| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: bsdfrbf.c,v 2.32 2019/04/09 22:39:33 greg Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* Radial basis function representation for BSDF data. |
| 6 |
| 7 |
* G. Ward |
| 8 |
| 9 |
| 10 |
| 11 |
1) Collect samples into a grid using the Shirley-Chiu |
| 12 |
angular mapping from a hemisphere to a square. |
| 13 |
| 14 |
2) Compute an adaptive quadtree by subdividing the grid so that |
| 15 |
each leaf node has at least one sample up to as many |
| 16 |
samples as fit nicely on a plane to within a certain |
| 17 |
MSE tolerance. |
| 18 |
| 19 |
3) Place one Gaussian lobe at each leaf node in the quadtree, |
| 20 |
sizing it to have a radius equal to the leaf size and |
| 21 |
a volume equal to the energy in that node. |
| 22 |
| 23 |
| 24 |
#define _USE_MATH_DEFINES |
| 25 |
#include <stdio.h> |
| 26 |
#include <stdlib.h> |
| 27 |
#include <string.h> |
| 28 |
#include <math.h> |
| 29 |
#include "bsdfrep.h" |
| 30 |
| 31 |
#ifndef RSCA |
| 32 |
#define RSCA 2.0 /* radius scaling factor (empirical) */ |
| 33 |
#endif |
| 34 |
#ifndef MAXSLOPE |
| 35 |
#define MAXSLOPE 200.0 /* maximum slope for smooth region */ |
| 36 |
#endif |
| 37 |
#ifndef SMOOTH_MSE |
| 38 |
#define SMOOTH_MSE 5e-5 /* acceptable mean squared error */ |
| 39 |
#endif |
| 40 |
#ifndef SMOOTH_MSER |
| 41 |
#define SMOOTH_MSER 0.0016 /* acceptable relative MSE */ |
| 42 |
#endif |
| 43 |
#define MAX_RAD (GRIDRES/8) /* maximum lobe radius */ |
| 44 |
| 45 |
#define RBFALLOCB 10 /* RBF allocation block size */ |
| 46 |
| 47 |
/* loaded grid or comparison DSFs */ |
| 48 |
GRIDVAL dsf_grid[GRIDRES][GRIDRES]; |
| 49 |
/* allocated chrominance sums if any */ |
| 50 |
float (*spec_grid)[GRIDRES][GRIDRES]; |
| 51 |
int nspec_grid = 0; |
| 52 |
| 53 |
/* Set up visible spectrum sampling */ |
| 54 |
void |
| 55 |
set_spectral_samples(int nspec) |
| 56 |
| 57 |
if (rbf_colorimetry == RBCunknown) { |
| 58 |
if (nspec_grid > 0) { |
| 59 |
free(spec_grid); |
| 60 |
spec_grid = NULL; |
| 61 |
nspec_grid = 0; |
| 62 |
| 63 |
if (nspec == 1) { |
| 64 |
rbf_colorimetry = RBCphotopic; |
| 65 |
return; |
| 66 |
| 67 |
if (nspec == 3) { |
| 68 |
rbf_colorimetry = RBCtristimulus; |
| 69 |
spec_grid = (float (*)[GRIDRES][GRIDRES])calloc( |
| 70 |
2*GRIDRES*GRIDRES, sizeof(float) ); |
| 71 |
if (spec_grid == NULL) |
| 72 |
goto mem_error; |
| 73 |
nspec_grid = 2; |
| 74 |
return; |
| 75 |
| 76 |
fprintf(stderr, |
| 77 |
"%s: only 1 or 3 spectral samples currently supported\n", |
| 78 |
progname); |
| 79 |
exit(1); |
| 80 |
| 81 |
if (nspec != nspec_grid+1) { |
| 82 |
fprintf(stderr, |
| 83 |
"%s: number of spectral samples cannot be changed\n", |
| 84 |
progname); |
| 85 |
exit(1); |
| 86 |
| 87 |
return; |
| 88 |
mem_error: |
| 89 |
fprintf(stderr, "%s: out of memory in set_spectral_samples()\n", |
| 90 |
progname); |
| 91 |
exit(1); |
| 92 |
| 93 |
| 94 |
/* Start new DSF input grid */ |
| 95 |
void |
| 96 |
new_bsdf_data(double new_theta, double new_phi) |
| 97 |
| 98 |
if (!new_input_direction(new_theta, new_phi)) |
| 99 |
exit(1); |
| 100 |
memset(dsf_grid, 0, sizeof(dsf_grid)); |
| 101 |
if (nspec_grid > 0) |
| 102 |
memset(spec_grid, 0, sizeof(float)*GRIDRES*GRIDRES*nspec_grid); |
| 103 |
| 104 |
| 105 |
/* Add BSDF data point */ |
| 106 |
void |
| 107 |
add_bsdf_data(double theta_out, double phi_out, const double val[], int isDSF) |
| 108 |
| 109 |
FVECT ovec; |
| 110 |
double cfact, Yval; |
| 111 |
int pos[2]; |
| 112 |
| 113 |
if (nspec_grid > 2) { |
| 114 |
fprintf(stderr, "%s: unsupported color space\n", progname); |
| 115 |
exit(1); |
| 116 |
| 117 |
if (!output_orient) /* check output orientation */ |
| 118 |
output_orient = 1 - 2*(theta_out > 90.); |
| 119 |
else if (output_orient > 0 ^ theta_out < 90.) { |
| 120 |
fprintf(stderr, |
| 121 |
"%s: cannot handle output angles on both sides of surface\n", |
| 122 |
progname); |
| 123 |
exit(1); |
| 124 |
| 125 |
ovec[2] = sin((M_PI/180.)*theta_out); |
| 126 |
ovec[0] = cos((M_PI/180.)*phi_out) * ovec[2]; |
| 127 |
ovec[1] = sin((M_PI/180.)*phi_out) * ovec[2]; |
| 128 |
ovec[2] = sqrt(1. - ovec[2]*ovec[2]); |
| 129 |
/* BSDF to DSF correction */ |
| 130 |
cfact = isDSF ? 1. : ovec[2]; |
| 131 |
| 132 |
Yval = cfact * val[rbf_colorimetry==RBCtristimulus]; |
| 133 |
/* update BSDF histogram */ |
| 134 |
if (BSDF2SML*ovec[2] < Yval && Yval < BSDF2BIG*ovec[2]) |
| 135 |
++bsdf_hist[histndx(Yval/ovec[2])]; |
| 136 |
| 137 |
pos_from_vec(pos, ovec); |
| 138 |
| 139 |
dsf_grid[pos[0]][pos[1]].sum.v += Yval; |
| 140 |
dsf_grid[pos[0]][pos[1]].sum.n++; |
| 141 |
/* add in X and Z values */ |
| 142 |
if (rbf_colorimetry == RBCtristimulus) { |
| 143 |
spec_grid[0][pos[0]][pos[1]] += cfact * val[0]; |
| 144 |
spec_grid[1][pos[0]][pos[1]] += cfact * val[2]; |
| 145 |
| 146 |
| 147 |
| 148 |
/* Compute minimum BSDF from histogram (does not clear) */ |
| 149 |
static void |
| 150 |
comp_bsdf_min() |
| 151 |
| 152 |
unsigned long cnt, target; |
| 153 |
int i; |
| 154 |
| 155 |
cnt = 0; |
| 156 |
for (i = HISTLEN; i--; ) |
| 157 |
cnt += bsdf_hist[i]; |
| 158 |
if (!cnt) { /* shouldn't happen */ |
| 159 |
bsdf_min = 0; |
| 160 |
return; |
| 161 |
| 162 |
target = cnt/100; /* ignore bottom 1% */ |
| 163 |
cnt = 0; |
| 164 |
for (i = 0; cnt <= target; i++) |
| 165 |
| 166 |
bsdf_min = histval(i-1); |
| 167 |
| 168 |
| 169 |
/* Determine if the given region is empty of grid samples */ |
| 170 |
static int |
| 171 |
empty_region(int x0, int x1, int y0, int y1) |
| 172 |
| 173 |
int x, y; |
| 174 |
| 175 |
for (x = x0; x < x1; x++) |
| 176 |
for (y = y0; y < y1; y++) |
| 177 |
if (dsf_grid[x][y].sum.n) |
| 178 |
return(0); |
| 179 |
return(1); |
| 180 |
| 181 |
| 182 |
/* Determine if the given region is smooth enough to be a single lobe */ |
| 183 |
static int |
| 184 |
smooth_region(int x0, int x1, int y0, int y1) |
| 185 |
| 186 |
RREAL rMtx[3][3]; |
| 187 |
FVECT xvec; |
| 188 |
double A, B, C, nvs, sqerr; |
| 189 |
int x, y, n; |
| 190 |
/* compute planar regression */ |
| 191 |
memset(rMtx, 0, sizeof(rMtx)); |
| 192 |
memset(xvec, 0, sizeof(xvec)); |
| 193 |
| 194 |
| 195 |
if ((n = dsf_grid[x][y].sum.n) > 0) { |
| 196 |
double z = dsf_grid[x][y].sum.v; |
| 197 |
rMtx[0][0] += x*x*(double)n; |
| 198 |
rMtx[0][1] += x*y*(double)n; |
| 199 |
rMtx[0][2] += x*(double)n; |
| 200 |
rMtx[1][1] += y*y*(double)n; |
| 201 |
rMtx[1][2] += y*(double)n; |
| 202 |
rMtx[2][2] += (double)n; |
| 203 |
xvec[0] += x*z; |
| 204 |
xvec[1] += y*z; |
| 205 |
xvec[2] += z; |
| 206 |
| 207 |
rMtx[1][0] = rMtx[0][1]; |
| 208 |
rMtx[2][0] = rMtx[0][2]; |
| 209 |
rMtx[2][1] = rMtx[1][2]; |
| 210 |
nvs = rMtx[2][2]; |
| 211 |
if (SDinvXform(rMtx, rMtx) != SDEnone) |
| 212 |
return(1); /* colinear values */ |
| 213 |
A = DOT(rMtx[0], xvec); |
| 214 |
B = DOT(rMtx[1], xvec); |
| 215 |
if (A*A + B*B > MAXSLOPE*MAXSLOPE) /* too steep? */ |
| 216 |
return(0); |
| 217 |
C = DOT(rMtx[2], xvec); |
| 218 |
sqerr = 0.0; /* compute mean squared error */ |
| 219 |
| 220 |
| 221 |
| 222 |
double d = A*x + B*y + C - dsf_grid[x][y].sum.v/n; |
| 223 |
sqerr += n*d*d; |
| 224 |
| 225 |
if (sqerr <= nvs*SMOOTH_MSE) /* below absolute MSE threshold? */ |
| 226 |
return(1); |
| 227 |
/* OR below relative MSE threshold? */ |
| 228 |
return(sqerr*nvs <= xvec[2]*xvec[2]*SMOOTH_MSER); |
| 229 |
| 230 |
| 231 |
/* Create new lobe based on integrated samples in region */ |
| 232 |
static int |
| 233 |
create_lobe(RBFVAL *rvp, int x0, int x1, int y0, int y1) |
| 234 |
| 235 |
double vtot = 0.0; |
| 236 |
double CIEXtot = 0.0, CIEZtot = 0.0; |
| 237 |
int nv = 0; |
| 238 |
double wxsum = 0.0, wysum = 0.0, wtsum = 0.0; |
| 239 |
double rad; |
| 240 |
int x, y; |
| 241 |
/* compute average for region */ |
| 242 |
| 243 |
| 244 |
if (dsf_grid[x][y].sum.n) { |
| 245 |
const double v = dsf_grid[x][y].sum.v; |
| 246 |
const int n = dsf_grid[x][y].sum.n; |
| 247 |
| 248 |
if (v > 0) { |
| 249 |
const double wt = v / (double)n; |
| 250 |
wxsum += wt * x; |
| 251 |
wysum += wt * y; |
| 252 |
wtsum += wt; |
| 253 |
| 254 |
vtot += v; |
| 255 |
nv += n; |
| 256 |
| 257 |
CIEXtot += spec_grid[0][x][y]; |
| 258 |
CIEZtot += spec_grid[1][x][y]; |
| 259 |
| 260 |
| 261 |
if (!nv) { |
| 262 |
fprintf(stderr, "%s: internal - missing samples in create_lobe\n", |
| 263 |
progname); |
| 264 |
exit(1); |
| 265 |
| 266 |
if (vtot <= 0) /* only create positive lobes */ |
| 267 |
return(0); |
| 268 |
/* assign color */ |
| 269 |
| 270 |
const double df = 1.0 / (CIEXtot + vtot + CIEZtot); |
| 271 |
C_COLOR cclr; |
| 272 |
c_cset(&cclr, CIEXtot*df, vtot*df); |
| 273 |
rvp->chroma = c_encodeChroma(&cclr); |
| 274 |
} else |
| 275 |
rvp->chroma = c_dfchroma; |
| 276 |
/* peak value based on integral */ |
| 277 |
vtot *= (x1-x0)*(y1-y0)*(2.*M_PI/GRIDRES/GRIDRES)/(double)nv; |
| 278 |
rad = (RSCA/(double)GRIDRES)*(x1-x0); |
| 279 |
rvp->peak = vtot / ((2.*M_PI) * rad*rad); |
| 280 |
rvp->crad = ANG2R(rad); /* put peak at centroid */ |
| 281 |
rvp->gx = (int)(wxsum/wtsum + .5); |
| 282 |
rvp->gy = (int)(wysum/wtsum + .5); |
| 283 |
return(1); |
| 284 |
| 285 |
| 286 |
/* Recursive function to build radial basis function representation */ |
| 287 |
static int |
| 288 |
build_rbfrep(RBFVAL **arp, int *np, int x0, int x1, int y0, int y1) |
| 289 |
| 290 |
int xmid = (x0+x1)>>1; |
| 291 |
int ymid = (y0+y1)>>1; |
| 292 |
int branched[4]; |
| 293 |
int nadded, nleaves; |
| 294 |
/* need to make this a leaf? */ |
| 295 |
if (empty_region(x0, xmid, y0, ymid) || |
| 296 |
empty_region(xmid, x1, y0, ymid) || |
| 297 |
empty_region(x0, xmid, ymid, y1) || |
| 298 |
empty_region(xmid, x1, ymid, y1)) |
| 299 |
return(0); |
| 300 |
/* add children (branches+leaves) */ |
| 301 |
if ((branched[0] = build_rbfrep(arp, np, x0, xmid, y0, ymid)) < 0) |
| 302 |
return(-1); |
| 303 |
if ((branched[1] = build_rbfrep(arp, np, xmid, x1, y0, ymid)) < 0) |
| 304 |
return(-1); |
| 305 |
if ((branched[2] = build_rbfrep(arp, np, x0, xmid, ymid, y1)) < 0) |
| 306 |
return(-1); |
| 307 |
if ((branched[3] = build_rbfrep(arp, np, xmid, x1, ymid, y1)) < 0) |
| 308 |
return(-1); |
| 309 |
nadded = branched[0] + branched[1] + branched[2] + branched[3]; |
| 310 |
nleaves = !branched[0] + !branched[1] + !branched[2] + !branched[3]; |
| 311 |
if (!nleaves) /* nothing but branches? */ |
| 312 |
return(nadded); |
| 313 |
/* combine 4 leaves into 1? */ |
| 314 |
if ((nleaves == 4) & (x1-x0 <= MAX_RAD) && |
| 315 |
smooth_region(x0, x1, y0, y1)) |
| 316 |
return(0); |
| 317 |
/* need more array space? */ |
| 318 |
if ((*np+nleaves-1)>>RBFALLOCB != (*np-1)>>RBFALLOCB) { |
| 319 |
*arp = (RBFVAL *)realloc(*arp, |
| 320 |
sizeof(RBFVAL)*(*np+nleaves-1+(1<<RBFALLOCB))); |
| 321 |
if (*arp == NULL) |
| 322 |
return(-1); |
| 323 |
| 324 |
/* create lobes for leaves */ |
| 325 |
if (!branched[0] && create_lobe(*arp+*np, x0, xmid, y0, ymid)) { |
| 326 |
++(*np); ++nadded; |
| 327 |
| 328 |
if (!branched[1] && create_lobe(*arp+*np, xmid, x1, y0, ymid)) { |
| 329 |
| 330 |
| 331 |
if (!branched[2] && create_lobe(*arp+*np, x0, xmid, ymid, y1)) { |
| 332 |
| 333 |
| 334 |
if (!branched[3] && create_lobe(*arp+*np, xmid, x1, ymid, y1)) { |
| 335 |
| 336 |
| 337 |
return(nadded); |
| 338 |
| 339 |
| 340 |
/* Count up filled nodes and build RBF representation from current grid */ |
| 341 |
RBFNODE * |
| 342 |
make_rbfrep() |
| 343 |
| 344 |
RBFNODE *newnode; |
| 345 |
RBFVAL *rbfarr; |
| 346 |
int nn; |
| 347 |
/* compute minimum BSDF */ |
| 348 |
comp_bsdf_min(); |
| 349 |
/* create RBF node list */ |
| 350 |
rbfarr = NULL; nn = 0; |
| 351 |
if (build_rbfrep(&rbfarr, &nn, 0, GRIDRES, 0, GRIDRES) <= 0) { |
| 352 |
if (nn) |
| 353 |
goto memerr; |
| 354 |
fprintf(stderr, |
| 355 |
"%s: warning - skipping bad incidence (%.1f,%.1f)\n", |
| 356 |
progname, theta_in_deg, phi_in_deg); |
| 357 |
return(NULL); |
| 358 |
| 359 |
/* (re)allocate RBF array */ |
| 360 |
newnode = (RBFNODE *)realloc(rbfarr, |
| 361 |
sizeof(RBFNODE) + sizeof(RBFVAL)*(nn-1)); |
| 362 |
if (newnode == NULL) |
| 363 |
goto memerr; |
| 364 |
/* copy computed lobes into RBF node */ |
| 365 |
memmove(newnode->rbfa, newnode, sizeof(RBFVAL)*nn); |
| 366 |
newnode->ord = -1; |
| 367 |
newnode->next = NULL; |
| 368 |
newnode->ejl = NULL; |
| 369 |
newnode->invec[2] = sin((M_PI/180.)*theta_in_deg); |
| 370 |
newnode->invec[0] = cos((M_PI/180.)*phi_in_deg)*newnode->invec[2]; |
| 371 |
newnode->invec[1] = sin((M_PI/180.)*phi_in_deg)*newnode->invec[2]; |
| 372 |
newnode->invec[2] = input_orient*sqrt(1. - newnode->invec[2]*newnode->invec[2]); |
| 373 |
newnode->vtotal = .0; |
| 374 |
newnode->nrbf = nn; |
| 375 |
/* compute sum for normalization */ |
| 376 |
while (nn-- > 0) |
| 377 |
newnode->vtotal += rbf_volume(&newnode->rbfa[nn]); |
| 378 |
#ifdef DEBUG |
| 379 |
fprintf(stderr, "Built RBF with %d lobes\n", newnode->nrbf); |
| 380 |
fprintf(stderr, "Integrated DSF at (%.1f,%.1f) deg. is %.2f\n", |
| 381 |
get_theta180(newnode->invec), get_phi360(newnode->invec), |
| 382 |
newnode->vtotal); |
| 383 |
#endif |
| 384 |
insert_dsf(newnode); |
| 385 |
return(newnode); |
| 386 |
memerr: |
| 387 |
fprintf(stderr, "%s: Out of memory in make_rbfrep()\n", progname); |
| 388 |
exit(1); |
| 389 |
