root/radiance/src/gen/README
Revision: 2.2
Committed: Wed Sep 30 11:57:10 1992 UTC (33 years ago) by greg
Changes since 2.1: +5 -1 lines
added descriptions of .cal files
1 GENERATOR PROGRAMS
2 SCCSid "$SunId$ LBL"
3
4 This directory contains programs for generating and transforming
5 Radiance scene descriptions.
6
7 mkillum.h common definitions for mkillum
8 genbeads.c generate a string of spheres using Hermite curve
9 genblinds.c make some curved or flat venetian blinds
10 genbox.c generate a parallelepiped
11 genprism.c generate a prism
12 genrev.c program to generate functions of rotation about z
13 gensky.c program to generate sky functions
14 gensurf.c program to generate functional surfaces
15 genworm.c program to generate worms (strings with varying thickness)
16 hermite3.c routines for 3D hermite curves
17 illum.cal function file for mkillum output
18 mkillum.c make illum sources for optimizing rendering process
19 mkillum2.c routines to do the actual calculation for mkillum
20 mkillum3.c routines to print mkillum objects
21 replmarks.c replace markers with objects or instances
22 rev.cal function file for smoothing option of genrev
23 skybright.cal function file for gensky output
24 sun.c solar postion calculations
25 surf.cal function file for gensurf smoothing
26 xform.c program to transform object files
