| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: mgf2rad.c,v 2.31 2016/10/03 18:16:45 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* Convert MGF (Materials and Geometry Format) to Radiance |
| 6 |
| 7 |
| 8 |
#include <stdio.h> |
| 9 |
#include <stdlib.h> |
| 10 |
#include <math.h> |
| 11 |
#include <string.h> |
| 12 |
| 13 |
#include "platform.h" |
| 14 |
#include "mgf_parser.h" |
| 15 |
#include "color.h" |
| 16 |
#include "tmesh.h" |
| 17 |
| 18 |
#define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2]) |
| 19 |
| 20 |
#define invert (xf_context != NULL && xf_context->rev) |
| 21 |
| 22 |
double glowdist = FHUGE; /* glow test distance */ |
| 23 |
| 24 |
double emult = 1.; /* emitter multiplier */ |
| 25 |
| 26 |
FILE *matfp; /* material output file */ |
| 27 |
| 28 |
| 29 |
extern int r_comment(int ac, char **av); |
| 30 |
extern int r_cone(int ac, char **av); |
| 31 |
extern int r_cyl(int ac, char **av); |
| 32 |
extern int r_sph(int ac, char **av); |
| 33 |
extern int r_ring(int ac, char **av); |
| 34 |
extern int r_face(int ac, char **av); |
| 35 |
extern int r_ies(int ac, char **av); |
| 36 |
extern void putsided(char *mname); |
| 37 |
extern char * material(void); |
| 38 |
extern char * object(void); |
| 39 |
extern char * addarg(char *op, char *arg); |
| 40 |
extern void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv); |
| 41 |
extern void cvtcolor(COLOR radrgb, register C_COLOR *ciec, double intensity); |
| 42 |
| 43 |
| 44 |
int |
| 45 |
main( |
| 46 |
int argc, |
| 47 |
char *argv[] |
| 48 |
| 49 |
| 50 |
int i; |
| 51 |
| 52 |
matfp = stdout; |
| 53 |
/* print out parser version */ |
| 54 |
printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR); |
| 55 |
/* initialize dispatch table */ |
| 56 |
mg_ehand[MG_E_COMMENT] = r_comment; /* we pass comments */ |
| 57 |
mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */ |
| 58 |
mg_ehand[MG_E_CONE] = r_cone; /* we do cones */ |
| 59 |
mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */ |
| 60 |
mg_ehand[MG_E_CSPEC] = c_hcolor; /* they get spectra */ |
| 61 |
mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */ |
| 62 |
mg_ehand[MG_E_CCT] = c_hcolor; /* they get color temp's */ |
| 63 |
mg_ehand[MG_E_CYL] = r_cyl; /* we do cylinders */ |
| 64 |
mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */ |
| 65 |
mg_ehand[MG_E_FACE] = r_face; /* we do faces */ |
| 66 |
mg_ehand[MG_E_IES] = r_ies; /* we do IES files */ |
| 67 |
mg_ehand[MG_E_IR] = c_hmaterial; /* they get refractive index */ |
| 68 |
mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* they get materials */ |
| 69 |
mg_ehand[MG_E_NORMAL] = c_hvertex; /* they get normals */ |
| 70 |
mg_ehand[MG_E_OBJECT] = obj_handler; /* they track object names */ |
| 71 |
mg_ehand[MG_E_POINT] = c_hvertex; /* they get points */ |
| 72 |
mg_ehand[MG_E_RD] = c_hmaterial; /* they get diffuse refl. */ |
| 73 |
mg_ehand[MG_E_RING] = r_ring; /* we do rings */ |
| 74 |
mg_ehand[MG_E_RS] = c_hmaterial; /* they get specular refl. */ |
| 75 |
mg_ehand[MG_E_SIDES] = c_hmaterial; /* they get # sides */ |
| 76 |
mg_ehand[MG_E_SPH] = r_sph; /* we do spheres */ |
| 77 |
mg_ehand[MG_E_TD] = c_hmaterial; /* they get diffuse trans. */ |
| 78 |
mg_ehand[MG_E_TS] = c_hmaterial; /* they get specular trans. */ |
| 79 |
mg_ehand[MG_E_VERTEX] = c_hvertex; /* they get vertices */ |
| 80 |
mg_ehand[MG_E_XF] = xf_handler; /* they track transforms */ |
| 81 |
mg_init(); /* initialize the parser */ |
| 82 |
/* get our options & print header */ |
| 83 |
printf("## %s", argv[0]); |
| 84 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) { |
| 85 |
printf(" %s", argv[i]); |
| 86 |
switch (argv[i][1]) { |
| 87 |
case 'g': /* glow distance (meters) */ |
| 88 |
if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f")) |
| 89 |
goto userr; |
| 90 |
glowdist = atof(argv[++i]); |
| 91 |
| 92 |
break; |
| 93 |
case 'e': /* emitter multiplier */ |
| 94 |
| 95 |
goto userr; |
| 96 |
emult = atof(argv[++i]); |
| 97 |
| 98 |
break; |
| 99 |
case 'm': /* materials file */ |
| 100 |
matfp = fopen(argv[++i], "a"); |
| 101 |
if (matfp == NULL) { |
| 102 |
fprintf(stderr, "%s: cannot append\n", argv[i]); |
| 103 |
exit(1); |
| 104 |
| 105 |
| 106 |
break; |
| 107 |
default: |
| 108 |
goto userr; |
| 109 |
| 110 |
| 111 |
putchar('\n'); |
| 112 |
if (i == argc) { /* convert stdin */ |
| 113 |
if (mg_load(NULL) != MG_OK) |
| 114 |
exit(1); |
| 115 |
if (mg_nunknown) |
| 116 |
printf("## %s: %u unknown entities\n", |
| 117 |
argv[0], mg_nunknown); |
| 118 |
} else /* convert each file */ |
| 119 |
for ( ; i < argc; i++) { |
| 120 |
printf("## %s %s ##############################\n", |
| 121 |
argv[0], argv[i]); |
| 122 |
if (mg_load(argv[i]) != MG_OK) |
| 123 |
exit(1); |
| 124 |
if (mg_nunknown) { |
| 125 |
printf("## %s %s: %u unknown entities\n", |
| 126 |
argv[0], argv[i], mg_nunknown); |
| 127 |
mg_nunknown = 0; |
| 128 |
| 129 |
| 130 |
exit(0); |
| 131 |
userr: |
| 132 |
fprintf(stderr, "Usage: %s [-g dist][-e mult][-m matf] [file.mgf] ..\n", |
| 133 |
argv[0]); |
| 134 |
exit(1); |
| 135 |
| 136 |
| 137 |
| 138 |
int |
| 139 |
r_comment( /* repeat a comment verbatim */ |
| 140 |
register int ac, |
| 141 |
register char **av |
| 142 |
| 143 |
| 144 |
putchar('#'); /* use Radiance comment character */ |
| 145 |
while (--ac) { /* pass through verbatim */ |
| 146 |
putchar(' '); |
| 147 |
fputs(*++av, stdout); |
| 148 |
| 149 |
putchar('\n'); |
| 150 |
return(MG_OK); |
| 151 |
| 152 |
| 153 |
| 154 |
int |
| 155 |
r_cone( /* put out a cone */ |
| 156 |
int ac, |
| 157 |
char **av |
| 158 |
| 159 |
| 160 |
static int ncones; |
| 161 |
char *mat; |
| 162 |
double r1, r2; |
| 163 |
C_VERTEX *cv1, *cv2; |
| 164 |
FVECT p1, p2; |
| 165 |
int inv; |
| 166 |
/* check argument count and type */ |
| 167 |
if (ac != 5) |
| 168 |
return(MG_EARGC); |
| 169 |
if (!isflt(av[2]) || !isflt(av[4])) |
| 170 |
return(MG_ETYPE); |
| 171 |
/* get the endpoint vertices */ |
| 172 |
if ((cv1 = c_getvert(av[1])) == NULL || |
| 173 |
(cv2 = c_getvert(av[3])) == NULL) |
| 174 |
return(MG_EUNDEF); |
| 175 |
xf_xfmpoint(p1, cv1->p); /* transform endpoints */ |
| 176 |
xf_xfmpoint(p2, cv2->p); |
| 177 |
r1 = xf_scale(atof(av[2])); /* scale radii */ |
| 178 |
r2 = xf_scale(atof(av[4])); |
| 179 |
inv = r1 < 0.; /* check for inverted cone */ |
| 180 |
if (r1 == 0.) { /* check for illegal radii */ |
| 181 |
if (r2 == 0.) |
| 182 |
return(MG_EILL); |
| 183 |
inv = r2 < 0.; |
| 184 |
} else if (r2 != 0. && inv ^ (r2 < 0.)) |
| 185 |
return(MG_EILL); |
| 186 |
if (inv) { |
| 187 |
r1 = -r1; |
| 188 |
r2 = -r2; |
| 189 |
| 190 |
if ((mat = material()) == NULL) /* get material */ |
| 191 |
return(MG_EBADMAT); |
| 192 |
/* spit the sucker out */ |
| 193 |
printf("\n%s %s %sc%d\n", mat, inv ? "cup" : "cone", |
| 194 |
object(), ++ncones); |
| 195 |
printf("0\n0\n8\n"); |
| 196 |
putv(p1); |
| 197 |
putv(p2); |
| 198 |
printf("%18.12g %18.12g\n", r1, r2); |
| 199 |
return(MG_OK); |
| 200 |
| 201 |
| 202 |
| 203 |
int |
| 204 |
r_cyl( /* put out a cylinder */ |
| 205 |
int ac, |
| 206 |
char **av |
| 207 |
| 208 |
| 209 |
static int ncyls; |
| 210 |
char *mat; |
| 211 |
double rad; |
| 212 |
| 213 |
FVECT p1, p2; |
| 214 |
int inv; |
| 215 |
| 216 |
if (ac != 4) |
| 217 |
return(MG_EARGC); |
| 218 |
if (!isflt(av[2])) |
| 219 |
return(MG_ETYPE); |
| 220 |
| 221 |
| 222 |
| 223 |
| 224 |
| 225 |
| 226 |
rad = xf_scale(atof(av[2])); /* scale radius */ |
| 227 |
if ((inv = rad < 0.)) /* check for inverted cylinder */ |
| 228 |
rad = -rad; |
| 229 |
| 230 |
| 231 |
/* spit out the primitive */ |
| 232 |
printf("\n%s %s %scy%d\n", mat, inv ? "tube" : "cylinder", |
| 233 |
object(), ++ncyls); |
| 234 |
printf("0\n0\n7\n"); |
| 235 |
putv(p1); |
| 236 |
putv(p2); |
| 237 |
printf("%18.12g\n", rad); |
| 238 |
return(MG_OK); |
| 239 |
| 240 |
| 241 |
| 242 |
int |
| 243 |
r_sph( /* put out a sphere */ |
| 244 |
int ac, |
| 245 |
char **av |
| 246 |
| 247 |
| 248 |
static int nsphs; |
| 249 |
char *mat; |
| 250 |
double rad; |
| 251 |
C_VERTEX *cv; |
| 252 |
FVECT cent; |
| 253 |
int inv; |
| 254 |
| 255 |
if (ac != 3) |
| 256 |
return(MG_EARGC); |
| 257 |
| 258 |
return(MG_ETYPE); |
| 259 |
if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */ |
| 260 |
| 261 |
xf_xfmpoint(cent, cv->p); /* transform center */ |
| 262 |
| 263 |
if ((inv = rad < 0.)) /* check for inversion */ |
| 264 |
rad = -rad; |
| 265 |
| 266 |
| 267 |
/* spit out primitive */ |
| 268 |
printf("\n%s %s %ss%d\n", mat, inv ? "bubble" : "sphere", |
| 269 |
object(), ++nsphs); |
| 270 |
printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n", |
| 271 |
cent[0], cent[1], cent[2], rad); |
| 272 |
return(MG_OK); |
| 273 |
| 274 |
| 275 |
| 276 |
int |
| 277 |
r_ring( /* put out a ring */ |
| 278 |
int ac, |
| 279 |
char **av |
| 280 |
| 281 |
| 282 |
static int nrings; |
| 283 |
char *mat; |
| 284 |
double r1, r2; |
| 285 |
C_VERTEX *cv; |
| 286 |
FVECT cent, norm; |
| 287 |
| 288 |
if (ac != 4) |
| 289 |
return(MG_EARGC); |
| 290 |
if (!isflt(av[2]) || !isflt(av[3])) |
| 291 |
return(MG_ETYPE); |
| 292 |
| 293 |
| 294 |
if (is0vect(cv->n)) /* make sure we have normal */ |
| 295 |
return(MG_EILL); |
| 296 |
| 297 |
xf_rotvect(norm, cv->n); /* rotate normal */ |
| 298 |
| 299 |
r2 = xf_scale(atof(av[3])); |
| 300 |
if ((r1 < 0.) | (r2 <= r1)) |
| 301 |
return(MG_EILL); |
| 302 |
| 303 |
| 304 |
| 305 |
printf("\n%s ring %sr%d\n", mat, object(), ++nrings); |
| 306 |
| 307 |
putv(cent); |
| 308 |
putv(norm); |
| 309 |
| 310 |
return(MG_OK); |
| 311 |
| 312 |
| 313 |
| 314 |
int |
| 315 |
r_face( /* convert a face */ |
| 316 |
int ac, |
| 317 |
char **av |
| 318 |
| 319 |
| 320 |
static int nfaces; |
| 321 |
int myi = invert; |
| 322 |
char *mat; |
| 323 |
register int i; |
| 324 |
register C_VERTEX *cv; |
| 325 |
FVECT v; |
| 326 |
| 327 |
| 328 |
if (ac < 4) |
| 329 |
return(MG_EARGC); |
| 330 |
| 331 |
| 332 |
if (ac <= 5) { /* check for smoothing */ |
| 333 |
C_VERTEX *cva[5]; |
| 334 |
for (i = 1; i < ac; i++) { |
| 335 |
if ((cva[i-1] = c_getvert(av[i])) == NULL) |
| 336 |
| 337 |
if (is0vect(cva[i-1]->n)) |
| 338 |
break; |
| 339 |
| 340 |
if (i < ac) |
| 341 |
i = ISFLAT; |
| 342 |
else |
| 343 |
i = flat_tri(cva[0]->p, cva[1]->p, cva[2]->p, |
| 344 |
cva[0]->n, cva[1]->n, cva[2]->n); |
| 345 |
if (i == DEGEN) |
| 346 |
return(MG_OK); /* degenerate (error?) */ |
| 347 |
if (i == RVBENT) { |
| 348 |
myi = !myi; |
| 349 |
i = ISBENT; |
| 350 |
} else if (i == RVFLAT) { |
| 351 |
myi = !myi; |
| 352 |
i = ISFLAT; |
| 353 |
| 354 |
if (i == ISBENT) { /* smoothed triangles */ |
| 355 |
do_tri(mat, cva[0], cva[1], cva[2], myi); |
| 356 |
if (ac == 5) |
| 357 |
do_tri(mat, cva[2], cva[3], cva[0], myi); |
| 358 |
return(MG_OK); |
| 359 |
| 360 |
| 361 |
/* spit out unsmoothed primitive */ |
| 362 |
printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces); |
| 363 |
printf("0\n0\n%d\n", 3*(ac-1)); |
| 364 |
for (i = 1; i < ac; i++) { /* get, transform, print each vertex */ |
| 365 |
if ((cv = c_getvert(av[myi ? ac-i : i])) == NULL) |
| 366 |
| 367 |
xf_xfmpoint(v, cv->p); |
| 368 |
putv(v); |
| 369 |
| 370 |
return(MG_OK); |
| 371 |
| 372 |
| 373 |
| 374 |
int |
| 375 |
r_ies( /* convert an IES luminaire file */ |
| 376 |
int ac, |
| 377 |
char **av |
| 378 |
| 379 |
| 380 |
int xa0 = 2; |
| 381 |
char combuf[128]; |
| 382 |
char fname[48]; |
| 383 |
char *oname; |
| 384 |
register char *op; |
| 385 |
register int i; |
| 386 |
/* check argument count */ |
| 387 |
if (ac < 2) |
| 388 |
return(MG_EARGC); |
| 389 |
/* construct output file name */ |
| 390 |
if ((op = strrchr(av[1], '/')) != NULL) |
| 391 |
op++; |
| 392 |
else |
| 393 |
op = av[1]; |
| 394 |
(void)strcpy(fname, op); |
| 395 |
if ((op = strrchr(fname, '.')) == NULL) |
| 396 |
op = fname + strlen(fname); |
| 397 |
(void)strcpy(op, ".rad"); |
| 398 |
/* see if we need to run ies2rad */ |
| 399 |
if (access(fname, 0) == -1) { |
| 400 |
(void)strcpy(combuf, "ies2rad");/* build ies2rad command */ |
| 401 |
op = combuf + 7; /* get -m option (first) */ |
| 402 |
if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) { |
| 403 |
if (!isflt(av[xa0+1])) |
| 404 |
return(MG_ETYPE); |
| 405 |
op = addarg(addarg(op, "-m"), av[xa0+1]); |
| 406 |
xa0 += 2; |
| 407 |
| 408 |
*op++ = ' '; /* build IES filename */ |
| 409 |
i = 0; |
| 410 |
if (mg_file != NULL && |
| 411 |
(oname = strrchr(mg_file->fname,'/')) != NULL) { |
| 412 |
i = oname - mg_file->fname + 1; |
| 413 |
(void)strcpy(op, mg_file->fname); |
| 414 |
| 415 |
(void)strcpy(op+i, av[1]); |
| 416 |
if (access(op, 0) == -1) /* check for file existence */ |
| 417 |
return(MG_ENOFILE); |
| 418 |
system(combuf); /* run ies2rad */ |
| 419 |
if (access(fname, 0) == -1) /* check success */ |
| 420 |
return(MG_EINCL); |
| 421 |
| 422 |
printf("\n!xform"); /* put out xform command */ |
| 423 |
oname = object(); |
| 424 |
if (*oname) { |
| 425 |
printf(" -n "); |
| 426 |
for (op = oname; op[1]; op++) /* remove trailing separator */ |
| 427 |
putchar(*op); |
| 428 |
| 429 |
for (i = xa0; i < ac; i++) |
| 430 |
printf(" %s", av[i]); |
| 431 |
if (ac > xa0 && xf_argc > 0) |
| 432 |
printf(" -i 1"); |
| 433 |
for (i = 0; i < xf_argc; i++) |
| 434 |
printf(" %s", xf_argv[i]); |
| 435 |
printf(" %s\n", fname); |
| 436 |
return(MG_OK); |
| 437 |
| 438 |
| 439 |
| 440 |
void |
| 441 |
do_tri( /* put out smoothed triangle */ |
| 442 |
char *mat, |
| 443 |
C_VERTEX *cv1, |
| 444 |
C_VERTEX *cv2, |
| 445 |
C_VERTEX *cv3, |
| 446 |
int iv |
| 447 |
| 448 |
| 449 |
static int ntris; |
| 450 |
BARYCCM bvecs; |
| 451 |
RREAL bcoor[3][3]; |
| 452 |
C_VERTEX *cvt; |
| 453 |
FVECT v1, v2, v3; |
| 454 |
FVECT n1, n2, n3; |
| 455 |
register int i; |
| 456 |
| 457 |
if (iv) { /* swap vertex order if inverted */ |
| 458 |
cvt = cv1; |
| 459 |
cv1 = cv3; |
| 460 |
cv3 = cvt; |
| 461 |
| 462 |
xf_xfmpoint(v1, cv1->p); |
| 463 |
xf_xfmpoint(v2, cv2->p); |
| 464 |
xf_xfmpoint(v3, cv3->p); |
| 465 |
/* compute barycentric coords. */ |
| 466 |
if (comp_baryc(&bvecs, v1, v2, v3) < 0) |
| 467 |
return; /* degenerate triangle! */ |
| 468 |
printf("\n%s texfunc T-nor\n", mat); /* put out texture */ |
| 469 |
printf("4 dx dy dz %s\n0\n", TCALNAME); |
| 470 |
xf_rotvect(n1, cv1->n); |
| 471 |
xf_rotvect(n2, cv2->n); |
| 472 |
xf_rotvect(n3, cv3->n); |
| 473 |
for (i = 0; i < 3; i++) { |
| 474 |
bcoor[i][0] = n1[i]; |
| 475 |
bcoor[i][1] = n2[i]; |
| 476 |
bcoor[i][2] = n3[i]; |
| 477 |
| 478 |
fput_baryc(&bvecs, bcoor, 3, stdout); |
| 479 |
/* put out triangle */ |
| 480 |
printf("\nT-nor polygon %st%d\n", object(), ++ntris); |
| 481 |
printf("0\n0\n9\n"); |
| 482 |
putv(v1); |
| 483 |
putv(v2); |
| 484 |
putv(v3); |
| 485 |
| 486 |
| 487 |
| 488 |
void |
| 489 |
putsided(char *mname) /* print out mixfunc for sided material */ |
| 490 |
| 491 |
fprintf(matfp, "\nvoid mixfunc %s\n", mname); |
| 492 |
fprintf(matfp, "4 %s void if(Rdot,1,0) .\n0\n0\n", mname); |
| 493 |
| 494 |
| 495 |
| 496 |
char * |
| 497 |
material(void) /* get (and print) current material */ |
| 498 |
| 499 |
char *mname = "mat"; |
| 500 |
COLOR radrgb, c2; |
| 501 |
double d; |
| 502 |
| 503 |
if (c_cmname != NULL) |
| 504 |
mname = c_cmname; |
| 505 |
if (!c_cmaterial->clock) |
| 506 |
return(mname); /* already current */ |
| 507 |
/* else update output */ |
| 508 |
c_cmaterial->clock = 0; |
| 509 |
if (c_cmaterial->ed > .1) { /* emitter */ |
| 510 |
cvtcolor(radrgb, &c_cmaterial->ed_c, |
| 511 |
emult*c_cmaterial->ed/(PI*WHTEFFICACY)); |
| 512 |
if (glowdist < FHUGE) { /* do a glow */ |
| 513 |
fprintf(matfp, "\nvoid glow %s\n0\n0\n", mname); |
| 514 |
fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED), |
| 515 |
colval(radrgb,GRN), |
| 516 |
colval(radrgb,BLU), glowdist); |
| 517 |
} else { |
| 518 |
fprintf(matfp, "\nvoid light %s\n0\n0\n", mname); |
| 519 |
fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED), |
| 520 |
| 521 |
colval(radrgb,BLU)); |
| 522 |
| 523 |
return(mname); |
| 524 |
| 525 |
d = c_cmaterial->rd + c_cmaterial->td + |
| 526 |
c_cmaterial->rs + c_cmaterial->ts; |
| 527 |
if ((d < 0.) | (d > 1.)) |
| 528 |
return(NULL); |
| 529 |
/* check for glass/dielectric */ |
| 530 |
if (c_cmaterial->nr > 1.1 && |
| 531 |
c_cmaterial->ts > .25 && c_cmaterial->rs <= .125 && |
| 532 |
c_cmaterial->td <= .01 && c_cmaterial->rd <= .01 && |
| 533 |
c_cmaterial->rs_a <= .01 && c_cmaterial->ts_a <= .01) { |
| 534 |
cvtcolor(radrgb, &c_cmaterial->ts_c, |
| 535 |
c_cmaterial->ts + c_cmaterial->rs); |
| 536 |
if (c_cmaterial->sided) { /* dielectric */ |
| 537 |
colval(radrgb,RED) = pow(colval(radrgb,RED), |
| 538 |
1./C_1SIDEDTHICK); |
| 539 |
colval(radrgb,GRN) = pow(colval(radrgb,GRN), |
| 540 |
| 541 |
colval(radrgb,BLU) = pow(colval(radrgb,BLU), |
| 542 |
| 543 |
fprintf(matfp, "\nvoid dielectric %s\n0\n0\n", mname); |
| 544 |
fprintf(matfp, "5 %g %g %g %f 0\n", colval(radrgb,RED), |
| 545 |
colval(radrgb,GRN), colval(radrgb,BLU), |
| 546 |
c_cmaterial->nr); |
| 547 |
return(mname); |
| 548 |
| 549 |
/* glass */ |
| 550 |
fprintf(matfp, "\nvoid glass %s\n0\n0\n", mname); |
| 551 |
| 552 |
| 553 |
c_cmaterial->nr); |
| 554 |
return(mname); |
| 555 |
| 556 |
/* check for trans */ |
| 557 |
if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) { |
| 558 |
double a5, a6; |
| 559 |
/* average colors */ |
| 560 |
d = c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts; |
| 561 |
cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d); |
| 562 |
cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d); |
| 563 |
addcolor(radrgb, c2); |
| 564 |
cvtcolor(c2, &c_cmaterial->ts_c, c_cmaterial->ts/d); |
| 565 |
| 566 |
if (c_cmaterial->rs + c_cmaterial->ts > .0001) |
| 567 |
a5 = (c_cmaterial->rs*c_cmaterial->rs_a + |
| 568 |
c_cmaterial->ts*c_cmaterial->ts_a) / |
| 569 |
(c_cmaterial->rs + c_cmaterial->ts); |
| 570 |
a6 = (c_cmaterial->td + c_cmaterial->ts) / |
| 571 |
(c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts); |
| 572 |
if (a6 < .999) |
| 573 |
d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6); |
| 574 |
else |
| 575 |
d = c_cmaterial->td + c_cmaterial->ts; |
| 576 |
scalecolor(radrgb, d); |
| 577 |
fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname); |
| 578 |
fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED), |
| 579 |
colval(radrgb,GRN), colval(radrgb,BLU)); |
| 580 |
fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6, |
| 581 |
c_cmaterial->ts/(c_cmaterial->ts + c_cmaterial->td)); |
| 582 |
if (c_cmaterial->sided) |
| 583 |
putsided(mname); |
| 584 |
return(mname); |
| 585 |
| 586 |
/* check for plastic */ |
| 587 |
if (c_cmaterial->rs < .08 && (c_cmaterial->rs < .1*c_cmaterial->rd || |
| 588 |
c_isgrey(&c_cmaterial->rs_c))) { |
| 589 |
cvtcolor(radrgb, &c_cmaterial->rd_c, |
| 590 |
c_cmaterial->rd/(1.-c_cmaterial->rs)); |
| 591 |
fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname); |
| 592 |
fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), |
| 593 |
| 594 |
c_cmaterial->rs, c_cmaterial->rs_a); |
| 595 |
| 596 |
putsided(mname); |
| 597 |
return(mname); |
| 598 |
| 599 |
/* else it's metal */ |
| 600 |
| 601 |
cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd); |
| 602 |
cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs); |
| 603 |
| 604 |
fprintf(matfp, "\nvoid metal %s\n0\n0\n", mname); |
| 605 |
| 606 |
| 607 |
c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs), |
| 608 |
| 609 |
| 610 |
putsided(mname); |
| 611 |
return(mname); |
| 612 |
| 613 |
| 614 |
| 615 |
void |
| 616 |
cvtcolor( /* convert a CIE XYZ color to RGB */ |
| 617 |
COLOR radrgb, |
| 618 |
register C_COLOR *ciec, |
| 619 |
double intensity |
| 620 |
| 621 |
| 622 |
static COLOR ciexyz; |
| 623 |
| 624 |
c_ccvt(ciec, C_CSXY); /* get xy representation */ |
| 625 |
ciexyz[1] = intensity; |
| 626 |
ciexyz[0] = ciec->cx/ciec->cy*ciexyz[1]; |
| 627 |
ciexyz[2] = ciexyz[1]*(1./ciec->cy - 1.) - ciexyz[0]; |
| 628 |
cie_rgb(radrgb, ciexyz); |
| 629 |
| 630 |
| 631 |
| 632 |
char * |
| 633 |
object(void) /* return current object name */ |
| 634 |
| 635 |
static char objbuf[64]; |
| 636 |
register int i; |
| 637 |
register char *cp; |
| 638 |
int len; |
| 639 |
/* tracked by obj_handler */ |
| 640 |
i = obj_nnames - sizeof(objbuf)/16; |
| 641 |
if (i < 0) |
| 642 |
i = 0; |
| 643 |
for (cp = objbuf; i < obj_nnames && |
| 644 |
cp + (len=strlen(obj_name[i])) < objbuf+sizeof(objbuf)-1; |
| 645 |
i++, *cp++ = '.') { |
| 646 |
strcpy(cp, obj_name[i]); |
| 647 |
cp += len; |
| 648 |
| 649 |
*cp = '\0'; |
| 650 |
return(objbuf); |
| 651 |
| 652 |
| 653 |
| 654 |
char * |
| 655 |
addarg( /* add argument and advance pointer */ |
| 656 |
register char *op, |
| 657 |
register char *arg |
| 658 |
| 659 |
| 660 |
*op = ' '; |
| 661 |
while ( (*++op = *arg++) ) |
| 662 |
| 663 |
return(op); |
| 664 |
