root/radiance/src/cv/mgf2rad.c
Sat Jan 25 18:02:06 2014 UTC (11 years, 8 months ago) by greg
Changes since 2.29: +38 -31 lines
Diff to previous 2.29
Made one-sided materials really work using mixfunc
Tue Feb 22 16:45:12 2011 UTC (14 years, 7 months ago) by greg
Diff to previous 2.28
Fixed a few compile errors due to code reorg
Sat Nov 15 17:54:06 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.27: +70 -41 lines
Diff to previous 2.27
Sun Jul 27 22:12:01 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.26: +5 -5 lines
Diff to previous 2.26
Thu Jun 26 00:58:09 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 2.25
Sat Feb 22 02:07:23 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.24: +21 -13 lines
Diff to previous 2.24
Wed Jun 9 14:06:00 1999 UTC (26 years, 4 months ago) by gwlarson
Changes since 2.23: +3 -1 lines
Diff to previous 2.23
moved output file initialization into main for Linux non-constant stdout
Wed Jul 24 13:07:48 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.22: +21 -16 lines
Diff to previous 2.22
added check for flat triangles with normals
Thu Jun 6 11:49:53 1996 UTC (29 years, 4 months ago) by greg
Changes since 2.21: +3 -1 lines
Diff to previous 2.21
bug fix in r_ies() associated with IES file pathnames
Tue Feb 27 20:11:27 1996 UTC (29 years, 7 months ago) by greg
Changes since 2.20: +2 -3 lines
Diff to previous 2.20
made choice of plastic more typical
Wed Nov 22 15:38:04 1995 UTC (29 years, 11 months ago) by greg
Diff to previous 2.19
minor change removing unneeded variable
Thu May 11 21:49:05 1995 UTC (30 years, 5 months ago) by greg
Changes since 2.18: +2 -0 lines
Diff to previous 2.18
added MGF version tracking
Thu May 11 20:17:56 1995 UTC (30 years, 5 months ago) by greg
Changes since 2.17: +9 -1 lines
Diff to previous 2.17
added default handling of undefined entities
Mon May 1 17:05:22 1995 UTC (30 years, 5 months ago) by greg
Diff to previous 2.16
bug fix in r_ies
Fri Apr 14 19:03:20 1995 UTC (30 years, 6 months ago) by greg
Changes since 2.15: +94 -83 lines
Diff to previous 2.15
added lots of comments and added file precheck to r_ies()
Fri Apr 14 10:47:50 1995 UTC (30 years, 6 months ago) by greg
Changes since 2.14: +12 -5 lines
Diff to previous 2.14
fixed bug in ies conversion routine for getting file context
Thu Apr 13 14:43:33 1995 UTC (30 years, 6 months ago) by greg
Changes since 2.13: +28 -0 lines
Diff to previous 2.13
added MGF index of refraction (ir) and dielectric support
Tue Mar 7 12:18:15 1995 UTC (30 years, 7 months ago) by greg
Changes since 2.12: +1 -0 lines
Diff to previous 2.12
added cct entity
Wed Dec 7 12:40:37 1994 UTC (30 years, 10 months ago) by greg
fixed conversion of emittance
Fri Aug 26 12:54:24 1994 UTC (31 years, 1 month ago) by greg
Changes since 2.10: +22 -12 lines
added -m option for separate materials file
Thu Jul 21 17:23:43 1994 UTC (31 years, 3 months ago) by greg
fixed bad argument parsing
Thu Jul 21 15:04:23 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.8: +10 -3 lines
added vertex reversal
Tue Jul 19 15:54:44 1994 UTC (31 years, 3 months ago) by greg
spelling correction in comment (really!)
Fri Jul 8 16:10:09 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.6: +17 -19 lines
numerous bug fixes and enhancements
Fri Jul 1 18:06:36 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.5: +7 -2 lines
added "sides" entity for one- vs. two-sided surfaces
Fri Jul 1 10:20:19 1994 UTC (31 years, 3 months ago) by greg
changed context names from struct members to extern variables
Sat Jun 25 09:45:22 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.3: +8 -2 lines
added further color support
Fri Jun 24 17:16:51 1994 UTC (31 years, 3 months ago) by greg
Changes since 2.2: +4 -2 lines
slight modification to color handling
Wed Jun 22 17:16:03 1994 UTC (31 years, 4 months ago) by greg
Changes since 2.1: +16 -25 lines
bug fixes
Wed Jun 22 15:33:03 1994 UTC (31 years, 4 months ago) by greg
