root/radiance/src/cv/SConscript
Revision: 1.16
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 10 months ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, HEAD
Changes since 1.15: +4 -1 lines
# User Rev Content
1 schorsch 1.16 from __future__ import division, print_function, unicode_literals
2
3 greg 1.11 import os
4
5     Import ('env')
6
7     # math libs
8     mlib = env['RAD_MLIB']
9
10     # compose paths
11     def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
12
13     trans = env.Object(source="trans.c")
14 schorsch 1.13 bsdfrep = env.Object(source="bsdfrep.c")
15     bsdfinterp = env.Object(source="bsdfinterp.c")
16
17 greg 1.11 # standard targets
18     PROGS = [
19 schorsch 1.15 ('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c'), ['mgf','rtrad'] + mlib),
20     ('ies2rad', ['ies2rad.c'], ['rtrad'] + mlib),
21     #('arch2rad', ['arch2rad.c',trans],['rtrad'] + mlib),
22 greg 1.11 ('nff2rad', ['nff2rad.c'], []),
23 schorsch 1.15 ('lampcolor', ['lampcolor.c'], ['rtrad'] ),
24     ('tmesh2rad', ['tmesh2rad.c'], ['rtrad'] + mlib),
25     ('obj2rad', ['obj2rad.c',trans], ['rtrad'] + mlib),
26     ('mgf2rad', ['mgf2rad.c'], ['mgf','rtrad'] + mlib),
27     ('rad2mgf', ['rad2mgf.c'], ['rtrad'] + mlib),
28     ('mgfilt', ['mgfilt.c'], ['mgf','rtrad'] + mlib),
29     ('mgf2inv', ['mgf2inv.c'], ['mgf','rtrad'] + mlib),
30 schorsch 1.13 ('pabopto2bsdf',
31     ['pabopto2bsdf.c',bsdfrep,'bsdfrbf.c', 'bsdfmesh.c', 'bsdftrans.cpp',],
32 schorsch 1.15 ['rtrad'] + mlib),
33     ('bsdf2klems',['bsdf2klems.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib),
34     ('bsdf2ttree',['bsdf2ttree.c', bsdfrep, bsdfinterp,], ['rtrad'] + mlib),
35     ('pkgBSDF', ['pkgBSDF.c', ], ['rtrad'] + mlib),
36     ('epw2wea', ['epw2wea.c', ], ['rtrad'] + mlib),
37     ('mgf2meta', ['mgf2meta.c'], ['meta', 'mgf','rtrad'] + mlib,
38     [os.path.join('#src','meta')]),
39 greg 1.11 ]
40     for p in PROGS:
41 schorsch 1.15 if len(p) == 4: inclp = env.get('CPPPATH', []) + [os.path.join('#src','meta')],
42     else: inclp = env.get('CPPPATH', [])
43     prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2], CPPPATH=inclp)
44 greg 1.11 Default(prog)
45     env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
46
47 schorsch 1.16 LIBFILES = Split('bsdf2rad.cal source.cal tilt.cal window.cal')
48 greg 1.11 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
49
50     if os.name == 'posix':
51     for s in Split('''optics2rad'''):
52 schorsch 1.12 Default(env.InstallScript(rbin(s), s + '.csh'))
53 schorsch 1.13
54     # vim: set syntax=python:
55 schorsch 1.16 # vi: set ts=4 sw=4 :
