root/radiance/src/cv/mgflib/iesnotes.txt
Revision: 1.2
Committed: Fri Feb 28 20:19:26 2003 UTC (22 years, 8 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
Fixed RCSid's
# User Rev Content
1 greg 1.1 Enclosing IES File Notes
2 greg 1.2 RCSid "$Id$"
3 greg 1.1
4     The following notes describe how MGF data is to be referred to by
5     an enclosing IES luminaire file, and these notes are in a state of flux.
6
7     The basic method for specifying an MGF geometry file within an IES
8     file is a single line immediately preceeding the TILT= line, which reads:
9
10     GEOM=file.mgf
11
12     where "file.mgf" is replaced by the name of the relevant MGF file.
13
14     IES data file contains simplified geometry, which must completely
15     enclose the detailed geometry specified by the "GEOM=file.mgf" line.
16     This detailed geometry file is always in meters, whatever the units of
17     the enclosing IES file, and must have its origin at the center of the
18     simplified geometry. The X-axis corresponds to the 0-180 degree plane,
19     the Y-axis corresponds to the 90-270 degree plane, and the Z-axis
20     corresponds to the up direction. (This is a right-handed coordinate
21     system.)
22
23     The emission values in the MGF file will be multiplied by the usual
24     IES luminaire factors, i.e. the tilt factors (if any), the candela
25     multiplier, the ballast factor and the ballast lamp factor. Thus,
26     the MGF file emissions should correspond to those of the as-tested
27     luminaire configuration.
