root/radiance/src/cv/mgflib/rayopt.h
Revision: 1.3
Committed: Sat Jun 7 01:11:17 2003 UTC (22 years, 4 months ago) by schorsch
CVS Tags: rad3R7P1, rad3R6, rad3R6P1, rad3R8, rad3R7P2
Changes since 1.2: +12 -3 lines
Removed NOPROTO sections.
1 /* RCSid: $Id: rayopt.h,v 1.2 2003/02/28 20:11:30 greg Exp $ */
2 /*-------------------------------------------------------------------------
3
4 Triangle Bounder/Smoother for POV-Ray
5 Copyright (c) 1993 Steve Anger
6
7 A number of C routines that can be used to generate POV-Ray ray tracer
8 files from triangle data. Supports generation of smooth triangles and an
9 optimal set of bounding shapes for much faster traces. This program may be
10 freely modified and distributed.
11
12 CompuServe: 70714,3113
13 YCCMR BBS: (708)358-5611
14
15 --------------------------------------------------------------------------*/
16
17 #ifndef _MGF_RAYOPT_H
18 #define _MGF_RAYOPT_H
19 #ifdef __cplusplus
20 extern "C" {
21 #endif
22
23
24 #include "vect.h"
25
26 void opt_set_format (int format);
27 void opt_set_fname (char *pov_name, char *inc_name);
28 void opt_set_quiet (int quiet);
29 void opt_set_bound (int bound);
30 void opt_set_smooth (float smooth);
31 void opt_set_vert (unsigned vert);
32 void opt_set_dec (int dec);
33
34 void opt_set_color (float red, float green, float blue);
35 void opt_set_texture (char *texture_name);
36 void opt_set_transform (Matrix mat);
37 void opt_clear_transform();
38 int opt_add_tri (float ax, float ay, float az,
39 float bx, float by, float bz,
40 float cx, float cy, float cz);
41
42 void opt_write_pov (char *obj_name);
43 void opt_write_file (char *obj_name);
44 void opt_write_box (char *obj_name);
45 void opt_finish (void);
46
47 void opt_get_limits (float *min_x, float *min_y, float *min_z,
48 float *max_x, float *max_y, float *max_z);
49 void opt_get_glimits (float *min_x, float *min_y, float *min_z,
50 float *max_x, float *max_y, float *max_z);
51 unsigned opt_get_vert_cnt (void);
52 unsigned opt_get_tri_cnt (void);
53 float opt_get_index (void);
54 unsigned opt_get_bounds (void);
55
56 void abortmsg (char *msg, int exit_code);
57 void add_ext (char *fname, char *ext, int force);
58 void cleanup_name (char *name);
59
60
61 #ifdef __cplusplus
62 }
63 #endif
64 #endif /* _MGF_RAYOPT_H */
65
