root/radiance/src/cv/Rmakefile
Revision: 2.15
Committed: Fri Jan 19 09:47:34 1996 UTC (29 years, 9 months ago) by greg
1 #
2 # SCCSid "$SunId$ LBL"
3 # Makefile for conversion programs
4 #
5
6 OPT = -O
7
8 MACH = -DBSD
9
10 CFLAGS = $(OPT) $(MACH) -I../common -L../lib
11
12 CC = cc
13
14 MLIB = -lm
15
16 INSTDIR = /usr/local/bin
17
18 LIBDIR = /usr/local/lib/ray
19
20 PROGS = thf2rad ies2rad arch2rad nff2rad lampcolor tmesh2rad obj2rad \
21 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv
22
23 LIBFILES = source.cal tilt.cal lamp.tab tmesh.cal
24
25 all: $(PROGS)
26
27 install: $(PROGS) $(LIBFILES)
28 cp $(PROGS) $(INSTDIR)
29 cd $(LIBDIR) ; rm -f $(LIBFILES)
30 cp $(LIBFILES) $(LIBDIR)
31
32 clean:
33 set nonomatch; rm -f $(PROGS) *.o core
34 cd mgflib ; make clean
35
36 thf2rad: thf2rad.o
37 $(CC) $(CFLAGS) -o thf2rad thf2rad.o
38
39 ies2rad: ies2rad.o
40 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrt -lm
41
42 arch2rad: arch2rad.o trans.o
43 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrt
44
45 nff2rad: nff2rad.o
46 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
47
48 lampcolor: lampcolor.o
49 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrt
50
51 tmesh2rad: tmesh2rad.o tmesh.o
52 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o tmesh.o -lrt $(MLIB)
53
54 obj2rad: obj2rad.o trans.o tmesh.o
55 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o tmesh.o -lrt $(MLIB)
56
57 mgf2rad: MGF_LIB mgf2rad.o tmesh.o
58 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o tmesh.o -lmgf -lrt $(MLIB)
59
60 rad2mgf: rad2mgf.o
61 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrt $(MLIB)
62
63 mgf2meta: MGF_LIB mgf2meta.o
64 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrt $(MLIB)
65
66 mgfilt:
67 cd mgflib ; rm -f mgfilt ; \
68 make mgfilt CC=$(CC) \
69 CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \
70 mv mgfilt ..
71
72 mgf2inv:
73 cd mgflib ; rm -f mgf2inv ; \
74 make mgf2inv CC=$(CC) \
75 CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \
76 mv mgf2inv ..
77
78 MGF_LIB:
79 cd mgflib ; rm -f libmgf.a ; \
80 make libmgf.a CC=$(CC) \
81 CFLAGS="$(OPT) $(MACH) '-DMEM_PTR=char *' -DNOPROTO" ; \
82 cp libmgf.a ../../lib
83
84 mgf2rad.o: mgflib/parser.h tmesh.h ../common/color.h
85 $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2rad.c
86
87 mgf2meta.o: mgflib/parser.h
88 $(CC) $(CFLAGS) '-DMEM_PTR=char *' -DNOPROTO -c mgf2meta.c
89
90 arch2rad.o trans.o: trans.h
91
92 ies2rad.o lampcolor.o: ../common/color.h
93
94 ies2rad.o: ../common/paths.h
95
96 obj2rad.o tmesh2rad.o: tmesh.h \
97 ../common/standard.h ../common/mat4.h ../common/fvect.h
98
99 obj2rad.o: trans.h
100
101 tmesh.o: tmesh.h ../common/fvect.h
102
103 rad2mgf.o: ../common/fvect.h ../common/object.h ../common/color.h \
104 ../common/lookup.h
