root/radiance/src/gen/Rmakefile
Sat Aug 21 11:54:06 2004 UTC (21 years, 1 month ago) by greg
Changes since 2.11: +5 -3 lines
Thu Jan 1 19:31:45 2004 UTC (21 years, 9 months ago) by greg
Mon Oct 20 15:10:18 2003 UTC (22 years ago) by greg
Mon Aug 4 22:37:53 2003 UTC (22 years, 2 months ago) by greg
Fri Jun 27 06:53:22 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.7: +7 -5 lines
Sat Feb 22 02:07:23 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.6: +10 -5 lines
Tue Mar 19 12:37:44 1996 UTC (29 years, 7 months ago) by greg
added -r option to genprism
Thu May 25 16:38:09 1995 UTC (30 years, 4 months ago) by greg
Changes since 2.4: +8 -5 lines
added genclock program
Thu Dec 9 17:29:24 1993 UTC (31 years, 10 months ago) by greg
Changes since 2.3: +12 -11 lines
added MLIB for redefining math library
Fri Jul 9 09:10:05 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.2: +1 -3 lines
removed genpine and genwindow
Wed Jul 1 15:07:08 1992 UTC (33 years, 3 months ago) by greg
Changes since 2.1: +14 -13 lines
Tue Nov 12 17:04:55 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.22: +0 -0 lines
Diff to previous 1.22
Thu Nov 7 11:05:20 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.21
removed STRUCTASSIGN macro
Thu Oct 24 10:32:19 1991 UTC (33 years, 11 months ago) by greg
Diff to previous 1.20
changed definition of luminous efficacy!
Wed Oct 23 10:46:07 1991 UTC (34 years ago) by greg
Diff to previous 1.19
standardized macro settings
Thu Aug 22 09:23:41 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.18: +7 -8 lines
Diff to previous 1.18
moved librt.a to ../lib
Thu Aug 22 08:55:34 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.17: +7 -1 lines
Diff to previous 1.17
added cal files
Wed Jul 24 16:48:28 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.16: +10 -3 lines
Diff to previous 1.16
first version of mkillum
Mon Jul 15 13:07:29 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.15: +16 -32 lines
Diff to previous 1.15
moved many routines to a common library
Wed Jun 26 13:00:30 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.14
corrected oversight for xf.o dependencies
Tue Apr 23 15:53:11 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.13
added RCONST to compilation of caldefn.o
Thu Apr 11 09:21:21 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.12
Tue Mar 19 12:11:03 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.11
modified for LESO machines
Thu Mar 7 14:48:28 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.10: +6 -3 lines
Diff to previous 1.10
Sun Feb 17 22:37:05 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.9: +5 -2 lines
Diff to previous 1.9
added replmarks
Sat Dec 15 15:00:54 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.8: +4 -2 lines
Diff to previous 1.8
added MAT4 type
Thu Dec 13 11:25:57 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.7: +2 -0 lines
Diff to previous 1.7
added otypes.h to xform.c for upward compatibility
Fri Jan 19 00:01:15 1990 UTC (35 years, 9 months ago) by greg
Changes since 1.6: +4 -2 lines
Diff to previous 1.6
added portability of bcopy()
Wed Oct 18 17:44:07 1989 UTC (36 years ago) by greg
Diff to previous 1.5
improved smoothing in gensurf
Sat Oct 14 11:34:08 1989 UTC (36 years ago) by greg
Changes since 1.4: +3 -1 lines
Diff to previous 1.4
Wed Oct 4 16:07:54 1989 UTC (36 years ago) by greg
Diff to previous 1.3
Added fgetline.o
Thu Mar 9 09:06:00 1989 UTC (36 years, 7 months ago) by greg
Changes since 1.2: +0 -1 lines
got rid of sccs check
Thu Feb 2 14:58:40 1989 UTC (36 years, 8 months ago) by greg
Changes since 1.1: +5 -2 lines
fixed .csh installs
Thu Feb 2 11:16:21 1989 UTC (36 years, 8 months ago) by greg
