDID,
43 SAMPDENS,
44 NSAMPS,
45 };
46
47 char matcheck[MAXSTR]; /* current material to include or exclude */
48 int matselect = S_ALL; /* selection criterion */
49
50 FUN ofun[NUMOTYPE] = INIT_OTYPE; /* object types */
51
52 int gargc; /* global argc */
53 char **gargv; /* global argv */
54 #define progname gargv[0]
55
56 int doneheader = 0; /* printed header yet? */
57 #define checkhead() if (!doneheader++) printhead(gargc,gargv)
58
59 int warnings = 1; /* print warnings? */
60
61 extern char *fgetline(), *fgetword(), *sskip(),
62 *atos(), *iskip(), *fskip(), *strcpy();
63 extern FILE *popen();
64
65
66 main(argc, argv) /* compute illum distributions using rtrace */
67 int argc;
68 char *argv[];
69 {
70 extern char *getenv(), *getpath();
71 char *rtpath;
72 FILE *fp;
73 register int i;
74 /* set global arguments */
75 gargv = argv;
76 /* set up rtrace command */
77 for (i = 1; i < argc; i++) {
78 if (argv[i][0] == '<' && !argv[i][1])
79 break;
80 rtargv[rtargc++] = argv[i];
81 if (argv[i][0] == '-' && argv[i][1] == 'w')
82 warnings = !warnings;
83 }
84 if ((gargc = i) < 2)
85 error(USER, "too few arguments");
86 rtargc--;
87 for (i = 0; myrtopts[i] != NULL; i++)
88 rtargv[rtargc++] = myrtopts[i];
89 rtargv[rtargc++] = argv[gargc-1];
90 rtargv[rtargc] = NULL;
91 /* just asking for defaults? */
92 if (!strcmp(argv[gargc-1], "-defaults")) {
93 printopts(); fflush(stdout);
94 rtpath = getpath(rtargv[0], getenv("PATH"), X_OK);
95 if (rtpath == NULL) {
96 eputs(rtargv[0]);
97 eputs(": command not found\n");
98 exit(1);
99 }
100 execv(rtpath, rtargv);
101 perror(rtpath);
102 exit(1);
103 }
104 /* else initialize and run our calculation */
105 init();
106 if (gargc+1 < argc)
107 for (i = gargc+1; i < argc; i++) {
108 if ((fp = fopen(argv[i], "r")) == NULL) {
109 sprintf(errmsg,
110 "cannot open scene file \"%s\"", argv[i]);
111 error(SYSTEM, errmsg);
112 }
113 filter(fp, argv[i]);
114 fclose(fp);
115 }
116 else
117 filter(stdin, "standard input");
118 quit(0);
119 }
120
121
122 quit(status) /* exit with status */
123 int status;
124 {
125 int rtstat;
126
127 rtstat = close_process(rt.pd);
128 if (status == 0)
129 if (rtstat < 0)
130 error(WARNING,
131 "unknown return status from rtrace process");
132 else
133 status = rtstat;
134 exit(status);
135 }
136
137
138 init() /* start rtrace and set up buffers */
139 {
140 extern int o_face(), o_sphere(), o_ring();
141 int maxbytes;
142 /* set up object functions */
143 ofun[OBJ_FACE].funp = o_face;
144 ofun[OBJ_SPHERE].funp = o_sphere;
145 ofun[OBJ_RING].funp = o_ring;
146 /* set up signal handling */
147 signal(SIGPIPE, quit);
148 /* start rtrace process */
149 maxbytes = open_process(rt.pd, rtargv);
150 if (maxbytes == 0) {
151 eputs(rtargv[0]);
152 eputs(": command not found\n");
153 exit(1);
154 }
155 if (maxbytes < 0)
156 error(SYSTEM, "cannot start rtrace process");
157 rt.bsiz = maxbytes/(6*sizeof(float));
158 rt.buf = (float *)malloc(6*sizeof(float)*rt.bsiz--);
159 rt.dest = (float **)malloc(sizeof(float *)*rt.bsiz);
160 if (rt.buf == NULL || rt.dest == NULL)
161 error(SYSTEM, "out of memory in init");
162 rt.nrays = 0;
163 /* set up urand */
164 initurand(2048);
165 }
166
167
168 eputs(s) /* put string to stderr */
169 register char *s;
170 {
171 static int midline = 0;
172
173 if (!*s) return;
174 if (!midline) {
175 fputs(progname, stderr);
176 fputs(": ", stderr);
177 }
178 fputs(s, stderr);
179 midline = s[strlen(s)-1] != '\n';
180 }
181
182
183 wputs(s) /* print warning if enabled */
184 char *s;
185 {
186 if (warnings)
187 eputs(s);
188 }
189
190
191 filter(infp, name) /* process stream */
192 register FILE *infp;
193 char *name;
194 {
195 char buf[512];
196 FILE *pfp;
197 register int c;
198
199 while ((c = getc(infp)) != EOF) {
200 if (isspace(c))
201 continue;
202 if (c == '#') { /* comment/options */
203 buf[0] = c;
204 fgets(buf+1, sizeof(buf)-1, infp);
205 xoptions(buf, name);
206 } else if (c == '!') { /* command */
207 buf[0] = c;
208 fgetline(buf+1, sizeof(buf)-1, infp);
209 if ((pfp = popen(buf+1, "r")) == NULL) {
210 sprintf(errmsg, "cannot execute \"%s\"", buf);
211 error(SYSTEM, errmsg);
212 }
213 filter(pfp, buf);
214 pclose(pfp);
215 } else { /* object */
216 ungetc(c, infp);
217 xobject(infp, name);
218 }
219 }
220 }
221
222
223 xoptions(s, nm) /* process options in string s */
224 char *s;
225 char *nm;
226 {
227 extern FILE *freopen();
228 char buf[64];
229 int nerrs = 0;
230 register char *cp;
231
232 if (strncmp(s, "#@mkillum", 9) || !isspace(s[9])) {
233 fputs(s, stdout); /* not for us */
234 return;
235 }
236 cp = s+10;
237 while (*cp) {
238 switch (*cp) {
239 case ' ':
240 case '\t':
241 case '\n':
242 cp++;
243 continue;
244 case 'm': /* material name */
245 if (*++cp != '=')
246 break;
247 if (!*++cp)
248 break;
249 atos(thisillum.matname, MAXSTR, cp);
250 cp = sskip(cp);
251 if (!(thisillum.flags & IL_DATCLB)) {
252 strcpy(thisillum.datafile, thisillum.matname);
253 thisillum.dfnum = 0;
254 }
255 continue;
256 case 'f': /* data file name */
257 if (*++cp != '=')
258 break;
259 if (!*++cp) {
260 strcpy(thisillum.datafile,thisillum.matname);
261 thisillum.dfnum = 0;
262 thisillum.flags &= ~IL_DATCLB;
263 continue;
264 }
265 atos(thisillum.datafile, MAXSTR, cp);
266 cp = sskip(cp);
267 thisillum.dfnum = 0;
268 thisillum.flags |= IL_DATCLB;
269 continue;
270 case 'i': /* include material */
271 case 'e': /* exclude material */
272 if (cp[1] != '=')
273 break;
274 matselect = (*cp == 'i') ? S_ELEM : S_COMPL;
275 cp += 2;
276 atos(matcheck, MAXSTR, cp);
277 cp = sskip(cp);
278 continue;
279 case 'a': /* use everything */
280 cp = sskip(cp);
281 matselect = S_ALL;
282 continue;
283 case 'n': /* use nothing (passive) */
284 cp = sskip(cp);
285 matselect = S_NONE;
286 continue;
287 case 'c': /* color calculation */
288 if (*++cp != '=')
289 break;
290 switch (*++cp) {
291 case 'a': /* average */
292 thisillum.flags = (thisillum.flags|IL_COLAVG)
293 & ~IL_COLDST;
294 break;
295 case 'd': /* distribution */
296 thisillum.flags |= (IL_COLDST|IL_COLAVG);
297 break;
298 case 'n': /* none */
299 thisillum.flags &= ~(IL_COLAVG|IL_COLDST);
300 break;
301 default:
302 goto opterr;
303 }
304 cp = sskip(cp);
305 continue;
306 case 'd': /* point sample density */
307 if (*++cp != '=')
308 break;
309 if (!isintd(++cp, " \t\n"))
310 break;
311 thisillum.sampdens = atoi(cp);
312 cp = sskip(cp);
313 continue;
314 case 's': /* point super-samples */
315 if (*++cp != '=')
316 break;
317 if (!isintd(++cp, " \t\n"))
318 break;
319 thisillum.nsamps = atoi(cp);
320 cp = sskip(cp);
321 continue;
322 case 'l': /* light sources */
323 cp++;
324 if (*cp == '+')
325 thisillum.flags |= IL_LIGHT;
326 else if (*cp == '-')
327 thisillum.flags &= ~IL_LIGHT;
328 else
329 break;
330 cp++;
331 continue;
332 case 'o': /* output file */
333 if (*++cp != '=')
334 break;
335 if (!*++cp)
336 break;
337 atos(buf, sizeof(buf), cp);
338 cp = sskip(cp);
339 if (freopen(buf, "w", stdout) == NULL) {
340 sprintf(errmsg,
341 "cannot open output file \"%s\"", buf);
342 error(SYSTEM, errmsg);
343 }
344 doneheader = 0;
345 continue;
346 case '!': /* processed file! */
347 sprintf(errmsg, "(%s): already processed!", nm);
348 error(WARNING, errmsg);
349 matselect = S_NONE;
350 return;
351 }
352 opterr: /* skip faulty option */
353 cp = sskip(cp);
354 nerrs++;
355 }
356 /* print header? */
357 checkhead();
358 /* issue warnings? */
359 if (nerrs) {
360 sprintf(errmsg, "(%s): %d error(s) in option line:",
361 nm, nerrs);
362 error(WARNING, errmsg);
363 wputs(s);
364 printf("# %s: the following option line has %d error(s):\n",
365 progname, nerrs);
366 }
367 /* print pure comment */
368 printf("# %s", s+2);
369 }
370
371
372 printopts() /* print out option default values */
373 {
374 printf("m=%s\t\t\t# material name\n", thisillum.matname);
375 printf("f=%s\t\t\t# data file name\n", thisillum.datafile);
376 printf("c=n\t\t\t\t# color none\n");
377 printf("d=%d\t\t\t\t# density of points\n", thisillum.sampdens);
378 printf("s=%d\t\t\t\t# samples per point\n", thisillum.nsamps);
379 }
380
381
382 printhead(ac, av) /* print out header */
383 register int ac;
384 register char **av;
385 {
386 putchar('#');
387 while (ac-- > 0) {
388 putchar(' ');
389 fputs(*av++, stdout);
390 }
391 fputs("\n#@mkillum !\n", stdout);
392 }
393
394
395 xobject(fp, nm) /* translate an object from fp */
396 FILE *fp;
397 char *nm;
398 {
399 OBJREC thisobj;
400 char str[MAXSTR];
401 int doit;
402 /* read the object */
403 if (fgetword(thisillum.altmat, MAXSTR, fp) == NULL)
404 goto readerr;
405 if (fgetword(str, MAXSTR, fp) == NULL)
406 goto readerr;
407 /* is it an alias? */
408 if (!strcmp(str, ALIASID)) {
409 if (fgetword(str, MAXSTR, fp) == NULL)
410 goto readerr;
411 printf("\n%s %s %s", thisillum.altmat, ALIASID, str);
412 if (fgetword(str, MAXSTR, fp) == NULL)
413 goto readerr;
414 printf("\t%s\n", str);
415 return;
416 }
417 thisobj.omod = OVOID; /* unused field */
418 if ((thisobj.otype = otype(str)) < 0) {
419 sprintf(errmsg, "(%s): unknown type \"%s\"", nm, str);
420 error(USER, errmsg);
421 }
422 if (fgetword(str, MAXSTR, fp) == NULL)
423 goto readerr;
424 thisobj.oname = str;
425 if (readfargs(&thisobj.oargs, fp) != 1)
426 goto readerr;
427 thisobj.os = NULL;
428 /* check for translation */
429 switch (matselect) {
430 case S_NONE:
431 doit = 0;
432 break;
433 case S_ALL:
434 doit = 1;
435 break;
436 case S_ELEM:
437 doit = !strcmp(thisillum.altmat, matcheck);
438 break;
439 case S_COMPL:
440 doit = strcmp(thisillum.altmat, matcheck);
441 break;
442 }
443 doit = doit && issurface(thisobj.otype);
444 /* print header? */
445 checkhead();
446 /* process object */
447 if (doit)
448 (*ofun[thisobj.otype].funp)(&thisobj, &thisillum, &rt, nm);
449 else
450 printobj(thisillum.altmat, &thisobj);
451 /* free arguments */
452 freefargs(&thisobj.oargs);
453 return;
454 readerr:
455 sprintf(errmsg, "(%s): error reading scene", nm);
456 error(USER, errmsg);
457 }
