root/radiance/src/gen/gensurf.c
Revision: 2.27
Committed: Sun Jun 14 03:54:23 2020 UTC (5 years, 4 months ago) by greg
Changes since 2.26: +5 -4 lines
Fixed bug with valid() function and surface normals
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.27 static const char RCSid[] = "$Id: gensurf.c,v 2.26 2019/12/07 02:21:42 greg Exp $";
3 greg 1.1 #endif
4 greg 1.2 /*
5 greg 1.1 * gensurf.c - program to generate functional surfaces
6     *
7     * Parametric functions x(s,t), y(s,t) and z(s,t)
8     * specify the surface, which is tesselated into an m by n
9     * array of paired triangles.
10     * The surface normal is defined by the right hand
11     * rule applied to (s,t).
12     *
13     * 4/3/87
14 greg 2.6 *
15     * 4/16/02 Added conditional vertex output
16 greg 1.1 */
17
18 greg 2.14 #include "standard.h"
19 schorsch 2.15
20     #include "paths.h"
21 greg 2.16 #include "resolu.h"
22     #include "rterror.h"
23 schorsch 2.13 #include "calcomp.h"
24 greg 1.1
25 greg 2.6 char XNAME[] = "X`SYS"; /* x function name */
26     char YNAME[] = "Y`SYS"; /* y function name */
27     char ZNAME[] = "Z`SYS"; /* z function name */
28
29     char VNAME[] = "valid"; /* valid vertex name */
30 greg 1.1
31 greg 1.4 #define ABS(x) ((x)>=0 ? (x) : -(x))
32
33 greg 2.9 #define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY)
34
35 greg 1.3 #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
36 greg 1.1
37 greg 2.18 char vformat[] = "%18.12g %18.12g %18.12g\n";
38 greg 2.19 char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal";
39 greg 1.3 char texname[] = "Phong";
40 greg 1.1
41 greg 1.3 int smooth = 0; /* apply smoothing? */
42 greg 2.7 int objout = 0; /* output .OBJ format? */
43 greg 1.1
44 greg 1.3 char *modname, *surfname;
45 greg 1.1
46 greg 2.2 /* recorded data flags */
47     #define HASBORDER 01
48     #define TRIPLETS 02
49     /* a data structure */
50     struct {
51     int flags; /* data type */
52     short m, n; /* number of s and t values */
53 schorsch 2.11 RREAL *data; /* the data itself, s major sort */
54 greg 2.2 } datarec; /* our recorded data */
55 greg 1.3
56 schorsch 2.13 /* XXX this is redundant with rt/noise3.c, should go to a library */
57 greg 2.2 double l_hermite(), l_bezier(), l_bspline(), l_dataval();
58
59 greg 1.3 typedef struct {
60 greg 2.7 int valid; /* point is valid (vertex number) */
61 greg 2.21 int nvalid; /* normal is valid */
62 greg 1.3 FVECT p; /* vertex position */
63     FVECT n; /* average normal */
64 schorsch 2.11 RREAL uv[2]; /* (u,v) position */
65 greg 1.3 } POINT;
66
67 greg 2.23 int nverts = 0; /* vertex output count */
68     int nnorms = 0; /* normal output count */
69 greg 1.3
70 schorsch 2.13 void loaddata(char *file, int m, int n, int pointsize);
71     double l_dataval(char *nam);
72     void putobjrow(POINT *rp, int n);
73 greg 2.23 void putobjvert(POINT *p);
74 schorsch 2.13 void putsquare(POINT *p0, POINT *p1, POINT *p2, POINT *p3);
75     void comprow(double s, POINT *row, int siz);
76     void compnorms(POINT *r0, POINT *r1, POINT *r2, int siz);
77     int norminterp(FVECT resmat[4], POINT *p0, POINT *p1, POINT *p2, POINT *p3);
78
79
80     int
81 greg 1.1 main(argc, argv)
82     int argc;
83     char *argv[];
84     {
85 greg 1.3 POINT *row0, *row1, *row2, *rp;
86 greg 1.1 int i, j, m, n;
87     char stmp[256];
88
89 greg 2.24 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
90     esupport &= ~(E_OUTCHAN|E_INCHAN);
91 greg 1.13 varset("PI", ':', PI);
92 greg 1.14 funset("hermite", 5, ':', l_hermite);
93     funset("bezier", 5, ':', l_bezier);
94     funset("bspline", 5, ':', l_bspline);
95 greg 1.1
96     if (argc < 8)
97     goto userror;
98
99     for (i = 8; i < argc; i++)
100     if (!strcmp(argv[i], "-e"))
101 greg 1.10 scompile(argv[++i], NULL, 0);
102 greg 2.25 else if (!strcmp(argv[i], "-f")) {
103     char *fpath = getpath(argv[++i], getrlibpath(), 0);
104     if (fpath == NULL) {
105     fprintf(stderr, "%s: cannot find file '%s'\n",
106     argv[0], argv[i]);
107     quit(1);
108     }
109     fcompile(fpath);
110     } else if (!strcmp(argv[i], "-s"))
111 greg 1.3 smooth++;
112 greg 2.7 else if (!strcmp(argv[i], "-o"))
113     objout++;
114 greg 1.1 else
115     goto userror;
116
117 greg 1.3 modname = argv[1];
118     surfname = argv[2];
119 greg 2.26 m = eval(argv[6]) + .5;
120     n = eval(argv[7]) + .5;
121 greg 1.1 if (m <= 0 || n <= 0)
122     goto userror;
123 greg 2.2 if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
124     funset(ZNAME, 2, ':', l_dataval);
125     if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
126     loaddata(argv[5], m, n, 3);
127     funset(XNAME, 2, ':', l_dataval);
128     funset(YNAME, 2, ':', l_dataval);
129     } else {
130     loaddata(argv[5], m, n, 1);
131     sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
132     scompile(stmp, NULL, 0);
133     sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
134     scompile(stmp, NULL, 0);
135     }
136     } else {
137     sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
138     scompile(stmp, NULL, 0);
139     sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
140     scompile(stmp, NULL, 0);
141     sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
142     scompile(stmp, NULL, 0);
143     }
144 greg 1.4 row0 = (POINT *)malloc((n+3)*sizeof(POINT));
145     row1 = (POINT *)malloc((n+3)*sizeof(POINT));
146     row2 = (POINT *)malloc((n+3)*sizeof(POINT));
147 greg 1.3 if (row0 == NULL || row1 == NULL || row2 == NULL) {
148 greg 1.1 fprintf(stderr, "%s: out of memory\n", argv[0]);
149     quit(1);
150     }
151 greg 1.4 row0++; row1++; row2++;
152 greg 1.3 /* print header */
153 greg 2.16 fputs("# ", stdout);
154     printargs(argc, argv, stdout);
155 greg 1.9 eclock = 0;
156 greg 1.4 /* initialize */
157     comprow(-1.0/m, row0, n);
158 greg 1.3 comprow(0.0, row1, n);
159     comprow(1.0/m, row2, n);
160 greg 1.4 compnorms(row0, row1, row2, n);
161 greg 2.8 if (objout) {
162     printf("\nusemtl %s\n\n", modname);
163 greg 2.7 putobjrow(row1, n);
164 greg 2.8 }
165 greg 1.3 /* for each row */
166 greg 1.1 for (i = 0; i < m; i++) {
167     /* compute next row */
168 greg 1.3 rp = row0;
169 greg 1.1 row0 = row1;
170 greg 1.3 row1 = row2;
171     row2 = rp;
172 greg 1.4 comprow((double)(i+2)/m, row2, n);
173     compnorms(row0, row1, row2, n);
174 greg 2.7 if (objout)
175     putobjrow(row1, n);
176 greg 1.1
177     for (j = 0; j < n; j++) {
178 greg 2.6 int orient = (j & 1);
179 greg 1.3 /* put polygons */
180 greg 2.7 if (!(row0[j].valid && row1[j+1].valid))
181 greg 2.6 orient = 1;
182 greg 2.7 else if (!(row1[j].valid && row0[j+1].valid))
183 greg 2.6 orient = 0;
184     if (orient)
185 greg 1.3 putsquare(&row0[j], &row1[j],
186     &row0[j+1], &row1[j+1]);
187     else
188     putsquare(&row1[j], &row1[j+1],
189     &row0[j], &row0[j+1]);
190 greg 1.1 }
191     }
192
193 schorsch 2.13 return 0;
194 greg 1.1
195     userror:
196     fprintf(stderr, "Usage: %s material name ", argv[0]);
197 greg 2.17 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-o][-e expr][-f file]\n");
198 schorsch 2.13 return 1;
199 greg 2.2 }
200
201
202 schorsch 2.13 void
203     loaddata( /* load point data from file */
204     char *file,
205     int m,
206     int n,
207     int pointsize
208     )
209 greg 2.2 {
210     FILE *fp;
211     char word[64];
212 greg 2.22 int size;
213     RREAL *dp;
214 greg 2.2
215     datarec.flags = HASBORDER; /* assume border values */
216 greg 2.3 datarec.m = m+1;
217     datarec.n = n+1;
218     size = datarec.m*datarec.n*pointsize;
219 greg 2.2 if (pointsize == 3)
220     datarec.flags |= TRIPLETS;
221 schorsch 2.11 dp = (RREAL *)malloc(size*sizeof(RREAL));
222 greg 2.2 if ((datarec.data = dp) == NULL) {
223     fputs("Out of memory\n", stderr);
224     exit(1);
225     }
226     if (!strcmp(file, "-")) {
227     file = "<stdin>";
228     fp = stdin;
229     } else if ((fp = fopen(file, "r")) == NULL) {
230     fputs(file, stderr);
231     fputs(": cannot open\n", stderr);
232     exit(1);
233     }
234     while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
235     if (!isflt(word)) {
236     fprintf(stderr, "%s: garbled data value: %s\n",
237     file, word);
238     exit(1);
239     }
240     *dp++ = atof(word);
241     size--;
242     }
243     if (size == (m+n+1)*pointsize) { /* no border after all */
244 greg 2.20 dp = (RREAL *)realloc(datarec.data,
245 schorsch 2.11 m*n*pointsize*sizeof(RREAL));
246 greg 2.2 if (dp != NULL)
247     datarec.data = dp;
248     datarec.flags &= ~HASBORDER;
249 greg 2.3 datarec.m = m;
250     datarec.n = n;
251 greg 2.2 size = 0;
252     }
253 greg 2.3 if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
254     fgetword(word, sizeof(word), fp) != NULL) {
255 greg 2.2 fputs(file, stderr);
256     fputs(": bad number of data points\n", stderr);
257     exit(1);
258     }
259     fclose(fp);
260     }
261
262
263     double
264 schorsch 2.13 l_dataval( /* return recorded data value */
265     char *nam
266     )
267 greg 2.2 {
268     double u, v;
269 greg 2.22 int i, j;
270     RREAL *dp;
271 greg 2.2 double d00, d01, d10, d11;
272     /* compute coordinates */
273     u = argument(1); v = argument(2);
274     if (datarec.flags & HASBORDER) {
275 greg 2.3 i = u *= datarec.m-1;
276     j = v *= datarec.n-1;
277 greg 2.2 } else {
278 greg 2.3 i = u = u*datarec.m - .5;
279     j = v = v*datarec.n - .5;
280 greg 2.2 }
281     if (i < 0) i = 0;
282     else if (i > datarec.m-2) i = datarec.m-2;
283     if (j < 0) j = 0;
284     else if (j > datarec.n-2) j = datarec.n-2;
285     /* compute value */
286     if (datarec.flags & TRIPLETS) {
287 greg 2.3 dp = datarec.data + 3*(j*datarec.m + i);
288     if (nam == ZNAME)
289     dp += 2;
290     else if (nam == YNAME)
291 greg 2.2 dp++;
292     d00 = dp[0]; d01 = dp[3];
293 greg 2.3 dp += 3*datarec.m;
294 greg 2.2 d10 = dp[0]; d11 = dp[3];
295     } else {
296 greg 2.3 dp = datarec.data + j*datarec.m + i;
297 greg 2.2 d00 = dp[0]; d01 = dp[1];
298 greg 2.3 dp += datarec.m;
299 greg 2.2 d10 = dp[0]; d11 = dp[1];
300     }
301     /* bilinear interpolation */
302     return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
303 greg 1.1 }
304
305
306 schorsch 2.13 void
307     putobjrow( /* output vertex row to .OBJ */
308 greg 2.22 POINT *rp,
309 schorsch 2.13 int n
310     )
311 greg 2.7 {
312     for ( ; n-- >= 0; rp++) {
313     if (!rp->valid)
314     continue;
315     fputs("v ", stdout);
316 greg 2.9 pvect(rp->p);
317 greg 2.21 if (smooth && !ZEROVECT(rp->n)) {
318 greg 2.7 printf("\tvn %.9g %.9g %.9g\n",
319     rp->n[0], rp->n[1], rp->n[2]);
320 greg 2.21 rp->nvalid = ++nnorms;
321     } else
322     rp->nvalid = 0;
323 greg 2.7 printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
324     rp->valid = ++nverts;
325     }
326     }
327
328
329 schorsch 2.13 void
330 greg 2.23 putobjvert( /* put out OBJ vertex index triplet */
331     POINT *p
332     )
333     {
334     int pti = p->valid ? p->valid-nverts-1 : 0;
335     int ni = p->nvalid ? p->nvalid-nnorms-1 : 0;
336
337     printf(" %d/%d/%d", pti, pti, ni);
338     }
339
340
341     void
342 schorsch 2.13 putsquare( /* put out a square */
343     POINT *p0,
344     POINT *p1,
345     POINT *p2,
346     POINT *p3
347     )
348 greg 1.3 {
349     static int nout = 0;
350     FVECT norm[4];
351     int axis;
352     FVECT v1, v2, vc1, vc2;
353     int ok1, ok2;
354     /* compute exact normals */
355 greg 2.7 ok1 = (p0->valid && p1->valid && p2->valid);
356 greg 2.6 if (ok1) {
357 greg 2.9 VSUB(v1, p1->p, p0->p);
358     VSUB(v2, p2->p, p0->p);
359 greg 2.6 fcross(vc1, v1, v2);
360     ok1 = (normalize(vc1) != 0.0);
361     }
362 greg 2.7 ok2 = (p1->valid && p2->valid && p3->valid);
363 greg 2.6 if (ok2) {
364 greg 2.9 VSUB(v1, p2->p, p3->p);
365     VSUB(v2, p1->p, p3->p);
366 greg 2.6 fcross(vc2, v1, v2);
367     ok2 = (normalize(vc2) != 0.0);
368     }
369 greg 1.3 if (!(ok1 | ok2))
370     return;
371 greg 2.7 if (objout) { /* output .OBJ faces */
372     if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
373 greg 2.23 putc('f', stdout);
374     putobjvert(p0); putobjvert(p1);
375     putobjvert(p3); putobjvert(p2);
376     putc('\n', stdout);
377 greg 2.7 return;
378     }
379 greg 2.23 if (ok1) {
380     putc('f', stdout);
381     putobjvert(p0); putobjvert(p1); putobjvert(p2);
382     putc('\n', stdout);
383     }
384     if (ok2) {
385     putc('f', stdout);
386     putobjvert(p2); putobjvert(p1); putobjvert(p3);
387     putc('\n', stdout);
388     }
389 greg 2.7 return;
390     }
391 greg 1.3 /* compute normal interpolation */
392     axis = norminterp(norm, p0, p1, p2, p3);
393
394     /* put out quadrilateral? */
395     if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
396     printf("\n%s ", modname);
397     if (axis != -1) {
398 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
399 greg 1.3 printf("0\n13\t%d\n", axis);
400     pvect(norm[0]);
401     pvect(norm[1]);
402     pvect(norm[2]);
403     fvsum(v1, norm[3], vc1, -0.5);
404     fvsum(v1, v1, vc2, -0.5);
405     pvect(v1);
406     printf("\n%s ", texname);
407     }
408     printf("polygon %s.%d\n", surfname, ++nout);
409     printf("0\n0\n12\n");
410     pvect(p0->p);
411     pvect(p1->p);
412     pvect(p3->p);
413     pvect(p2->p);
414     return;
415     }
416     /* put out triangles? */
417     if (ok1) {
418     printf("\n%s ", modname);
419     if (axis != -1) {
420 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
421 greg 1.3 printf("0\n13\t%d\n", axis);
422     pvect(norm[0]);
423     pvect(norm[1]);
424     pvect(norm[2]);
425     fvsum(v1, norm[3], vc1, -1.0);
426     pvect(v1);
427     printf("\n%s ", texname);
428     }
429     printf("polygon %s.%d\n", surfname, ++nout);
430     printf("0\n0\n9\n");
431     pvect(p0->p);
432     pvect(p1->p);
433     pvect(p2->p);
434     }
435     if (ok2) {
436     printf("\n%s ", modname);
437     if (axis != -1) {
438 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
439 greg 1.3 printf("0\n13\t%d\n", axis);
440     pvect(norm[0]);
441     pvect(norm[1]);
442     pvect(norm[2]);
443     fvsum(v2, norm[3], vc2, -1.0);
444     pvect(v2);
445     printf("\n%s ", texname);
446     }
447     printf("polygon %s.%d\n", surfname, ++nout);
448     printf("0\n0\n9\n");
449     pvect(p2->p);
450     pvect(p1->p);
451     pvect(p3->p);
452     }
453     }
454
455
456 schorsch 2.13 void
457     comprow( /* compute row of values */
458     double s,
459 greg 2.22 POINT *row,
460 schorsch 2.13 int siz
461     )
462 greg 1.1 {
463 greg 1.4 double st[2];
464 greg 1.8 int end;
465 greg 2.6 int checkvalid;
466 greg 2.22 int i;
467 greg 1.8
468     if (smooth) {
469     i = -1; /* compute one past each end */
470     end = siz+1;
471     } else {
472     if (s < -FTINY || s > 1.0+FTINY)
473     return;
474     i = 0;
475     end = siz;
476     }
477 greg 1.1 st[0] = s;
478 greg 2.6 checkvalid = (fundefined(VNAME) == 2);
479 greg 1.8 while (i <= end) {
480 greg 1.4 st[1] = (double)i/siz;
481 greg 2.6 if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
482     row[i].valid = 0;
483     row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
484 greg 2.7 row[i].uv[0] = row[i].uv[1] = 0.0;
485 greg 2.6 } else {
486     row[i].valid = 1;
487     row[i].p[0] = funvalue(XNAME, 2, st);
488     row[i].p[1] = funvalue(YNAME, 2, st);
489     row[i].p[2] = funvalue(ZNAME, 2, st);
490 greg 2.7 row[i].uv[0] = st[0];
491     row[i].uv[1] = st[1];
492 greg 2.6 }
493 greg 1.8 i++;
494 greg 1.1 }
495 greg 1.3 }
496
497
498 schorsch 2.13 void
499     compnorms( /* compute row of averaged normals */
500 greg 2.22 POINT *r0,
501     POINT *r1,
502     POINT *r2,
503 schorsch 2.13 int siz
504     )
505 greg 1.3 {
506 greg 1.11 FVECT v1, v2;
507 greg 1.3
508     if (!smooth) /* not needed if no smoothing */
509     return;
510 greg 2.6 /* compute row 1 normals */
511 greg 1.4 while (siz-- >= 0) {
512 greg 2.6 if (!r1[0].valid)
513 greg 2.27 goto skip;
514 greg 2.6 if (!r0[0].valid) {
515     if (!r2[0].valid) {
516     r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
517 greg 2.27 goto skip;
518 greg 2.6 }
519     fvsum(v1, r2[0].p, r1[0].p, -1.0);
520     } else if (!r2[0].valid)
521     fvsum(v1, r1[0].p, r0[0].p, -1.0);
522     else
523     fvsum(v1, r2[0].p, r0[0].p, -1.0);
524     if (!r1[-1].valid) {
525     if (!r1[1].valid) {
526     r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
527 greg 2.27 goto skip;
528 greg 2.6 }
529     fvsum(v2, r1[1].p, r1[0].p, -1.0);
530     } else if (!r1[1].valid)
531     fvsum(v2, r1[0].p, r1[-1].p, -1.0);
532     else
533     fvsum(v2, r1[1].p, r1[-1].p, -1.0);
534 greg 1.3 fcross(r1[0].n, v1, v2);
535     normalize(r1[0].n);
536 greg 2.27 skip:
537 greg 1.3 r0++; r1++; r2++;
538     }
539     }
540
541
542     int
543 schorsch 2.13 norminterp( /* compute normal interpolation */
544 greg 2.22 FVECT resmat[4],
545 schorsch 2.13 POINT *p0,
546     POINT *p1,
547     POINT *p2,
548     POINT *p3
549     )
550 greg 1.3 {
551     #define u ((ax+1)%3)
552     #define v ((ax+2)%3)
553
554 greg 2.22 int ax;
555 greg 1.12 MAT4 eqnmat;
556 greg 1.3 FVECT v1;
557 greg 2.22 int i, j;
558 greg 1.3
559     if (!smooth) /* no interpolation if no smoothing */
560     return(-1);
561     /* find dominant axis */
562     VCOPY(v1, p0->n);
563     fvsum(v1, v1, p1->n, 1.0);
564     fvsum(v1, v1, p2->n, 1.0);
565     fvsum(v1, v1, p3->n, 1.0);
566 greg 1.4 ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
567     ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
568 greg 1.3 /* assign equation matrix */
569     eqnmat[0][0] = p0->p[u]*p0->p[v];
570     eqnmat[0][1] = p0->p[u];
571     eqnmat[0][2] = p0->p[v];
572     eqnmat[0][3] = 1.0;
573     eqnmat[1][0] = p1->p[u]*p1->p[v];
574     eqnmat[1][1] = p1->p[u];
575     eqnmat[1][2] = p1->p[v];
576     eqnmat[1][3] = 1.0;
577     eqnmat[2][0] = p2->p[u]*p2->p[v];
578     eqnmat[2][1] = p2->p[u];
579     eqnmat[2][2] = p2->p[v];
580     eqnmat[2][3] = 1.0;
581     eqnmat[3][0] = p3->p[u]*p3->p[v];
582     eqnmat[3][1] = p3->p[u];
583     eqnmat[3][2] = p3->p[v];
584     eqnmat[3][3] = 1.0;
585     /* invert matrix (solve system) */
586 greg 2.5 if (!invmat4(eqnmat, eqnmat))
587 greg 1.3 return(-1); /* no solution */
588     /* compute result matrix */
589     for (j = 0; j < 4; j++)
590     for (i = 0; i < 3; i++)
591 greg 1.4 resmat[j][i] = eqnmat[j][0]*p0->n[i] +
592     eqnmat[j][1]*p1->n[i] +
593     eqnmat[j][2]*p2->n[i] +
594     eqnmat[j][3]*p3->n[i];
595 greg 1.3 return(ax);
596
597     #undef u
598     #undef v
599 greg 1.1 }
600
601
602     double
603 greg 2.12 l_hermite(char *nm)
604 greg 1.1 {
605     double t;
606
607     t = argument(5);
608     return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
609     argument(2)*(-2.0*t+3.0)*t*t +
610     argument(3)*((t-2.0)*t+1.0)*t +
611     argument(4)*(t-1.0)*t*t );
612 greg 1.6 }
613
614
615     double
616 greg 2.12 l_bezier(char *nm)
617 greg 1.6 {
618     double t;
619
620     t = argument(5);
621     return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
622     argument(2) * 3.*t*(1.+t*(-2.+t)) +
623     argument(3) * 3.*t*t*(1.-t) +
624     argument(4) * t*t*t );
625 greg 1.7 }
626
627
628     double
629 greg 2.12 l_bspline(char *nm)
630 greg 1.7 {
631     double t;
632
633     t = argument(5);
634     return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
635     argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
636     argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
637     argument(4) * (1./6.*t*t*t) );
638 greg 1.1 }
