root/radiance/src/gen/gensky.c
Revision: 2.13
Committed: Fri Nov 5 17:25:34 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.12: +78 -31 lines
added intermediate sky and changed +c option to -u
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * gensky.c - program to generate sky functions.
9 * Our zenith is along the Z-axis, the X-axis
10 * points east, and the Y-axis points north.
11 * Radiance is in watts/steradian/sq. meter.
12 *
13 * 3/26/86
14 */
15
16 #include <stdio.h>
17
18 #include <math.h>
19
20 #include "color.h"
21
22 extern char *strcpy(), *strcat(), *malloc();
23 extern double stadj(), sdec(), sazi(), salt();
24
25 #define PI 3.141592654
26
27 #define DOT(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2])
28
29 #define S_CLEAR 1
30 #define S_OVER 2
31 #define S_UNIF 3
32 #define S_INTER 4
33
34 #define overcast (skytype==S_OVER|skytype==S_UNIF)
35
36 double normsc();
37 /* sun calculation constants */
38 extern double s_latitude;
39 extern double s_longitude;
40 extern double s_meridian;
41 /* required values */
42 int month, day; /* date */
43 double hour; /* time */
44 int tsolar; /* 0=standard, 1=solar */
45 double altitude, azimuth; /* or solar angles */
46 /* default values */
47 int skytype = S_CLEAR; /* sky type */
48 int dosun = 1;
49 double zenithbr = 0.0;
50 int u_zenith = 0; /* -1=irradiance, 1=radiance */
51 double turbidity = 2.75;
52 double gprefl = 0.2;
53 /* computed values */
54 double sundir[3];
55 double groundbr;
56 double F2;
57 double solarbr = 0.0;
58 int u_solar = 0; /* -1=irradiance, 1=radiance */
59
60 char *progname;
61 char errmsg[128];
62
63
64 main(argc, argv)
65 int argc;
66 char *argv[];
67 {
68 int i;
69
70 progname = argv[0];
71 if (argc == 2 && !strcmp(argv[1], "-defaults")) {
72 printdefaults();
73 exit(0);
74 }
75 if (argc < 4)
76 userror("arg count");
77 if (!strcmp(argv[1], "-ang")) {
78 altitude = atof(argv[2]) * (PI/180);
79 azimuth = atof(argv[3]) * (PI/180);
80 month = 0;
81 } else {
82 month = atoi(argv[1]);
83 if (month < 1 || month > 12)
84 userror("bad month");
85 day = atoi(argv[2]);
86 if (day < 1 || day > 31)
87 userror("bad day");
88 hour = atof(argv[3]);
89 if (hour < 0 || hour >= 24)
90 userror("bad hour");
91 tsolar = argv[3][0] == '+';
92 }
93 for (i = 4; i < argc; i++)
94 if (argv[i][0] == '-' || argv[i][0] == '+')
95 switch (argv[i][1]) {
96 case 's':
97 skytype = S_CLEAR;
98 dosun = argv[i][0] == '+';
99 break;
100 case 'r':
101 case 'R':
102 u_solar = argv[i][1]=='R' ? -1 : 1;
103 solarbr = atof(argv[++i]);
104 break;
105 case 'c':
106 skytype = S_OVER;
107 dosun = 0;
108 break;
109 case 'u':
110 skytype = S_UNIF;
111 dosun = 0;
112 break;
113 case 'i':
114 skytype = S_INTER;
115 dosun = argv[i][0] == '+';
116 break;
117 case 't':
118 turbidity = atof(argv[++i]);
119 break;
120 case 'b':
121 case 'B':
122 u_zenith = argv[i][1]=='B' ? -1 : 1;
123 zenithbr = atof(argv[++i]);
124 break;
125 case 'g':
126 gprefl = atof(argv[++i]);
127 break;
128 case 'a':
129 s_latitude = atof(argv[++i]) * (PI/180);
130 break;
131 case 'o':
132 s_longitude = atof(argv[++i]) * (PI/180);
133 break;
134 case 'm':
135 s_meridian = atof(argv[++i]) * (PI/180);
136 break;
137 default:
138 sprintf(errmsg, "unknown option: %s", argv[i]);
139 userror(errmsg);
140 }
141 else
142 userror("bad option");
143
144 if (fabs(s_meridian-s_longitude) > 30*PI/180)
145 fprintf(stderr,
146 "%s: warning: %.1f hours btwn. standard meridian and longitude\n",
147 progname, (s_longitude-s_meridian)*12/PI);
148
149 printhead(argc, argv);
150
151 computesky();
152 printsky();
153 }
154
155
156 computesky() /* compute sky parameters */
157 {
158 double normfactor;
159 /* compute solar direction */
160 if (month) { /* from date and time */
161 int jd;
162 double sd, st;
163
164 jd = jdate(month, day); /* Julian date */
165 sd = sdec(jd); /* solar declination */
166 if (tsolar) /* solar time */
167 st = hour;
168 else
169 st = hour + stadj(jd);
170 altitude = salt(sd, st);
171 azimuth = sazi(sd, st);
172 printf("# Solar altitude and azimuth: %.1f %.1f\n",
173 180./PI*altitude, 180./PI*azimuth);
174 }
175 if (!overcast && altitude > 87.*PI/180.) {
176 fprintf(stderr,
177 "%s: warning - sun too close to zenith, reducing altitude to 87 degrees\n",
178 progname);
179 printf(
180 "# warning - sun too close to zenith, reducing altitude to 87 degrees\n");
181 altitude = 87.*PI/180.;
182 }
183 sundir[0] = -sin(azimuth)*cos(altitude);
184 sundir[1] = -cos(azimuth)*cos(altitude);
185 sundir[2] = sin(altitude);
186
187 /* Compute normalization factor */
188 switch (skytype) {
189 case S_UNIF:
190 normfactor = 1.0;
191 break;
192 case S_OVER:
193 normfactor = 0.777778;
194 break;
195 case S_CLEAR:
196 F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) +
197 0.45*sundir[2]*sundir[2]);
198 normfactor = normsc()/F2/PI;
199 break;
200 case S_INTER:
201 F2 = (2.739 + .9891*sin(.3119+2.6*altitude)) *
202 exp(-(PI/2.0-altitude)*(.4441+1.48*altitude));
203 normfactor = normsc()/F2/PI;
204 break;
205 }
206 /* Compute zenith brightness */
207 if (u_zenith == -1)
208 zenithbr /= normfactor*PI;
209 else if (u_zenith == 0) {
210 if (overcast)
211 zenithbr = 8.6*sundir[2] + .123;
212 else
213 zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38;
214 if (skytype == S_INTER)
215 zenithbr = (zenithbr + 8.6*sundir[2] + .123)/2.0;
216 if (zenithbr < 0.0)
217 zenithbr = 0.0;
218 else
219 zenithbr *= 1000.0/SKYEFFICACY;
220 }
221 /* Compute horizontal radiance */
222 groundbr = zenithbr*normfactor;
223 printf("# Ground ambient level: %.1f\n", groundbr);
224 if (sundir[2] > 0.0 && (!u_solar || solarbr > 0.0)) {
225 if (u_solar == -1)
226 solarbr /= 6e-5*sundir[2];
227 else if (u_solar == 0) {
228 solarbr = 1.5e9/SUNEFFICACY *
229 (1.147 - .147/(sundir[2]>.16?sundir[2]:.16));
230 if (skytype == S_INTER)
231 solarbr *= 0.15; /* fudge factor! */
232 }
233 groundbr += 6e-5/PI*solarbr*sundir[2];
234 } else
235 dosun = 0;
236 groundbr *= gprefl;
237 }
238
239
240 printsky() /* print out sky */
241 {
242 if (dosun) {
243 printf("\nvoid light solar\n");
244 printf("0\n0\n");
245 printf("3 %.2e %.2e %.2e\n", solarbr, solarbr, solarbr);
246 printf("\nsolar source sun\n");
247 printf("0\n0\n");
248 printf("4 %f %f %f 0.5\n", sundir[0], sundir[1], sundir[2]);
249 }
250
251 printf("\nvoid brightfunc skyfunc\n");
252 printf("2 skybr skybright.cal\n");
253 printf("0\n");
254 if (overcast)
255 printf("3 %d %.2e %.2e\n", skytype, zenithbr, groundbr);
256 else
257 printf("7 %d %.2e %.2e %.2e %f %f %f\n",
258 skytype, zenithbr, groundbr, F2,
259 sundir[0], sundir[1], sundir[2]);
260 }
261
262
263 printdefaults() /* print default values */
264 {
265 switch (skytype) {
266 case S_OVER:
267 printf("-c\t\t\t\t# Cloudy sky\n");
268 break;
269 case S_UNIF:
270 printf("-u\t\t\t\t# Uniform cloudy sky\n");
271 break;
272 case S_INTER:
273 if (dosun)
274 printf("+i\t\t\t\t# Intermediate sky with sun\n");
275 else
276 printf("-i\t\t\t\t# Intermediate sky without sun\n");
277 break;
278 case S_CLEAR:
279 if (dosun)
280 printf("+s\t\t\t\t# Sunny sky with sun\n");
281 else
282 printf("-s\t\t\t\t# Sunny sky without sun\n");
283 break;
284 }
285 printf("-g %f\t\t\t# Ground plane reflectance\n", gprefl);
286 if (zenithbr > 0.0)
287 printf("-b %f\t\t\t# Zenith radiance (watts/ster/m2\n", zenithbr);
288 else
289 printf("-t %f\t\t\t# Atmospheric turbidity\n", turbidity);
290 printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI));
291 printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI));
292 printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI));
293 }
294
295
296 userror(msg) /* print usage error and quit */
297 char *msg;
298 {
299 if (msg != NULL)
300 fprintf(stderr, "%s: Use error - %s\n", progname, msg);
301 fprintf(stderr, "Usage: %s month day hour [options]\n", progname);
302 fprintf(stderr, " Or: %s -ang altitude azimuth [options]\n", progname);
303 fprintf(stderr, " Or: %s -defaults\n", progname);
304 exit(1);
305 }
306
307
308 double
309 normsc() /* compute normalization factor (E0*F2/L0) */
310 {
311 static double nfc[2][5] = {
312 /* clear sky approx. */
313 {2.766521, 0.547665, -0.369832, 0.009237, 0.059229},
314 /* intermediate sky approx. */
315 {3.5556, -2.7152, -1.3081, 1.0660, 0.60227},
316 };
317 register double *nf;
318 double x, nsc;
319 register int i;
320 /* polynomial approximation */
321 nf = nfc[skytype==S_INTER];
322 x = (altitude - PI/4.0)/(PI/4.0);
323 nsc = nf[i=4];
324 while (i--)
325 nsc = nsc*x + nf[i];
326
327 return(nsc);
328 }
329
330
331 printhead(ac, av) /* print command header */
332 register int ac;
333 register char **av;
334 {
335 putchar('#');
336 while (ac--) {
337 putchar(' ');
338 fputs(*av++, stdout);
339 }
340 putchar('\n');
341 }
