root/radiance/src/cv/mgf2rad.c
Revision: 2.28
Committed: Sat Nov 15 17:54:06 2003 UTC (21 years, 11 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9
Changes since 2.27: +70 -41 lines
2 static const char RCSid[] = "$Id: mgf2rad.c,v 2.27 2003/07/27 22:12:01 schorsch Exp $";
5 * Convert MGF (Materials and Geometry Format) to Radiance
6 */
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <math.h>
11 #include <string.h>
12
13 #include "platform.h"
14 #include "mgflib/parser.h"
15 #include "color.h"
16 #include "tmesh.h"
17
18 #define putv(v) printf("%18.12g %18.12g %18.12g\n",(v)[0],(v)[1],(v)[2])
19
20 #define invert (xf_context != NULL && xf_context->rev)
21
22 double glowdist = FHUGE; /* glow test distance */
23
24 double emult = 1.; /* emitter multiplier */
25
26 FILE *matfp; /* material output file */
27
28
29 int r_comment(int ac, char **av);
30 int r_cone(int ac, char **av);
31 int r_cyl(int ac, char **av);
32 int r_sph(int ac, char **av);
33 int r_ring(int ac, char **av);
34 int r_face(int ac, char **av);
35 int r_ies(int ac, char **av);
36 char * material(void);
37 char * object(void);
38 char * addarg(char *op, char *arg);
39 void do_tri(char *mat, C_VERTEX *cv1, C_VERTEX *cv2, C_VERTEX *cv3, int iv);
40 void cvtcolor(COLOR radrgb, register C_COLOR *ciec, double intensity);
41
42
43 int
44 main(
45 int argc,
46 char *argv[]
47 )
48 {
49 int i;
50
51 matfp = stdout;
52 /* print out parser version */
53 printf("## Translated from MGF Version %d.%d\n", MG_VMAJOR, MG_VMINOR);
54 /* initialize dispatch table */
55 mg_ehand[MG_E_COMMENT] = r_comment; /* we pass comments */
56 mg_ehand[MG_E_COLOR] = c_hcolor; /* they get color */
57 mg_ehand[MG_E_CONE] = r_cone; /* we do cones */
58 mg_ehand[MG_E_CMIX] = c_hcolor; /* they mix colors */
59 mg_ehand[MG_E_CSPEC] = c_hcolor; /* they get spectra */
60 mg_ehand[MG_E_CXY] = c_hcolor; /* they get chromaticities */
61 mg_ehand[MG_E_CCT] = c_hcolor; /* they get color temp's */
62 mg_ehand[MG_E_CYL] = r_cyl; /* we do cylinders */
63 mg_ehand[MG_E_ED] = c_hmaterial; /* they get emission */
64 mg_ehand[MG_E_FACE] = r_face; /* we do faces */
65 mg_ehand[MG_E_IES] = r_ies; /* we do IES files */
66 mg_ehand[MG_E_IR] = c_hmaterial; /* they get refractive index */
67 mg_ehand[MG_E_MATERIAL] = c_hmaterial; /* they get materials */
68 mg_ehand[MG_E_NORMAL] = c_hvertex; /* they get normals */
69 mg_ehand[MG_E_OBJECT] = obj_handler; /* they track object names */
70 mg_ehand[MG_E_POINT] = c_hvertex; /* they get points */
71 mg_ehand[MG_E_RD] = c_hmaterial; /* they get diffuse refl. */
72 mg_ehand[MG_E_RING] = r_ring; /* we do rings */
73 mg_ehand[MG_E_RS] = c_hmaterial; /* they get specular refl. */
74 mg_ehand[MG_E_SIDES] = c_hmaterial; /* they get # sides */
75 mg_ehand[MG_E_SPH] = r_sph; /* we do spheres */
76 mg_ehand[MG_E_TD] = c_hmaterial; /* they get diffuse trans. */
77 mg_ehand[MG_E_TS] = c_hmaterial; /* they get specular trans. */
78 mg_ehand[MG_E_VERTEX] = c_hvertex; /* they get vertices */
79 mg_ehand[MG_E_XF] = xf_handler; /* they track transforms */
80 mg_init(); /* initialize the parser */
81 /* get our options & print header */
82 printf("## %s", argv[0]);
83 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
84 printf(" %s", argv[i]);
85 switch (argv[i][1]) {
86 case 'g': /* glow distance (meters) */
87 if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f"))
88 goto userr;
89 glowdist = atof(argv[++i]);
90 printf(" %s", argv[i]);
91 break;
92 case 'e': /* emitter multiplier */
93 if (argv[i][2] || badarg(argc-i-1, argv+i+1, "f"))
94 goto userr;
95 emult = atof(argv[++i]);
96 printf(" %s", argv[i]);
97 break;
98 case 'm': /* materials file */
99 matfp = fopen(argv[++i], "a");
100 if (matfp == NULL) {
101 fprintf(stderr, "%s: cannot append\n", argv[i]);
102 exit(1);
103 }
104 printf(" %s", argv[i]);
105 break;
106 default:
107 goto userr;
108 }
109 }
110 putchar('\n');
111 if (i == argc) { /* convert stdin */
112 if (mg_load(NULL) != MG_OK)
113 exit(1);
114 if (mg_nunknown)
115 printf("## %s: %u unknown entities\n",
116 argv[0], mg_nunknown);
117 } else /* convert each file */
118 for ( ; i < argc; i++) {
119 printf("## %s %s ##############################\n",
120 argv[0], argv[i]);
121 if (mg_load(argv[i]) != MG_OK)
122 exit(1);
123 if (mg_nunknown) {
124 printf("## %s %s: %u unknown entities\n",
125 argv[0], argv[i], mg_nunknown);
126 mg_nunknown = 0;
127 }
128 }
129 exit(0);
130 userr:
131 fprintf(stderr, "Usage: %s [-g dist][-e mult][-m matf] [file.mgf] ..\n",
132 argv[0]);
133 exit(1);
134 }
135
136
137 int
138 r_comment( /* repeat a comment verbatim */
139 register int ac,
140 register char **av
141 )
142 {
143 putchar('#'); /* use Radiance comment character */
144 while (--ac) { /* pass through verbatim */
145 putchar(' ');
146 fputs(*++av, stdout);
147 }
148 putchar('\n');
149 return(MG_OK);
150 }
151
152
153 int
154 r_cone( /* put out a cone */
155 int ac,
156 char **av
157 )
158 {
159 static int ncones;
160 char *mat;
161 double r1, r2;
162 C_VERTEX *cv1, *cv2;
163 FVECT p1, p2;
164 int inv;
165 /* check argument count and type */
166 if (ac != 5)
167 return(MG_EARGC);
168 if (!isflt(av[2]) || !isflt(av[4]))
169 return(MG_ETYPE);
170 /* get the endpoint vertices */
171 if ((cv1 = c_getvert(av[1])) == NULL ||
172 (cv2 = c_getvert(av[3])) == NULL)
173 return(MG_EUNDEF);
174 xf_xfmpoint(p1, cv1->p); /* transform endpoints */
175 xf_xfmpoint(p2, cv2->p);
176 r1 = xf_scale(atof(av[2])); /* scale radii */
177 r2 = xf_scale(atof(av[4]));
178 inv = r1 < 0.; /* check for inverted cone */
179 if (r1 == 0.) { /* check for illegal radii */
180 if (r2 == 0.)
181 return(MG_EILL);
182 inv = r2 < 0.;
183 } else if (r2 != 0. && inv ^ (r2 < 0.))
184 return(MG_EILL);
185 if (inv) {
186 r1 = -r1;
187 r2 = -r2;
188 }
189 if ((mat = material()) == NULL) /* get material */
190 return(MG_EBADMAT);
191 /* spit the sucker out */
192 printf("\n%s %s %sc%d\n", mat, inv ? "cup" : "cone",
193 object(), ++ncones);
194 printf("0\n0\n8\n");
195 putv(p1);
196 putv(p2);
197 printf("%18.12g %18.12g\n", r1, r2);
198 return(MG_OK);
199 }
200
201
202 int
203 r_cyl( /* put out a cylinder */
204 int ac,
205 char **av
206 )
207 {
208 static int ncyls;
209 char *mat;
210 double rad;
211 C_VERTEX *cv1, *cv2;
212 FVECT p1, p2;
213 int inv;
214 /* check argument count and type */
215 if (ac != 4)
216 return(MG_EARGC);
217 if (!isflt(av[2]))
218 return(MG_ETYPE);
219 /* get the endpoint vertices */
220 if ((cv1 = c_getvert(av[1])) == NULL ||
221 (cv2 = c_getvert(av[3])) == NULL)
222 return(MG_EUNDEF);
223 xf_xfmpoint(p1, cv1->p); /* transform endpoints */
224 xf_xfmpoint(p2, cv2->p);
225 rad = xf_scale(atof(av[2])); /* scale radius */
226 if ((inv = rad < 0.)) /* check for inverted cylinder */
227 rad = -rad;
228 if ((mat = material()) == NULL) /* get material */
229 return(MG_EBADMAT);
230 /* spit out the primitive */
231 printf("\n%s %s %scy%d\n", mat, inv ? "tube" : "cylinder",
232 object(), ++ncyls);
233 printf("0\n0\n7\n");
234 putv(p1);
235 putv(p2);
236 printf("%18.12g\n", rad);
237 return(MG_OK);
238 }
239
240
241 int
242 r_sph( /* put out a sphere */
243 int ac,
244 char **av
245 )
246 {
247 static int nsphs;
248 char *mat;
249 double rad;
250 C_VERTEX *cv;
251 FVECT cent;
252 int inv;
253 /* check argument count and type */
254 if (ac != 3)
255 return(MG_EARGC);
256 if (!isflt(av[2]))
257 return(MG_ETYPE);
258 if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */
259 return(MG_EUNDEF);
260 xf_xfmpoint(cent, cv->p); /* transform center */
261 rad = xf_scale(atof(av[2])); /* scale radius */
262 if ((inv = rad < 0.)) /* check for inversion */
263 rad = -rad;
264 if ((mat = material()) == NULL) /* get material */
265 return(MG_EBADMAT);
266 /* spit out primitive */
267 printf("\n%s %s %ss%d\n", mat, inv ? "bubble" : "sphere",
268 object(), ++nsphs);
269 printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
270 cent[0], cent[1], cent[2], rad);
271 return(MG_OK);
272 }
273
274
275 int
276 r_ring( /* put out a ring */
277 int ac,
278 char **av
279 )
280 {
281 static int nrings;
282 char *mat;
283 double r1, r2;
284 C_VERTEX *cv;
285 FVECT cent, norm;
286 /* check argument count and type */
287 if (ac != 4)
288 return(MG_EARGC);
289 if (!isflt(av[2]) || !isflt(av[3]))
290 return(MG_ETYPE);
291 if ((cv = c_getvert(av[1])) == NULL) /* get center vertex */
292 return(MG_EUNDEF);
293 if (is0vect(cv->n)) /* make sure we have normal */
294 return(MG_EILL);
295 xf_xfmpoint(cent, cv->p); /* transform center */
296 xf_rotvect(norm, cv->n); /* rotate normal */
297 r1 = xf_scale(atof(av[2])); /* scale radii */
298 r2 = xf_scale(atof(av[3]));
299 if ((r1 < 0.) | (r2 <= r1))
300 return(MG_EILL);
301 if ((mat = material()) == NULL) /* get material */
302 return(MG_EBADMAT);
303 /* spit out primitive */
304 printf("\n%s ring %sr%d\n", mat, object(), ++nrings);
305 printf("0\n0\n8\n");
306 putv(cent);
307 putv(norm);
308 printf("%18.12g %18.12g\n", r1, r2);
309 return(MG_OK);
310 }
311
312
313 int
314 r_face( /* convert a face */
315 int ac,
316 char **av
317 )
318 {
319 static int nfaces;
320 int myi = invert;
321 char *mat;
322 register int i;
323 register C_VERTEX *cv;
324 FVECT v;
325
326 /* check argument count and type */
327 if (ac < 4)
328 return(MG_EARGC);
329 if ((mat = material()) == NULL) /* get material */
330 return(MG_EBADMAT);
331 if (ac <= 5) { /* check for smoothing */
332 C_VERTEX *cva[5];
333 for (i = 1; i < ac; i++) {
334 if ((cva[i-1] = c_getvert(av[i])) == NULL)
335 return(MG_EUNDEF);
336 if (is0vect(cva[i-1]->n))
337 break;
338 }
339 if (i < ac)
340 i = ISFLAT;
341 else
342 i = flat_tri(cva[0]->p, cva[1]->p, cva[2]->p,
343 cva[0]->n, cva[1]->n, cva[2]->n);
344 if (i == DEGEN)
345 return(MG_OK); /* degenerate (error?) */
346 if (i == RVBENT) {
347 myi = !myi;
348 i = ISBENT;
349 } else if (i == RVFLAT) {
350 myi = !myi;
351 i = ISFLAT;
352 }
353 if (i == ISBENT) { /* smoothed triangles */
354 do_tri(mat, cva[0], cva[1], cva[2], myi);
355 if (ac == 5)
356 do_tri(mat, cva[2], cva[3], cva[0], myi);
357 return(MG_OK);
358 }
359 }
360 /* spit out unsmoothed primitive */
361 printf("\n%s polygon %sf%d\n", mat, object(), ++nfaces);
362 printf("0\n0\n%d\n", 3*(ac-1));
363 for (i = 1; i < ac; i++) { /* get, transform, print each vertex */
364 if ((cv = c_getvert(av[myi ? ac-i : i])) == NULL)
365 return(MG_EUNDEF);
366 xf_xfmpoint(v, cv->p);
367 putv(v);
368 }
369 return(MG_OK);
370 }
371
372
373 int
374 r_ies( /* convert an IES luminaire file */
375 int ac,
376 char **av
377 )
378 {
379 int xa0 = 2;
380 char combuf[128];
381 char fname[48];
382 char *oname;
383 register char *op;
384 register int i;
385 /* check argument count */
386 if (ac < 2)
387 return(MG_EARGC);
388 /* construct output file name */
389 if ((op = strrchr(av[1], '/')) != NULL)
390 op++;
391 else
392 op = av[1];
393 (void)strcpy(fname, op);
394 if ((op = strrchr(fname, '.')) == NULL)
395 op = fname + strlen(fname);
396 (void)strcpy(op, ".rad");
397 /* see if we need to run ies2rad */
398 if (access(fname, 0) == -1) {
399 (void)strcpy(combuf, "ies2rad");/* build ies2rad command */
400 op = combuf + 7; /* get -m option (first) */
401 if (ac-xa0 >= 2 && !strcmp(av[xa0], "-m")) {
402 if (!isflt(av[xa0+1]))
403 return(MG_ETYPE);
404 op = addarg(addarg(op, "-m"), av[xa0+1]);
405 xa0 += 2;
406 }
407 *op++ = ' '; /* build IES filename */
408 i = 0;
409 if (mg_file != NULL &&
410 (oname = strrchr(mg_file->fname,'/')) != NULL) {
411 i = oname - mg_file->fname + 1;
412 (void)strcpy(op, mg_file->fname);
413 }
414 (void)strcpy(op+i, av[1]);
415 if (access(op, 0) == -1) /* check for file existence */
416 return(MG_ENOFILE);
417 system(combuf); /* run ies2rad */
418 if (access(fname, 0) == -1) /* check success */
419 return(MG_EINCL);
420 }
421 printf("\n!xform"); /* put out xform command */
422 oname = object();
423 if (*oname) {
424 printf(" -n ");
425 for (op = oname; op[1]; op++) /* remove trailing separator */
426 putchar(*op);
427 }
428 for (i = xa0; i < ac; i++)
429 printf(" %s", av[i]);
430 if (ac > xa0 && xf_argc > 0)
431 printf(" -i 1");
432 for (i = 0; i < xf_argc; i++)
433 printf(" %s", xf_argv[i]);
434 printf(" %s\n", fname);
435 return(MG_OK);
436 }
437
438
439 void
440 do_tri( /* put out smoothed triangle */
441 char *mat,
442 C_VERTEX *cv1,
443 C_VERTEX *cv2,
444 C_VERTEX *cv3,
445 int iv
446 )
447 {
448 static int ntris;
449 BARYCCM bvecs;
450 RREAL bcoor[3][3];
451 C_VERTEX *cvt;
452 FVECT v1, v2, v3;
453 FVECT n1, n2, n3;
454 register int i;
455
456 if (iv) { /* swap vertex order if inverted */
457 cvt = cv1;
458 cv1 = cv3;
459 cv3 = cvt;
460 }
461 xf_xfmpoint(v1, cv1->p);
462 xf_xfmpoint(v2, cv2->p);
463 xf_xfmpoint(v3, cv3->p);
464 /* compute barycentric coords. */
465 if (comp_baryc(&bvecs, v1, v2, v3) < 0)
466 return; /* degenerate triangle! */
467 printf("\n%s texfunc T-nor\n", mat); /* put out texture */
468 printf("4 dx dy dz %s\n0\n", TCALNAME);
469 xf_rotvect(n1, cv1->n);
470 xf_rotvect(n2, cv2->n);
471 xf_rotvect(n3, cv3->n);
472 for (i = 0; i < 3; i++) {
473 bcoor[i][0] = n1[i];
474 bcoor[i][1] = n2[i];
475 bcoor[i][2] = n3[i];
476 }
477 put_baryc(&bvecs, bcoor, 3);
478 /* put out triangle */
479 printf("\nT-nor polygon %st%d\n", object(), ++ntris);
480 printf("0\n0\n9\n");
481 putv(v1);
482 putv(v2);
483 putv(v3);
484 }
485
486
487 char *
488 material(void) /* get (and print) current material */
489 {
490 char *mname = "mat";
491 COLOR radrgb, c2;
492 double d;
493
494 if (c_cmname != NULL)
495 mname = c_cmname;
496 if (!c_cmaterial->clock)
497 return(mname); /* already current */
498 /* else update output */
499 c_cmaterial->clock = 0;
500 if (c_cmaterial->ed > .1) { /* emitter */
501 cvtcolor(radrgb, &c_cmaterial->ed_c,
502 emult*c_cmaterial->ed/(PI*WHTEFFICACY));
503 if (glowdist < FHUGE) { /* do a glow */
504 fprintf(matfp, "\nvoid glow %s\n0\n0\n", mname);
505 fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED),
506 colval(radrgb,GRN),
507 colval(radrgb,BLU), glowdist);
508 } else {
509 fprintf(matfp, "\nvoid light %s\n0\n0\n", mname);
510 fprintf(matfp, "3 %f %f %f\n", colval(radrgb,RED),
511 colval(radrgb,GRN),
512 colval(radrgb,BLU));
513 }
514 return(mname);
515 }
516 d = c_cmaterial->rd + c_cmaterial->td +
517 c_cmaterial->rs + c_cmaterial->ts;
518 if ((d < 0.) | (d > 1.))
519 return(NULL);
520 /* check for glass/dielectric */
521 if (c_cmaterial->nr > 1.1 &&
522 c_cmaterial->ts > .25 && c_cmaterial->rs <= .125 &&
523 c_cmaterial->td <= .01 && c_cmaterial->rd <= .01 &&
524 c_cmaterial->rs_a <= .01 && c_cmaterial->ts_a <= .01) {
525 cvtcolor(radrgb, &c_cmaterial->ts_c,
526 c_cmaterial->ts + c_cmaterial->rs);
527 if (c_cmaterial->sided) { /* dielectric */
528 colval(radrgb,RED) = pow(colval(radrgb,RED),
529 1./C_1SIDEDTHICK);
530 colval(radrgb,GRN) = pow(colval(radrgb,GRN),
531 1./C_1SIDEDTHICK);
532 colval(radrgb,BLU) = pow(colval(radrgb,BLU),
533 1./C_1SIDEDTHICK);
534 fprintf(matfp, "\nvoid dielectric %s\n0\n0\n", mname);
535 fprintf(matfp, "5 %g %g %g %f 0\n", colval(radrgb,RED),
536 colval(radrgb,GRN), colval(radrgb,BLU),
537 c_cmaterial->nr);
538 return(mname);
539 }
540 /* glass */
541 fprintf(matfp, "\nvoid glass %s\n0\n0\n", mname);
542 fprintf(matfp, "4 %f %f %f %f\n", colval(radrgb,RED),
543 colval(radrgb,GRN), colval(radrgb,BLU),
544 c_cmaterial->nr);
545 return(mname);
546 }
547 /* check for trans */
548 if (c_cmaterial->td > .01 || c_cmaterial->ts > .01) {
549 double ts, a5, a6;
550
551 if (c_cmaterial->sided) {
552 ts = sqrt(c_cmaterial->ts); /* approximate */
553 a5 = .5;
554 } else {
555 ts = c_cmaterial->ts;
556 a5 = 1.;
557 }
558 /* average colors */
559 d = c_cmaterial->rd + c_cmaterial->td + ts;
560 cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd/d);
561 cvtcolor(c2, &c_cmaterial->td_c, c_cmaterial->td/d);
562 addcolor(radrgb, c2);
563 cvtcolor(c2, &c_cmaterial->ts_c, ts/d);
564 addcolor(radrgb, c2);
565 if (c_cmaterial->rs + ts > .0001)
566 a5 = (c_cmaterial->rs*c_cmaterial->rs_a +
567 ts*a5*c_cmaterial->ts_a) /
568 (c_cmaterial->rs + ts);
569 a6 = (c_cmaterial->td + ts) /
570 (c_cmaterial->rd + c_cmaterial->td + ts);
571 if (a6 < .999)
572 d = c_cmaterial->rd/(1. - c_cmaterial->rs)/(1. - a6);
573 else
574 d = c_cmaterial->td + ts;
575 scalecolor(radrgb, d);
576 fprintf(matfp, "\nvoid trans %s\n0\n0\n", mname);
577 fprintf(matfp, "7 %f %f %f\n", colval(radrgb,RED),
578 colval(radrgb,GRN), colval(radrgb,BLU));
579 fprintf(matfp, "\t%f %f %f %f\n", c_cmaterial->rs, a5, a6,
580 ts/(ts + c_cmaterial->td));
581 return(mname);
582 }
583 /* check for plastic */
584 if (c_cmaterial->rs < .1) {
585 cvtcolor(radrgb, &c_cmaterial->rd_c,
586 c_cmaterial->rd/(1.-c_cmaterial->rs));
587 fprintf(matfp, "\nvoid plastic %s\n0\n0\n", mname);
588 fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED),
589 colval(radrgb,GRN), colval(radrgb,BLU),
590 c_cmaterial->rs, c_cmaterial->rs_a);
591 return(mname);
592 }
593 /* else it's metal */
594 /* average colors */
595 cvtcolor(radrgb, &c_cmaterial->rd_c, c_cmaterial->rd);
596 cvtcolor(c2, &c_cmaterial->rs_c, c_cmaterial->rs);
597 addcolor(radrgb, c2);
598 fprintf(matfp, "\nvoid metal %s\n0\n0\n", mname);
599 fprintf(matfp, "5 %f %f %f %f %f\n", colval(radrgb,RED),
600 colval(radrgb,GRN), colval(radrgb,BLU),
601 c_cmaterial->rs/(c_cmaterial->rd + c_cmaterial->rs),
602 c_cmaterial->rs_a);
603 return(mname);
604 }
605
606
607 void
608 cvtcolor( /* convert a CIE XYZ color to RGB */
609 COLOR radrgb,
610 register C_COLOR *ciec,
611 double intensity
612 )
613 {
614 static COLOR ciexyz;
615
616 c_ccvt(ciec, C_CSXY); /* get xy representation */
617 ciexyz[1] = intensity;
618 ciexyz[0] = ciec->cx/ciec->cy*ciexyz[1];
619 ciexyz[2] = ciexyz[1]*(1./ciec->cy - 1.) - ciexyz[0];
620 cie_rgb(radrgb, ciexyz);
621 }
622
623
624 char *
625 object(void) /* return current object name */
626 {
627 static char objbuf[64];
628 register int i;
629 register char *cp;
630 int len;
631 /* tracked by obj_handler */
632 i = obj_nnames - sizeof(objbuf)/16;
633 if (i < 0)
634 i = 0;
635 for (cp = objbuf; i < obj_nnames &&
636 cp + (len=strlen(obj_name[i])) < objbuf+sizeof(objbuf)-1;
637 i++, *cp++ = '.') {
638 strcpy(cp, obj_name[i]);
639 cp += len;
640 }
641 *cp = '\0';
642 return(objbuf);
643 }
644
645
646 char *
647 addarg( /* add argument and advance pointer */
648 register char *op,
649 register char *arg
650 )
651 {
652 *op = ' ';
653 while ( (*++op = *arg++) )
654 ;
655 return(op);
656 }
