| 1 | #ifndef lint |
| 2 | static const char       RCSid[] = "$Id: mgf2rad.c,v 2.29 2011/02/22 16:45:12 greg Exp $"; |
| 3 | #endif |
| 4 | /* |
| 5 | * Convert MGF (Materials and Geometry Format) to Radiance |
| 6 | */ |
| 7 |  |
| 8 | #include <stdio.h> |
| 9 | #include <stdlib.h> |
| 10 | #include <math.h> |
| 11 | #include <string.h> |
| 12 |  |
| 13 | #include "platform.h" |
| 14 | #include "mgf_parser.h" |
| 15 | #include "color.h" |
| 16 | #include "tmesh.h" |
| 17 |  |
| 18 | #define putv(v)         printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2]) |
| 19 |  |
| 20 | #define invert          (xf_context != NULL && xf_context->rev) |
| 21 |  |
| 22 | double  glowdist = FHUGE;               /* glow test distance */ |
| 23 |  |
| 24 | double  emult = 1.;                     /* emitter multiplier */ |
| 25 |  |
| 26 | FILE    *matfp;                         /* material output file */ |
| 27 |  |
| 28 |  |
| 29 | extern int r_comment(int ac, char **av); |
| 30 | extern int r_cone(int ac, char **av); |
| 31 | extern int r_cyl(int ac, char **av); |
| 32 | extern int r_sph(int ac, char **av); |
| 33 | extern int r_ring(int ac, char **av); |
| 34 | extern int r_face(int ac, char **av); |
| 35 | extern int r_ies(int ac, char **av); |
| 36 | extern void putsided(char *mname); |
| 37 | extern char * material(void); |
| 38 | extern char * object(void); |
| 39 | extern char * addarg(char *op, char *arg); |
| 40 | extern void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv); |
| 41 | extern void cvtcolor(COLOR radrgb, register C_COLOR *ciec, double intensity); |
| 42 |  |
| 43 |  |
| 44 | int |
| 45 | main( |
| 46 | int     argc, |
| 47 | char    *argv[] |
| 48 | ) |
| 49 | { |
| 50 | int     i; |
| 51 |  |
| 52 | matfp = stdout; |
| 53 | /* print out parser version */ |
| 54 | printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR); |
| 55 | /* initialize dispatch table */ |
| 56 | mg_ehand[MG_E_COMMENT] = r_comment;     /* we pass comments */ |
| 57 | mg_ehand[MG_E_COLOR] = c_hcolor;        /* they get color */ |
| 58 | mg_ehand[MG_E_CONE] = r_cone;           /* we do cones */ |
| 59 | mg_ehand[MG_E_CMIX] = c_hcolor;         /* they mix colors */ |
| 60 | mg_ehand[MG_E_CSPEC] = c_hcolor;        /* they get spectra */ |
| 61 | mg_ehand[MG_E_CXY] = c_hcolor;          /* they get chromaticities */ |
| 62 | mg_ehand[MG_E_CCT] = c_hcolor;          /* they get color temp's */ |
| 63 | mg_ehand[MG_E_CYL] = r_cyl;             /* we do cylinders */ |
| 64 | mg_ehand[MG_E_ED] = c_hmaterial;        /* they get emission */ |
| 65 | mg_ehand[MG_E_FACE] = r_face;           /* we do faces */ |
| 66 | mg_ehand[MG_E_IES] = r_ies;             /* we do IES files */ |
| 67 | mg_ehand[MG_E_IR] = c_hmaterial;        /* they get refractive index */ |
| 68 | mg_ehand[MG_E_MATERIAL] = c_hmaterial;  /* they get materials */ |
| 69 | mg_ehand[MG_E_NORMAL] = c_hvertex;      /* they get normals */ |
| 70 | mg_ehand[MG_E_OBJECT] = obj_handler;    /* they track object names */ |
| 71 | mg_ehand[MG_E_POINT] = c_hvertex;       /* they get points */ |
| 72 | mg_ehand[MG_E_RD] = c_hmaterial;        /* they get diffuse refl. */ |
| 73 | mg_ehand[MG_E_RING] = r_ring;           /* we do rings */ |
| 74 | mg_ehand[MG_E_RS] = c_hmaterial;        /* they get specular refl. */ |
| 75 | mg_ehand[MG_E_SIDES] = c_hmaterial;     /* they get # sides */ |
| 76 | mg_ehand[MG_E_SPH] = r_sph;             /* we do spheres */ |
| 77 | mg_ehand[MG_E_TD] = c_hmaterial;        /* they get diffuse trans. */ |
| 78 | mg_ehand[MG_E_TS] = c_hmaterial;        /* they get specular trans. */ |
| 79 | mg_ehand[MG_E_VERTEX] = c_hvertex;      /* they get vertices */ |
| 80 | mg_ehand[MG_E_XF] = xf_handler;         /* they track transforms */ |
| 81 | mg_init();              /* initialize the parser */ |
| 82 | /* get our options & print header */ |
| 83 | printf("## %s", argv[0]); |
| 84 | for (i = 1; i < argc && argv[i][0] == '-'; i++) { |
| 85 | printf(" %s", argv[i]); |
| 86 | switch (argv[i][1]) { |
| 87 | case 'g':                       /* glow distance (meters) */ |
| 88 | if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f")) |
| 89 | goto userr; |
| 90 | glowdist = atof(argv[++i]); |
| 91 | printf(" %s", argv[i]); |
| 92 | break; |
| 93 | case 'e':                       /* emitter multiplier */ |
| 94 | if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f")) |
| 95 | goto userr; |
| 96 | emult = atof(argv[++i]); |
| 97 | printf(" %s", argv[i]); |
| 98 | break; |
| 99 | case 'm':                       /* materials file */ |
| 100 | matfp = fopen(argv[++i], "a"); |
| 101 | if (matfp == NULL) { |
| 102 | fprintf(stderr, "%s: cannot append\n", argv[i]); |
| 103 | exit(1); |
| 104 | } |
| 105 | printf(" %s", argv[i]); |
| 106 | break; |
| 107 | default: |
| 108 | goto userr; |
| 109 | } |
| 110 | } |
| 111 | putchar('\n'); |
| 112 | if (i == argc) {                /* convert stdin */ |
| 113 | if (mg_load(NULL) != MG_OK) |
| 114 | exit(1); |
| 115 | if (mg_nunknown) |
| 116 | printf("## %s: %u unknown entities\n", |
| 117 | argv[0], mg_nunknown); |
| 118 | } else                          /* convert each file */ |
| 119 | for ( ; i < argc; i++) { |
| 120 | printf("## %s %s ##############################\n", |
| 121 | argv[0], argv[i]); |
| 122 | if (mg_load(argv[i]) != MG_OK) |
| 123 | exit(1); |
| 124 | if (mg_nunknown) { |
| 125 | printf("## %s %s: %u unknown entities\n", |
| 126 | argv[0], argv[i], mg_nunknown); |
| 127 | mg_nunknown = 0; |
| 128 | } |
| 129 | } |
| 130 | exit(0); |
| 131 | userr: |
| 132 | fprintf(stderr, "Usage: %s [-g dist][-e mult][-m matf] [file.mgf] ..\n", |
| 133 | argv[0]); |
| 134 | exit(1); |
| 135 | } |
| 136 |  |
| 137 |  |
| 138 | int |
| 139 | r_comment(              /* repeat a comment verbatim */ |
| 140 | register int    ac, |
| 141 | register char   **av |
| 142 | ) |
| 143 | { |
| 144 | putchar('#');           /* use Radiance comment character */ |
| 145 | while (--ac) {                  /* pass through verbatim */ |
| 146 | putchar(' '); |
| 147 | fputs(*++av, stdout); |
| 148 | } |
| 149 | putchar('\n'); |
| 150 | return(MG_OK); |
| 151 | } |
| 152 |  |
| 153 |  |
| 154 | int |
| 155 | r_cone(                 /* put out a cone */ |
| 156 | int     ac, |
| 157 | char    **av |
| 158 | ) |
| 159 | { |
| 160 | static int      ncones; |
| 161 | char    *mat; |
| 162 | double  r1, r2; |
| 163 | C_VERTEX        *cv1, *cv2; |
| 164 | FVECT   p1, p2; |
| 165 | int     inv; |
| 166 | /* check argument count and type */ |
| 167 | if (ac != 5) |
| 168 | return(MG_EARGC); |
| 169 | if (!isflt(av[2]) || !isflt(av[4])) |
| 170 | return(MG_ETYPE); |
| 171 | /* get the endpoint vertices */ |
| 172 | if ((cv1 = c_getvert(av[1])) == NULL || |
| 173 | (cv2 = c_getvert(av[3])) == NULL) |
| 174 | return(MG_EUNDEF); |
| 175 | xf_xfmpoint(p1, cv1->p);        /* transform endpoints */ |
| 176 | xf_xfmpoint(p2, cv2->p); |
| 177 | r1 = xf_scale(atof(av[2]));     /* scale radii */ |
| 178 | r2 = xf_scale(atof(av[4])); |
| 179 | inv = r1 < 0.;                  /* check for inverted cone */ |
| 180 | if (r1 == 0.) {                 /* check for illegal radii */ |
| 181 | if (r2 == 0.) |
| 182 | return(MG_EILL); |
| 183 | inv = r2 < 0.; |
| 184 | } else if (r2 != 0. && inv ^ (r2 < 0.)) |
| 185 | return(MG_EILL); |
| 186 | if (inv) { |
| 187 | r1 = -r1; |
| 188 | r2 = -r2; |
| 189 | } |
| 190 | if ((mat = material()) == NULL) /* get material */ |
| 191 | return(MG_EBADMAT); |
| 192 | /* spit the sucker out */ |
| 193 | printf("\n%s %s %sc%d\n", mat, inv ? "cup" : "cone", |
| 194 | object(), ++ncones); |
| 195 | printf("0\n0\n8\n"); |
| 196 | putv(p1); |
| 197 | putv(p2); |
| 198 | printf("%18.12g %18.12g\n", r1, r2); |
| 199 | return(MG_OK); |
| 200 | } |
| 201 |  |
| 202 |  |
| 203 | int |
| 204 | r_cyl(                  /* put out a cylinder */ |
| 205 | int     ac, |
| 206 | char    **av |
| 207 | ) |
| 208 | { |
| 209 | static int      ncyls; |
| 210 | char    *mat; |
| 211 | double  rad; |
| 212 | C_VERTEX        *cv1, *cv2; |
| 213 | FVECT   p1, p2; |
| 214 | int     inv; |
| 215 | /* check argument count and type */ |
| 216 | if (ac != 4) |
| 217 | return(MG_EARGC); |
| 218 | if (!isflt(av[2])) |
| 219 | return(MG_ETYPE); |
| 220 | /* get the endpoint vertices */ |
| 221 | if ((cv1 = c_getvert(av[1])) == NULL || |
| 222 | (cv2 = c_getvert(av[3])) == NULL) |
| 223 | return(MG_EUNDEF); |
| 224 | xf_xfmpoint(p1, cv1->p);        /* transform endpoints */ |
| 225 | xf_xfmpoint(p2, cv2->p); |
| 226 | rad = xf_scale(atof(av[2]));    /* scale radius */ |
| 227 | if ((inv = rad < 0.))           /* check for inverted cylinder */ |
| 228 | rad = -rad; |
| 229 | if ((mat = material()) == NULL) /* get material */ |
| 230 | return(MG_EBADMAT); |
| 231 | /* spit out the primitive */ |
| 232 | printf("\n%s %s %scy%d\n", mat, inv ? "tube" : "cylinder", |
| 233 | object(), ++ncyls); |
| 234 | printf("0\n0\n7\n"); |
| 235 | putv(p1); |
| 236 | putv(p2); |
| 237 | printf("%18.12g\n", rad); |
| 238 | return(MG_OK); |
| 239 | } |
| 240 |  |
| 241 |  |
| 242 | int |
| 243 | r_sph(                  /* put out a sphere */ |
| 244 | int     ac, |
| 245 | char    **av |
| 246 | ) |
| 247 | { |
| 248 | static int      nsphs; |
| 249 | char    *mat; |
| 250 | double  rad; |
| 251 | C_VERTEX        *cv; |
| 252 | FVECT   cent; |
| 253 | int     inv; |
| 254 | /* check argument count and type */ |
| 255 | if (ac != 3) |
| 256 | return(MG_EARGC); |
| 257 | if (!isflt(av[2])) |
| 258 | return(MG_ETYPE); |
| 259 | if ((cv = c_getvert(av[1])) == NULL)    /* get center vertex */ |
| 260 | return(MG_EUNDEF); |
| 261 | xf_xfmpoint(cent, cv->p);               /* transform center */ |
| 262 | rad = xf_scale(atof(av[2]));            /* scale radius */ |
| 263 | if ((inv = rad < 0.))                   /* check for inversion */ |
| 264 | rad = -rad; |
| 265 | if ((mat = material()) == NULL)         /* get material */ |
| 266 | return(MG_EBADMAT); |
| 267 | /* spit out primitive */ |
| 268 | printf("\n%s %s %ss%d\n", mat, inv ? "bubble" : "sphere", |
| 269 | object(), ++nsphs); |
| 270 | printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n", |
| 271 | cent[0], cent[1], cent[2], rad); |
| 272 | return(MG_OK); |
| 273 | } |
| 274 |  |
| 275 |  |
| 276 | int |
| 277 | r_ring(                 /* put out a ring */ |
| 278 | int     ac, |
| 279 | char    **av |
| 280 | ) |
| 281 | { |
| 282 | static int      nrings; |
| 283 | char    *mat; |
| 284 | double  r1, r2; |
| 285 | C_VERTEX        *cv; |
| 286 | FVECT   cent, norm; |
| 287 | /* check argument count and type */ |
| 288 | if (ac != 4) |
| 289 | return(MG_EARGC); |
| 290 | if (!isflt(av[2]) || !isflt(av[3])) |
| 291 | return(MG_ETYPE); |
| 292 | if ((cv = c_getvert(av[1])) == NULL)    /* get center vertex */ |
| 293 | return(MG_EUNDEF); |
| 294 | if (is0vect(cv->n))                     /* make sure we have normal */ |
| 295 | return(MG_EILL); |
| 296 | xf_xfmpoint(cent, cv->p);               /* transform center */ |
| 297 | xf_rotvect(norm, cv->n);                /* rotate normal */ |
| 298 | r1 = xf_scale(atof(av[2]));             /* scale radii */ |
| 299 | r2 = xf_scale(atof(av[3])); |
| 300 | if ((r1 < 0.) | (r2 <= r1)) |
| 301 | return(MG_EILL); |
| 302 | if ((mat = material()) == NULL)         /* get material */ |
| 303 | return(MG_EBADMAT); |
| 304 | /* spit out primitive */ |
| 305 | printf("\n%s ring %sr%d\n", mat, object(), ++nrings); |
| 306 | printf("0\n0\n8\n"); |
| 307 | putv(cent); |
| 308 | putv(norm); |
| 309 | printf("%18.12g %18.12g\n", r1, r2); |
| 310 | return(MG_OK); |
| 311 | } |
| 312 |  |
| 313 |  |
| 314 | int |
| 315 | r_face(                 /* convert a face */ |
| 316 | int     ac, |
| 317 | char    **av |
| 318 | ) |
| 319 | { |
| 320 | static int      nfaces; |
| 321 | int             myi = invert; |
| 322 | char    *mat; |
| 323 | register int    i; |
| 324 | register C_VERTEX       *cv; |
| 325 | FVECT   v; |
| 326 |  |
| 327 | /* check argument count and type */ |
| 328 | if (ac < 4) |
| 329 | return(MG_EARGC); |
| 330 | if ((mat = material()) == NULL) /* get material */ |
| 331 | return(MG_EBADMAT); |
| 332 | if (ac <= 5) {                          /* check for smoothing */ |
| 333 | C_VERTEX        *cva[5]; |
| 334 | for (i = 1; i < ac; i++) { |
| 335 | if ((cva[i-1] = c_getvert(av[i])) == NULL) |
| 336 | return(MG_EUNDEF); |
| 337 | if (is0vect(cva[i-1]->n)) |
| 338 | break; |
| 339 | } |
| 340 | if (i < ac) |
| 341 | i = ISFLAT; |
| 342 | else |
| 343 | i = flat_tri(cva[0]->p, cva[1]->p, cva[2]->p, |
| 344 | cva[0]->n, cva[1]->n, cva[2]->n); |
| 345 | if (i == DEGEN) |
| 346 | return(MG_OK);          /* degenerate (error?) */ |
| 347 | if (i == RVBENT) { |
| 348 | myi = !myi; |
| 349 | i = ISBENT; |
| 350 | } else if (i == RVFLAT) { |
| 351 | myi = !myi; |
| 352 | i = ISFLAT; |
| 353 | } |
| 354 | if (i == ISBENT) {              /* smoothed triangles */ |
| 355 | do_tri(mat, cva[0], cva[1], cva[2], myi); |
| 356 | if (ac == 5) |
| 357 | do_tri(mat, cva[2], cva[3], cva[0], myi); |
| 358 | return(MG_OK); |
| 359 | } |
| 360 | } |
| 361 | /* spit out unsmoothed primitive */ |
| 362 | printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces); |
| 363 | printf("0\n0\n%d\n", 3*(ac-1)); |
| 364 | for (i = 1; i < ac; i++) {      /* get, transform, print each vertex */ |
| 365 | if ((cv = c_getvert(av[myi ? ac-i : i])) == NULL) |
| 366 | return(MG_EUNDEF); |
| 367 | xf_xfmpoint(v, cv->p); |
| 368 | putv(v); |
| 369 | } |
| 370 | return(MG_OK); |
| 371 | } |
| 372 |  |
| 373 |  |
| 374 | int |
| 375 | r_ies(                          /* convert an IES luminaire file */ |
| 376 | int     ac, |
| 377 | char    **av |
| 378 | ) |
| 379 | { |
| 380 | int     xa0 = 2; |
| 381 | char    combuf[128]; |
| 382 | char    fname[48]; |
| 383 | char    *oname; |
| 384 | register char   *op; |
| 385 | register int    i; |
| 386 | /* check argument count */ |
| 387 | if (ac < 2) |
| 388 | return(MG_EARGC); |
| 389 | /* construct output file name */ |
| 390 | if ((op = strrchr(av[1], '/')) != NULL) |
| 391 | op++; |
| 392 | else |
| 393 | op = av[1]; |
| 394 | (void)strcpy(fname, op); |
| 395 | if ((op = strrchr(fname, '.')) == NULL) |
| 396 | op = fname + strlen(fname); |
| 397 | (void)strcpy(op, ".rad"); |
| 398 | /* see if we need to run ies2rad */ |
| 399 | if (access(fname, 0) == -1) { |
| 400 | (void)strcpy(combuf, "ies2rad");/* build ies2rad command */ |
| 401 | op = combuf + 7;                /* get -m option (first) */ |
| 402 | if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) { |
| 403 | if (!isflt(av[xa0+1])) |
| 404 | return(MG_ETYPE); |
| 405 | op = addarg(addarg(op, "-m"), av[xa0+1]); |
| 406 | xa0 += 2; |
| 407 | } |
| 408 | *op++ = ' ';                    /* build IES filename */ |
| 409 | i = 0; |
| 410 | if (mg_file != NULL && |
| 411 | (oname = strrchr(mg_file->fname,'/')) != NULL) { |
| 412 | i = oname - mg_file->fname + 1; |
| 413 | (void)strcpy(op, mg_file->fname); |
| 414 | } |
| 415 | (void)strcpy(op+i, av[1]); |
| 416 | if (access(op, 0) == -1)        /* check for file existence */ |
| 417 | return(MG_ENOFILE); |
| 418 | system(combuf);                 /* run ies2rad */ |
| 419 | if (access(fname, 0) == -1)     /* check success */ |
| 420 | return(MG_EINCL); |
| 421 | } |
| 422 | printf("\n!xform");                     /* put out xform command */ |
| 423 | oname = object(); |
| 424 | if (*oname) { |
| 425 | printf(" -n "); |
| 426 | for (op = oname; op[1]; op++)   /* remove trailing separator */ |
| 427 | putchar(*op); |
| 428 | } |
| 429 | for (i = xa0; i < ac; i++) |
| 430 | printf(" %s", av[i]); |
| 431 | if (ac > xa0 && xf_argc > 0) |
| 432 | printf(" -i 1"); |
| 433 | for (i = 0; i < xf_argc; i++) |
| 434 | printf(" %s", xf_argv[i]); |
| 435 | printf(" %s\n", fname); |
| 436 | return(MG_OK); |
| 437 | } |
| 438 |  |
| 439 |  |
| 440 | void |
| 441 | do_tri(         /* put out smoothed triangle */ |
| 442 | char    *mat, |
| 443 | C_VERTEX        *cv1, |
| 444 | C_VERTEX        *cv2, |
| 445 | C_VERTEX        *cv3, |
| 446 | int     iv |
| 447 | ) |
| 448 | { |
| 449 | static int      ntris; |
| 450 | BARYCCM bvecs; |
| 451 | RREAL   bcoor[3][3]; |
| 452 | C_VERTEX        *cvt; |
| 453 | FVECT   v1, v2, v3; |
| 454 | FVECT   n1, n2, n3; |
| 455 | register int    i; |
| 456 |  |
| 457 | if (iv) {                       /* swap vertex order if inverted */ |
| 458 | cvt = cv1; |
| 459 | cv1 = cv3; |
| 460 | cv3 = cvt; |
| 461 | } |
| 462 | xf_xfmpoint(v1, cv1->p); |
| 463 | xf_xfmpoint(v2, cv2->p); |
| 464 | xf_xfmpoint(v3, cv3->p); |
| 465 | /* compute barycentric coords. */ |
| 466 | if (comp_baryc(&bvecs, v1, v2, v3) < 0) |
| 467 | return;                         /* degenerate triangle! */ |
| 468 | printf("\n%s texfunc T-nor\n", mat);    /* put out texture */ |
| 469 | printf("4 dx dy dz %s\n0\n", TCALNAME); |
| 470 | xf_rotvect(n1, cv1->n); |
| 471 | xf_rotvect(n2, cv2->n); |
| 472 | xf_rotvect(n3, cv3->n); |
| 473 | for (i = 0; i < 3; i++) { |
| 474 | bcoor[i][0] = n1[i]; |
| 475 | bcoor[i][1] = n2[i]; |
| 476 | bcoor[i][2] = n3[i]; |
| 477 | } |
| 478 | put_baryc(&bvecs, bcoor, 3); |
| 479 | /* put out triangle */ |
| 480 | printf("\nT-nor polygon %st%d\n", object(), ++ntris); |
| 481 | printf("0\n0\n9\n"); |
| 482 | putv(v1); |
| 483 | putv(v2); |
| 484 | putv(v3); |
| 485 | } |
| 486 |  |
| 487 |  |
| 488 | void |
| 489 | putsided(char *mname)           /* print out mixfunc for sided material */ |
| 490 | { |
| 491 | fprintf(matfp, "\nvoid mixfunc %s\n", mname); |
| 492 | fprintf(matfp, "4 %s void if(Rdot,1,0) .\n0\n0\n", mname); |
| 493 | } |
| 494 |  |
| 495 |  |
| 496 | char * |
| 497 | material(void)                  /* get (and print) current material */ |
| 498 | { |
| 499 | char    *mname = "mat"; |
| 500 | COLOR   radrgb, c2; |
| 501 | double  d; |
| 502 |  |
| 503 | if (c_cmname != NULL) |
| 504 | mname = c_cmname; |
| 505 | if (!c_cmaterial->clock) |
| 506 | return(mname);          /* already current */ |
| 507 | /* else update output */ |
| 508 | c_cmaterial->clock = 0; |
| 509 | if (c_cmaterial->ed > .1) {     /* emitter */ |
| 510 | cvtcolor(radrgb, &c_cmaterial->ed_c, |
| 511 | emult*c_cmaterial->ed/(PI*WHTEFFICACY)); |
| 512 | if (glowdist < FHUGE) {         /* do a glow */ |
| 513 | fprintf(matfp, "\nvoid glow %s\n0\n0\n", mname); |
| 514 | fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED), |
| 515 | colval(radrgb,GRN), |
| 516 | colval(radrgb,BLU), glowdist); |
| 517 | } else { |
| 518 | fprintf(matfp, "\nvoid light %s\n0\n0\n", mname); |
| 519 | fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED), |
| 520 | colval(radrgb,GRN), |
| 521 | colval(radrgb,BLU)); |
| 522 | } |
| 523 | return(mname); |
| 524 | } |
| 525 | d = c_cmaterial->rd + c_cmaterial->td + |
| 526 | c_cmaterial->rs + c_cmaterial->ts; |
| 527 | if ((d < 0.) | (d > 1.)) |
| 528 | return(NULL); |
| 529 | /* check for glass/dielectric */ |
| 530 | if (c_cmaterial->nr > 1.1 && |
| 531 | c_cmaterial->ts > .25 && c_cmaterial->rs <= .125 && |
| 532 | c_cmaterial->td <= .01 && c_cmaterial->rd <= .01 && |
| 533 | c_cmaterial->rs_a <= .01 && c_cmaterial->ts_a <= .01) { |
| 534 | cvtcolor(radrgb, &c_cmaterial->ts_c, |
| 535 | c_cmaterial->ts + c_cmaterial->rs); |
| 536 | if (c_cmaterial->sided) {               /* dielectric */ |
| 537 | colval(radrgb,RED) = pow(colval(radrgb,RED), |
| 538 | 1./C_1SIDEDTHICK); |
| 539 | colval(radrgb,GRN) = pow(colval(radrgb,GRN), |
| 540 | 1./C_1SIDEDTHICK); |
| 541 | colval(radrgb,BLU) = pow(colval(radrgb,BLU), |
| 542 | 1./C_1SIDEDTHICK); |
| 543 | fprintf(matfp, "\nvoid dielectric %s\n0\n0\n", mname); |
| 544 | fprintf(matfp, "5 %g %g %g %f 0\n", colval(radrgb,RED), |
| 545 | colval(radrgb,GRN), colval(radrgb,BLU), |
| 546 | c_cmaterial->nr); |
| 547 | return(mname); |
| 548 | } |
| 549 | /* glass */ |
| 550 | fprintf(matfp, "\nvoid glass %s\n0\n0\n", mname); |
| 551 | fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED), |
| 552 | colval(radrgb,GRN), colval(radrgb,BLU), |
| 553 | c_cmaterial->nr); |
| 554 | return(mname); |
| 555 | } |
| 556 | /* check for trans */ |
| 557 | if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) { |
| 558 | double  a5, a6; |
| 559 | /* average colors */ |
| 560 | d = c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts; |
| 561 | cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d); |
| 562 | cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d); |
| 563 | addcolor(radrgb, c2); |
| 564 | cvtcolor(c2, &c_cmaterial->ts_c, c_cmaterial->ts/d); |
| 565 | addcolor(radrgb, c2); |
| 566 | if (c_cmaterial->rs + c_cmaterial->ts > .0001) |
| 567 | a5 = (c_cmaterial->rs*c_cmaterial->rs_a + |
| 568 | c_cmaterial->ts*c_cmaterial->ts_a) / |
| 569 | (c_cmaterial->rs + c_cmaterial->ts); |
| 570 | a6 = (c_cmaterial->td + c_cmaterial->ts) / |
| 571 | (c_cmaterial->rd + c_cmaterial->td + c_cmaterial->ts); |
| 572 | if (a6 < .999) |
| 573 | d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6); |
| 574 | else |
| 575 | d = c_cmaterial->td + c_cmaterial->ts; |
| 576 | scalecolor(radrgb, d); |
| 577 | fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname); |
| 578 | fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED), |
| 579 | colval(radrgb,GRN), colval(radrgb,BLU)); |
| 580 | fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6, |
| 581 | c_cmaterial->ts/(c_cmaterial->ts + c_cmaterial->td)); |
| 582 | if (c_cmaterial->sided) |
| 583 | putsided(mname); |
| 584 | return(mname); |
| 585 | } |
| 586 | /* check for plastic */ |
| 587 | if (c_cmaterial->rs < .1) { |
| 588 | cvtcolor(radrgb, &c_cmaterial->rd_c, |
| 589 | c_cmaterial->rd/(1.-c_cmaterial->rs)); |
| 590 | fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname); |
| 591 | fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), |
| 592 | colval(radrgb,GRN), colval(radrgb,BLU), |
| 593 | c_cmaterial->rs, c_cmaterial->rs_a); |
| 594 | if (c_cmaterial->sided) |
| 595 | putsided(mname); |
| 596 | return(mname); |
| 597 | } |
| 598 | /* else it's metal */ |
| 599 | /* average colors */ |
| 600 | cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd); |
| 601 | cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs); |
| 602 | addcolor(radrgb, c2); |
| 603 | fprintf(matfp, "\nvoid metal %s\n0\n0\n", mname); |
| 604 | fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED), |
| 605 | colval(radrgb,GRN), colval(radrgb,BLU), |
| 606 | c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs), |
| 607 | c_cmaterial->rs_a); |
| 608 | if (c_cmaterial->sided) |
| 609 | putsided(mname); |
| 610 | return(mname); |
| 611 | } |
| 612 |  |
| 613 |  |
| 614 | void |
| 615 | cvtcolor(       /* convert a CIE XYZ color to RGB */ |
| 616 | COLOR   radrgb, |
| 617 | register C_COLOR        *ciec, |
| 618 | double  intensity |
| 619 | ) |
| 620 | { |
| 621 | static COLOR    ciexyz; |
| 622 |  |
| 623 | c_ccvt(ciec, C_CSXY);           /* get xy representation */ |
| 624 | ciexyz[1] = intensity; |
| 625 | ciexyz[0] = ciec->cx/ciec->cy*ciexyz[1]; |
| 626 | ciexyz[2] = ciexyz[1]*(1./ciec->cy - 1.) - ciexyz[0]; |
| 627 | cie_rgb(radrgb, ciexyz); |
| 628 | } |
| 629 |  |
| 630 |  |
| 631 | char * |
| 632 | object(void)                    /* return current object name */ |
| 633 | { |
| 634 | static char     objbuf[64]; |
| 635 | register int    i; |
| 636 | register char   *cp; |
| 637 | int     len; |
| 638 | /* tracked by obj_handler */ |
| 639 | i = obj_nnames - sizeof(objbuf)/16; |
| 640 | if (i < 0) |
| 641 | i = 0; |
| 642 | for (cp = objbuf; i < obj_nnames && |
| 643 | cp + (len=strlen(obj_name[i])) < objbuf+sizeof(objbuf)-1; |
| 644 | i++, *cp++ = '.') { |
| 645 | strcpy(cp, obj_name[i]); |
| 646 | cp += len; |
| 647 | } |
| 648 | *cp = '\0'; |
| 649 | return(objbuf); |
| 650 | } |
| 651 |  |
| 652 |  |
| 653 | char * |
| 654 | addarg(                         /* add argument and advance pointer */ |
| 655 | register char *op, |
| 656 | register char *arg |
| 657 | ) |
| 658 | { |
| 659 | *op = ' '; |
| 660 | while ( (*++op = *arg++) ) |
| 661 | ; |
| 662 | return(op); |
| 663 | } |
