| 1 | greg | 1.1 | #!/bin/csh -f |
| 2 | greg | 2.2 | # RCSid: $Id$ |
| 3 | greg | 1.1 | # |
| 4 |  |  | #  Generate source description for window with venetian blinds. |
| 5 |  |  | # |
| 6 |  |  | #       1/11/88         Greg Ward |
| 7 |  |  | # |
| 8 |  |  | #  Usage: genwindow shellfile |
| 9 |  |  | # |
| 10 |  |  | #  Takes as input the following shell variables from file $1: |
| 11 |  |  | # |
| 12 |  |  | #       worient         Window orientation (degrees from south) |
| 13 |  |  | #       wwidth          Window width |
| 14 |  |  | #       wheight         Window height |
| 15 |  |  | #       wtrans          Window transmission |
| 16 |  |  | #       bdepth          Blind depth |
| 17 |  |  | #       bspac           Blind vertical spacing |
| 18 |  |  | #       gap             Gap between blinds and window |
| 19 |  |  | #       brcurv          Blind curvature radius (negative upward, zero none) |
| 20 |  |  | #       bangle          Blind inclination (degrees from horizontal, up and out) |
| 21 |  |  | #       material        Blind material type (metal or plastic) |
| 22 |  |  | #       ucolor          Blind up side color ("red green blue") |
| 23 |  |  | #       uspec           Blind up side specularity (0 to 1) |
| 24 |  |  | #       urough          Blind up side roughness (0 to .2) |
| 25 |  |  | #       dcolor          Blind down side color (opt) |
| 26 |  |  | #       dspec           Blind down side specularity (opt) |
| 27 |  |  | #       drough          Blind down side roughness (opt) |
| 28 |  |  | #       lat             Site latitude (degrees) |
| 29 |  |  | #       long            Site longitude (degrees) |
| 30 |  |  | #       mer             Site standard meridian (degrees) |
| 31 |  |  | #       hour            Hour (standard 24hr time) |
| 32 |  |  | #       day             Day (of month) |
| 33 |  |  | #       month           Month (of year) |
| 34 |  |  | #       grefl           Ground plane reflectance |
| 35 |  |  | #       sky             Sky conditions (sunny, clear, cloudy) |
| 36 |  |  | #       nsources        Number of sources to divide window |
| 37 |  |  | # |
| 38 |  |  | #  Creates the following output files: |
| 39 |  |  | # |
| 40 |  |  | #       stdout          Window description for Radiance |
| 41 |  |  | #       $1.d$$          Window output distribution |
| 42 |  |  | # |
| 43 |  |  |  |
| 44 |  |  | if ( $#argv != 1 ) then |
| 45 |  |  | echo Usage: $0 input |
| 46 |  |  | exit 1 |
| 47 |  |  | endif |
| 48 |  |  |  |
| 49 |  |  | #       Set input and output files |
| 50 |  |  | set input = $1 |
| 51 |  |  | set distrib = $1.d$$ |
| 52 |  |  | set tmpdir = /tmp |
| 53 |  |  | set descrip = $tmpdir/gw$$.des |
| 54 |  |  | set distoct = $tmpdir/gw$$.oct |
| 55 |  |  | set skydesc = $tmpdir/gw$$.sky |
| 56 |  |  | set remove = ( $distoct $skydesc $descrip ) |
| 57 |  |  | set removerr = ( $remove $distrib ) |
| 58 |  |  | onintr error |
| 59 |  |  |  |
| 60 |  |  | #       Set default values |
| 61 |  |  | set worient = 0. |
| 62 |  |  | set wtrans = ( .96 .96 .96 ) |
| 63 |  |  | set bdepth = 0.025 |
| 64 |  |  | set bspac = 0.0155 |
| 65 |  |  | set gap = 0. |
| 66 |  |  | set brcurv = 0. |
| 67 |  |  | set bangle = 0. |
| 68 |  |  | set material = plastic |
| 69 |  |  | set ucolor = ( 0.5 0.5 0.5 ) |
| 70 |  |  | set uspec = 0. |
| 71 |  |  | set urough = 0.05 |
| 72 |  |  | set lat = 37.8 |
| 73 |  |  | set long = 122 |
| 74 |  |  | set mer = 120 |
| 75 |  |  | set hour = 12 |
| 76 |  |  | set day = 21 |
| 77 |  |  | set month = 10 |
| 78 |  |  | set grefl = .2 |
| 79 |  |  | set sky = sunny |
| 80 |  |  | set nsources = 6 |
| 81 |  |  |  |
| 82 |  |  | #       Get input |
| 83 |  |  | source $input |
| 84 |  |  | if ( $status ) goto error |
| 85 |  |  |  |
| 86 |  |  | #       Create window |
| 87 |  |  | cat > $descrip <<_EOF_ |
| 88 |  |  |  |
| 89 |  |  | void glass clear_glass |
| 90 |  |  | 0 |
| 91 |  |  | 0 |
| 92 |  |  | 3 $wtrans |
| 93 |  |  |  |
| 94 |  |  | clear_glass polygon window |
| 95 |  |  | 0 |
| 96 |  |  | 0 |
| 97 |  |  | 12 |
| 98 |  |  | 0       0       0 |
| 99 |  |  | 0       0       $wheight |
| 100 |  |  | $wwidth 0       $wheight |
| 101 |  |  | $wwidth 0       0 |
| 102 |  |  |  |
| 103 |  |  | void $material blind_upmat |
| 104 |  |  | 0 |
| 105 |  |  | 0 |
| 106 |  |  | 5 $ucolor $uspec $urough |
| 107 |  |  | _EOF_ |
| 108 |  |  | if ( $status ) goto error |
| 109 |  |  |  |
| 110 |  |  | #       Blinds |
| 111 |  |  | genblinds blind_upmat blind_up $bdepth $wwidth $wheight \ |
| 112 |  |  | `ev "ceil($wheight/$bspac)"` $bangle -r $brcurv \ |
| 113 |  |  | | xform -t $gap -$wwidth 1e-4 -rz 90 >> $descrip |
| 114 |  |  | if ( $status ) goto error |
| 115 |  |  | if ( $?dcolor ) then |
| 116 |  |  | cat >> $descrip <<_EOF_ |
| 117 |  |  |  |
| 118 |  |  | void $material blind_dnmat |
| 119 |  |  | 0 |
| 120 |  |  | 0 |
| 121 |  |  | 5 $dcolor $dspec $drough |
| 122 |  |  | _EOF_ |
| 123 |  |  | genblinds blind_dnmat blind_down $bdepth $wwidth $wheight \ |
| 124 |  |  | `ev "ceil($wheight/$bspac)"` $bangle -r $brcurv \ |
| 125 |  |  | | xform -t $gap -$wwidth 0 -rz 90 >> $descrip |
| 126 |  |  | if ( $status ) goto error |
| 127 |  |  | endif |
| 128 |  |  |  |
| 129 |  |  | #       Make sky |
| 130 |  |  | switch ($sky) |
| 131 |  |  | case sun*: |
| 132 |  |  | set skysw = +s |
| 133 |  |  | breaksw |
| 134 |  |  | case clear: |
| 135 |  |  | set skysw = -s |
| 136 |  |  | breaksw |
| 137 |  |  | case cloud*: |
| 138 |  |  | set skysw = -c |
| 139 |  |  | breaksw |
| 140 |  |  | endsw |
| 141 |  |  | dosky: |
| 142 |  |  | gensky $month $day $hour $skysw -a $lat -o $long -m $mer -g $grefl \ |
| 143 |  |  | | xform -rz `ev "-($worient)"` > $skydesc |
| 144 |  |  | if ( $skysw == +s ) then |
| 145 |  |  | if ( `sed -n 13p $skydesc | rcalc -e '$1=if($3,-1,1)'` < 0 ) then |
| 146 |  |  | set skysw = -s |
| 147 |  |  | goto dosky |
| 148 |  |  | endif |
| 149 |  |  | endif |
| 150 |  |  | cat >> $skydesc <<_EOF_ |
| 151 |  |  |  |
| 152 |  |  | skyfunc glow skyglow |
| 153 |  |  | 0 |
| 154 |  |  | 0 |
| 155 |  |  | 4 1 1 1 0 |
| 156 |  |  |  |
| 157 |  |  | skyglow source sky |
| 158 |  |  | 0 |
| 159 |  |  | 0 |
| 160 |  |  | 4 0 -1 0 180 |
| 161 |  |  | _EOF_ |
| 162 |  |  |  |
| 163 |  |  | #       Make distribution |
| 164 |  |  | oconv $skydesc $descrip > $distoct |
| 165 |  |  | if ( $status ) goto error |
| 166 |  |  | echo 2 5 85 9 0 340 18 > $distrib |
| 167 |  |  | makedist -h -d -x1 0 1 0 -x2 0 0 1 -x3 1 0 0 -alpha 5-85:10 -beta 0-340:20 \ |
| 168 |  |  | -tw $bspac -th $bspac -td `ev "2*($bdepth+$gap)"` \ |
| 169 |  |  | -tc `ev "$wwidth/2" "$bdepth+$gap" "$wheight/2"` \ |
| 170 |  |  | -ab 2 -aa .1 -ad 64 -as 64 \ |
| 171 |  |  | -x 16 -y 16 $distoct >> $distrib |
| 172 |  |  | if ( $status ) goto error |
| 173 |  |  |  |
| 174 |  |  | set wsgrid = (`ev "floor(sqrt($nsources*$wwidth/$wheight)+.5)" "floor(sqrt($nsources*$wheight/$wwidth)+.5)"`) |
| 175 |  |  | @ nsources = $wsgrid[1] * $wsgrid[2] |
| 176 |  |  | #       Print header |
| 177 |  |  | cat <<_EOF_ |
| 178 |  |  | # |
| 179 |  |  | #  Window with venetian blinds |
| 180 |  |  | #  Created from $input `date` |
| 181 |  |  | # |
| 182 |  |  | #       Window orientation (degrees from south):        $worient |
| 183 |  |  | #       Window height:                                  $wheight |
| 184 |  |  | #       Window width:                                   $wwidth |
| 185 |  |  | #       Window transmission:                            $wtrans |
| 186 |  |  | #       Blind depth:                                    $bdepth |
| 187 |  |  | #       Blind spacing:                                  $bspac |
| 188 |  |  | #       Gap to window:                                  $gap |
| 189 |  |  | #       Blind curvature radius:                         $brcurv |
| 190 |  |  | #       Blind inclination (degrees altitude):           $bangle |
| 191 |  |  | #       Blind material:                                 $material |
| 192 |  |  | #       Up side color:                                  $ucolor |
| 193 |  |  | #       Up side specularity:                            $uspec |
| 194 |  |  | #       Up side roughness:                              $urough |
| 195 |  |  | _EOF_ |
| 196 |  |  | if ( $?dcolor ) then |
| 197 |  |  | cat <<_EOF_ |
| 198 |  |  | #       Down side color:                                $dcolor |
| 199 |  |  | #       Down side specularity:                          $dspec |
| 200 |  |  | #       Down side roughness:                            $drough |
| 201 |  |  | _EOF_ |
| 202 |  |  | else |
| 203 |  |  | echo \#\        Down side same as up |
| 204 |  |  | endif |
| 205 |  |  | cat <<_EOF_ |
| 206 |  |  | #       Latitude (degrees):                             $lat |
| 207 |  |  | #       Longitude (degrees):                            $long |
| 208 |  |  | #       Standard Meridian (degrees):                    $mer |
| 209 |  |  | #       Month Day Hour:                                 $month $day $hour |
| 210 |  |  | #       Ground plane reflectance:                       $grefl |
| 211 |  |  | #       Sky condition:                                  $sky |
| 212 |  |  | #       Number of window sources:                       $nsources |
| 213 |  |  | # |
| 214 |  |  | _EOF_ |
| 215 |  |  |  |
| 216 |  |  | #       Send sources |
| 217 |  |  | xform -e -rz $worient <<_EOF_ |
| 218 |  |  |  |
| 219 |  |  | void brightdata wdistrib |
| 220 |  |  | 10 noop $distrib source.cal src_theta src_phi -rx 90 -ry -90 -mx |
| 221 |  |  | 0 |
| 222 |  |  | 0 |
| 223 |  |  |  |
| 224 |  |  | wdistrib illum willum |
| 225 |  |  | 0 |
| 226 |  |  | 0 |
| 227 |  |  | 3 1 1 1 |
| 228 |  |  |  |
| 229 |  |  | !gensurf willum wsource "$wwidth*t" $bdepth "$wheight*s" $wsgrid[2] $wsgrid[1] |
| 230 |  |  | _EOF_ |
| 231 |  |  | if ( $status ) goto error |
| 232 |  |  |  |
| 233 |  |  | #       Send window |
| 234 |  |  | xform -rz $worient $descrip |
| 235 |  |  | if ( $status ) goto error |
| 236 |  |  |  |
| 237 |  |  | #       All done, print and exit |
| 238 |  |  | rm -f $remove |
| 239 |  |  | exit 0 |
| 240 |  |  |  |
| 241 |  |  | #       Error exit |
| 242 |  |  | error: |
| 243 |  |  | rm -f $removerr |
| 244 |  |  | exit 1 |
