root/radiance/src/cv/SConscript
Revision: 1.11
Committed: Fri Apr 15 21:52:16 2011 UTC (14 years, 8 months ago) by greg
CVS Tags: rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1
Changes since 1.10: +53 -60 lines
SCONS fixes for latest build
1 import os
2
3 Import ('env')
4
5 # math libs
6 mlib = env['RAD_MLIB']
7
8 # compose paths
9 def rbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
10
11 MGFPROGS = (
12 ('3ds2mgf', Split('3ds2mgf.c rayopt3ds.c vect3ds.c')),
13 )
14 for p in MGFPROGS:
15 prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=mlib+['mgf','rtcont'])
16 Default(prog)
17 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
18
19 trans = env.Object(source="trans.c")
20
21 # standard targets
22 PROGS = [
23 ('ies2rad', ['ies2rad.c'], ['rtlamps','rtcolor','rtio','rtpath']+ mlib),
24 ('arch2rad', ['arch2rad.c',trans],['rtcont','rtmem'] + mlib),
25 ('nff2rad', ['nff2rad.c'], []),
26 ('lampcolor', ['lampcolor.c'], ['rtlamps','rtcolor','rtio','rtpath']),
27 ('tmesh2rad', ['tmesh2rad.c'], ['rtscene','rtmath'] + mlib),
28 ('mgf2inv', ['mgf2inv.c'], ['mgf','rtall'] + mlib),
29 ('obj2rad', ['obj2rad.c',trans],
30 ['rtscene','rtargs','rtio','rtcont','rtmem','rtmath','rterror'] + mlib),
31 ('mgf2rad', ['mgf2rad.c'], ['mgf','rtall'] + mlib),
32 ('mgfilt', ['mgfilt.c'], ['mgf','rtall'] + mlib),
33 ('rad2mgf', ['rad2mgf.c'],
34 ['rtproc', 'rtpath', # for win_popen()
35 'rtscene','rtio','rtcolor','rtcont','rtmem','rterror'] + mlib),
36 ]
37 for p in PROGS:
38 prog = env.Program(target=rbin(p[0]), source=p[1], LIBS=p[2])
39 Default(prog)
40 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
41
42 # meta targets
43 prog = env.Program(target=rbin('mgf2meta'), source=['mgf2meta.c'],
44 CPPPATH=env.get('CPPPATH', []) + [os.path.join('#src','meta')],
45 LIBS=['meta','mgf','rtall'] + mlib)
46 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
47
48 LIBFILES = Split('source.cal tilt.cal window.cal')
49 env.Append(RAD_RLIBINSTALL=env.Install(env['RAD_RLIBDIR'], LIBFILES))
50
51 if os.name == 'posix':
52 for s in Split('''optics2rad'''):
53 Default(env.InstallCsh(rbin(s), s + '.csh'))
