root/radiance/src/cv/bsdfrbf.c
Revision: 2.34
Committed: Wed Jun 29 15:52:07 2022 UTC (3 years, 3 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
Changes since 2.33: +3 -2 lines
fix: Added missing check in make_rbfrep() for failure to add RBF
2 static const char RCSid[] = "$Id: bsdfrbf.c,v 2.33 2019/05/08 16:38:19 greg Exp $";
5 * Radial basis function representation for BSDF data.
6 *
7 * G. Ward
8 */
9
10 /****************************************************************
11 1) Collect samples into a grid using the Shirley-Chiu
12 angular mapping from a hemisphere to a square.
13
14 2) Compute an adaptive quadtree by subdividing the grid so that
15 each leaf node has at least one sample up to as many
16 samples as fit nicely on a plane to within a certain
17 MSE tolerance.
18
19 3) Place one Gaussian lobe at each leaf node in the quadtree,
20 sizing it to have a radius equal to the leaf size and
21 a volume equal to the energy in that node.
22 *****************************************************************/
23
24 #define _USE_MATH_DEFINES
25 #include <stdio.h>
26 #include <stdlib.h>
27 #include <string.h>
28 #include <math.h>
29 #include "bsdfrep.h"
30
31 #ifndef RSCA
32 #define RSCA 2.0 /* radius scaling factor (empirical) */
33 #endif
34 #ifndef MAXSLOPE
35 #define MAXSLOPE 200.0 /* maximum slope for smooth region */
36 #endif
37 #ifndef SMOOTH_MSE
38 #define SMOOTH_MSE 5e-5 /* acceptable mean squared error */
39 #endif
40 #ifndef SMOOTH_MSER
41 #define SMOOTH_MSER 0.0016 /* acceptable relative MSE */
42 #endif
43 #define MAX_RAD (GRIDRES/8) /* maximum lobe radius */
44
45 #define RBFALLOCB 10 /* RBF allocation block size */
46
47 /* loaded grid or comparison DSFs */
48 GRIDVAL dsf_grid[GRIDRES][GRIDRES];
49 /* allocated chrominance sums if any */
50 float (*spec_grid)[GRIDRES][GRIDRES];
51 int nspec_grid = 0;
52
53 /* Set up visible spectrum sampling */
54 void
55 set_spectral_samples(int nspec)
56 {
57 if (rbf_colorimetry == RBCunknown) {
58 if (nspec_grid > 0) {
59 free(spec_grid);
60 spec_grid = NULL;
61 nspec_grid = 0;
62 }
63 if (nspec == 1) {
64 rbf_colorimetry = RBCphotopic;
65 return;
66 }
67 if (nspec == 3) {
68 rbf_colorimetry = RBCtristimulus;
69 spec_grid = (float (*)[GRIDRES][GRIDRES])calloc(
70 2*GRIDRES*GRIDRES, sizeof(float) );
71 if (spec_grid == NULL)
72 goto mem_error;
73 nspec_grid = 2;
74 return;
75 }
76 fprintf(stderr,
77 "%s: only 1 or 3 spectral samples currently supported\n",
78 progname);
79 exit(1);
80 }
81 if (nspec != nspec_grid+1) {
82 fprintf(stderr,
83 "%s: number of spectral samples cannot be changed\n",
84 progname);
85 exit(1);
86 }
87 return;
88 mem_error:
89 fprintf(stderr, "%s: out of memory in set_spectral_samples()\n",
90 progname);
91 exit(1);
92 }
93
94 /* Start new DSF input grid */
95 void
96 new_bsdf_data(double new_theta, double new_phi)
97 {
98 if (!new_input_direction(new_theta, new_phi))
99 exit(1);
100 memset(dsf_grid, 0, sizeof(dsf_grid));
101 if (nspec_grid > 0)
102 memset(spec_grid, 0, sizeof(float)*GRIDRES*GRIDRES*nspec_grid);
103 }
104
105 /* Add BSDF data point */
106 void
107 add_bsdf_data(double theta_out, double phi_out, const double val[], int isDSF)
108 {
109 FVECT ovec;
110 double cfact, Yval;
111 int pos[2];
112
113 if (nspec_grid > 2) {
114 fprintf(stderr, "%s: unsupported color space\n", progname);
115 exit(1);
116 }
117 if (!output_orient) /* check output orientation */
118 output_orient = 1 - 2*(theta_out > 90.);
119 else if (output_orient > 0 ^ theta_out < 90.) {
120 fprintf(stderr,
121 "%s: cannot handle output angles on both sides of surface\n",
122 progname);
123 exit(1);
124 }
125 ovec[2] = sin((M_PI/180.)*theta_out);
126 ovec[0] = cos((M_PI/180.)*phi_out) * ovec[2];
127 ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2];
128 ovec[2] = sqrt(1. - ovec[2]*ovec[2]);
129 /* BSDF to DSF correction */
130 cfact = isDSF ? 1. : ovec[2];
131
132 Yval = cfact * val[rbf_colorimetry==RBCtristimulus];
133 /* update BSDF histogram */
134 if (BSDF2SML*ovec[2] < Yval && Yval < BSDF2BIG*ovec[2])
135 ++bsdf_hist[histndx(Yval/ovec[2])];
136
137 pos_from_vec(pos, ovec);
138
139 dsf_grid[pos[0]][pos[1]].sum.v += Yval;
140 dsf_grid[pos[0]][pos[1]].sum.n++;
141 /* add in X and Z values */
142 if (rbf_colorimetry == RBCtristimulus) {
143 spec_grid[0][pos[0]][pos[1]] += cfact * val[0];
144 spec_grid[1][pos[0]][pos[1]] += cfact * val[2];
145 }
146 }
147
148 /* Compute minimum BSDF from histogram (does not clear) */
149 static void
150 comp_bsdf_min()
151 {
152 unsigned long cnt, target;
153 int i;
154
155 cnt = 0;
156 for (i = HISTLEN; i--; )
157 cnt += bsdf_hist[i];
158 if (!cnt) { /* shouldn't happen */
159 bsdf_min = 0;
160 return;
161 }
162 target = cnt/100; /* ignore bottom 1% */
163 cnt = 0;
164 for (i = 0; cnt <= target; i++)
165 cnt += bsdf_hist[i];
166 bsdf_min = histval(i-1);
167 }
168
169 /* Determine if the given region is empty of grid samples */
170 static int
171 empty_region(int x0, int x1, int y0, int y1)
172 {
173 int x, y;
174
175 for (x = x0; x < x1; x++)
176 for (y = y0; y < y1; y++)
177 if (dsf_grid[x][y].sum.n)
178 return(0);
179 return(1);
180 }
181
182 /* Determine if the given region is smooth enough to be a single lobe */
183 static int
184 smooth_region(int x0, int x1, int y0, int y1)
185 {
186 RREAL rMtx[3][3];
187 FVECT xvec;
188 double A, B, C, nvs, sqerr;
189 int x, y, n;
190 /* compute planar regression */
191 memset(rMtx, 0, sizeof(rMtx));
192 memset(xvec, 0, sizeof(xvec));
193 for (x = x0; x < x1; x++)
194 for (y = y0; y < y1; y++)
195 if ((n = dsf_grid[x][y].sum.n) > 0) {
196 double z = dsf_grid[x][y].sum.v;
197 rMtx[0][0] += x*x*(double)n;
198 rMtx[0][1] += x*y*(double)n;
199 rMtx[0][2] += x*(double)n;
200 rMtx[1][1] += y*y*(double)n;
201 rMtx[1][2] += y*(double)n;
202 rMtx[2][2] += (double)n;
203 xvec[0] += x*z;
204 xvec[1] += y*z;
205 xvec[2] += z;
206 }
207 rMtx[1][0] = rMtx[0][1];
208 rMtx[2][0] = rMtx[0][2];
209 rMtx[2][1] = rMtx[1][2];
210 nvs = rMtx[2][2];
211 if (SDinvXform(rMtx, rMtx) != SDEnone)
212 return(1); /* colinear values */
213 A = DOT(rMtx[0], xvec);
214 B = DOT(rMtx[1], xvec);
215 if (A*A + B*B > MAXSLOPE*MAXSLOPE) /* too steep? */
216 return(0);
217 C = DOT(rMtx[2], xvec);
218 sqerr = 0.0; /* compute mean squared error */
219 for (x = x0; x < x1; x++)
220 for (y = y0; y < y1; y++)
221 if ((n = dsf_grid[x][y].sum.n) > 0) {
222 double d = A*x + B*y + C - dsf_grid[x][y].sum.v/n;
223 sqerr += n*d*d;
224 }
225 if (sqerr <= nvs*SMOOTH_MSE) /* below absolute MSE threshold? */
226 return(1);
227 /* OR below relative MSE threshold? */
228 return(sqerr*nvs <= xvec[2]*xvec[2]*SMOOTH_MSER);
229 }
230
231 /* Create new lobe based on integrated samples in region */
232 static int
233 create_lobe(RBFVAL *rvp, int x0, int x1, int y0, int y1)
234 {
235 double vtot = 0.0;
236 double CIEXtot = 0.0, CIEZtot = 0.0;
237 int nv = 0;
238 double wxsum = 0.0, wysum = 0.0, wtsum = 0.0;
239 double rad;
240 int x, y;
241 /* compute average for region */
242 for (x = x0; x < x1; x++)
243 for (y = y0; y < y1; y++)
244 if (dsf_grid[x][y].sum.n) {
245 const double v = dsf_grid[x][y].sum.v;
246 const int n = dsf_grid[x][y].sum.n;
247
248 if (v > 0) {
249 const double wt = v / (double)n;
250 wxsum += wt * x;
251 wysum += wt * y;
252 wtsum += wt;
253 }
254 vtot += v;
255 nv += n;
256 if (rbf_colorimetry == RBCtristimulus) {
257 CIEXtot += spec_grid[0][x][y];
258 CIEZtot += spec_grid[1][x][y];
259 }
260 }
261 if (!nv) {
262 fprintf(stderr, "%s: internal - missing samples in create_lobe\n",
263 progname);
264 exit(1);
265 }
266 if (vtot <= 0) /* only create positive lobes */
267 return(0);
268 /* assign color */
269 if (rbf_colorimetry == RBCtristimulus) {
270 const double df = 1.0 / (CIEXtot + vtot + CIEZtot);
271 C_COLOR cclr;
272 c_cset(&cclr, CIEXtot*df, vtot*df);
273 rvp->chroma = c_encodeChroma(&cclr);
274 } else
275 rvp->chroma = c_dfchroma;
276 /* peak value based on integral */
277 vtot *= (x1-x0)*(y1-y0)*(2.*M_PI/GRIDRES/GRIDRES)/(double)nv;
278 rad = (RSCA/(double)GRIDRES)*(x1-x0);
279 rvp->peak = vtot / ((2.*M_PI) * rad*rad);
280 rvp->crad = ANG2R(rad); /* put peak at centroid */
281 rvp->gx = (int)(wxsum/wtsum + .5);
282 rvp->gy = (int)(wysum/wtsum + .5);
283 return(1);
284 }
285
286 /* Recursive function to build radial basis function representation */
287 static int
288 build_rbfrep(RBFVAL **arp, int *np, int x0, int x1, int y0, int y1)
289 {
290 int xmid = (x0+x1)>>1;
291 int ymid = (y0+y1)>>1;
292 int branched[4];
293 int nadded, nleaves;
294 /* need to make this a leaf? */
295 if (empty_region(x0, xmid, y0, ymid) ||
296 empty_region(xmid, x1, y0, ymid) ||
297 empty_region(x0, xmid, ymid, y1) ||
298 empty_region(xmid, x1, ymid, y1))
299 return(0);
300 /* add children (branches+leaves) */
301 if ((branched[0] = build_rbfrep(arp, np, x0, xmid, y0, ymid)) < 0)
302 return(-1);
303 if ((branched[1] = build_rbfrep(arp, np, xmid, x1, y0, ymid)) < 0)
304 return(-1);
305 if ((branched[2] = build_rbfrep(arp, np, x0, xmid, ymid, y1)) < 0)
306 return(-1);
307 if ((branched[3] = build_rbfrep(arp, np, xmid, x1, ymid, y1)) < 0)
308 return(-1);
309 nadded = branched[0] + branched[1] + branched[2] + branched[3];
310 nleaves = !branched[0] + !branched[1] + !branched[2] + !branched[3];
311 if (!nleaves) /* nothing but branches? */
312 return(nadded);
313 /* combine 4 leaves into 1? */
314 if ((nleaves == 4) & (x1-x0 <= MAX_RAD) &&
315 smooth_region(x0, x1, y0, y1))
316 return(0);
317 /* need more array space? */
318 if ((*np+nleaves-1)>>RBFALLOCB != (*np-1)>>RBFALLOCB) {
319 *arp = (RBFVAL *)realloc(*arp,
320 sizeof(RBFVAL)*(*np+nleaves-1+(1<<RBFALLOCB)));
321 if (*arp == NULL)
322 return(-1);
323 }
324 /* create lobes for leaves */
325 if (!branched[0] && create_lobe(*arp+*np, x0, xmid, y0, ymid)) {
326 ++(*np); ++nadded;
327 }
328 if (!branched[1] && create_lobe(*arp+*np, xmid, x1, y0, ymid)) {
329 ++(*np); ++nadded;
330 }
331 if (!branched[2] && create_lobe(*arp+*np, x0, xmid, ymid, y1)) {
332 ++(*np); ++nadded;
333 }
334 if (!branched[3] && create_lobe(*arp+*np, xmid, x1, ymid, y1)) {
335 ++(*np); ++nadded;
336 }
337 return(nadded);
338 }
339
340 /* Count up filled nodes and build RBF representation from current grid */
341 RBFNODE *
342 make_rbfrep()
343 {
344 RBFNODE *newnode;
345 RBFVAL *rbfarr;
346 int nn;
347 /* compute minimum BSDF */
348 comp_bsdf_min();
349 /* create RBF node list */
350 rbfarr = NULL; nn = 0;
351 if (build_rbfrep(&rbfarr, &nn, 0, GRIDRES, 0, GRIDRES) <= 0) {
352 if (nn)
353 goto memerr;
354 fprintf(stderr,
355 "%s: warning - skipping bad incidence (%.1f,%.1f)\n",
356 progname, theta_in_deg, phi_in_deg);
357 return(NULL);
358 }
359 /* (re)allocate RBF array */
360 newnode = (RBFNODE *)realloc(rbfarr,
361 sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1));
362 if (newnode == NULL)
363 goto memerr;
364 /* copy computed lobes into RBF node */
365 memmove(newnode->rbfa, newnode, sizeof(RBFVAL)*nn);
366 newnode->ord = -1;
367 newnode->next = NULL;
368 newnode->ejl = NULL;
369 newnode->invec[2] = sin((M_PI/180.)*theta_in_deg);
370 newnode->invec[0] = cos((M_PI/180.)*phi_in_deg)*newnode->invec[2];
371 newnode->invec[1] = sin((M_PI/180.)*phi_in_deg)*newnode->invec[2];
372 newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]);
373 newnode->vtotal = .0;
374 newnode->nrbf = nn;
375 /* compute sum for normalization */
376 while (nn-- > 0)
377 newnode->vtotal += rbf_volume(&newnode->rbfa[nn]);
378 #ifdef DEBUG
379 fprintf(stderr, "Built RBF with %d lobes\n", newnode->nrbf);
380 fprintf(stderr, "Integrated DSF at (%.1f,%.1f) deg. is %.2f\n",
381 get_theta180(newnode->invec), get_phi360(newnode->invec),
382 newnode->vtotal);
383 #endif
384 if (insert_dsf(newnode) < 0)
385 return(NULL);
386 return(newnode);
387 memerr:
388 fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname);
389 exit(1);
390 }
