root/radiance/src/cv/transportSimplex.h
Revision: 2.2
Committed: Sat Aug 1 23:27:04 2015 UTC (10 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad6R0, HEAD
Changes since 2.1: +5 -5 lines
Error occurred while calculating annotation data.
1 /* RCSid $Id: transportSimplex.h,v 2.1 2014/03/26 02:52:31 greg Exp $ */
2 /*
3 transportSimplex.h
4
5 A C++ implementation of the transportation simplex algorithm.
6
7 Last edit Sept 3 2006
8
9 Copyright (C) 2006 Darren MacDonald
10 [email protected]
11 www.site.uottawa.ca/~dmacd070/emd
12
13 except some data structures and interface adapted from
14 http://ai.stanford.edu/~rubner/emd/emd.c,
15 Copyright 1998 Yossi Rubner.
16
17 This algorithm solves the problem of finding the least-cost way to transport
18 goods from a set of source (supply) nodes to a set of sink (demand) nodes.
19
20 To use the code, simply include this file in the user code and add 'using namespace t_simplex;'.
21 Organize the nodes into signatures using the TsSignature<TF> class, which contains a feature
22 array (of type TF) and an array of the respective weights of the features.
23
24 Solve the system by calling
25 transportSimplex(&Sig1, &Sig2, grndDist);
26 where Sig1 is the source signature, containing an array of source features and an array of their respective
27 supplies, Sig2 is the sink signature, containing the sink features and and their respective demands, and
28 grndDist is a pointer to a function which accepts two features pointers as arguments and returns the unit
29 cost of transporting goods between the two.
30
31 transportSimplex either returns the optimal transportation cost or throws a TsError.
32
33 For more information see the documentation at
34 www.site.uottawa.ca/~dmacd070/emd/index.html
35 and the example implemenation at
36 www.site.uottawa.ca/~dmacd070/emd/main.cpp.
37 */
38
39 #ifndef _T_SIMPLEX_H
40 #define _T_SIMPLEX_H
41 #include <iostream>
42 #include <stdlib.h>
43 #include <math.h>
44 #include <new>
45
46 #define TSINFINITY 1e20
47 #define TSEPSILON 1e-6
48 #define TSPIVOTLIMIT 0.00
49
50 namespace t_simplex {
51
52 /* DECLARATION OF DATA TYPES */
53 enum TsError { TsErrBadInput };
54
55 //TsSignature is used for inputting the source and sink signatures
56 template <class TF>
57 class TsSignature {
58 public:
59 int n; // Number of features in the signature
60 TF *features; // Pointer to the features vector
61 double *weights; // Pointer to the weights of the features
62 TsSignature(int nin, TF *fin, double * win):n(nin), features(fin), weights(win){};
63 };
64
65 //TsFlow is used for outputting the final flow table
66 typedef struct TsFlow {
67 int from; // Feature number in signature 1
68 int to; // Feature number in signature 2
69 double amount; // Amount of flow from signature1.features[from] to signature2.features[to]
70 } TsFlow;
71
72 // TsBasic is used for 2D lists, allowing for easy navigation of the basic variables
73 typedef struct TsBasic{
74 int i, j;
75 double val;
76 TsBasic *nextSnk, *prevSnk; // next/previous node in the column
77 TsBasic *nextSrc, *prevSrc; // next/previous node in the row
78 } TsBasic;
79
80 // TsStone is used for _BFS
81 typedef struct TsStone {
82 struct TsStone *prev;
83 struct TsBasic *node;
84 } TsStone;
85
86 // TsRusPen is used for 1D lists in _initRussel
87 typedef struct TsRusPen {
88 int i;
89 double val;
90 struct TsRusPen *next, *prev;
91 } TsRusPen;
92
93 // TsVogPen is used for 1D lists in _initVogel
94 typedef struct TsVogPen {
95 int i;
96 struct TsVogPen *next, *prev;
97 int one, two;
98 double oneCost, twoCost;
99 } TsVogPen;
100
101 /* DECLARATION OF GLOBALS */
102 double ** _tsC = NULL; // Cost matrix
103 double _tsMaxC; // Maximum of all costs
104 double _tsMaxW; // Maximum of all weights
105
106
107 /* INTERNAL FUNCTIONS */
108 double _pivot(TsBasic * basics, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2);
109 TsStone * _BFS(TsStone *stoneTree, TsBasic ** srcBasics, TsBasic ** snkBasics, bool complete = false);
110 void _initVogel(double *S, double *D, TsBasic * basicsEnd, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2);
111 void _initRussel(double *S, double *D, TsBasic * basicsEnd, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2);
112
113 /*
114 transportSimplex() - Program entry point.
115
116 signature1 and signature2 define the source and sink sets. Unit costs between two features are computed from
117 grndDist. Signature weights must be positive and all costs must be positive.
118 TsFlow is an output parameter which can be set to an array that will be filled with the final flow amounts.
119 The array must be of size signature1->n + signature2->n - 1 . flowSize is a pointer to an integer which
120 indicates the number of functional entries in Flow, because all spaces are not necessarily used. Flow and
121 flowSize can be set to NULL or omitted from the argument list if this information is not important.
122
123 The return value is the transportation cost.
124
125 */
126 template <class TF>
127 double transportSimplex(TsSignature<TF> *signature1, TsSignature<TF> *signature2, double (*grndDist)(TF *, TF *),
128 TsFlow *flowTable = NULL, int *flowSize = NULL) {
129
130 int n1, n2; // number of features in signature1 and Signature 2
131 int i, j;
132
133 double totalCost;
134 double w;
135
136 double srcSum, snkSum, diff;
137
138 TF *P1, *P2;
139
140 n1 = signature1->n;
141 n2 = signature2->n;
142
143 TsBasic * basics = NULL; ///Array of basic variables.
144 bool ** isBasic = NULL; //Flag matrix. isBasic[i][j] is true there is flow between source i and sink j
145 TsBasic **srcBasics = NULL; //Array of pointers to the first basic variable in each row
146 TsBasic **snkBasics = NULL; //Array of pointers to the first basic variable in each column
147 double * src = NULL; //Array of source supplies
148 double * snk =NULL; //Array of sink demands
149
150
151 // Equalize source and sink weights. A dummy source or sink may be added to equalize the total sink
152 // and source weights. n1 = signature1->n + 1 if there is a dummy source, and n2 = signature2->n + 1
153 // if there is a dummy sink.
154 srcSum = 0.0;
155 for(i=0; i < n1; i++)
156 srcSum += signature1->weights[i];
157
158 snkSum = 0.0;
159 for(j=0; j < n2; j++)
160 snkSum += signature2->weights[j];
161
162 diff = srcSum - snkSum;
163 if (fabs(diff) > TSEPSILON * srcSum) {
164 if (diff < 0.0)
165 n1++;
166 else
167 n2++;
168 }
169 _tsMaxW = srcSum > snkSum ? srcSum : snkSum;
170 w = srcSum < snkSum ? srcSum : snkSum;
171
172 //Allocate memory for arrays
173 try {
174
175 basics = new TsBasic[n1 + n2];
176
177 isBasic = new bool*[n1];
178 for(i = 0; i < n1; i++)
179 isBasic[i] = NULL;
180
181 for(i = 0; i < n1; i++) {
182 isBasic[i] = new bool[n2];
183 for (j=0; j < n2; j++)
184 isBasic[i][j] = 0;
185 }
186
187 srcBasics = new TsBasic*[n1];
188 for (i = 0; i < n1; i++)
189 srcBasics[i] = NULL;
190
191 snkBasics = new TsBasic*[n2];
192 for (i = 0; i < n2; i++)
193 snkBasics[i] = NULL;
194
195 // Compute the cost matrix
196 _tsMaxC = 0;
197 _tsC = new double*[n1];
198 for(i=0; i < n1; i++)
199 _tsC[i] = NULL;
200
201 for(i=0, P1=signature1->features; i < n1; i++, P1++) {
202 _tsC[i] = new double[n2]; //What happens if bad here?
203 for(j=0, P2=signature2->features; j < n2; j++, P2++) {
204 if (i == signature1->n || j == signature2->n) {
205 _tsC[i][j] = 0; // cost is zero for flow to or from a dummy
206 } else {
207 _tsC[i][j] = grndDist(P1, P2);
208 if (_tsC[i][j] < 0) throw TsErrBadInput;
209 }
210
211
212 if (_tsC[i][j] > _tsMaxC)
213 _tsMaxC = _tsC[i][j];
214 }
215 }
216
217 src = new double[n1]; //init the source array
218 for (i = 0; i < signature1->n; i++) {
219 src[i] = signature1->weights[i];
220 if (src[i] < 0) throw TsErrBadInput;
221 }
222 if (n1 != signature1->n)
223 src[signature1->n] = -diff;
224
225 snk = new double[n2]; //init the sink array
226 for (i = 0; i < signature2->n; i++) {
227 snk[i] = signature2->weights[i];
228 if (snk[i] < 0) throw TsErrBadInput;
229 }
230 if (n2 != signature2->n)
231 snk[signature2->n] = diff;
232
233 // Find the initail basic feasible solution. Use either _initRussel or _initVogel
234
235
236 _initRussel(src, snk, basics, srcBasics, snkBasics, isBasic, n1, n2);
237 //_initVogel(src, snk, basics, srcBasics, snkBasics, isBasic, n1, n2);
238
239
240 // Enter the main pivot loop
241 totalCost = _pivot(basics, srcBasics, snkBasics, isBasic, n1, n2);
242
243 } catch (...) {
244 for(i = 0; i < n1; i++)
245 delete[] isBasic[i];
246 delete[] isBasic;
247
248 for (i = 0; i < n1; i++)
249 delete[] _tsC[i];
250 delete[] _tsC;
251
252 delete[] src;
253 delete[] snk;
254 delete[] srcBasics;
255 delete[] snkBasics;
256 delete[] basics;
257
258 throw;
259 }
260
261 // Fill the Flow data structure
262 TsBasic * basicPtr;
263 TsFlow * flowPtr = flowTable;
264 if (flowTable != NULL) {
265 for (i = 0; i < n1+n2 -1; i++) {
266 basicPtr = basics + i;
267 if (isBasic[basicPtr->i][basicPtr->j] && basicPtr->i != signature1->n && basicPtr->j != signature2->n && basicPtr->val != 0.0) {
268 flowPtr->to = basicPtr->j;
269 flowPtr->from = basicPtr->i;
270 flowPtr->amount = basicPtr->val;
271 flowPtr++;
272 }
273 }
274 }
275 if (flowSize != NULL) {
276 *flowSize = (int)(flowPtr - flowTable);
277 }
278
279
280 for(i = 0; i < n1; i++)
281 delete[] isBasic[i];
282 delete[] isBasic;
283
284 for (i = 0; i < n1; i++)
285 delete[] _tsC[i];
286 delete[] _tsC;
287
288 delete[] src;
289 delete[] snk;
290 delete[] srcBasics;
291 delete[] snkBasics;
292 delete[] basics;
293
294 return totalCost;
295 }
296
297 /*
298 Main pivot loop.
299 Pivots until the system is optimal and return the optimal transportation cost.
300 */
301 double _pivot(TsBasic * basics, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2) {
302
303 double * srcDuals = NULL;
304 double * snkDuals = NULL;
305 TsStone * stonePath = NULL;
306
307 TsStone * spitra, * spitrb, * leaving;
308 TsBasic * XP;
309 TsBasic * basicsEnd = basics + n1 + n2;
310 TsBasic * entering = basicsEnd - 1 ;
311 TsBasic dummyBasic;
312 dummyBasic.i = -1;
313 dummyBasic.j = 0;
314
315 int i,j, lowI, lowJ;
316 double objectiveValue = TSINFINITY, oldObjectiveValue = 0;
317 double lowVal;
318 int numPivots = 0;
319
320 try {
321 srcDuals = new double[n1];
322 snkDuals = new double[n2];
323 stonePath = new TsStone[n1 + n2];
324 } catch (std::bad_alloc) {
325 delete[] srcDuals;
326 delete[] snkDuals;
327 delete[] stonePath;
328 throw;
329 }
330
331 while (1) {
332
333 oldObjectiveValue = objectiveValue;
334 objectiveValue = 0;
335
336 for (XP = basics; XP != basicsEnd; XP++){
337 if (XP != entering)
338 objectiveValue += _tsC[XP->i][XP->j] * XP->val;
339 }
340
341 // Compute the dual variables for each row and column. Begin by finding a spanning tree (stonepath)
342 // of the basic variables using the breadth-first search routine seeded at an imaginary basic
343 // variable in the first column. The dual variables can then be computed incrementally by traversing
344 // the tree.
345 stonePath[0].node = &dummyBasic;
346 stonePath[0].prev = NULL;
347 spitrb = _BFS(stonePath, srcBasics, snkBasics, true);
348
349 spitra = stonePath;
350 snkDuals[spitra->node->j] = 0;
351 for (spitra++; spitra != spitrb; spitra++) {
352 if (spitra->node->i == spitra->prev->node->i) {
353 //node is in same row as parent
354 snkDuals[spitra->node->j] = _tsC[spitra->node->i][spitra->node->j] - srcDuals[spitra->node->i];
355 } else if (spitra->node->j == spitra->prev->node->j) {
356 srcDuals[spitra->node->i] = _tsC[spitra->node->i][spitra->node->j] - snkDuals[spitra->node->j];
357 }
358 }
359
360 // After computing the duals, find the non-basic variable that has the greatest negative value of
361 // delta = _tsC[i][j] - srcDuals[i] - snkDuals[j]. This is the entering variable
362 lowVal = 0.0;
363 for (i = 0; i < n1; i++)
364 for (j = 0; j < n2; j++)
365 if (!isBasic[i][j] && _tsC[i][j] - srcDuals[i] - snkDuals[j] < lowVal) {
366 lowVal = _tsC[i][j] - srcDuals[i] - snkDuals[j];
367 lowI = i;
368 lowJ = j;
369 }
370
371 // If all delta values are non-negative, the table is optimal
372 if (lowVal >= -TSEPSILON * _tsMaxC || (oldObjectiveValue - objectiveValue) < TSPIVOTLIMIT) {
373 delete[] srcDuals;
374 delete[] snkDuals;
375 delete[] stonePath;
376 //std::cout << numPivots << "\t";
377 return objectiveValue;
378 }
379
380 // Add the entering variable
381 entering->i = lowI;
382 entering->j = lowJ;
383 isBasic[lowI][lowJ] = 1;
384 entering->val = 0;
385
386 entering->nextSrc = srcBasics[lowI];
387 if (srcBasics[lowI] != NULL) srcBasics[lowI]->prevSrc = entering;
388 entering->nextSnk = snkBasics[lowJ];
389 if (snkBasics[lowJ] != NULL) snkBasics[lowJ]->prevSnk = entering;
390
391 srcBasics[lowI] = entering;
392 entering->prevSrc = srcBasics[lowI];
393 snkBasics[lowJ] = entering;
394 entering->prevSnk = snkBasics[lowJ];
395
396 stonePath[0].node = entering;
397 stonePath[0].prev = NULL;
398
399 // Use breadth-first search to find a loop of basics.
400 spitra = spitrb = _BFS(stonePath, srcBasics, snkBasics);
401 lowVal = TSINFINITY;
402 bool add = false;
403
404 // Find the lowest flow along the loop (leaving variable)
405 do {
406 if (!add && spitrb->node->val < lowVal) {
407 leaving = spitrb;
408 lowVal = spitrb->node->val;
409 }
410 add = !add;
411 } while ((spitrb = spitrb->prev));
412
413 add = false;
414 spitrb = spitra;
415
416 // Alternately increase and decrease flow along the loop
417 do {
418 if (add) spitrb->node->val += lowVal;
419 else spitrb->node->val -= lowVal;
420 add = !add;
421 } while ((spitrb = spitrb->prev));
422
423 i = leaving->node->i;
424 j = leaving->node->j;
425 isBasic[i][j] = 0;
426
427
428 if (srcBasics[i] == leaving->node) {
429 srcBasics[i] = leaving->node->nextSrc;
430 srcBasics[i]->prevSrc = NULL;
431 } else {
432 leaving->node->prevSrc->nextSrc = leaving->node->nextSrc;
433 if (leaving->node->nextSrc != NULL)
434 leaving->node->nextSrc->prevSrc = leaving->node->prevSrc;
435 }
436
437 if (snkBasics[j] == leaving->node) {
438 snkBasics[j] = leaving->node->nextSnk;
439 snkBasics[j]->prevSnk = NULL;
440 } else {
441 leaving->node->prevSnk->nextSnk = leaving->node->nextSnk;
442 if (leaving->node->nextSnk != NULL)
443 leaving->node->nextSnk->prevSnk = leaving->node->prevSnk;
444 }
445 entering = leaving->node;
446 numPivots++;
447 }
448 };
449
450
451 /*******************
452 _BFS
453 Perform a breadth-first search of the basic varaibles. The search tree is stored in stoneTree, where each
454 'stone' contains a pointer to a basic variable, and a pointer to that stone's parent. srcBasics and snkBasics
455 are arrays of linked lists which allow for easy identification of a node's neighbours in the flow network.
456 If complete == true, find all basics in the table. Otherwise, terminate when a basic variable which completes
457 a loop has been found and return a pointer to the final stone in the loop.
458 *********************/
459 TsStone * _BFS(TsStone * stoneTree, TsBasic ** srcBasics, TsBasic ** snkBasics, bool complete) {
460 bool column = true;
461 int jumpoffset = 0;
462 TsBasic * bitr;
463 TsStone * sitra = &stoneTree[0], * sitrb = &stoneTree[1];
464 do {
465 if (column) {
466 for (bitr = snkBasics[sitra->node->j]; bitr != NULL; bitr = bitr->nextSnk) {
467 if (bitr != sitra->node){
468 sitrb->node = bitr;
469 sitrb->prev = sitra;
470 sitrb++;
471 }
472 }
473 } else {
474 for (bitr = srcBasics[sitra->node->i]; bitr != NULL; bitr = bitr->nextSrc) {
475 if (bitr != sitra->node){
476 sitrb->node = bitr;
477 sitrb->prev = sitra;
478 sitrb++;
479 }
480 }
481 }
482
483 sitra++;
484 if (sitra == sitrb) //no cycle found and no cycles in tree
485 return sitra;
486
487 if (sitra->node->i == sitra->prev->node->i)
488 column = true;
489 else
490 column = false;
491
492 // cycle found
493 if (!complete && sitra->node->i == stoneTree[0].node->i && sitra->node->j != stoneTree[0].node->j && column == false)
494 return sitra;
495 } while(1);
496 }
497
498
499 // Helper function for _initVogel
500 inline void addPenalty(TsVogPen * pitr, double cost, int i) {
501 if (cost < pitr->oneCost) {
502 pitr->twoCost = pitr->oneCost;
503 pitr->two = pitr->one;
504 pitr->oneCost = cost;
505 pitr->one = i;
506 } else if (cost < pitr->twoCost) {
507 pitr->twoCost = cost;
508 pitr->two = i;
509 }
510 }
511
512
513 /**********************
514 Vogel's initialization method
515 **********************/
516 void _initVogel(double *S, double *D, TsBasic * basicsEnd, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2) {
517 int i, j;
518 TsVogPen *srcPens = NULL;
519 TsVogPen *snkPens = NULL;
520 TsVogPen *pitra, *pitrb; //iterators
521 TsVogPen *maxPen;
522 TsVogPen srcPenHead, snkPenHead;
523 bool maxIsSrc;
524 double lowVal;
525
526 try {
527 srcPens = new TsVogPen[n1];
528 snkPens = new TsVogPen[n2];
529 } catch (std::bad_alloc) {
530 delete[] srcPens;
531 delete[] snkPens;
532 throw;
533 }
534
535 srcPenHead.next = pitra = srcPens;
536 for (i=0; i < n1; i++) {
537 pitra->i = i;
538 pitra->next = pitra+1;
539 pitra->prev = pitra-1;
540 pitra->one = pitra->two = 0;
541 pitra->oneCost = pitra->twoCost = TSINFINITY;
542 pitra++;
543 }
544 (--pitra)->next = NULL;
545 srcPens[0].prev = &srcPenHead;
546
547 snkPenHead.next = pitra = snkPens;
548 for (i=0; i < n2; i++) {
549 pitra->i = i;
550 pitra->next = pitra+1;
551 pitra->prev = pitra-1;
552 pitra->one = pitra->two = 0;
553 pitra->oneCost = pitra->twoCost = TSINFINITY;
554 pitra++;
555 }
556 (--pitra)->next = NULL;
557 snkPens[0].prev = &snkPenHead;
558
559
560 for (pitra = srcPenHead.next, i=0; pitra != NULL; pitra = pitra->next, i++)
561 for (pitrb = snkPenHead.next, j=0; pitrb != NULL; pitrb = pitrb->next, j++) {
562 //initialize Source Penalties;
563 addPenalty(pitra, _tsC[i][j], j);
564 addPenalty(pitrb, _tsC[i][j], i);
565 }
566
567
568 while (srcPenHead.next != NULL && snkPenHead.next != NULL) {
569 maxIsSrc = true;
570 for (maxPen = pitra = srcPenHead.next; pitra != NULL; pitra = pitra->next)
571 if ((pitra->twoCost - pitra->oneCost) > (maxPen->twoCost - maxPen->oneCost))
572 maxPen = pitra;
573
574 for (pitra = snkPenHead.next; pitra != NULL; pitra = pitra->next)
575 if ((pitra->twoCost - pitra->oneCost) > (maxPen->twoCost - maxPen->oneCost)) {
576 maxPen = pitra;
577 maxIsSrc = false;
578 }
579
580 if (maxIsSrc) {
581 i = maxPen->i;
582 j = maxPen->one;
583 } else {
584 j = maxPen->i;
585 i = maxPen->one;
586 }
587
588 if (D[j] - S[i] > _tsMaxW * TSEPSILON || (srcPenHead.next->next != NULL && fabs(S[i] - D[j]) < _tsMaxW * TSEPSILON)) {
589 //delete source
590 lowVal = S[i];
591 maxPen = srcPens + i;
592 maxPen->prev->next = maxPen->next;
593 if (maxPen->next != NULL)
594 maxPen->next->prev = maxPen->prev;
595
596 for (pitra = snkPenHead.next; pitra != NULL; pitra = pitra->next) {
597 if (pitra->one == i || pitra->two == i){
598 pitra->oneCost = TSINFINITY;
599 pitra->twoCost = TSINFINITY;
600 for (pitrb = srcPenHead.next; pitrb != NULL; pitrb = pitrb->next)
601 addPenalty(pitra, _tsC[pitrb->i][pitra->i], pitrb->i);
602 }
603 }
604 } else {
605 //delete sink
606 lowVal = D[j];
607 maxPen = snkPens + j;
608 maxPen->prev->next = maxPen->next;
609 if (maxPen->next != NULL)
610 maxPen->next->prev = maxPen->prev;
611
612 for (pitra = srcPenHead.next; pitra != NULL; pitra = pitra->next) {
613 if (pitra->one == j || pitra->two == j){
614 pitra->oneCost = TSINFINITY;
615 pitra->twoCost = TSINFINITY;
616 for (pitrb = snkPenHead.next; pitrb != NULL; pitrb = pitrb->next)
617 addPenalty(pitra, _tsC[pitra->i][pitrb->i], pitrb->i);
618 }
619 }
620 }
621
622 S[i] -= lowVal;
623 D[j] -= lowVal;
624
625 isBasic[i][j] = 1;
626 basicsEnd->val = lowVal;
627 basicsEnd->i = i;
628 basicsEnd->j = j;
629
630 basicsEnd->nextSnk = snkBasics[j];
631 if (snkBasics[j] != NULL) snkBasics[j]->prevSnk = basicsEnd;
632 basicsEnd->nextSrc = srcBasics[i];
633 if (srcBasics[i] != NULL) srcBasics[i]->prevSrc = basicsEnd;
634
635 srcBasics[i] = basicsEnd;
636 basicsEnd->prevSnk = NULL;
637 snkBasics[j] = basicsEnd;
638 basicsEnd->prevSrc = NULL;
639
640 basicsEnd++;
641
642 }
643 delete[] srcPens;
644 delete[] snkPens;
645 }
646
647
648 /**********************
649 Russel's initialization method
650 **********************/
651 void _initRussel(double *S, double *D, TsBasic * basicsEnd, TsBasic ** srcBasics, TsBasic ** snkBasics, bool ** isBasic, int n1, int n2) {
652 double ** Delta = NULL;
653 int i, j, lowI, lowJ;
654 TsRusPen *U = NULL;
655 TsRusPen *V = NULL;
656 TsRusPen *Uhead, *Vhead;
657 TsRusPen *Uitr, *Vitr;
658 double cost, lowVal;
659
660 try {
661 Delta = new double*[n1];
662 for (i = 0; i < n1; i++)
663 Delta[i] = new double[n2];
664
665 U = new TsRusPen[n1];
666 V = new TsRusPen[n2];
667 } catch (std::bad_alloc) {
668 for (i = 0; i < n1; i++)
669 delete[] Delta[i];
670 delete[] Delta;
671
672 delete[] U;
673 delete[] V;
674 throw;
675 }
676
677 for (i = 0; i < n1; i++) {
678 U[i].i = i;
679 U[i].val = 0;
680 U[i].next = &U[i+1];
681 U[i].prev = &U[i-1];
682 }
683 U[n1-1].next = NULL;
684 U[0].prev = NULL;
685
686 for (i = 0; i < n2; i++) {
687 V[i].i = i;
688 V[i].val = 0;
689 V[i].next = &V[i+1];
690 V[i].prev = &V[i-1];
691 }
692 V[n2-1].next = NULL;
693 V[0].prev = NULL;
694
695 for (i = 0; i < n1; i++)
696 for (j = 0; j < n2; j++) {
697 cost = _tsC[i][j];
698 if (cost > U[i].val)
699 U[i].val = cost;
700 if (cost > V[j].val)
701 V[j].val = cost;
702 }
703
704 for (i = 0; i < n1; i++)
705 for (j = 0; j < n2; j++)
706 Delta[i][j] = _tsC[i][j] - U[i].val - V[j].val;
707
708 Uhead = U;
709 Vhead = V;
710 while (Uhead != NULL && Vhead != NULL) {
711
712 //Find lowest Delta
713 lowVal = TSINFINITY;
714 for (Uitr = Uhead; Uitr != NULL; Uitr = Uitr->next)
715 for (Vitr = Vhead; Vitr != NULL; Vitr = Vitr->next)
716 if (Delta[Uitr->i][Vitr->i] < lowVal) {
717 lowI = Uitr->i;
718 lowJ = Vitr->i;
719 lowVal = Delta[Uitr->i][Vitr->i];
720 }
721
722
723 if (D[lowJ] - S[lowI] > _tsMaxW * TSEPSILON || (fabs(S[lowI] - D[lowJ]) < _tsMaxW * TSEPSILON && Uhead->next != NULL)) {
724 //Delete Source
725 if (&U[lowI] == Uhead) { //Entering variable is first in list
726 Uhead = Uhead->next;
727 if (Uhead != NULL) Uhead->prev = NULL;
728 } else {
729 U[lowI].prev->next = U[lowI].next; //Entering variable is in middle of list;
730 if (U[lowI].next != NULL) //Entering variable is at the end of the list;
731 U[lowI].next->prev = U[lowI].prev;
732 }
733 //See if this source was the maximum cost for any dest
734 for (Vitr = Vhead; Vitr != NULL; Vitr = Vitr->next) {
735 if (Vitr->val == _tsC[lowI][Vitr->i]) {
736 //it is; update the dest
737 //find maximum cost in the dest
738 Vitr->val = 0;
739 for (Uitr = Uhead; Uitr != NULL; Uitr = Uitr->next)
740 if (_tsC[Uitr->i][Vitr->i] > Vitr->val)
741 Vitr->val = _tsC[Uitr->i][Vitr->i];
742 //update Delta
743 for (Uitr = Uhead; Uitr != NULL; Uitr = Uitr->next)
744 Delta[Uitr->i][Vitr->i] = _tsC[Uitr->i][Vitr->i] - Uitr->val - Vitr->val;
745
746 }
747 }
748 lowVal = S[lowI];
749
750 } else {
751 //Delete Dest
752 if (&V[lowJ] == Vhead) { //Entering variable is first in list
753 Vhead = Vhead->next;
754 if (Vhead != NULL) Vhead->prev = NULL;
755 } else {
756 V[lowJ].prev->next = V[lowJ].next; //Entering variable is in middle of list;
757 if (V[lowJ].next != NULL) //Entering variable is at the end of the list;
758 V[lowJ].next->prev = V[lowJ].prev;
759 }
760 //See if this source was the maximum cost for any dest
761 for (Uitr = Uhead; Uitr != NULL; Uitr = Uitr->next) {
762 if (Uitr->val == _tsC[Uitr->i][lowJ]) {
763 //it is; update the dest
764 //find maximum cost in the dest
765 Uitr->val = 0;
766 for (Vitr = Vhead; Vitr != NULL; Vitr = Vitr->next)
767 if (_tsC[Uitr->i][Vitr->i] > Uitr->val)
768 Uitr->val = _tsC[Uitr->i][Vitr->i];
769 //update Delta
770 for (Vitr = Vhead; Vitr != NULL; Vitr = Vitr->next)
771 Delta[Uitr->i][Vitr->i] = _tsC[Uitr->i][Vitr->i] - Uitr->val - Vitr->val;
772
773 }
774 }
775 lowVal = D[lowJ];
776 }
777
778 S[lowI] -= lowVal;
779 D[lowJ] -= lowVal;
780
781 isBasic[lowI][lowJ] = 1;
782 basicsEnd->val = lowVal;
783 basicsEnd->i = lowI;
784 basicsEnd->j = lowJ;
785
786 basicsEnd->nextSnk = snkBasics[lowJ];
787 if (snkBasics[lowJ] != NULL) snkBasics[lowJ]->prevSnk = basicsEnd;
788 basicsEnd->nextSrc = srcBasics[lowI];
789 if (srcBasics[lowI] != NULL) srcBasics[lowI]->prevSrc = basicsEnd;
790
791 srcBasics[lowI] = basicsEnd;
792 basicsEnd->prevSnk = NULL;
793 snkBasics[lowJ] = basicsEnd;
794 basicsEnd->prevSrc = NULL;
795
796 basicsEnd++;
797
798 }
799
800 delete[] U;
801 delete[] V;
802 for (i = 0; i < n1; i++)
803 delete[] Delta[i];
804 delete[] Delta;
805 }
806 }
807 #endif
808
