| 1 | MGF PACKAGE DESCRIPTION |
| 2 | RCSid "$Id: readme.txt,v 1.9 2007/07/28 07:12:21 greg Exp $" |
| 3 |  |
| 4 | This package includes a description and parser for a new scene |
| 5 | description standard, called for the lack of a better name, MGF |
| 6 | for Materials and Geometry Format.  It was developed by Greg |
| 7 | Ward of the Lawrence Berkeley Laboratory <[email protected]> with |
| 8 | help and advice from Rob Shakespeare of Indiana University |
| 9 | <[email protected]>, Ian Ashdown of Ledalite Corporation |
| 10 | <[email protected]> and Holly Rushmeier of the National |
| 11 | Institute for Standards and Technology <[email protected]>. |
| 12 |  |
| 13 | The language itself is described in the file "spec.txt", and |
| 14 | the included Makefile should make building the parser library |
| 15 | fairly straightforward on most systems.  What's left then, is |
| 16 | explaining the why and how of using this package. |
| 17 |  |
| 18 | The initial purpose of developing a scene description standard |
| 19 | was for inclusion in the Illumination Engineering Society's (IES) |
| 20 | standard data representation for luminaires.  It occurred to us |
| 21 | early on that such a standard might have broader applications, |
| 22 | so an effort was made to create a fairly general description |
| 23 | language, while keeping it as simple as possible for the people |
| 24 | who have to create descriptions with it as well as the programmers |
| 25 | who have to support it. |
| 26 |  |
| 27 | Why create a new standard rather than exploiting an existing one? |
| 28 | Some of the rationale for our decision is explained at the end of |
| 29 | the specification document, but it mostly boils down to materials. |
| 30 | As easy as it is to describe physically valid materials, most |
| 31 | scene description languages cannot do it.  The material specification |
| 32 | included in the MGF standard may not be perfect, but at least it's |
| 33 | physically plausible.  Furthermore, we are committed to making any |
| 34 | future modifications to the standard backwards-compatible -- a rather |
| 35 | tricky proposition. |
| 36 |  |
| 37 | This takes us to the how of supporting this new standard.  The basic |
| 38 | approach is to use the standard parser, which does a lot of the work |
| 39 | in supporting the language itself.  The programmer tells the parser |
| 40 | which entities it will support, and the parser does the rest. |
| 41 | That way, it isn't necessary to modify the program when a new version |
| 42 | of the standard comes out; all one has to do is link to the new |
| 43 | standard's parser.  (The include file will change as well, so it's |
| 44 | not QUITE that simple, but close.) |
| 45 |  |
| 46 | There are two ways to support the language, by linking the parser to |
| 47 | the program itself, or by linking the parser to a translator program |
| 48 | that expresses MGF entities in the native scene description format. |
| 49 | The differences in the two approaches are slight, and we will mention |
| 50 | them following a general explanation of the parser and support library. |
| 51 |  |
| 52 | The Parser |
| 53 | ========== |
| 54 | The MGF parser is written in ANSI-C (though the -DNOPROTO flag may be |
| 55 | used to get back K&R compatibility).  All of the declarations and |
| 56 | definitions needed are in the single include file "parser.h".  This |
| 57 | file is a good place to look for details on using the various support |
| 58 | routines as well.  The parser itself is parser.c, though it relies for |
| 59 | some translations on other C modules.  These same support routines will |
| 60 | no doubt be useful for applications programmers, and we will explain |
| 61 | some of them in the following sections. |
| 62 |  |
| 63 | Initializing the parser is the most important part of writing an MGF |
| 64 | program, and it is done through the mg_ehand array and a call to mg_init. |
| 65 | The global mg_ehand variable is an array of pointers to entity handler |
| 66 | functions.  The arguments to these functions are always the same, an |
| 67 | argument count and an array of argument pointers (ala main).  The return |
| 68 | value for these integer functions is one of the error codes defined in |
| 69 | parser.h, or MG_OK if the entity was handled correctly.  You must |
| 70 | set the appropriate entries for the entities you can support, then call |
| 71 | mg_init to fill in the rest.  Most of the entities you cannot support |
| 72 | will be translated into (approximately) equivalent ones you can. |
| 73 | Entities that have no equivalent (such as color), will be safely |
| 74 | ignored on the input.  If you have specified support for some entities |
| 75 | without offering support to their prerequisites, mg_init will report an |
| 76 | error and exit. |
| 77 |  |
| 78 | Once the parser has been properly initialized, MGF input files may be |
| 79 | loaded at will with the mg_load call.  This function takes a single |
| 80 | argument, which is the name of the MGF file.  (The NULL pointer may be |
| 81 | used to specify standard input.)  The behavior of the parser in part |
| 82 | depends on input history, so the mg_clear call should be used after |
| 83 | each file if starting fresh is important.  This also frees any data |
| 84 | structures used by the parser, which may be desirable if the program |
| 85 | is going to do something after loading besides exit. |
| 86 |  |
| 87 | Support Functions |
| 88 | ================= |
| 89 | In translating unsupported entities, the parser makes use of a number |
| 90 | of support functions, contained in associated C modules.  The most |
| 91 | important of these are in context.c, which includes three handler |
| 92 | functions that can support all color, material and vertex entities. |
| 93 | To understand what these functions do, it is necessary to know a |
| 94 | little about the MGF language itself, so please familiarize yourself |
| 95 | with it now if you haven't already.  (See the file "spec.txt".) |
| 96 |  |
| 97 | Context Support |
| 98 | =============== |
| 99 | The MGF language defines three named contexts, the current vertex, |
| 100 | the current color and the current material.  (The current color is |
| 101 | used mostly for setting parameters in the current material.)  There |
| 102 | are three handler routines defined in context.c, and they can handle |
| 103 | all entities related to these three contexts.  The simplest way to |
| 104 | support materials, for example, is to initialize the mg_ehand array |
| 105 | such that the MG_E_MATERIAL, MG_E_RD, MG_E_RS, etc. entries all point |
| 106 | to c_hmaterial.  Then, whenever a material is needed, the global |
| 107 | c_cmaterial variable will be pointing to a structure with all the |
| 108 | current settings.  (Note that you would have to also set the color |
| 109 | mg_ehand entries to c_hcolor if you intended to support color |
| 110 | materials.)  A list of related mg_ehand assignments is given below: |
| 111 |  |
| 112 | mg_ehand[MG_E_COLOR] = c_hcolor; |
| 113 | mg_ehand[MG_E_CCT] = c_hcolor; |
| 114 | mg_ehand[MG_E_CMIX] = c_hcolor; |
| 115 | mg_ehand[MG_E_CSPEC] = c_hcolor; |
| 116 | mg_ehand[MG_E_CXY] = c_hcolor; |
| 117 | mg_ehand[MG_E_ED] = c_hmaterial; |
| 118 | mg_ehand[MG_E_IR] = c_hmaterial; |
| 119 | mg_ehand[MG_E_MATERIAL] = c_hmaterial; |
| 120 | mg_ehand[MG_E_NORMAL] = c_hvertex; |
| 121 | mg_ehand[MG_E_POINT] = c_hvertex; |
| 122 | mg_ehand[MG_E_RD] = c_hmaterial; |
| 123 | mg_ehand[MG_E_RS] = c_hmaterial; |
| 124 | mg_ehand[MG_E_SIDES] = c_hmaterial; |
| 125 | mg_ehand[MG_E_TD] = c_hmaterial; |
| 126 | mg_ehand[MG_E_TS] = c_hmaterial; |
| 127 | mg_ehand[MG_E_VERTEX] = c_hvertex; |
| 128 |  |
| 129 | In addition to the three handler functions, context.c contains a |
| 130 | few support routines that make life simpler.  For vertices, there |
| 131 | is the c_getvertex call, which returns a pointer to a named vertex |
| 132 | structure (or NULL if there is no corresponding definition for the |
| 133 | given name).  This function is needed for support of most surface |
| 134 | entities.  For color support, there is the analogous c_getcolor call, |
| 135 | and the c_ccvt routine, which is used to convert from one color |
| 136 | representation to another (e.g.  spectral color to xy chromaticity |
| 137 | coordinates).  Also, there is a function called c_isgrey, which |
| 138 | simply returns 1 or 0 based on whether the passed color structure |
| 139 | is close to grey or not.  Finally, there is the c_clearall routine, |
| 140 | which clears and frees all context data structures, and is the |
| 141 | principal action of the parser's mg_clear function. |
| 142 |  |
| 143 | Transform Support |
| 144 | ================= |
| 145 | If your program is supporting any geometry at all (and what would be |
| 146 | the point if it wasn't?) you will need to support the transform |
| 147 | entity (MG_E_XF).  This would be tricky, if it weren't for the support |
| 148 | routines provided, which make the task fairly painless.  First, there |
| 149 | is the transform handler itself, xf_handler.  Just set the MG_E_XF |
| 150 | entry of the mg_ehand array to this function.  Then, anytime you want |
| 151 | to transform something, call one of the associated functions, xf_xfmpoint, |
| 152 | xf_xfmvect, xf_rotvect or xf_scale.  These functions transform a 3-D |
| 153 | point, 3-D vector (without translation), rotate a 3-D vector (without |
| 154 | scaling) and scale a floating-point value, respectively. |
| 155 |  |
| 156 | Object Support |
| 157 | ============== |
| 158 | The MGF language includes a single entity for naming objects, MG_E_OBJECT. |
| 159 | It is mostly provided as a convenience for the user, so that individual |
| 160 | geometric parts may be easily identified.  Although supporting this entity |
| 161 | directly is possible, it's hierarchical nature requires maintaining a stack |
| 162 | of object names.  The object handler in object.c provides this functionality. |
| 163 | Simply set the MG_E_OBJECT entry of the mg_ehand array to obj_handler, |
| 164 | and the current object name list will be kept in the global array obj_name. |
| 165 | The number of names is stored in the global obj_nnames variable.  To clear |
| 166 | this array (freeing any memory used in the process), call obj_clear. |
| 167 |  |
| 168 | Loading vs. Translating |
| 169 | ======================= |
| 170 | As mentioned in the introduction, the parser may be used either to load |
| 171 | data into a rendering program directly, or to get MGF input for translation |
| 172 | to another file format.  In either case, the procedure is nearly identical. |
| 173 | The only important difference is what you do with the parser data structures |
| 174 | after loading.  For a translator, this is not an issue, but rendering |
| 175 | programs usually need all the memory they can get.  Therefore, once the |
| 176 | input process is complete, you should call the mg_clear function to free |
| 177 | the parser data structures and return to an initialized state (i.e. it |
| 178 | is never necessary to recall the mg_init routine). |
| 179 |  |
| 180 | Also, if you use some of the support functions, you should call their |
| 181 | specific clearing functions.  For the transform module, the call is |
| 182 | xf_clear.  For the object support module, the call is obj_clear.  The |
| 183 | context routines use the c_clearall function, but this is actually |
| 184 | called by mg_clear, so calling it again is unnecessary. |
| 185 |  |
| 186 | Linking Vertices |
| 187 | ================ |
| 188 | Although the MGF language was designed with linking vertices in mind, |
| 189 | there are certain aspects which make this goal more challenging. |
| 190 | Specifically, the ability to redefine values for a previously named |
| 191 | vertex is troublesome for the programmer, since the same vertex can |
| 192 | have different values at different points in the input.  Likewise, the |
| 193 | effect of the transform entity on surfaces rather than vertices means |
| 194 | that the same named vertex can appear in many positions. |
| 195 |  |
| 196 | It is not possible to use the parser data structures directly for |
| 197 | linking vertices, but we've taken a couple of steps in the support |
| 198 | routines to make the task of organizing your own data structures a |
| 199 | little easier.  First, there is a clock member in the C_VERTEX |
| 200 | structure that is incremented on each change.  (The same member is |
| 201 | contained in the C_COLOR and C_MATERIAL structures.)  Second, the |
| 202 | current transform (pointed to by xf_context) contains a unique |
| 203 | identifier, xf_context->xid.  This is a long integer that will be |
| 204 | different for each unique transform.  (It is actually a hash key on the |
| 205 | transformation matrix, and there is about 1 chance in 2 billion that |
| 206 | two different matrices will hash to the same value.  Is this a bug? |
| 207 | I guess it depends on how long the programmer lives -- or vice versa.) |
| 208 |  |
| 209 | There are two ways to use of this additional information.  One |
| 210 | is to record the vertex clock value along with it's id and the |
| 211 | current xf_context->xid value.  If another vertex comes along with |
| 212 | the same name, but one of these two additional values fails to match, |
| 213 | then it (probably) is a different vertex.  Alternatively, one can reset |
| 214 | the clock member every time a new vertex is stored.  That way, it is |
| 215 | only necessary to check the clock against zero rather than storing this |
| 216 | value along with the vertex name and transform id.  If the name and |
| 217 | transform are the same and the clock is zero, then it's the same vertex |
| 218 | as last time. |
| 219 |  |
| 220 | Yet another approach is to ignore the parser structures entirely and |
| 221 | focus on the actual vertex values.  After all, the user is not compelled |
| 222 | to reuse the same vertex names for the same points.  It is just as likely |
| 223 | that the same vertices will appear under different names, so that none |
| 224 | of the above would help to merge them.  The most sure-fire approach to |
| 225 | linking identical vertices is therefore to hash the point and normal |
| 226 | values directly and use the functions in lookup.c to associate them. |
| 227 | You will have to write your own hash function, and we recommend making |
| 228 | one that allows a little slop so that nearly identical points hash to |
| 229 | the same value. |
| 230 |  |
| 231 | Examples |
| 232 | ======== |
| 233 | Two example translator programs are included with this package. |
| 234 |  |
| 235 | The simplest is a translator from MGF to MGF called mgfilt.c, which |
| 236 | produces on the standard output only those entities from the standard |
| 237 | input that are supported according to the first command line argument. |
| 238 | For example, one could remove everything but the raw, flat polygonal |
| 239 | geometry with the following command: |
| 240 |  |
| 241 | mgfilt v,p,f,xf any.mgf > faces.mgf |
| 242 |  |
| 243 | Note that the xf entity must also be included, for its support is |
| 244 | required by all geometric entities. |
| 245 |  |
| 246 | The second translator converts from MGF to the Radiance scene description |
| 247 | language, and is a more practical example of parser use.  Unfortunately, |
| 248 | we did not include all of the support functions required by this translator, |
| 249 | so it serves as a source code example only.  If you wish to get the rest |
| 250 | of it because you intend to run it, contact Greg Ward <[email protected]> |
| 251 | and he'll be happy to provide you with the missing pieces. |
| 252 |  |
| 253 | Copyright |
| 254 | ========= |
| 255 | This library was put in public domain and is offered free |
| 256 | of charge to all those who wish to use it for any purpose. |
| 257 | We take no responsibility for its use, misuse, correctess, |
| 258 | or suitability. |
| 259 |  |
| 260 | Questions |
| 261 | ========= |
| 262 | Questions should be directed to Greg Ward <[email protected]>>, who will be |
| 263 | happy to offer any reasonable assistance in using this standard. |
