| 1 |
/* RCSid: $Id: rayopt.h,v 1.4 2007/09/05 01:36:37 greg Exp $ */ |
| 2 |
| 3 |
| 4 |
Triangle Bounder/Smoother for POV-Ray |
| 5 |
by Steve Anger 1993 |
| 6 |
| 7 |
A number of C routines that can be used to generate POV-Ray ray tracer |
| 8 |
files from triangle data. Supports generation of smooth triangles and an |
| 9 |
optimal set of bounding shapes for much faster traces. |
| 10 |
| 11 |
| 12 |
| 13 |
#ifndef _MGF_RAYOPT_H |
| 14 |
#define _MGF_RAYOPT_H |
| 15 |
#ifdef __cplusplus |
| 16 |
extern "C" { |
| 17 |
#endif |
| 18 |
| 19 |
| 20 |
#include "vect3ds.h" |
| 21 |
| 22 |
void opt_set_format (int format); |
| 23 |
void opt_set_fname (char *pov_name, char *inc_name); |
| 24 |
void opt_set_quiet (int quiet); |
| 25 |
void opt_set_bound (int bound); |
| 26 |
void opt_set_smooth (float smooth); |
| 27 |
void opt_set_vert (unsigned vert); |
| 28 |
void opt_set_dec (int dec); |
| 29 |
| 30 |
void opt_set_color (float red, float green, float blue); |
| 31 |
void opt_set_texture (char *texture_name); |
| 32 |
void opt_set_transform (Matrix mat); |
| 33 |
void opt_clear_transform(); |
| 34 |
int opt_add_tri (float ax, float ay, float az, |
| 35 |
float bx, float by, float bz, |
| 36 |
float cx, float cy, float cz); |
| 37 |
| 38 |
void opt_write_pov (char *obj_name); |
| 39 |
void opt_write_file (char *obj_name); |
| 40 |
void opt_write_box (char *obj_name); |
| 41 |
void opt_finish (void); |
| 42 |
| 43 |
void opt_get_limits (float *min_x, float *min_y, float *min_z, |
| 44 |
float *max_x, float *max_y, float *max_z); |
| 45 |
void opt_get_glimits (float *min_x, float *min_y, float *min_z, |
| 46 |
| 47 |
unsigned opt_get_vert_cnt (void); |
| 48 |
unsigned opt_get_tri_cnt (void); |
| 49 |
float opt_get_index (void); |
| 50 |
unsigned opt_get_bounds (void); |
| 51 |
| 52 |
void abortmsg (char *msg, int exit_code); |
| 53 |
void add_ext (char *fname, char *ext, int force); |
| 54 |
void cleanup_name (char *name); |
| 55 |
| 56 |
| 57 |
| 58 |
| 59 |
#endif |
| 60 |
#endif /* _MGF_RAYOPT_H */ |
| 61 |
