root/radiance/src/gen/genglaze.c
Revision: 2.2
Committed: Tue Jun 10 23:13:13 2025 UTC (4 months, 1 week ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.1: +37 -9 lines
fix(genglaze): TW fixed a memory leak and some minor improvements
1 /*
2 Glazing system multi-layer optics calculation.
3 Source equations: LBNL WINDOW technical documention.
4 System calcuation: Section 7.6.1
5 Anuglar calculation Section 7.7
6 T. Wang
7 */
8
9 #include "rtmath.h"
10 #include "color.h"
11 #include "data.h"
12
13 enum {
14 NTHETA = 59,
15 MAX_NAME = 256,
16 };
17
18 const double DBL_EPSILON = 1E-9;
19 const double LARGE_DOUBE = 3.40282347E+38;
20 const double RAD_PER_DEG = 0.0174532925199;
21 const double COEFFS_TAU_CLEAR[] = {-0.0015, 3.355, -3.84, 1.46, 0.0288};
22 const double COEFFS_TAU_BRONZE[] = {0.002, 2.813, -2.341, -0.05725, 0.599};
23 const double COEFFS_RHO_CLEAR[] = {0.999, -0.563, 2.043, -2.532, 1.054};
24 const double COEFFS_RHO_BRONZE[] = {0.997, -1.868, 6.513, -7.862, 3.225};
25
26 const double THETAS[NTHETA] = {
27 0., 5., 10., 15., 20., 25., 30., 35., 40.,
28 41., 42., 43., 44., 45., 46., 47., 48., 49, 50.,
29 51., 52., 53., 54., 55., 56., 57., 58., 59, 60.,
30 61., 62., 63., 64., 65., 66., 67., 68., 69, 70.,
31 71., 72., 73., 74., 75., 76., 77., 78., 79, 80.,
32 81., 82., 83., 84., 85., 86., 87., 88., 89, 90.,
33 };
34
35
36 char *progname;
37
38 typedef struct {
39 char *filename;
40 int is_mono;
41 double thickness_m;
42
43 /* Interpolated data at standard wavelengths */
44 double *t_0;
45 double *rf_0;
46 double *rb_0;
47
48 /* Calculated angular data */
49 double *t_lambda_theta;
50 double *rf_lambda_theta;
51 double *rb_lambda_theta;
52
53 } GlazingLayer;
54
55
56 static inline double polynomial_5(double x, const double coeffs[5]) {
57 return x * ( x * ( x * (coeffs[4] * x + coeffs[3]) + coeffs[2]) + coeffs[1]) + coeffs[0];
58 }
59
60
61 /* Calculate rho0 (unpolarized reflectance of a single surface) */
62 static void rho0_calc(const double *t_0, const double *r_0, const int nwvl, double *rho0) {
63 for (int i = 0; i < nwvl; ++i) {
64 const double beta = t_0[i] * t_0[i] - r_0[i] * r_0[i] + 2.0 * r_0[i] + 1.0;
65 double denominator = 2.0 * (2.0 - r_0[i]);
66 if (fabs(denominator) < DBL_EPSILON)
67 denominator = DBL_EPSILON;
68 double discriminant = beta * beta - 2.0 * denominator * r_0[i];
69 if (discriminant < 0.0)
70 discriminant = 0.0;
71 rho0[i] = (beta - sqrt(discriminant)) / denominator;
72 if (rho0[i] < 0.0)
73 rho0[i] = 0.0;
74 if (rho0[i] > 1.0)
75 rho0[i] = 1.0;
76 }
77 }
78
79 /* refraction index calc */
80 static void n_calc(const double *rho_0, const int nwvl, double *n)
81 {
82 for (int i=0; i < nwvl; ++i) {
83 const double sqrt_rho = sqrt(rho_0[i]);
84 n[i] = ((1.0 - sqrt_rho) < DBL_EPSILON) ? 1.0 : (1.0 + sqrt_rho) / (1.0 - sqrt_rho);
85 }
86 }
87
88 /* Calculate absoprtion coefficient */
89 static void alpha_calc(const double *t0, const double *r0, const double *rho0,
90 const double thickness_m, const int nwvl, double *abs_coeff)
91 {
92 for (int i = 0; i < nwvl; ++i) {
93 const double numerator = r0[i] - rho0[i];
94 const double denominator = rho0[i] * t0[i];
95 if (denominator > DBL_EPSILON && numerator > DBL_EPSILON) {
96 const double log_val = log(numerator / denominator);
97 abs_coeff[i] = -log_val / thickness_m;
98 } else {
99 abs_coeff[i] = 1.0;
100 }
101 if (abs_coeff[i] < 0.0 || isnan(abs_coeff[i]) || isinf(abs_coeff[i])) {
102 abs_coeff[i] = 0.0;
103 }
104 }
105 }
106
107
108 void angular_monolithic(GlazingLayer *layer, const int nwvl) {
109 double *rho_0 = malloc(nwvl * sizeof(double));
110 double *refrac = malloc(nwvl * sizeof(double));
111 double *abs_coeff = malloc(nwvl * sizeof(double));
112
113 rho0_calc(layer->t_0, layer->rf_0, nwvl, rho_0);
114 n_calc(rho_0, nwvl, refrac);
115 alpha_calc(layer->t_0, layer->rf_0, rho_0, layer->thickness_m, nwvl, abs_coeff);
116
117 for (int itheta = 0; itheta < NTHETA; ++itheta) {
118 double phi = THETAS[itheta] * RAD_PER_DEG;
119 double cos_phi = cos(phi);
120 double sin_phi = sin(phi);
121
122 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
123 double sin_phi_prime_sq = sin_phi * sin_phi / (refrac[iwvl] * refrac[iwvl]);
124
125 double cos_phi_prime = (sin_phi_prime_sq >= 1.0) ? 0.0 : sqrt(1.0 - sin_phi_prime_sq);
126
127 double rho_lambda;
128 if (cos_phi_prime <= DBL_EPSILON) {
129 rho_lambda = 1.0;
130 } else {
131 double nf_cos_phi = refrac[iwvl] * cos_phi;
132 double nf_cos_phi_p = refrac[iwvl] * cos_phi_prime;
133 double par_num = nf_cos_phi - cos_phi_prime;
134 double par_den = nf_cos_phi + cos_phi_prime;
135 double per_num = nf_cos_phi_p - cos_phi;
136 double per_den = nf_cos_phi_p + cos_phi;
137 if (fabs(par_den) < DBL_EPSILON || fabs(per_den) < DBL_EPSILON) {
138 rho_lambda = 1.0;
139 } else {
140 double par_comp = pow(par_num / par_den, 2.0);
141 double per_comp = pow(per_num / per_den, 2.0);
142 rho_lambda = 0.5 * (par_comp + per_comp);
143 }
144 }
145 if (rho_lambda < 0.0)
146 rho_lambda = 0.0;
147 if (rho_lambda > 1.0)
148 rho_lambda = 1.0;
149
150 double exp_arg = (cos_phi_prime < DBL_EPSILON) ? -LARGE_DOUBE : (-abs_coeff[iwvl] * layer->thickness_m / cos_phi_prime);
151 /* Clamp exponent argument to prevent overflow in exp() */
152 if (exp_arg < -700.0)
153 exp_arg = -700.0;
154
155 double T_internal = exp(exp_arg);
156
157 double denominator = 1.0 - rho_lambda * rho_lambda * T_internal * T_internal;
158
159 double t_lambda, r_lambda;
160
161 if (fabs(denominator) < DBL_EPSILON || rho_lambda >= 1.0) {
162 t_lambda = 0.0;
163 r_lambda = 1.0;
164 } else {
165 double tau_lambda = 1.0 - rho_lambda;
166 t_lambda = tau_lambda * tau_lambda * T_internal / denominator;
167 r_lambda = rho_lambda * (1.0 + t_lambda * T_internal);
168
169 }
170 if (t_lambda < 0.0)
171 t_lambda = 0.0;
172 if (t_lambda > 1.0)
173 t_lambda = 1.0;
174
175 const int flat_idx = itheta * nwvl + iwvl;
176 layer->t_lambda_theta[flat_idx] = t_lambda;
177 layer->rf_lambda_theta[flat_idx] = r_lambda;
178 layer->rb_lambda_theta[flat_idx] = r_lambda;
179 }
180 }
181 free(rho_0);
182 free(refrac);
183 free(abs_coeff);
184 }
185
186
187 void angular_coated(GlazingLayer *layer, const int nwvl) {
188 for (int itheta = 0; itheta < NTHETA; ++itheta) {
189 const double phi = THETAS[itheta] * RAD_PER_DEG;
190 const double cos_phi = cos(phi);
191
192 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
193 const double t_0_lambda = layer->t_0[iwvl];
194 const double *coeffs_tau = (t_0_lambda > 0.645) ? COEFFS_TAU_CLEAR : COEFFS_TAU_BRONZE;
195 const double *coeffs_rho = (t_0_lambda > 0.645) ? COEFFS_RHO_CLEAR : COEFFS_RHO_BRONZE;
196
197 const double tau_bar = polynomial_5(cos_phi, coeffs_tau);
198 const double rho_bar_term = polynomial_5(cos_phi, coeffs_rho);
199 const double rho_bar = rho_bar_term - tau_bar;
200
201 const int flat_idx = itheta * nwvl + iwvl;
202 layer->t_lambda_theta[flat_idx] = t_0_lambda * tau_bar;
203 layer->rf_lambda_theta[flat_idx] = layer->rf_0[iwvl] * (1.0 - rho_bar) + rho_bar;
204 layer->rb_lambda_theta[flat_idx] = layer->rb_0[iwvl] * (1.0 - rho_bar) + rho_bar;
205 }
206 }
207 }
208
209
210 void multi_layer_calc(
211 GlazingLayer *layers,
212 int nlayers,
213 int nwvl,
214 double *total_t,
215 double *total_rf,
216 double *total_rb)
217 {
218 if (nlayers <= 0)
219 return;
220
221 size_t total_size = (size_t)NTHETA * nwvl * sizeof(double);
222
223 memcpy(total_t, layers[0].t_lambda_theta, total_size);
224 memcpy(total_rf, layers[0].rf_lambda_theta, total_size);
225 memcpy(total_rb, layers[0].rb_lambda_theta, total_size);
226
227 if (nlayers == 1)
228 return;
229
230 double *prev_t = malloc(total_size);
231 double *prev_rf = malloc(total_size);
232 double *prev_rb = malloc(total_size);
233
234 if (!prev_t || !prev_rf || !prev_rb)
235 perror("Failed to allocate temporary storage in multi_layer");
236
237 for (int j = 1; j < nlayers; ++j) {
238 memcpy(prev_t, total_t, total_size);
239 memcpy(prev_rf, total_rf, total_size);
240 memcpy(prev_rb, total_rb, total_size);
241
242 double *t_j = layers[j].t_lambda_theta;
243 double *rf_j = layers[j].rf_lambda_theta;
244 double *rb_j = layers[j].rb_lambda_theta;
245
246 for (int itheta = 0; itheta < NTHETA; ++itheta) {
247 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
248 const int idx = itheta * nwvl + iwvl;
249 double denominator = 1.0 - rf_j[idx] * prev_rb[idx];
250 if (fabs(denominator) < DBL_EPSILON) {
251 denominator = DBL_EPSILON;
252 }
253 total_t[idx] = prev_t[idx] * t_j[idx] / denominator;
254 total_rf[idx] = prev_rf[idx] + prev_t[idx] * prev_t[idx] * rf_j[idx] / denominator;
255 total_rb[idx] = rb_j[idx] + t_j[idx] * t_j[idx] * prev_rb[idx] / denominator;
256 }
257 }
258 }
259 free(prev_t);
260 free(prev_rf);
261 free(prev_rb);
262 }
263
264
265 int add_layer(GlazingLayer **layers_array, int *count, int *capacity,
266 const char *filename, double thickness_m, int is_monolithic) {
267 if (*count >= *capacity) {
268 *capacity = (*capacity == 0) ? 4 : *capacity * 2;
269 GlazingLayer *new_layers = realloc(*layers_array, *capacity * sizeof(GlazingLayer));
270 if (!new_layers) {
271 perror("Failed to reallocate memory for layers");
272 return 0;
273 }
274 *layers_array = new_layers;
275 }
276
277 memset(&((*layers_array)[*count]), 0, sizeof(GlazingLayer));
278
279 #ifdef _WIN32
280 (*layers_array)[*count].filename = _strdup(filename);
281 #else
282 (*layers_array)[*count].filename = strdup(filename);
283 #endif
284
285 if (!(*layers_array)[*count].filename) {
286 perror("Failed to duplicate filename");
287 return 0;
288 }
289 (*layers_array)[*count].is_mono = is_monolithic;
290 (*layers_array)[*count].thickness_m = thickness_m;
291 (*layers_array)[*count].t_0 = NULL;
292 (*layers_array)[*count].rf_0 = NULL;
293 (*layers_array)[*count].rb_0 = NULL;
294 (*layers_array)[*count].t_lambda_theta = NULL;
295 (*layers_array)[*count].rf_lambda_theta = NULL;
296 (*layers_array)[*count].rb_lambda_theta = NULL;
297
298 (*count)++;
299 return 1;
300 }
301
302
303 int interpolate(GlazingLayer *layer, const double wvl_start, const double wvl_end, const double wvl_interval, const int nwvl) {
304 DATARRAY *dp = getdata(layer->filename);
305 if (!dp) {
306 fprintf(stderr, "Error: Cannot open file '%s'\n", layer->filename);
307 return 0;
308 }
309
310 layer->t_0 = malloc(nwvl * sizeof(double));
311 layer->rf_0 = malloc(nwvl * sizeof(double));
312 layer->rb_0 = malloc(nwvl * sizeof(double));
313
314 double wvl = wvl_start;
315 int i = 0;
316 while (wvl <= wvl_end) {
317 double t_pt[2] = {2., wvl};
318 layer->t_0[i] = datavalue(dp, t_pt);
319 double rf_pt[2] = {0., wvl};
320 layer->rf_0[i] = datavalue(dp, rf_pt);
321 double rb_pt[2] = {1., wvl};
322 layer->rb_0[i] = datavalue(dp, rb_pt);
323 wvl = wvl + wvl_interval;
324 i = i + 1;
325
326 }
327 freedata(dp);
328 return 1;
329 }
330
331
332 int write_output_file(
333 const char *tfilename,
334 const char *rfilename,
335 const double *tdata,
336 const double *rfdata,
337 const double *rbdata,
338 const double wvl_start,
339 const double wvl_end,
340 const int nwvl,
341 int argc, char *argv[])
342 {
343 FILE *tfp = fopen(tfilename, "w");
344 FILE *rfp = fopen(rfilename, "w");
345 if (!tfp || !rfp) {
346 fprintf(stderr, "Error: Cannot open output files\n");
347 return(0);
348 }
349
350 fprintf(tfp, "# ");
351 for (int i = 0; i< argc; ++i) {
352 fprintf(tfp, "%s ", argv[i]);
353 }
354 fprintf(tfp, "\n2\n0 0 %d", NTHETA);
355 for (int i = 0; i < NTHETA; i++) {
356 fprintf(tfp, " %d", (int)THETAS[i]);
357 }
358 fprintf(tfp, "\n%.0f %.0f %d\n", wvl_start, wvl_end, nwvl);
359
360 for (int itheta = 0; itheta < NTHETA; ++itheta) {
361 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
362 fprintf(tfp, "%.6f\n", tdata[itheta*nwvl+iwvl]);
363 }
364 }
365 fclose(tfp);
366
367 fprintf(rfp, "# ");
368 for (int i = 0; i< argc; ++i) {
369 fprintf(rfp, "%s ", argv[i]);
370 }
371 fprintf(rfp, "\n2\n0 0 %d", NTHETA * 2 - 1);
372 for (int i = 0; i < NTHETA; i++) {
373 fprintf(rfp, " %d", (int)THETAS[i]);
374 }
375 for (int i = NTHETA-2; i >= 0; --i) {
376 fprintf(rfp, " %d", (int)(180 - THETAS[i]));
377 }
378 fprintf(rfp, "\n%.0f %.0f %d\n", wvl_start, wvl_end, nwvl);
379
380 for (int itheta = 0; itheta < NTHETA; ++itheta) {
381 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
382 fprintf(rfp, "%.6f\n", rfdata[itheta * nwvl + iwvl]);
383 }
384 }
385 for (int itheta = NTHETA - 2; itheta >= 0 ; --itheta) {
386 for (int iwvl = 0; iwvl < nwvl; ++iwvl) {
387 fprintf(rfp, "%.6f\n", rbdata[itheta * nwvl + iwvl]);
388 }
389 }
390
391 fclose(rfp);
392 return(1);
393 }
394
395
396 void print_usage() {
397 fprintf(stderr, "Usage: %s [-m monolithic_layer.dat thickness | -c coated_layer.dat] ...\n", progname);
398 fprintf(stderr, "Calculate multi-layer glazing optics from spectral data files.\n");
399 fprintf(stderr, "Options:\n");
400 fprintf(stderr, " -m <filename> thickness Specify an uncoated (monolithic) glazing layer .dat file and its thickness (meter).\n");
401 fprintf(stderr, " -c <filename> Specify a coated or laminate glazing layer .dat file.\n");
402 fprintf(stderr, " -s start_wvl end_wvl interval Specify wavelength range and interval.\n");
403 fprintf(stderr, " -p prefix Specify prefix name to the output files.\n");
404 fprintf(stderr, " -h, --help Show this help message.\n");
405 fprintf(stderr, "Layer order is determined by the sequence of options on the command line.\n");
406 fprintf(stderr, "Output Files: prefix_t.dat, prefix_r.dat\n");
407 }
408
409
410 static void free_layer_data(GlazingLayer *layer) {
411 if (!layer) return;
412
413 free(layer->filename);
414 free(layer->t_0);
415 free(layer->rf_0);
416 free(layer->rb_0);
417 free(layer->t_lambda_theta);
418 free(layer->rf_lambda_theta);
419 free(layer->rb_lambda_theta);
420
421 // Set pointers to NULL to prevent double-free errors
422 layer->filename = NULL;
423 layer->t_0 = NULL;
424 layer->rf_0 = NULL;
425 layer->rb_0 = NULL;
426 layer->t_lambda_theta = NULL;
427 layer->rf_lambda_theta = NULL;
428 layer->rb_lambda_theta = NULL;
429 }
430
431
432 void cleanup_layers(GlazingLayer *layers, int num_layers) {
433 if (!layers) return;
434 for (int i = 0; i < num_layers; ++i) {
435 if (layers[i].filename)
436 free_layer_data(&layers[i]);
437 }
438 free(layers);
439 }
440
441
442 int main(int argc, char *argv[])
443 {
444 GlazingLayer *layers = NULL;
445 int num_layers = 0;
446 int layer_capacity = 0;
447 int success = 1;
448 double wvl_start_nm = 380.;
449 double wvl_end_nm = 780.;
450 double wvl_interval_nm = 5.;
451 int nwvl = 81;
452 double thickness_m = 0.003;
453 char *filename;
454 char *prefix = "unnamed";
455 char file_t[MAX_NAME];
456 char file_r[MAX_NAME];
457 progname = argv[0];
458 if (argc <= 1) {
459 print_usage();
460 return EXIT_FAILURE;
461 }
462
463 for (int i=1; i < argc; ++i) {
464 switch (argv[i][1]) {
465 case 'm':
466 filename = argv[++i];
467 thickness_m = atof(argv[++i]);
468 if (!add_layer(&layers, &num_layers, &layer_capacity, filename, thickness_m, 1)) {
469 cleanup_layers(layers, num_layers);
470 return EXIT_FAILURE;
471 }
472 break;
473 case 'c':
474 filename = argv[++i];
475 if (!add_layer(&layers, &num_layers, &layer_capacity, filename, thickness_m, 0)) {
476 cleanup_layers(layers, num_layers);
477 return EXIT_FAILURE;
478 }
479 break;
480 case 'p':
481 prefix = argv[++i];
482 break;
483 case 's':
484 wvl_start_nm = atof(argv[++i]);
485 wvl_end_nm = atof(argv[++i]);
486 wvl_interval_nm = atof(argv[++i]);
487 if (wvl_start_nm > wvl_end_nm) {
488 fprintf(stderr, "Starting wavelength > End wavelength\n");
489 cleanup_layers(layers, num_layers);
490 return EXIT_FAILURE;
491 }
492 if (((int)(wvl_end_nm - wvl_start_nm) % (int)wvl_interval_nm) > 0) {
493 fprintf(stderr,
494 "Error: Wavelength range (%f to %f nm) must be evenly divisible by the interval (%f nm).\n",
495 wvl_start_nm, wvl_end_nm, wvl_interval_nm);
496 cleanup_layers(layers, num_layers);
497 return EXIT_FAILURE;
498 }
499 break;
500 case 'h':
501 print_usage();
502 return 1;
503 default:
504 break;
505 }
506 }
507 snprintf(file_t, MAX_NAME, "%s_t.dat", prefix);
508 snprintf(file_r, MAX_NAME, "%s_r.dat", prefix);
509
510 if (fabs(wvl_start_nm - wvl_end_nm) < DBL_EPSILON && wvl_interval_nm > DBL_EPSILON) {
511 nwvl = 1;
512 } else {
513 nwvl = (int)((wvl_end_nm - wvl_start_nm) / wvl_interval_nm + 1.5);
514 }
515
516 if (num_layers == 0) {
517 fprintf(stderr, "Error: No layers specified.\n");
518 print_usage();
519 return EXIT_FAILURE;
520 }
521
522 for (int i = 0; i < num_layers; ++i) {
523 if (!interpolate(&layers[i], wvl_start_nm, wvl_end_nm, wvl_interval_nm, nwvl)) {
524 fprintf(stderr, "Error: Failed to parse or interpolate data for layer %d.\n", i + 1);
525 success = 0;
526 break;
527 }
528 layers[i].t_lambda_theta = malloc(NTHETA * nwvl * sizeof(double));
529 layers[i].rf_lambda_theta = malloc(NTHETA * nwvl * sizeof(double));
530 layers[i].rb_lambda_theta = malloc(NTHETA * nwvl * sizeof(double));
531
532 if (layers[i].is_mono) {
533 angular_monolithic(&layers[i], nwvl);
534 } else {
535 angular_coated(&layers[i], nwvl);
536 }
537 }
538
539 if (!success) {
540 cleanup_layers(layers, num_layers);
541 return EXIT_FAILURE;
542 }
543
544
545 size_t total_flat_size = (size_t)NTHETA * nwvl * sizeof(double);
546 double *total_t = malloc(total_flat_size);
547 double *total_rf = malloc(total_flat_size);
548 double *total_rb = malloc(total_flat_size);
549
550 if (!total_t || !total_rf || !total_rb) {
551 perror("Failed to allocate memory for final results");
552 cleanup_layers(layers, num_layers);
553 free(total_t);
554 free(total_rf);
555 free(total_rb);
556 return EXIT_FAILURE;
557 }
558
559 multi_layer_calc(layers, num_layers, nwvl, total_t, total_rf, total_rb);
560
561 success &= write_output_file(file_t, file_r, total_t, total_rf, total_rb, wvl_start_nm, wvl_end_nm, nwvl, argc, argv);
562
563 if (success) {
564 printf("# ");
565 for (int i = 0;i < argc; ++i) {
566 printf("%s ", argv[i]);
567 }
568 printf("\nvoid specdata refl_spec_%s\n", prefix);
569 printf("4 noop %s . 'Acos(Rdot)/DEGREE'\n0\n0\n\n", file_r);
570 printf("void specdata trans_spec_%s\n", prefix);
571 printf("4 noop %s . 'Acos(abs(Rdot))/DEGREE'\n0\n0\n\n", file_t);
572 printf("void WGMDfunc glaze_mat_%s\n13\n\trefl_spec_%s 1 0 0\n\ttrans_spec_%s 1 0 0\n\tvoid\n\t0 0 1 .\n0\n9 0 0 0 0 0 0 0 0 0\n", prefix, prefix, prefix);
573 } else {
574 fprintf(stderr, "Error: Failed to write one or more output files.\n");
575 }
576
577 cleanup_layers(layers, num_layers);
578 free(total_t);
579 free(total_rf);
580 free(total_rb);
581
582 return success ? EXIT_SUCCESS : EXIT_FAILURE;
583 }
