root/radiance/src/gen/genprism.c
Revision: 2.2
Committed: Thu Dec 19 15:08:51 1991 UTC (33 years, 10 months ago) by greg
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * genprism.c - generate a prism.
9 * 2D vertices in the xy plane are given on the
10 * command line or from a file. Their order together
11 * with the extrude direction will determine surface
12 * orientation.
13 *
14 * 8/24/87
15 */
16
17 #include <stdio.h>
18
19 #include <ctype.h>
20
21 #define MAXVERT 1024 /* maximum # vertices */
22
23 #ifndef atof
24 extern double atof();
25 #endif
26
27 char *pmtype; /* material type */
28 char *pname; /* name */
29
30 double lvect[3] = {0.0, 0.0, 1.0};
31
32 double vert[MAXVERT][2];
33 int nverts = 0;
34
35 int do_ends = 1; /* include end caps */
36 int iscomplete = 0; /* polygon is already completed */
37
38
39 main(argc, argv)
40 int argc;
41 char **argv;
42 {
43 int an;
44
45 if (argc < 4)
46 goto userr;
47
48 pmtype = argv[1];
49 pname = argv[2];
50
51 if (!strcmp(argv[3], "-")) {
52 readverts(NULL);
53 an = 4;
54 } else if (isdigit(argv[3][0])) {
55 nverts = atoi(argv[3]);
56 if (argc-3 < 2*nverts)
57 goto userr;
58 for (an = 0; an < nverts; an++) {
59 vert[an][0] = atof(argv[2*an+4]);
60 vert[an][1] = atof(argv[2*an+5]);
61 }
62 an = 2*nverts+4;
63 } else {
64 readverts(argv[3]);
65 an = 4;
66 }
67 if (nverts < 3) {
68 fprintf(stderr, "%s: not enough vertices\n", argv[0]);
69 exit(1);
70 }
71
72 for ( ; an < argc; an++) {
73 if (argv[an][0] != '-')
74 goto userr;
75 switch (argv[an][1]) {
76 case 'l': /* length vector */
77 lvect[0] = atof(argv[++an]);
78 lvect[1] = atof(argv[++an]);
79 lvect[2] = atof(argv[++an]);
80 break;
81 case 'e': /* ends */
82 do_ends = !do_ends;
83 break;
84 case 'c': /* complete */
85 iscomplete = !iscomplete;
86 break;
87 default:
88 goto userr;
89 }
90 }
91
92 printhead(argc, argv);
93
94 if (do_ends)
95 printends();
96 printsides();
97
98 return(0);
99 userr:
100 fprintf(stderr, "Usage: %s material name ", argv[0]);
101 fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } ");
102 fprintf(stderr, "[-l lvect][-c][-e]\n");
103 exit(1);
104 }
105
106
107 readverts(fname) /* read vertices from a file */
108 char *fname;
109 {
110 FILE *fp;
111
112 if (fname == NULL)
113 fp = stdin;
114 else if ((fp = fopen(fname, "r")) == NULL) {
115 fprintf(stderr, "%s: cannot open\n", fname);
116 exit(1);
117 }
118 while (fscanf(fp, "%lf %lf", &vert[nverts][0], &vert[nverts][1]) == 2)
119 nverts++;
120 fclose(fp);
121 }
122
123
124 printends() /* print ends of prism */
125 {
126 register int i;
127
128 printf("\n%s polygon %s.b\n", pmtype, pname);
129 printf("0\n0\n%d\n", nverts*3);
130 for (i = 0; i < nverts; i++) {
131 printf("\t%18.12g\t%18.12g\t%18.12g\n",
132 vert[i][0],
133 vert[i][1],
134 0.0);
135 }
136 printf("\n%s polygon %s.e\n", pmtype, pname);
137 printf("0\n0\n%d\n", nverts*3);
138 for (i = nverts-1; i >= 0; i--) {
139 printf("\t%18.12g\t%18.12g\t%18.12g\n",
140 vert[i][0]+lvect[0],
141 vert[i][1]+lvect[1],
142 lvect[2]);
143 }
144 }
145
146
147 printsides() /* print prism sides */
148 {
149 register int i;
150
151 for (i = 0; i < nverts-1; i++)
152 side(i, i+1);
153 if (!iscomplete)
154 side(nverts-1, 0);
155 }
156
157
158 side(n1, n2) /* print single side */
159 register int n1, n2;
160 {
161 printf("\n%s polygon %s.%d\n", pmtype, pname, n1+1);
162 printf("0\n0\n12\n");
163 printf("\t%18.12g\t%18.12g\t%18.12g\n",
164 vert[n1][0],
165 vert[n1][1],
166 0.0);
167 printf("\t%18.12g\t%18.12g\t%18.12g\n",
168 vert[n1][0]+lvect[0],
169 vert[n1][1]+lvect[1],
170 lvect[2]);
171 printf("\t%18.12g\t%18.12g\t%18.12g\n",
172 vert[n2][0]+lvect[0],
173 vert[n2][1]+lvect[1],
174 lvect[2]);
175 printf("\t%18.12g\t%18.12g\t%18.12g\n",
176 vert[n2][0],
177 vert[n2][1],
178 0.0);
179 }
180
181
182 printhead(ac, av) /* print command header */
183 register int ac;
184 register char **av;
185 {
186 putchar('#');
187 while (ac--) {
188 putchar(' ');
189 fputs(*av++, stdout);
190 }
191 putchar('\n');
192 }
