| 1 |
#!/bin/csh -f |
| 2 |
# RCSid: $Id: genbackg.csh,v 2.1 2003/02/22 02:07:23 greg Exp $ |
| 3 |
| 4 |
# Generate height field to surround a mesh with an irregular border |
| 5 |
| 6 |
# 4/16/2002 Greg Ward |
| 7 |
| 8 |
if ( $#argv < 3 ) goto userr |
| 9 |
# Get arguments |
| 10 |
set mat = $1 |
| 11 |
set nam = $2 |
| 12 |
set mesh = $3 |
| 13 |
# Get options |
| 14 |
set smooth="" |
| 15 |
set i = 4 |
| 16 |
while ( $i <= $#argv ) |
| 17 |
switch ($argv[$i]) |
| 18 |
case -c: |
| 19 |
@ i++ ; set a=$i |
| 20 |
@ i++ ; set b=$i |
| 21 |
@ i++ ; set c=$i |
| 22 |
set c00=($argv[$a] $argv[$b] $argv[$c]) |
| 23 |
@ i++ ; set a=$i |
| 24 |
@ i++ ; set b=$i |
| 25 |
@ i++ ; set c=$i |
| 26 |
set c01=($argv[$a] $argv[$b] $argv[$c]) |
| 27 |
@ i++ ; set a=$i |
| 28 |
@ i++ ; set b=$i |
| 29 |
@ i++ ; set c=$i |
| 30 |
set c11=($argv[$a] $argv[$b] $argv[$c]) |
| 31 |
@ i++ ; set a=$i |
| 32 |
@ i++ ; set b=$i |
| 33 |
@ i++ ; set c=$i |
| 34 |
set c10=($argv[$a] $argv[$b] $argv[$c]) |
| 35 |
unset a b c |
| 36 |
breaksw |
| 37 |
case -r: |
| 38 |
@ i++ |
| 39 |
set step = $argv[$i] |
| 40 |
breaksw |
| 41 |
case -b: |
| 42 |
@ i++ |
| 43 |
set bord = $argv[$i] |
| 44 |
breaksw |
| 45 |
case -s: |
| 46 |
set smooth="-s" |
| 47 |
breaksw |
| 48 |
default: |
| 49 |
goto userr |
| 50 |
endsw |
| 51 |
@ i++ |
| 52 |
end |
| 53 |
# Get corner points |
| 54 |
set lim=(`getbbox -h $mesh`) |
| 55 |
if (! $?bord ) then |
| 56 |
set bord=`ev "($lim[2]-$lim[1]+$lim[4]-$lim[3])/20"` |
| 57 |
endif |
| 58 |
if (! $?c00 ) then |
| 59 |
set c00=(`ev "$lim[1]-$bord" "$lim[3]-$bord" "($lim[5]+$lim[6])/2"`) |
| 60 |
set c01=(`ev "$lim[2]+$bord" "$lim[3]-$bord" "($lim[5]+$lim[6])/2"`) |
| 61 |
set c10=(`ev "$lim[1]-$bord" "$lim[4]+$bord" "($lim[5]+$lim[6])/2"`) |
| 62 |
set c11=(`ev "$lim[2]+$bord" "$lim[4]+$bord" "($lim[5]+$lim[6])/2"`) |
| 63 |
endif |
| 64 |
# Get mesh resolution |
| 65 |
if (! $?step ) then |
| 66 |
set step=`ev "sqrt(($c11[1]-$c00[1])*($c11[1]-$c00[1])+($c11[2]-$c00[2])*($c11[2]-$c00[2]))/70"` |
| 67 |
endif |
| 68 |
set res=(`ev "ceil(sqrt(($c01[1]-$c00[1])*($c01[1]-$c00[1])+($c01[2]-$c00[2])*($c01[2]-$c00[2]))/$step)" "ceil(sqrt(($c10[1]-$c00[1])*($c10[1]-$c00[1])+($c10[2]-$c00[2])*($c10[2]-$c00[2]))/$step)"`) |
| 69 |
set edgef=`mktemp /tmp/edgerad.XXXXXX` |
| 70 |
cat > $edgef << _EOF_ |
| 71 |
void sphere c00 |
| 72 |
0 0 4 |
| 73 |
$c00 .001 |
| 74 |
void sphere c01 |
| 75 |
0 0 4 |
| 76 |
$c01 .001 |
| 77 |
void sphere c10 |
| 78 |
0 0 4 |
| 79 |
$c10 .001 |
| 80 |
void sphere c11 |
| 81 |
0 0 4 |
| 82 |
$c11 .001 |
| 83 |
void cylinder ex0 |
| 84 |
0 0 7 |
| 85 |
$c00 $c10 .001 |
| 86 |
void cylinder ex1 |
| 87 |
0 0 7 |
| 88 |
$c01 $c11 .001 |
| 89 |
void cylinder ey0 |
| 90 |
0 0 7 |
| 91 |
$c00 $c01 .001 |
| 92 |
void cylinder ey1 |
| 93 |
0 0 7 |
| 94 |
$c10 $c11 .001 |
| 95 |
_EOF_ |
| 96 |
set meshcal=`mkdir /tmp/meshcal.XXXXXX` |
| 97 |
cat > $meshcal << _EOF_ |
| 98 |
lerp(x,y0,y1):(1-x)*y0+x*y1; |
| 99 |
and(a,b):if(a,b,-1); |
| 100 |
or(a,b):if(a,1,b); |
| 101 |
not(a):if(a,-1,1); |
| 102 |
max(a,b):if(a-b,a,b); |
| 103 |
min(a,b):if(a-b,b,a); |
| 104 |
EPS:1e-7; |
| 105 |
XR:min(32,floor($res[1]/2)); |
| 106 |
YR:8; |
| 107 |
eq(a,b):and(a-b+EPS,b-a+EPS); |
| 108 |
sumfun2x(f,y,x0,x1):if(x1-x0+EPS,f(x0,y)+sumfun2x(f,y,x0+1,x1),0); |
| 109 |
sumfun2(f,x0,x1,y0,y1):if(y1-y0+EPS, |
| 110 |
sumfun2x(f,y0,x0,x1)+sumfun2(f,x0,x1,y0+1,y1), 0); |
| 111 |
xpos(xf,yf)=lerp(xf,lerp(yf,$c00[1],$c10[1]),lerp(yf,$c01[1],$c11[1])); |
| 112 |
ypos(xf,yf)=lerp(xf,lerp(yf,$c00[2],$c10[2]),lerp(yf,$c01[2],$c11[2])); |
| 113 |
onedge=or(or(eq(x,0),eq(x,xmax-1)),or(eq(y,0),eq(y,ymax-1))); |
| 114 |
z0:$lim[5]-$bord; |
| 115 |
height(xo,yo)=z0+gi(1,xo,yo); |
| 116 |
maxwt(xo,yo):if(and(eq(xo,0),eq(yo,0)),100,1/(xo*xo+yo*yo)); |
| 117 |
wt(xo,yo)=if(height(xo,yo)-1e9, 0, maxwt(xo,yo)); |
| 118 |
wtv(xo,yo)=wt(xo,yo)*height(xo,yo); |
| 119 |
wts=sumfun2(wt,-XR,XR,-YR,YR); |
| 120 |
sum=sumfun2(wtv,-XR,XR,-YR,YR); |
| 121 |
inmesh=and(not(onedge),eq(sumfun2(wt,-1,1,-1,1),sumfun2(maxwt,-1,1,-1,1))); |
| 122 |
lo=if(inmesh,1e10,if(wts-EPS,sum/wts,($lim[5]+$lim[6])/2)); |
| 123 |
_EOF_ |
| 124 |
# Generate height image |
| 125 |
set meshoct=`/tmp/meshoct.XXXXXXX` |
| 126 |
xform -m void $mesh | oconv - $edgef > $meshoct |
| 127 |
set meshpic=`mktemp /tmp/meshpic.XXXXXX` |
| 128 |
cnt $res[2] $res[1] \ |
| 129 |
| rcalc -e 'sp=$2/'"($res[1]-1)" -e 'tp=1-$1/'"($res[2]-1)" \ |
| 130 |
-f $meshcal -e "xp=xpos(sp,tp);yp=ypos(sp,tp)" \ |
| 131 |
-e '$1=xp;$2=yp;$3=z0;$4=0;$5=0;$6=1' \ |
| 132 |
| rtrace -w -faf -oL -x $res[1] -y $res[2] $meshoct \ |
| 133 |
| pvalue -r -b -df > $meshpic |
| 134 |
rm $edgef $meshoct |
| 135 |
# Output mesh surround |
| 136 |
cat << _EOF_ |
| 137 |
# $0 $argv[*] |
| 138 |
# Corner points: |
| 139 |
# $c00 |
| 140 |
# $c01 |
| 141 |
# $c11 |
| 142 |
# $c10 |
| 143 |
_EOF_ |
| 144 |
pflip -v $meshpic \ |
| 145 |
| pcomb -f $meshcal - \ |
| 146 |
| pvalue -h -H -pG -d \ |
| 147 |
| gensurf $mat $nam 'xpos(s,t)' 'ypos(s,t)' - \ |
| 148 |
`ev $res[1]-1 $res[2]-1` \ |
| 149 |
-e 'valid(xf,yf)=1e9-Z`SYS(xf,yf)' \ |
| 150 |
-f $meshcal $smooth |
| 151 |
rm $meshcal $meshpic |
| 152 |
# All done -- exit |
| 153 |
exit 0 |
| 154 |
# Usage error message |
| 155 |
userr: |
| 156 |
echo Usage: $0 "mat name mesh_file [-c corners][-b bord_width][-r step_size][-s]" |
| 157 |
exit 1 |
