root/radiance/src/cv/mgflib/parser.c
Revision: 1.28
Committed: Sat Nov 15 17:54:06 2003 UTC (21 years, 11 months ago) by schorsch
CVS Tags: rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad3R7P2
Changes since 1.27: +96 -70 lines
2 static const char RCSid[] = "$Id: parser.c,v 1.27 2003/02/28 20:11:29 greg Exp $";
5 * Parse an MGF file, converting or discarding unsupported entities
6 */
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <math.h>
11 #include <ctype.h>
12 #include <string.h>
13 #include "parser.h"
14 #include "lookup.h"
15 #include "messages.h"
16
17 /*
18 * Global definitions of variables declared in parser.h
19 */
20 /* entity names */
21
22 char mg_ename[MG_NENTITIES][MG_MAXELEN] = MG_NAMELIST;
23
24 /* Handler routines for each entity */
25
26 int (*mg_ehand[MG_NENTITIES])();
27
28 /* Handler routine for unknown entities */
29
30 int (*mg_uhand)() = mg_defuhand;
31
32 unsigned mg_nunknown; /* count of unknown entities */
33
34 /* error messages */
35
36 char *mg_err[MG_NERRS] = MG_ERRLIST;
37
38 MG_FCTXT *mg_file; /* current file context pointer */
39
40 int mg_nqcdivs = MG_NQCD; /* number of divisions per quarter circle */
41
42 /*
43 * The idea with this parser is to compensate for any missing entries in
44 * mg_ehand with alternate handlers that express these entities in terms
45 * of others that the calling program can handle.
46 *
47 * In some cases, no alternate handler is possible because the entity
48 * has no approximate equivalent. These entities are simply discarded.
49 *
50 * Certain entities are dependent on others, and mg_init() will fail
51 * if the supported entities are not consistent.
52 *
53 * Some alternate entity handlers require that earlier entities be
54 * noted in some fashion, and we therefore keep another array of
55 * parallel support handlers to assist in this effort.
56 */
57
58 /* temporary settings for testing */
59 #define e_ies e_any_toss
60 /* alternate handler routines */
61
62 static void make_axes(FVECT u, FVECT v, FVECT w);
63 static int put_cxy(void);
64 static int put_cspec(void);
65
66 static int e_any_toss(int ac, char **av); /* discard an unwanted entity */
67 static int e_cspec(int ac, char **av); /* handle spectral color */
68 static int e_cmix(int ac, char **av); /* handle mixing of colors */
69 static int e_cct(int ac, char **av); /* handle color temperature */
70
71
72 /* alternate handler support functions */
73
74 static int (*e_supp[MG_NENTITIES])(int ac, char **av);
75
76 static char FLTFMT[] = "%.12g";
77
78 static int warpconends; /* hack for generating good normals */
79
80
81 void
82 mg_init(void) /* initialize alternate entity handlers */
83 {
84 unsigned long ineed = 0, uneed = 0;
85 register int i;
86 /* pick up slack */
87 if (mg_ehand[MG_E_IES] == NULL)
88 mg_ehand[MG_E_IES] = e_ies;
89 if (mg_ehand[MG_E_INCLUDE] == NULL)
90 mg_ehand[MG_E_INCLUDE] = e_include;
91 if (mg_ehand[MG_E_SPH] == NULL) {
92 mg_ehand[MG_E_SPH] = e_sph;
93 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
94 } else
95 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
96 if (mg_ehand[MG_E_CYL] == NULL) {
97 mg_ehand[MG_E_CYL] = e_cyl;
98 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
99 } else
100 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
101 if (mg_ehand[MG_E_CONE] == NULL) {
102 mg_ehand[MG_E_CONE] = e_cone;
103 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
104 } else
105 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
106 if (mg_ehand[MG_E_RING] == NULL) {
107 mg_ehand[MG_E_RING] = e_ring;
108 ineed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX;
109 } else
110 uneed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX|1L<<MG_E_XF;
111 if (mg_ehand[MG_E_PRISM] == NULL) {
112 mg_ehand[MG_E_PRISM] = e_prism;
113 ineed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX;
114 } else
115 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
116 if (mg_ehand[MG_E_TORUS] == NULL) {
117 mg_ehand[MG_E_TORUS] = e_torus;
118 ineed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX;
119 } else
120 uneed |= 1L<<MG_E_POINT|1L<<MG_E_NORMAL|1L<<MG_E_VERTEX|1L<<MG_E_XF;
121 if (mg_ehand[MG_E_FACE] == NULL)
122 mg_ehand[MG_E_FACE] = mg_ehand[MG_E_FACEH];
123 else if (mg_ehand[MG_E_FACEH] == NULL)
124 mg_ehand[MG_E_FACEH] = e_faceh;
125 if (mg_ehand[MG_E_COLOR] != NULL) {
126 if (mg_ehand[MG_E_CMIX] == NULL) {
127 mg_ehand[MG_E_CMIX] = e_cmix;
128 ineed |= 1L<<MG_E_COLOR|1L<<MG_E_CXY|1L<<MG_E_CSPEC|1L<<MG_E_CMIX|1L<<MG_E_CCT;
129 }
130 if (mg_ehand[MG_E_CSPEC] == NULL) {
131 mg_ehand[MG_E_CSPEC] = e_cspec;
132 ineed |= 1L<<MG_E_COLOR|1L<<MG_E_CXY|1L<<MG_E_CSPEC|1L<<MG_E_CMIX|1L<<MG_E_CCT;
133 }
134 if (mg_ehand[MG_E_CCT] == NULL) {
135 mg_ehand[MG_E_CCT] = e_cct;
136 ineed |= 1L<<MG_E_COLOR|1L<<MG_E_CXY|1L<<MG_E_CSPEC|1L<<MG_E_CMIX|1L<<MG_E_CCT;
137 }
138 }
139 /* check for consistency */
140 if (mg_ehand[MG_E_FACE] != NULL)
141 uneed |= 1L<<MG_E_POINT|1L<<MG_E_VERTEX|1L<<MG_E_XF;
142 if (mg_ehand[MG_E_CXY] != NULL || mg_ehand[MG_E_CSPEC] != NULL ||
143 mg_ehand[MG_E_CMIX] != NULL)
144 uneed |= 1L<<MG_E_COLOR;
145 if (mg_ehand[MG_E_RD] != NULL || mg_ehand[MG_E_TD] != NULL ||
146 mg_ehand[MG_E_IR] != NULL ||
147 mg_ehand[MG_E_ED] != NULL ||
148 mg_ehand[MG_E_RS] != NULL ||
149 mg_ehand[MG_E_TS] != NULL ||
150 mg_ehand[MG_E_SIDES] != NULL)
151 uneed |= 1L<<MG_E_MATERIAL;
152 for (i = 0; i < MG_NENTITIES; i++)
153 if (uneed & 1L<<i && mg_ehand[i] == NULL) {
154 fprintf(stderr, "Missing support for \"%s\" entity\n",
155 mg_ename[i]);
156 exit(1);
157 }
158 /* add support as needed */
159 if (ineed & 1L<<MG_E_VERTEX && mg_ehand[MG_E_VERTEX] != c_hvertex)
160 e_supp[MG_E_VERTEX] = c_hvertex;
161 if (ineed & 1L<<MG_E_POINT && mg_ehand[MG_E_POINT] != c_hvertex)
162 e_supp[MG_E_POINT] = c_hvertex;
163 if (ineed & 1L<<MG_E_NORMAL && mg_ehand[MG_E_NORMAL] != c_hvertex)
164 e_supp[MG_E_NORMAL] = c_hvertex;
165 if (ineed & 1L<<MG_E_COLOR && mg_ehand[MG_E_COLOR] != c_hcolor)
166 e_supp[MG_E_COLOR] = c_hcolor;
167 if (ineed & 1L<<MG_E_CXY && mg_ehand[MG_E_CXY] != c_hcolor)
168 e_supp[MG_E_CXY] = c_hcolor;
169 if (ineed & 1L<<MG_E_CSPEC && mg_ehand[MG_E_CSPEC] != c_hcolor)
170 e_supp[MG_E_CSPEC] = c_hcolor;
171 if (ineed & 1L<<MG_E_CMIX && mg_ehand[MG_E_CMIX] != c_hcolor)
172 e_supp[MG_E_CMIX] = c_hcolor;
173 if (ineed & 1L<<MG_E_CCT && mg_ehand[MG_E_CCT] != c_hcolor)
174 e_supp[MG_E_CCT] = c_hcolor;
175 /* discard remaining entities */
176 for (i = 0; i < MG_NENTITIES; i++)
177 if (mg_ehand[i] == NULL)
178 mg_ehand[i] = e_any_toss;
179 }
180
181
182 int
183 mg_entity( /* get entity number from its name */
184 char *name
185 )
186 {
187 static LUTAB ent_tab = LU_SINIT(NULL,NULL); /* lookup table */
188 register char *cp;
189
190 if (!ent_tab.tsiz) { /* initialize hash table */
191 if (!lu_init(&ent_tab, MG_NENTITIES))
192 return(-1); /* what to do? */
193 for (cp = mg_ename[MG_NENTITIES-1]; cp >= mg_ename[0];
194 cp -= sizeof(mg_ename[0]))
195 lu_find(&ent_tab, cp)->key = cp;
196 }
197 cp = lu_find(&ent_tab, name)->key;
198 if (cp == NULL)
199 return(-1);
200 return((cp - mg_ename[0])/sizeof(mg_ename[0]));
201 }
202
203
204 int
205 mg_handle( /* pass entity to appropriate handler */
206 register int en,
207 int ac,
208 char **av
209 )
210 {
211 int rv;
212
213 if (en < 0 && (en = mg_entity(av[0])) < 0) { /* unknown entity */
214 if (mg_uhand != NULL)
215 return((*mg_uhand)(ac, av));
216 return(MG_EUNK);
217 }
218 if (e_supp[en] != NULL) { /* support handler */
219 if ((rv = (*e_supp[en])(ac, av)) != MG_OK)
220 return(rv);
221 }
222 return((*mg_ehand[en])(ac, av)); /* assigned handler */
223 }
224
225
226 int
227 mg_open( /* open new input file */
228 register MG_FCTXT *ctx,
229 char *fn
230 )
231 {
232 static int nfids;
233 register char *cp;
234
235 ctx->fid = ++nfids;
236 ctx->lineno = 0;
237 if (fn == NULL) {
238 strcpy(ctx->fname, "<stdin>");
239 ctx->fp = stdin;
240 ctx->prev = mg_file;
241 mg_file = ctx;
242 return(MG_OK);
243 }
244 /* get name relative to this context */
245 if (fn[0] != '/' && mg_file != NULL &&
246 (cp = strrchr(mg_file->fname, '/')) != NULL) {
247 strcpy(ctx->fname, mg_file->fname);
248 strcpy(ctx->fname+(cp-mg_file->fname+1), fn);
249 } else
250 strcpy(ctx->fname, fn);
251 ctx->fp = fopen(ctx->fname, "r");
252 if (ctx->fp == NULL)
253 return(MG_ENOFILE);
254 ctx->prev = mg_file; /* establish new context */
255 mg_file = ctx;
256 return(MG_OK);
257 }
258
259
260 void
261 mg_close(void) /* close input file */
262 {
263 register MG_FCTXT *ctx = mg_file;
264
265 mg_file = ctx->prev; /* restore enclosing context */
266 if (ctx->fp != stdin) /* close file if it's a file */
267 fclose(ctx->fp);
268 }
269
270
271 void
272 mg_fgetpos( /* get current position in input file */
273 register MG_FPOS *pos
274 )
275 {
276 pos->fid = mg_file->fid;
277 pos->lineno = mg_file->lineno;
278 pos->offset = ftell(mg_file->fp);
279 }
280
281
282 int
283 mg_fgoto( /* reposition input file pointer */
284 register MG_FPOS *pos
285 )
286 {
287 if (pos->fid != mg_file->fid)
288 return(MG_ESEEK);
289 if (pos->lineno == mg_file->lineno)
290 return(MG_OK);
291 if (mg_file->fp == stdin)
292 return(MG_ESEEK); /* cannot seek on standard input */
293 if (fseek(mg_file->fp, pos->offset, 0) == EOF)
294 return(MG_ESEEK);
295 mg_file->lineno = pos->lineno;
296 return(MG_OK);
297 }
298
299
300 int
301 mg_read(void) /* read next line from file */
302 {
303 register int len = 0;
304
305 do {
306 if (fgets(mg_file->inpline+len,
307 MG_MAXLINE-len, mg_file->fp) == NULL)
308 return(len);
309 len += strlen(mg_file->inpline+len);
310 if (len >= MG_MAXLINE-1)
311 return(len);
312 mg_file->lineno++;
313 } while (len > 1 && mg_file->inpline[len-2] == '\\');
314
315 return(len);
316 }
317
318
319 int
320 mg_parse(void) /* parse current input line */
321 {
322 char abuf[MG_MAXLINE];
323 char *argv[MG_MAXARGC];
324 register char *cp, *cp2, **ap;
325 /* copy line, removing escape chars */
326 cp = abuf; cp2 = mg_file->inpline;
327 while ((*cp++ = *cp2++))
328 if (cp2[0] == '\n' && cp2[-1] == '\\')
329 cp--;
330 cp = abuf; ap = argv; /* break into words */
331 for ( ; ; ) {
332 while (isspace(*cp))
333 *cp++ = '\0';
334 if (!*cp)
335 break;
336 if (ap - argv >= MG_MAXARGC-1)
337 return(MG_EARGC);
338 *ap++ = cp;
339 while (*++cp && !isspace(*cp))
340 ;
341 }
342 if (ap == argv)
343 return(MG_OK); /* no words in line */
344 *ap = NULL;
345 /* else handle it */
346 return(mg_handle(-1, ap-argv, argv));
347 }
348
349
350 int
351 mg_load( /* load an MGF file */
352 char *fn
353 )
354 {
355 MG_FCTXT cntxt;
356 int rval;
357 register int nbr;
358
359 if ((rval = mg_open(&cntxt, fn)) != MG_OK) {
360 fprintf(stderr, "%s: %s\n", fn, mg_err[rval]);
361 return(rval);
362 }
363 while ((nbr = mg_read()) > 0) { /* parse each line */
364 if (nbr >= MG_MAXLINE-1) {
365 fprintf(stderr, "%s: %d: %s\n", cntxt.fname,
366 cntxt.lineno, mg_err[rval=MG_ELINE]);
367 break;
368 }
369 if ((rval = mg_parse()) != MG_OK) {
370 fprintf(stderr, "%s: %d: %s:\n%s", cntxt.fname,
371 cntxt.lineno, mg_err[rval],
372 cntxt.inpline);
373 break;
374 }
375 }
376 mg_close();
377 return(rval);
378 }
379
380
381 int
382 mg_defuhand( /* default handler for unknown entities */
383 int ac,
384 char **av
385 )
386 {
387 if (mg_nunknown++ == 0) /* report first incident */
388 fprintf(stderr, "%s: %d: %s: %s\n", mg_file->fname,
389 mg_file->lineno, mg_err[MG_EUNK], av[0]);
390 return(MG_OK);
391 }
392
393
394 void
395 mg_clear(void) /* clear parser history */
396 {
397 c_clearall(); /* clear context tables */
398 while (mg_file != NULL) /* reset our file context */
399 mg_close();
400 }
401
402
403 /****************************************************************************
404 * The following routines handle unsupported entities
405 */
406
407
408 static int
409 e_any_toss( /* discard an unwanted entity */
410 int ac,
411 char **av
412 )
413 {
414 return(MG_OK);
415 }
416
417
418 int
419 e_include( /* include file */
420 int ac,
421 char **av
422 )
423 {
424 char *xfarg[MG_MAXARGC];
425 MG_FCTXT ictx;
426 XF_SPEC *xf_orig = xf_context;
427 register int rv;
428
429 if (ac < 2)
430 return(MG_EARGC);
431 if ((rv = mg_open(&ictx, av[1])) != MG_OK)
432 return(rv);
433 if (ac > 2) {
434 register int i;
435
436 xfarg[0] = mg_ename[MG_E_XF];
437 for (i = 1; i < ac-1; i++)
438 xfarg[i] = av[i+1];
439 xfarg[ac-1] = NULL;
440 if ((rv = mg_handle(MG_E_XF, ac-1, xfarg)) != MG_OK) {
441 mg_close();
442 return(rv);
443 }
444 }
445 do {
446 while ((rv = mg_read()) > 0) {
447 if (rv >= MG_MAXLINE-1) {
448 fprintf(stderr, "%s: %d: %s\n", ictx.fname,
449 ictx.lineno, mg_err[MG_ELINE]);
450 mg_close();
451 return(MG_EINCL);
452 }
453 if ((rv = mg_parse()) != MG_OK) {
454 fprintf(stderr, "%s: %d: %s:\n%s", ictx.fname,
455 ictx.lineno, mg_err[rv],
456 ictx.inpline);
457 mg_close();
458 return(MG_EINCL);
459 }
460 }
461 if (ac > 2)
462 if ((rv = mg_handle(MG_E_XF, 1, xfarg)) != MG_OK) {
463 mg_close();
464 return(rv);
465 }
466 } while (xf_context != xf_orig);
467 mg_close();
468 return(MG_OK);
469 }
470
471
472 int
473 e_faceh( /* replace face+holes with single contour */
474 int ac,
475 char **av
476 )
477 {
478 char *newav[MG_MAXARGC];
479 int lastp = 0;
480 register int i, j;
481
482 newav[0] = mg_ename[MG_E_FACE];
483 for (i = 1; i < ac; i++)
484 if (av[i][0] == '-') {
485 if (i < 4)
486 return(MG_EARGC);
487 if (i >= ac-1)
488 break;
489 if (!lastp)
490 lastp = i-1;
491 for (j = i+1; j < ac-1 && av[j+1][0] != '-'; j++)
492 ;
493 if (j - i < 3)
494 return(MG_EARGC);
495 newav[i] = av[j]; /* connect hole loop */
496 } else
497 newav[i] = av[i]; /* hole or perimeter vertex */
498 if (lastp)
499 newav[i++] = av[lastp]; /* finish seam to outside */
500 newav[i] = NULL;
501 return(mg_handle(MG_E_FACE, i, newav));
502 }
503
504
505 static void
506 make_axes( /* compute u and v given w (normalized) */
507 FVECT u,
508 FVECT v,
509 FVECT w
510 )
511 {
512 register int i;
513
514 v[0] = v[1] = v[2] = 0.;
515 for (i = 0; i < 3; i++)
516 if (w[i] < .6 && w[i] > -.6)
517 break;
518 v[i] = 1.;
519 fcross(u, v, w);
520 normalize(u);
521 fcross(v, w, u);
522 }
523
524
525 int
526 e_sph( /* expand a sphere into cones */
527 int ac,
528 char **av
529 )
530 {
531 static char p2x[24], p2y[24], p2z[24], r1[24], r2[24];
532 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_sv1","=","_sv2"};
533 static char *v2ent[4] = {mg_ename[MG_E_VERTEX],"_sv2","="};
534 static char *p2ent[5] = {mg_ename[MG_E_POINT],p2x,p2y,p2z};
535 static char *conent[6] = {mg_ename[MG_E_CONE],"_sv1",r1,"_sv2",r2};
536 register C_VERTEX *cv;
537 register int i;
538 int rval;
539 double rad;
540 double theta;
541
542 if (ac != 3)
543 return(MG_EARGC);
544 if ((cv = c_getvert(av[1])) == NULL)
545 return(MG_EUNDEF);
546 if (!isflt(av[2]))
547 return(MG_ETYPE);
548 rad = atof(av[2]);
549 /* initialize */
550 warpconends = 1;
551 if ((rval = mg_handle(MG_E_VERTEX, 3, v2ent)) != MG_OK)
552 return(rval);
553 sprintf(p2x, FLTFMT, cv->p[0]);
554 sprintf(p2y, FLTFMT, cv->p[1]);
555 sprintf(p2z, FLTFMT, cv->p[2]+rad);
556 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
557 return(rval);
558 r2[0] = '0'; r2[1] = '\0';
559 for (i = 1; i <= 2*mg_nqcdivs; i++) {
560 theta = i*(PI/2)/mg_nqcdivs;
561 if ((rval = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
562 return(rval);
563 sprintf(p2z, FLTFMT, cv->p[2]+rad*cos(theta));
564 if ((rval = mg_handle(MG_E_VERTEX, 2, v2ent)) != MG_OK)
565 return(rval);
566 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
567 return(rval);
568 strcpy(r1, r2);
569 sprintf(r2, FLTFMT, rad*sin(theta));
570 if ((rval = mg_handle(MG_E_CONE, 5, conent)) != MG_OK)
571 return(rval);
572 }
573 warpconends = 0;
574 return(MG_OK);
575 }
576
577
578 int
579 e_torus( /* expand a torus into cones */
580 int ac,
581 char **av
582 )
583 {
584 static char p2[3][24], r1[24], r2[24];
585 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_tv1","=","_tv2"};
586 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_tv2","="};
587 static char *p2ent[5] = {mg_ename[MG_E_POINT],p2[0],p2[1],p2[2]};
588 static char *conent[6] = {mg_ename[MG_E_CONE],"_tv1",r1,"_tv2",r2};
589 register C_VERTEX *cv;
590 register int i, j;
591 int rval;
592 int sgn;
593 double minrad, maxrad, avgrad;
594 double theta;
595
596 if (ac != 4)
597 return(MG_EARGC);
598 if ((cv = c_getvert(av[1])) == NULL)
599 return(MG_EUNDEF);
600 if (is0vect(cv->n))
601 return(MG_EILL);
602 if (!isflt(av[2]) || !isflt(av[3]))
603 return(MG_ETYPE);
604 minrad = atof(av[2]);
605 round0(minrad);
606 maxrad = atof(av[3]);
607 /* check orientation */
608 if (minrad > 0.)
609 sgn = 1;
610 else if (minrad < 0.)
611 sgn = -1;
612 else if (maxrad > 0.)
613 sgn = 1;
614 else if (maxrad < 0.)
615 sgn = -1;
616 else
617 return(MG_EILL);
618 if (sgn*(maxrad-minrad) <= 0.)
619 return(MG_EILL);
620 /* initialize */
621 warpconends = 1;
622 v2ent[3] = av[1];
623 for (j = 0; j < 3; j++)
624 sprintf(p2[j], FLTFMT, cv->p[j] +
625 .5*sgn*(maxrad-minrad)*cv->n[j]);
626 if ((rval = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
627 return(rval);
628 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
629 return(rval);
630 sprintf(r2, FLTFMT, avgrad=.5*(minrad+maxrad));
631 /* run outer section */
632 for (i = 1; i <= 2*mg_nqcdivs; i++) {
633 theta = i*(PI/2)/mg_nqcdivs;
634 if ((rval = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
635 return(rval);
636 for (j = 0; j < 3; j++)
637 sprintf(p2[j], FLTFMT, cv->p[j] +
638 .5*sgn*(maxrad-minrad)*cos(theta)*cv->n[j]);
639 if ((rval = mg_handle(MG_E_VERTEX, 2, v2ent)) != MG_OK)
640 return(rval);
641 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
642 return(rval);
643 strcpy(r1, r2);
644 sprintf(r2, FLTFMT, avgrad + .5*(maxrad-minrad)*sin(theta));
645 if ((rval = mg_handle(MG_E_CONE, 5, conent)) != MG_OK)
646 return(rval);
647 }
648 /* run inner section */
649 sprintf(r2, FLTFMT, -.5*(minrad+maxrad));
650 for ( ; i <= 4*mg_nqcdivs; i++) {
651 theta = i*(PI/2)/mg_nqcdivs;
652 for (j = 0; j < 3; j++)
653 sprintf(p2[j], FLTFMT, cv->p[j] +
654 .5*sgn*(maxrad-minrad)*cos(theta)*cv->n[j]);
655 if ((rval = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
656 return(rval);
657 if ((rval = mg_handle(MG_E_VERTEX, 2, v2ent)) != MG_OK)
658 return(rval);
659 if ((rval = mg_handle(MG_E_POINT, 4, p2ent)) != MG_OK)
660 return(rval);
661 strcpy(r1, r2);
662 sprintf(r2, FLTFMT, -avgrad - .5*(maxrad-minrad)*sin(theta));
663 if ((rval = mg_handle(MG_E_CONE, 5, conent)) != MG_OK)
664 return(rval);
665 }
666 warpconends = 0;
667 return(MG_OK);
668 }
669
670
671 int
672 e_cyl( /* replace a cylinder with equivalent cone */
673 int ac,
674 char **av
675 )
676 {
677 static char *avnew[6] = {mg_ename[MG_E_CONE]};
678
679 if (ac != 4)
680 return(MG_EARGC);
681 avnew[1] = av[1];
682 avnew[2] = av[2];
683 avnew[3] = av[3];
684 avnew[4] = av[2];
685 return(mg_handle(MG_E_CONE, 5, avnew));
686 }
687
688
689 int
690 e_ring( /* turn a ring into polygons */
691 int ac,
692 char **av
693 )
694 {
695 static char p3[3][24], p4[3][24];
696 static char *nzent[5] = {mg_ename[MG_E_NORMAL],"0","0","0"};
697 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_rv1","="};
698 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_rv2","=","_rv3"};
699 static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_rv3","="};
700 static char *p3ent[5] = {mg_ename[MG_E_POINT],p3[0],p3[1],p3[2]};
701 static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_rv4","="};
702 static char *p4ent[5] = {mg_ename[MG_E_POINT],p4[0],p4[1],p4[2]};
703 static char *fent[6] = {mg_ename[MG_E_FACE],"_rv1","_rv2","_rv3","_rv4"};
704 register C_VERTEX *cv;
705 register int i, j;
706 FVECT u, v;
707 double minrad, maxrad;
708 int rv;
709 double theta, d;
710
711 if (ac != 4)
712 return(MG_EARGC);
713 if ((cv = c_getvert(av[1])) == NULL)
714 return(MG_EUNDEF);
715 if (is0vect(cv->n))
716 return(MG_EILL);
717 if (!isflt(av[2]) || !isflt(av[3]))
718 return(MG_ETYPE);
719 minrad = atof(av[2]);
720 round0(minrad);
721 maxrad = atof(av[3]);
722 if (minrad < 0. || maxrad <= minrad)
723 return(MG_EILL);
724 /* initialize */
725 make_axes(u, v, cv->n);
726 for (j = 0; j < 3; j++)
727 sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*u[j]);
728 if ((rv = mg_handle(MG_E_VERTEX, 3, v3ent)) != MG_OK)
729 return(rv);
730 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
731 return(rv);
732 if (minrad == 0.) { /* closed */
733 v1ent[3] = av[1];
734 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
735 return(rv);
736 if ((rv = mg_handle(MG_E_NORMAL, 4, nzent)) != MG_OK)
737 return(rv);
738 for (i = 1; i <= 4*mg_nqcdivs; i++) {
739 theta = i*(PI/2)/mg_nqcdivs;
740 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
741 return(rv);
742 for (j = 0; j < 3; j++)
743 sprintf(p3[j], FLTFMT, cv->p[j] +
744 maxrad*u[j]*cos(theta) +
745 maxrad*v[j]*sin(theta));
746 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
747 return(rv);
748 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
749 return(rv);
750 if ((rv = mg_handle(MG_E_FACE, 4, fent)) != MG_OK)
751 return(rv);
752 }
753 } else { /* open */
754 if ((rv = mg_handle(MG_E_VERTEX, 3, v4ent)) != MG_OK)
755 return(rv);
756 for (j = 0; j < 3; j++)
757 sprintf(p4[j], FLTFMT, cv->p[j] + minrad*u[j]);
758 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
759 return(rv);
760 v1ent[3] = "_rv4";
761 for (i = 1; i <= 4*mg_nqcdivs; i++) {
762 theta = i*(PI/2)/mg_nqcdivs;
763 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
764 return(rv);
765 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
766 return(rv);
767 for (j = 0; j < 3; j++) {
768 d = u[j]*cos(theta) + v[j]*sin(theta);
769 sprintf(p3[j], FLTFMT, cv->p[j] + maxrad*d);
770 sprintf(p4[j], FLTFMT, cv->p[j] + minrad*d);
771 }
772 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
773 return(rv);
774 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
775 return(rv);
776 if ((rv = mg_handle(MG_E_VERTEX, 2, v4ent)) != MG_OK)
777 return(rv);
778 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
779 return(rv);
780 if ((rv = mg_handle(MG_E_FACE, 5, fent)) != MG_OK)
781 return(rv);
782 }
783 }
784 return(MG_OK);
785 }
786
787
788 int
789 e_cone( /* turn a cone into polygons */
790 int ac,
791 char **av
792 )
793 {
794 static char p3[3][24], p4[3][24], n3[3][24], n4[3][24];
795 static char *v1ent[5] = {mg_ename[MG_E_VERTEX],"_cv1","="};
796 static char *v2ent[5] = {mg_ename[MG_E_VERTEX],"_cv2","=","_cv3"};
797 static char *v3ent[4] = {mg_ename[MG_E_VERTEX],"_cv3","="};
798 static char *p3ent[5] = {mg_ename[MG_E_POINT],p3[0],p3[1],p3[2]};
799 static char *n3ent[5] = {mg_ename[MG_E_NORMAL],n3[0],n3[1],n3[2]};
800 static char *v4ent[4] = {mg_ename[MG_E_VERTEX],"_cv4","="};
801 static char *p4ent[5] = {mg_ename[MG_E_POINT],p4[0],p4[1],p4[2]};
802 static char *n4ent[5] = {mg_ename[MG_E_NORMAL],n4[0],n4[1],n4[2]};
803 static char *fent[6] = {mg_ename[MG_E_FACE],"_cv1","_cv2","_cv3","_cv4"};
804 char *v1n;
805 register C_VERTEX *cv1, *cv2;
806 register int i, j;
807 FVECT u, v, w;
808 double rad1, rad2;
809 int sgn;
810 double n1off, n2off;
811 double d;
812 int rv;
813 double theta;
814
815 if (ac != 5)
816 return(MG_EARGC);
817 if ((cv1 = c_getvert(av[1])) == NULL ||
818 (cv2 = c_getvert(av[3])) == NULL)
819 return(MG_EUNDEF);
820 v1n = av[1];
821 if (!isflt(av[2]) || !isflt(av[4]))
822 return(MG_ETYPE);
823 rad1 = atof(av[2]);
824 round0(rad1);
825 rad2 = atof(av[4]);
826 round0(rad2);
827 if (rad1 == 0.) {
828 if (rad2 == 0.)
829 return(MG_EILL);
830 } else if (rad2 != 0.) {
831 if ((rad1 < 0.) ^ (rad2 < 0.))
832 return(MG_EILL);
833 } else { /* swap */
834 C_VERTEX *cv;
835
836 cv = cv1;
837 cv1 = cv2;
838 cv2 = cv;
839 v1n = av[3];
840 d = rad1;
841 rad1 = rad2;
842 rad2 = d;
843 }
844 sgn = rad2 < 0. ? -1 : 1;
845 /* initialize */
846 for (j = 0; j < 3; j++)
847 w[j] = cv1->p[j] - cv2->p[j];
848 if ((d = normalize(w)) == 0.)
849 return(MG_EILL);
850 n1off = n2off = (rad2 - rad1)/d;
851 if (warpconends) { /* hack for e_sph and e_torus */
852 d = atan(n2off) - (PI/4)/mg_nqcdivs;
853 if (d <= -PI/2+FTINY)
854 n2off = -FHUGE;
855 else
856 n2off = tan(d);
857 }
858 make_axes(u, v, w);
859 for (j = 0; j < 3; j++) {
860 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*u[j]);
861 if (n2off <= -FHUGE)
862 sprintf(n3[j], FLTFMT, -w[j]);
863 else
864 sprintf(n3[j], FLTFMT, u[j] + w[j]*n2off);
865 }
866 if ((rv = mg_handle(MG_E_VERTEX, 3, v3ent)) != MG_OK)
867 return(rv);
868 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
869 return(rv);
870 if ((rv = mg_handle(MG_E_NORMAL, 4, n3ent)) != MG_OK)
871 return(rv);
872 if (rad1 == 0.) { /* triangles */
873 v1ent[3] = v1n;
874 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
875 return(rv);
876 for (j = 0; j < 3; j++)
877 sprintf(n4[j], FLTFMT, w[j]);
878 if ((rv = mg_handle(MG_E_NORMAL, 4, n4ent)) != MG_OK)
879 return(rv);
880 for (i = 1; i <= 4*mg_nqcdivs; i++) {
881 theta = sgn*i*(PI/2)/mg_nqcdivs;
882 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
883 return(rv);
884 for (j = 0; j < 3; j++) {
885 d = u[j]*cos(theta) + v[j]*sin(theta);
886 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*d);
887 if (n2off > -FHUGE)
888 sprintf(n3[j], FLTFMT, d + w[j]*n2off);
889 }
890 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
891 return(rv);
892 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
893 return(rv);
894 if (n2off > -FHUGE &&
895 (rv = mg_handle(MG_E_NORMAL, 4, n3ent)) != MG_OK)
896 return(rv);
897 if ((rv = mg_handle(MG_E_FACE, 4, fent)) != MG_OK)
898 return(rv);
899 }
900 } else { /* quads */
901 v1ent[3] = "_cv4";
902 if (warpconends) { /* hack for e_sph and e_torus */
903 d = atan(n1off) + (PI/4)/mg_nqcdivs;
904 if (d >= PI/2-FTINY)
905 n1off = FHUGE;
906 else
907 n1off = tan(atan(n1off)+(PI/4)/mg_nqcdivs);
908 }
909 for (j = 0; j < 3; j++) {
910 sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*u[j]);
911 if (n1off >= FHUGE)
912 sprintf(n4[j], FLTFMT, w[j]);
913 else
914 sprintf(n4[j], FLTFMT, u[j] + w[j]*n1off);
915 }
916 if ((rv = mg_handle(MG_E_VERTEX, 3, v4ent)) != MG_OK)
917 return(rv);
918 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
919 return(rv);
920 if ((rv = mg_handle(MG_E_NORMAL, 4, n4ent)) != MG_OK)
921 return(rv);
922 for (i = 1; i <= 4*mg_nqcdivs; i++) {
923 theta = sgn*i*(PI/2)/mg_nqcdivs;
924 if ((rv = mg_handle(MG_E_VERTEX, 4, v1ent)) != MG_OK)
925 return(rv);
926 if ((rv = mg_handle(MG_E_VERTEX, 4, v2ent)) != MG_OK)
927 return(rv);
928 for (j = 0; j < 3; j++) {
929 d = u[j]*cos(theta) + v[j]*sin(theta);
930 sprintf(p3[j], FLTFMT, cv2->p[j] + rad2*d);
931 if (n2off > -FHUGE)
932 sprintf(n3[j], FLTFMT, d + w[j]*n2off);
933 sprintf(p4[j], FLTFMT, cv1->p[j] + rad1*d);
934 if (n1off < FHUGE)
935 sprintf(n4[j], FLTFMT, d + w[j]*n1off);
936 }
937 if ((rv = mg_handle(MG_E_VERTEX, 2, v3ent)) != MG_OK)
938 return(rv);
939 if ((rv = mg_handle(MG_E_POINT, 4, p3ent)) != MG_OK)
940 return(rv);
941 if (n2off > -FHUGE &&
942 (rv = mg_handle(MG_E_NORMAL, 4, n3ent)) != MG_OK)
943 return(rv);
944 if ((rv = mg_handle(MG_E_VERTEX, 2, v4ent)) != MG_OK)
945 return(rv);
946 if ((rv = mg_handle(MG_E_POINT, 4, p4ent)) != MG_OK)
947 return(rv);
948 if (n1off < FHUGE &&
949 (rv = mg_handle(MG_E_NORMAL, 4, n4ent)) != MG_OK)
950 return(rv);
951 if ((rv = mg_handle(MG_E_FACE, 5, fent)) != MG_OK)
952 return(rv);
953 }
954 }
955 return(MG_OK);
956 }
957
958
959 int
960 e_prism( /* turn a prism into polygons */
961 int ac,
962 char **av
963 )
964 {
965 static char p[3][24];
966 static char *vent[5] = {mg_ename[MG_E_VERTEX],NULL,"="};
967 static char *pent[5] = {mg_ename[MG_E_POINT],p[0],p[1],p[2]};
968 static char *znorm[5] = {mg_ename[MG_E_NORMAL],"0","0","0"};
969 char *newav[MG_MAXARGC], nvn[MG_MAXARGC-1][8];
970 double length;
971 int hasnorm;
972 FVECT v1, v2, v3, norm;
973 register C_VERTEX *cv;
974 C_VERTEX *cv0;
975 int rv;
976 register int i, j;
977 /* check arguments */
978 if (ac < 5)
979 return(MG_EARGC);
980 if (!isflt(av[ac-1]))
981 return(MG_ETYPE);
982 length = atof(av[ac-1]);
983 if (length <= FTINY && length >= -FTINY)
984 return(MG_EILL);
985 /* compute face normal */
986 if ((cv0 = c_getvert(av[1])) == NULL)
987 return(MG_EUNDEF);
988 hasnorm = 0;
989 norm[0] = norm[1] = norm[2] = 0.;
990 v1[0] = v1[1] = v1[2] = 0.;
991 for (i = 2; i < ac-1; i++) {
992 if ((cv = c_getvert(av[i])) == NULL)
993 return(MG_EUNDEF);
994 hasnorm += !is0vect(cv->n);
995 v2[0] = cv->p[0] - cv0->p[0];
996 v2[1] = cv->p[1] - cv0->p[1];
997 v2[2] = cv->p[2] - cv0->p[2];
998 fcross(v3, v1, v2);
999 norm[0] += v3[0];
1000 norm[1] += v3[1];
1001 norm[2] += v3[2];
1002 VCOPY(v1, v2);
1003 }
1004 if (normalize(norm) == 0.)
1005 return(MG_EILL);
1006 /* create moved vertices */
1007 for (i = 1; i < ac-1; i++) {
1008 sprintf(nvn[i-1], "_pv%d", i);
1009 vent[1] = nvn[i-1];
1010 vent[3] = av[i];
1011 if ((rv = mg_handle(MG_E_VERTEX, 4, vent)) != MG_OK)
1012 return(rv);
1013 cv = c_getvert(av[i]); /* checked above */
1014 for (j = 0; j < 3; j++)
1015 sprintf(p[j], FLTFMT, cv->p[j] - length*norm[j]);
1016 if ((rv = mg_handle(MG_E_POINT, 4, pent)) != MG_OK)
1017 return(rv);
1018 }
1019 /* make faces */
1020 newav[0] = mg_ename[MG_E_FACE];
1021 /* do the side faces */
1022 newav[5] = NULL;
1023 newav[3] = av[ac-2];
1024 newav[4] = nvn[ac-3];
1025 for (i = 1; i < ac-1; i++) {
1026 newav[1] = nvn[i-1];
1027 newav[2] = av[i];
1028 if ((rv = mg_handle(MG_E_FACE, 5, newav)) != MG_OK)
1029 return(rv);
1030 newav[3] = newav[2];
1031 newav[4] = newav[1];
1032 }
1033 /* do top face */
1034 for (i = 1; i < ac-1; i++) {
1035 if (hasnorm) { /* zero normals */
1036 vent[1] = nvn[i-1];
1037 if ((rv = mg_handle(MG_E_VERTEX, 2, vent)) != MG_OK)
1038 return(rv);
1039 if ((rv = mg_handle(MG_E_NORMAL, 4, znorm)) != MG_OK)
1040 return(rv);
1041 }
1042 newav[ac-1-i] = nvn[i-1]; /* reverse */
1043 }
1044 if ((rv = mg_handle(MG_E_FACE, ac-1, newav)) != MG_OK)
1045 return(rv);
1046 /* do bottom face */
1047 if (hasnorm)
1048 for (i = 1; i < ac-1; i++) {
1049 vent[1] = nvn[i-1];
1050 vent[3] = av[i];
1051 if ((rv = mg_handle(MG_E_VERTEX, 4, vent)) != MG_OK)
1052 return(rv);
1053 if ((rv = mg_handle(MG_E_NORMAL, 4, znorm)) != MG_OK)
1054 return(rv);
1055 newav[i] = nvn[i-1];
1056 }
1057 else
1058 for (i = 1; i < ac-1; i++)
1059 newav[i] = av[i];
1060 newav[i] = NULL;
1061 if ((rv = mg_handle(MG_E_FACE, i, newav)) != MG_OK)
1062 return(rv);
1063 return(MG_OK);
1064 }
1065
1066
1067 static int
1068 put_cxy(void) /* put out current xy chromaticities */
1069 {
1070 static char xbuf[24], ybuf[24];
1071 static char *ccom[4] = {mg_ename[MG_E_CXY], xbuf, ybuf};
1072
1073 sprintf(xbuf, "%.4f", c_ccolor->cx);
1074 sprintf(ybuf, "%.4f", c_ccolor->cy);
1075 return(mg_handle(MG_E_CXY, 3, ccom));
1076 }
1077
1078
1079 static int
1080 put_cspec(void) /* put out current color spectrum */
1081 {
1082 char wl[2][6], vbuf[C_CNSS][24];
1083 char *newav[C_CNSS+4];
1084 double sf;
1085 register int i;
1086
1087 if (mg_ehand[MG_E_CSPEC] != c_hcolor) {
1088 sprintf(wl[0], "%d", C_CMINWL);
1089 sprintf(wl[1], "%d", C_CMAXWL);
1090 newav[0] = mg_ename[MG_E_CSPEC];
1091 newav[1] = wl[0];
1092 newav[2] = wl[1];
1093 sf = (double)C_CNSS / c_ccolor->ssum;
1094 for (i = 0; i < C_CNSS; i++) {
1095 sprintf(vbuf[i], "%.4f", sf*c_ccolor->ssamp[i]);
1096 newav[i+3] = vbuf[i];
1097 }
1098 newav[C_CNSS+3] = NULL;
1099 if ((i = mg_handle(MG_E_CSPEC, C_CNSS+3, newav)) != MG_OK)
1100 return(i);
1101 }
1102 return(MG_OK);
1103 }
1104
1105
1106 static int
1107 e_cspec( /* handle spectral color */
1108 int ac,
1109 char **av
1110 )
1111 {
1112 /* convert to xy chromaticity */
1113 c_ccvt(c_ccolor, C_CSXY);
1114 /* if it's really their handler, use it */
1115 if (mg_ehand[MG_E_CXY] != c_hcolor)
1116 return(put_cxy());
1117 return(MG_OK);
1118 }
1119
1120
1121 static int
1122 e_cmix( /* handle mixing of colors */
1123 int ac,
1124 char **av
1125 )
1126 {
1127 /*
1128 * Contorted logic works as follows:
1129 * 1. the colors are already mixed in c_hcolor() support function
1130 * 2. if we would handle a spectral result, make sure it's not
1131 * 3. if c_hcolor() would handle a spectral result, don't bother
1132 * 4. otherwise, make cspec entity and pass it to their handler
1133 * 5. if we have only xy results, handle it as c_spec() would
1134 */
1135 if (mg_ehand[MG_E_CSPEC] == e_cspec)
1136 c_ccvt(c_ccolor, C_CSXY);
1137 else if (c_ccolor->flags & C_CDSPEC)
1138 return(put_cspec());
1139 if (mg_ehand[MG_E_CXY] != c_hcolor)
1140 return(put_cxy());
1141 return(MG_OK);
1142 }
1143
1144
1145 static int
1146 e_cct( /* handle color temperature */
1147 int ac,
1148 char **av
1149 )
1150 {
1151 /*
1152 * Logic is similar to e_cmix here. Support handler has already
1153 * converted temperature to spectral color. Put it out as such
1154 * if they support it, otherwise convert to xy chromaticity and
1155 * put it out if they handle it.
1156 */
1157 if (mg_ehand[MG_E_CSPEC] != e_cspec)
1158 return(put_cspec());
1159 c_ccvt(c_ccolor, C_CSXY);
1160 if (mg_ehand[MG_E_CXY] != c_hcolor)
1161 return(put_cxy());
1162 return(MG_OK);
1163 }
