root/radiance/src/cv/SConscript
Mon Jan 8 13:38:37 2018 UTC (7 years, 11 months ago) by schorsch
Changes since 1.15: +4 -1 lines
Diff to previous 1.15 , to selected 1.1
Thu Mar 10 21:43:22 2016 UTC (9 years, 9 months ago) by schorsch
Changes since 1.14: +20 -33 lines
Diff to previous 1.14 , to selected 1.1
Sun Mar 6 01:13:17 2016 UTC (9 years, 10 months ago) by schorsch
Changes since 1.13: +2 -2 lines
Diff to previous 1.13 , to selected 1.1
Sat Mar 5 13:24:58 2016 UTC (9 years, 10 months ago) by schorsch
Changes since 1.12: +15 -3 lines
Diff to previous 1.12 , to selected 1.1
Sat Mar 5 00:29:28 2016 UTC (9 years, 10 months ago) by schorsch
Diff to previous 1.11 , to selected 1.1
update SCons
Fri Apr 15 21:52:16 2011 UTC (14 years, 8 months ago) by greg
Changes since 1.10: +53 -60 lines
Diff to previous 1.10 , to selected 1.1
SCONS fixes for latest build
Wed Dec 15 21:51:46 2010 UTC (15 years ago) by greg
Changes since 1.9: +60 -59 lines
Diff to previous 1.9 , to selected 1.1
Additional fixes for MINGW thanks to Guy Vaessen
Fri Jul 9 15:24:44 2010 UTC (15 years, 5 months ago) by greg
Diff to previous 1.8 , to selected 1.1
Removed duplicate installs and added dctimestep
Wed Jun 7 17:52:03 2006 UTC (19 years, 7 months ago) by schorsch
Diff to previous 1.7 , to selected 1.1
Tue Jun 6 22:30:07 2006 UTC (19 years, 7 months ago) by schorsch
Changes since 1.6: +4 -2 lines
Diff to previous 1.6 , to selected 1.1
Added window.cal to SCons
Mon Sep 12 14:44:09 2005 UTC (20 years, 3 months ago) by schorsch
Changes since 1.5: +9 -9 lines
Diff to previous 1.5 , to selected 1.1
Updates to SConscripts for 3R7.
Changes since 1.4: +0 -1 lines
Diff to previous 1.4 , to selected 1.1
Fri Mar 26 21:33:52 2004 UTC (21 years, 9 months ago) by schorsch
Diff to previous 1.3 , to selected 1.1
Lampcolor needs rtio.a.
Sat Nov 15 17:54:06 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 1.2: +5 -2 lines
Diff to previous 1.2 , to selected 1.1
Mon Oct 27 10:35:42 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 1.1: +16 -12 lines
Revision 1.1 - (view) (download) (annotate) - [selected]
Tue Oct 21 19:27:28 2003 UTC (22 years, 2 months ago) by schorsch
