root/radiance/src/gen/genglaze.c
Revision: 2.1
Committed: Mon May 5 19:20:16 2025 UTC (5 months, 1 week ago) by greg
feat(genglaze): New tool created by Taoning Wang added to distro
1 /*
2 Glazing system multi-layer optics calculation.
3 Source equations: LBNL WINDOW technical documention.
4 System calcuation: Section 7.6.1
5 Anuglar calculation Section 7.7
6 T. Wang
7 */
8
9 #include "rtmath.h"
10 #include "color.h"
11 #include "data.h"
12
13 enum {
14 NTHETA = 59,
15 MAX_NAME = 256,
16 };
17
18 const double DBL_EPSILON = 1E-9;
19 const double FLT_MAX = 3.40282347E+38;
20 const double RAD_PER_DEG = 0.0174532925199;
21 const double COEFFS_TAU_CLEAR[] = {-0.0015, 3.355, -3.84, 1.46, 0.0288};
22 const double COEFFS_TAU_BRONZE[] = {0.002, 2.813, -2.341, -0.05725, 0.599};
23 const double COEFFS_RHO_CLEAR[] = {0.999, -0.563, 2.043, -2.532, 1.054};
24 const double COEFFS_RHO_BRONZE[] = {0.997, -1.868, 6.513, -7.862, 3.225};
25
26 const double THETAS[NTHETA] = {
27 0., 5., 10., 15., 20., 25., 30., 35., 40.,
28 41., 42., 43., 44., 45., 46., 47., 48., 49, 50.,
29 51., 52., 53., 54., 55., 56., 57., 58., 59, 60.,
30 61., 62., 63., 64., 65., 66., 67., 68., 69, 70.,
31 71., 72., 73., 74., 75., 76., 77., 78., 79, 80.,
32 81., 82., 83., 84., 85., 86., 87., 88., 89, 90.,
33 };
34
35
36 char *progname;
37
38 typedef struct {
39 char *filename;
40 int is_mono;
41 double thickness_m;
42
43 /* Interpolated data at standard wavelengths */
44 double *t_0;
45 double *rf_0;
46 double *rb_0;
47
48 /* Calculated angular data */
49 double *t_lambda_theta;
50 double *rf_lambda_theta;
51 double *rb_lambda_theta;
52
53 } GlazingLayer;
54
55
56 inline double polynomial_5(double x, const double coeffs[5]) {
57 return x * ( x * ( x * (coeffs[4] * x + coeffs[3]) + coeffs[2]) + coeffs[1]) + coeffs[0];
58 }
59
60
61 /* Calculate rho0 (unpolarized reflectance of a single surface) */
62 static void rho0_calc(const double *t_0, const double *r_0, const int nwvl, double *rho0) {
63 for (int i = 0; i < nwvl; ++i) {
64 const double beta = t_0[i] * t_0[i] - r_0[i] * r_0[i] + 2.0 * r_0[i] + 1.0;
65 double denominator = 2.0 * (2.0 - r_0[i]);
66 if (fabs(denominator) < DBL_EPSILON)
67 denominator = DBL_EPSILON;
68 double discriminant = beta * beta - 2.0 * denominator * r_0[i];
69 if (discriminant < 0.0)
70 discriminant = 0.0;
71 rho0[i] = (beta - sqrt(discriminant)) / denominator;
72 if (rho0[i] < 0.0)
73 rho0[i] = 0.0;
74 if (rho0[i] > 1.0)
75 rho0[i] = 1.0;
76 }
77 }
78
79 /* refraction index calc */
80 static void n_calc(const double *rho_0, const int nwvl, double *n)
81 {
82 for (int i=0; i < nwvl; ++i) {
83 const double sqrt_rho = sqrt(rho_0[i]);
84 n[i] = ((1.0 - sqrt_rho) < DBL_EPSILON) ? 1.0 : (1.0 + sqrt_rho) / (1.0 - sqrt_rho);
85 }
86 }
87
88 /* Calculate absoprtion coefficient */
89 static void alpha_calc(const double *t0, const double *r0, const double *rho0,
90 const double thickness_m, const int nwvl, double *abs_coeff)
91 {
92 for (int i = 0; i < nwvl; ++i) {
93 const double numerator = r0[i] - rho0[i];
94 const double denominator = rho0[i] * t0[i];
95 if (denominator > DBL_EPSILON && numerator > DBL_EPSILON) {
96 const double log_val = log(numerator / denominator);
97 abs_coeff[i] = -log_val / thickness_m;
98 } else {
99 abs_coeff[i] = 1.0;
100 }
101 if (abs_coeff[i] < 0.0 || isnan(abs_coeff[i]) || isinf(abs_coeff[i])) {
102 abs_coeff[i] = 0.0;
103 }
104 }
105 }
106
107
108 void angular_monolithic(GlazingLayer *layer, const int nwvl) {
109 double *rho_0 = malloc(nwvl * sizeof(double));
110 double *refrac = malloc(nwvl * sizeof(double));
111 double *abs_coeff = malloc(nwvl * sizeof(double));
112
113 rho0_calc(layer->t_0, layer->rf_0, nwvl, rho_0);
114 n_calc(rho_0, nwvl, refrac);
115 alpha_calc(layer->t_0, layer->rf_0, rho_0, layer->thickness_m, nwvl, abs_coeff);
116
117 for (int itheta = 0; itheta < NTHETA; ++itheta) {
118 double phi = THETAS[itheta] * RAD_PER_DEG;
119 double cos_phi = cos(phi);
120 double sin_phi = sin(phi);
121
122 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
123 double sin_phi_prime_sq = sin_phi * sin_phi / (refrac[iwvl] * refrac[iwvl]);
124
125 double cos_phi_prime = (sin_phi_prime_sq >= 1.0) ? 0.0 : sqrt(1.0 - sin_phi_prime_sq);
126
127 double rho_lambda;
128 if (cos_phi_prime <= DBL_EPSILON) {
129 rho_lambda = 1.0;
130 } else {
131 double nf_cos_phi = refrac[iwvl] * cos_phi;
132 double nf_cos_phi_p = refrac[iwvl] * cos_phi_prime;
133 double par_num = nf_cos_phi - cos_phi_prime;
134 double par_den = nf_cos_phi + cos_phi_prime;
135 double per_num = nf_cos_phi_p - cos_phi;
136 double per_den = nf_cos_phi_p + cos_phi;
137 if (fabs(par_den) < DBL_EPSILON || fabs(per_den) < DBL_EPSILON) {
138 rho_lambda = 1.0;
139 } else {
140 double par_comp = pow(par_num / par_den, 2.0);
141 double per_comp = pow(per_num / per_den, 2.0);
142 rho_lambda = 0.5 * (par_comp + per_comp);
143 }
144 }
145 if (rho_lambda < 0.0)
146 rho_lambda = 0.0;
147 if (rho_lambda > 1.0)
148 rho_lambda = 1.0;
149
150 double exp_arg = (cos_phi_prime < DBL_EPSILON) ? -FLT_MAX : (-abs_coeff[iwvl] * layer->thickness_m / cos_phi_prime);
151 /* Clamp exponent argument to prevent overflow in exp() */
152 if (exp_arg < -700.0)
153 exp_arg = -700.0;
154
155 double T_internal = exp(exp_arg);
156
157 double denominator = 1.0 - rho_lambda * rho_lambda * T_internal * T_internal;
158
159 double t_lambda, r_lambda;
160
161 if (fabs(denominator) < DBL_EPSILON || rho_lambda >= 1.0) {
162 t_lambda = 0.0;
163 r_lambda = 1.0;
164 } else {
165 double tau_lambda = 1.0 - rho_lambda;
166 t_lambda = tau_lambda * tau_lambda * T_internal / denominator;
167 r_lambda = rho_lambda * (1.0 + t_lambda * T_internal);
168
169 }
170 if (t_lambda < 0.0)
171 t_lambda = 0.0;
172 if (t_lambda > 1.0)
173 t_lambda = 1.0;
174
175 const int flat_idx = itheta * nwvl + iwvl;
176 layer->t_lambda_theta[flat_idx] = t_lambda;
177 layer->rf_lambda_theta[flat_idx] = r_lambda;
178 layer->rb_lambda_theta[flat_idx] = r_lambda;
179 }
180 }
181 }
182
183
184 void angular_coated(GlazingLayer *layer, const int nwvl) {
185 for (int itheta = 0; itheta < NTHETA; ++itheta) {
186 const double phi = THETAS[itheta] * RAD_PER_DEG;
187 const double cos_phi = cos(phi);
188
189 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
190 const double t_0_lambda = layer->t_0[iwvl];
191 const double *coeffs_tau = (t_0_lambda > 0.645) ? COEFFS_TAU_CLEAR : COEFFS_TAU_BRONZE;
192 const double *coeffs_rho = (t_0_lambda > 0.645) ? COEFFS_RHO_CLEAR : COEFFS_RHO_BRONZE;
193
194 const double tau_bar = polynomial_5(cos_phi, coeffs_tau);
195 const double rho_bar_term = polynomial_5(cos_phi, coeffs_rho);
196 const double rho_bar = rho_bar_term - tau_bar;
197
198 const int flat_idx = itheta * nwvl + iwvl;
199 layer->t_lambda_theta[flat_idx] = t_0_lambda * tau_bar;
200 layer->rf_lambda_theta[flat_idx] = layer->rf_0[iwvl] * (1.0 - rho_bar) + rho_bar;
201 layer->rb_lambda_theta[flat_idx] = layer->rb_0[iwvl] * (1.0 - rho_bar) + rho_bar;
202 }
203 }
204 }
205
206
207 void multi_layer_calc(
208 GlazingLayer *layers,
209 int nlayers,
210 int nwvl,
211 double *total_t,
212 double *total_rf,
213 double *total_rb)
214 {
215 if (nlayers <= 0)
216 return;
217
218 size_t total_size = (size_t)NTHETA * nwvl * sizeof(double);
219
220 memcpy(total_t, layers[0].t_lambda_theta, total_size);
221 memcpy(total_rf, layers[0].rf_lambda_theta, total_size);
222 memcpy(total_rb, layers[0].rb_lambda_theta, total_size);
223
224 if (nlayers == 1)
225 return;
226
227 double *prev_t = malloc(total_size);
228 double *prev_rf = malloc(total_size);
229 double *prev_rb = malloc(total_size);
230
231 if (!prev_t || !prev_rf || !prev_rb)
232 perror("Failed to allocate temporary storage in multi_layer");
233
234 for (int j = 1; j < nlayers; ++j) {
235 memcpy(prev_t, total_t, total_size);
236 memcpy(prev_rf, total_rf, total_size);
237 memcpy(prev_rb, total_rb, total_size);
238
239 double *t_j = layers[j].t_lambda_theta;
240 double *rf_j = layers[j].rf_lambda_theta;
241 double *rb_j = layers[j].rb_lambda_theta;
242
243 for (int itheta = 0; itheta < NTHETA; ++itheta) {
244 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
245 const int idx = itheta * nwvl + iwvl;
246 double denominator = 1.0 - rf_j[idx] * prev_rb[idx];
247 if (fabs(denominator) < DBL_EPSILON) {
248 denominator = DBL_EPSILON;
249 }
250 total_t[idx] = prev_t[idx] * t_j[idx] / denominator;
251 total_rf[idx] = prev_rf[idx] + prev_t[idx] * prev_t[idx] * rf_j[idx] / denominator;
252 total_rb[idx] = rb_j[idx] + t_j[idx] * t_j[idx] * prev_rb[idx] / denominator;
253 }
254 }
255 }
256 free(prev_t);
257 free(prev_rf);
258 free(prev_rb);
259 }
260
261
262 int add_layer(GlazingLayer **layers_array, int *count, int *capacity,
263 const char *filename, double thickness_m, int is_monolithic) {
264 if (*count >= *capacity) {
265 *capacity = (*capacity == 0) ? 4 : *capacity * 2;
266 GlazingLayer *new_layers = realloc(*layers_array, *capacity * sizeof(GlazingLayer));
267 if (!new_layers) {
268 perror("Failed to reallocate memory for layers");
269 return 0;
270 }
271 *layers_array = new_layers;
272 }
273
274 memset(&((*layers_array)[*count]), 0, sizeof(GlazingLayer));
275
276 #ifdef _WIN32
277 (*layers_array)[*count].filename = _strdup(filename);
278 #else
279 (*layers_array)[*count].filename = strdup(filename);
280 #endif
281
282 if (!(*layers_array)[*count].filename) {
283 perror("Failed to duplicate filename");
284 return 0;
285 }
286 (*layers_array)[*count].is_mono = is_monolithic;
287 (*layers_array)[*count].thickness_m = thickness_m;
288 (*layers_array)[*count].t_0 = NULL;
289 (*layers_array)[*count].rf_0 = NULL;
290 (*layers_array)[*count].rb_0 = NULL;
291 (*layers_array)[*count].t_lambda_theta = NULL;
292 (*layers_array)[*count].rf_lambda_theta = NULL;
293 (*layers_array)[*count].rb_lambda_theta = NULL;
294
295 (*count)++;
296 return 1;
297 }
298
299
300 int interpolate(GlazingLayer *layer, const double wvl_start, const double wvl_end, const double wvl_interval, const int nwvl) {
301 DATARRAY *dp = getdata(layer->filename);
302 if (!dp) {
303 fprintf(stderr, "Error: Cannot open file '%s'\n", layer->filename);
304 return 0;
305 }
306
307 layer->t_0 = malloc(nwvl * sizeof(double));
308 layer->rf_0 = malloc(nwvl * sizeof(double));
309 layer->rb_0 = malloc(nwvl * sizeof(double));
310
311 double wvl = wvl_start;
312 int i = 0;
313 while (wvl <= wvl_end) {
314 double t_pt[2] = {2., wvl};
315 layer->t_0[i] = datavalue(dp, t_pt);
316 double rf_pt[2] = {0., wvl};
317 layer->rf_0[i] = datavalue(dp, rf_pt);
318 double rb_pt[2] = {1., wvl};
319 layer->rb_0[i] = datavalue(dp, rb_pt);
320 wvl = wvl + wvl_interval;
321 i = i + 1;
322
323 }
324 freedata(dp);
325 return 1;
326 }
327
328
329 int write_output_file(
330 const char *tfilename,
331 const char *rfilename,
332 const double *tdata,
333 const double *rfdata,
334 const double *rbdata,
335 const double wvl_start,
336 const double wvl_end,
337 const int nwvl,
338 int argc, char *argv[])
339 {
340 FILE *tfp = fopen(tfilename, "w");
341 FILE *rfp = fopen(rfilename, "w");
342 if (!tfp || !rfp) {
343 fprintf(stderr, "Error: Cannot open output files\n");
344 return(0);
345 }
346
347 fprintf(tfp, "# ");
348 for (int i = 0; i< argc; ++i) {
349 fprintf(tfp, "%s ", argv[i]);
350 }
351 fprintf(tfp, "\n2\n0 0 %d", NTHETA);
352 for (int i = 0; i < NTHETA; i++) {
353 fprintf(tfp, " %d", (int)THETAS[i]);
354 }
355 fprintf(tfp, "\n%.0f %.0f %d\n", wvl_start, wvl_end, nwvl);
356
357 for (int itheta = 0; itheta < NTHETA; ++itheta) {
358 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
359 fprintf(tfp, "%.6f\n", tdata[itheta*nwvl+iwvl]);
360 }
361 }
362 fclose(tfp);
363
364 fprintf(rfp, "# ");
365 for (int i = 0; i< argc; ++i) {
366 fprintf(rfp, "%s ", argv[i]);
367 }
368 fprintf(rfp, "\n2\n0 0 %d", NTHETA * 2 - 1);
369 for (int i = 0; i < NTHETA; i++) {
370 fprintf(rfp, " %d", (int)THETAS[i]);
371 }
372 for (int i = NTHETA-2; i >= 0; --i) {
373 fprintf(rfp, " %d", (int)(180 - THETAS[i]));
374 }
375 fprintf(rfp, "\n%.0f %.0f %d\n", wvl_start, wvl_end, nwvl);
376
377 for (int itheta = 0; itheta < NTHETA; ++itheta) {
378 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
379 fprintf(rfp, "%.6f\n", rfdata[itheta * nwvl + iwvl]);
380 }
381 }
382 for (int itheta = NTHETA - 2; itheta >= 0 ; --itheta) {
383 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
384 fprintf(rfp, "%.6f\n", rbdata[itheta * nwvl + iwvl]);
385 }
386 }
387
388 fclose(rfp);
389 return(1);
390 }
391
392
393 void print_usage() {
394 fprintf(stderr, "Usage: %s [-m monolithic_layer.dat thickness | -c coated_layer.dat] ...\n", progname);
395 fprintf(stderr, "Calculate multi-layer glazing optics from spectral data files.\n");
396 fprintf(stderr, "Options:\n");
397 fprintf(stderr, " -m <filename> thickness Specify an uncoated (monolithic) glazing layer .dat file and its thickness (meter).\n");
398 fprintf(stderr, " -c <filename> Specify a coated or laminate glazing layer .dat file.\n");
399 fprintf(stderr, " -s start_wvl end_wvl interval Specify wavelength range and interval.\n");
400 fprintf(stderr, " -p prefix Specify prefix name to the output files.\n");
401 fprintf(stderr, " -h, --help Show this help message.\n");
402 fprintf(stderr, "Layer order is determined by the sequence of options on the command line.\n");
403 fprintf(stderr, "Output Files: prefix_t.dat, prefix_r.dat\n");
404 }
405
406 void cleanup_layers(GlazingLayer *layers, int num_layers) {
407 if (!layers) return;
408 for (int i = 0; i < num_layers; ++i) {
409 if (layers[i].filename)
410 free(layers[i].filename);
411 }
412 free(layers);
413 }
414
415
416 int main(int argc, char *argv[])
417 {
418 GlazingLayer *layers = NULL;
419 int num_layers = 0;
420 int layer_capacity = 0;
421 int success = 1;
422 double wvl_start_nm = 380.;
423 double wvl_end_nm = 780.;
424 double wvl_interval_nm = 5.;
425 int nwvl = 81;
426 double thickness_m = 0.003;
427 char *filename;
428 char *prefix = "unnamed";
429 char file_t[MAX_NAME];
430 char file_r[MAX_NAME];
431 progname = argv[0];
432 if (argc <= 1) {
433 print_usage();
434 return EXIT_FAILURE;
435 }
436
437 for (int i=1; i < argc; ++i) {
438 switch (argv[i][1]) {
439 case 'm':
440 filename = argv[++i];
441 thickness_m = atof(argv[++i]);
442 if (!add_layer(&layers, &num_layers, &layer_capacity, filename, thickness_m, 1)) {
443 cleanup_layers(layers, num_layers);
444 return EXIT_FAILURE;
445 }
446 break;
447 case 'c':
448 filename = argv[++i];
449 if (!add_layer(&layers, &num_layers, &layer_capacity, filename, thickness_m, 0)) {
450 cleanup_layers(layers, num_layers);
451 return EXIT_FAILURE;
452 }
453 break;
454 case 'p':
455 prefix = argv[++i];
456 break;
457 case 's':
458 wvl_start_nm = atof(argv[++i]);
459 wvl_end_nm = atof(argv[++i]);
460 wvl_interval_nm = atof(argv[++i]);
461 if (wvl_start_nm > wvl_end_nm) {
462 fprintf(stderr, "Starting wavelength > End wavelength\n");
463 return EXIT_FAILURE;
464 }
465 if (((int)(wvl_end_nm - wvl_start_nm) % (int)wvl_interval_nm) > 0) {
466 fprintf(stderr,
467 "Error: Wavelength range (%f to %f nm) must be evenly divisible by the interval (%f nm).\n",
468 wvl_start_nm, wvl_end_nm, wvl_interval_nm);
469 return EXIT_FAILURE;
470 }
471 break;
472 case 'h':
473 print_usage();
474 return 1;
475 default:
476 break;
477 }
478 }
479 snprintf(file_t, MAX_NAME, "%s_t.dat", prefix);
480 snprintf(file_r, MAX_NAME, "%s_r.dat", prefix);
481
482 if (fabs(wvl_start_nm - wvl_end_nm) < DBL_EPSILON && wvl_interval_nm > DBL_EPSILON) {
483 nwvl = 1;
484 } else {
485 nwvl = (int)((wvl_end_nm - wvl_start_nm) / wvl_interval_nm + 1.5);
486 }
487
488 if (num_layers == 0) {
489 fprintf(stderr, "Error: No layers specified.\n");
490 print_usage();
491 return EXIT_FAILURE;
492 }
493
494 for (int i = 0; i < num_layers; ++i) {
495 if (!interpolate(&layers[i], wvl_start_nm, wvl_end_nm, wvl_interval_nm, nwvl)) {
496 fprintf(stderr, "Error: Failed to parse or interpolate data for layer %d.\n", i + 1);
497 success = 0;
498 break;
499 }
500 layers[i].t_lambda_theta = malloc(NTHETA * nwvl * sizeof(double));
501 layers[i].rf_lambda_theta = malloc(NTHETA * nwvl * sizeof(double));
502 layers[i].rb_lambda_theta = malloc(NTHETA * nwvl * sizeof(double));
503
504 if (layers[i].is_mono) {
505 angular_monolithic(&layers[i], nwvl);
506 } else {
507 angular_coated(&layers[i], nwvl);
508 }
509 }
510
511 if (!success) {
512 cleanup_layers(layers, num_layers);
513 return EXIT_FAILURE;
514 }
515
516
517 size_t total_flat_size = (size_t)NTHETA * nwvl * sizeof(double);
518 double *total_t = malloc(total_flat_size);
519 double *total_rf = malloc(total_flat_size);
520 double *total_rb = malloc(total_flat_size);
521
522 if (!total_t || !total_rf || !total_rb) {
523 perror("Failed to allocate memory for final results");
524 cleanup_layers(layers, num_layers);
525 free(total_t);
526 free(total_rf);
527 free(total_rb);
528 return EXIT_FAILURE;
529 }
530
531 multi_layer_calc(layers, num_layers, nwvl, total_t, total_rf, total_rb);
532
533 success &= write_output_file(file_t, file_r, total_t, total_rf, total_rb, wvl_start_nm, wvl_end_nm, nwvl, argc, argv);
534
535 if (success) {
536 printf("# ");
537 for (int i = 0;i < argc; ++i) {
538 printf("%s ", argv[i]);
539 }
540 printf("\nvoid specdata refl_spec\n");
541 printf("4 noop %s . 'Acos(Rdot)/DEGREE'\n0\n0\n\n", file_r);
542 printf("void specdata trans_spec\n");
543 printf("4 noop %s . 'Acos(abs(Rdot))/DEGREE'\n0\n0\n\n", file_t);
544 printf("void WGMDfunc glaze_mat\n13\n\trefl_spec 1 0 0\n\ttrans_spec 1 0 0\n\tvoid\n\t0 0 1 .\n0\n9 0 0 0 0 0 0 0 0 0\n");
545 } else {
546 fprintf(stderr, "Error: Failed to write one or more output files.\n");
547 }
548
549 cleanup_layers(layers, num_layers);
550 free(total_t);
551 free(total_rf);
552 free(total_rb);
553
554 return success ? EXIT_SUCCESS : EXIT_FAILURE;
555 }
