root/radiance/src/cv/Rmakefile
Revision: 2.60
Committed: Wed May 21 17:23:07 2025 UTC (4 months, 4 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.59: +9 -2 lines
feat(bsdfpeaks): Added new utility to find and measure peaks in BSDFs
1 # RCSid $Id: Rmakefile,v 2.59 2024/02/26 23:43:35 greg Exp $
2 #
3 # Makefile for conversion programs
4 #
5
6 OPT = -O
7
8 MACH = -DBSD
9
10 CFLAGS = -I../common -L../lib $(OPT) $(MACH)
11 CXXFLAGS = $(CFLAGS)
12 METACFLAGS = -I../meta
13
14 CC = cc
15 CXX = c++
16
17 MLIB = -lm
18
19 INSTDIR = /usr/local/bin
20
21 LIBDIR = /usr/local/lib/ray
22
23 PROGS = ies2rad nff2rad lampcolor tmesh2rad obj2rad robjutil \
24 mgf2rad rad2mgf mgf2meta mgfilt mgf2inv 3ds2mgf \
25 bsdfquery bsdfpeaks checkBSDF \
26 pabopto2xyz pabopto2bsdf bsdf2ttree bsdf2klems pkgBSDF epw2wea bsdf2rad
27
28 LIBFILES = source.cal tilt.cal lamp.tab window.cal bsdf2rad.cal
29
30 all: $(PROGS)
31
32 install: $(PROGS) $(LIBFILES) optics2rad.csh
33 cp $(PROGS) $(INSTDIR)
34 cp optics2rad.csh $(INSTDIR)/optics2rad
35 cp iso2klems.pl $(INSTDIR)/iso2klems
36 chmod 755 $(INSTDIR)/optics2rad $(INSTDIR)/iso2klems
37 cd $(LIBDIR) && rm -f $(LIBFILES)
38 cp $(LIBFILES) $(LIBDIR)
39
40 clean:
41 set nonomatch; rm -f $(PROGS) *.o
42
43 ies2rad: ies2rad.o
44 $(CC) $(CFLAGS) -o ies2rad ies2rad.o -lrtrad $(MLIB)
45
46 arch2rad: arch2rad.o trans.o
47 $(CC) $(CFLAGS) -o arch2rad arch2rad.o trans.o -lrtrad
48
49 nff2rad: nff2rad.o
50 $(CC) $(CFLAGS) -o nff2rad nff2rad.o
51
52 lampcolor: lampcolor.o
53 $(CC) $(CFLAGS) -o lampcolor lampcolor.o -lrtrad
54
55 tmesh2rad: tmesh2rad.o
56 $(CC) $(CFLAGS) -o tmesh2rad tmesh2rad.o -lrtrad $(MLIB)
57
58 obj2rad: obj2rad.o trans.o
59 $(CC) $(CFLAGS) -o obj2rad obj2rad.o trans.o -lrtrad $(MLIB)
60
61 mgf2rad: mgf2rad.o
62 $(CC) $(CFLAGS) -o mgf2rad mgf2rad.o -lmgf -lrtrad $(MLIB)
63
64 rad2mgf: rad2mgf.o
65 $(CC) $(CFLAGS) -o rad2mgf rad2mgf.o -lrtrad $(MLIB)
66
67 mgf2meta: mgf2meta.o
68 $(CC) $(CFLAGS) -o mgf2meta mgf2meta.o -lmgf -lmeta -lrtrad $(MLIB)
69
70 mgfilt: mgfilt.o
71 $(CC) $(CFLAGS) -o mgfilt mgfilt.o -lmgf -lrtrad $(MLIB)
72
73 mgf2inv: mgf2inv.o
74 $(CC) $(CFLAGS) -o mgf2inv mgf2inv.o -lmgf -lrtrad $(MLIB)
75
76 3ds2mgf: 3ds2mgf.o rayopt3ds.o vect3ds.o
77 $(CC) $(CFLAGS) -o 3ds2mgf 3ds2mgf.o rayopt3ds.o vect3ds.o \
78 -lmgf -lrtrad $(MLIB)
79
80 pabopto2xyz: pabopto2xyz.o
81 $(CXX) $(CXXFLAGS) -o pabopto2xyz pabopto2xyz.o \
82 -lrtrad $(MLIB)
83
84 pabopto2bsdf: pabopto2bsdf.o bsdfrep.o bsdfrbf.o bsdfmesh.o bsdftrans.o
85 $(CXX) $(CXXFLAGS) -o pabopto2bsdf pabopto2bsdf.o bsdfrep.o \
86 bsdfrbf.o bsdfmesh.o bsdftrans.o -lrtrad $(MLIB)
87
88 pabopto2rad: pabopto2rad.o bsdfrep.o bsdfrbf.o
89 $(CC) $(CFLAGS) -o pabopto2rad pabopto2rad.o bsdfrep.o \
90 bsdfrbf.o -lrtrad $(MLIB)
91
92 pabopto2rad.o: pabopto2bsdf.c bsdfrep.h
93 $(CC) $(CFLAGS) -c -DTEST_MAIN -o pabopto2rad.o pabopto2bsdf.c
94
95 bsdf2rad: bsdf2rad.o bsdfrep.o bsdfinterp.o
96 $(CC) $(CFLAGS) -o bsdf2rad bsdf2rad.o bsdfrep.o bsdfinterp.o \
97 -lrtrad $(MLIB)
98
99 bsdf2rado: bsdf2rado.o bsdfrep.o bsdfinterp.o
100 $(CC) $(CFLAGS) -o bsdf2rado bsdf2rado.o bsdfrep.o bsdfinterp.o \
101 -lrtrad $(MLIB)
102
103 bsdfquery: bsdfquery.o bsdfrep.o bsdfinterp.o
104 $(CC) $(CFLAGS) -o bsdfquery bsdfquery.o bsdfrep.o bsdfinterp.o \
105 -lrtrad $(MLIB)
106
107 bsdfpeaks: bsdfpeaks.o bsdfrep.o bsdfinterp.o
108 $(CC) $(CFLAGS) -o bsdfpeaks bsdfpeaks.o bsdfrep.o bsdfinterp.o \
109 -lrtrad $(MLIB)
110
111 bsdf2ttree: bsdf2ttree.o bsdfrep.o bsdfinterp.o
112 $(CC) $(CFLAGS) -o bsdf2ttree bsdf2ttree.o bsdfrep.o bsdfinterp.o \
113 -lrtrad $(MLIB)
114
115 bsdf2klems: bsdf2klems.o bsdfrep.o bsdfinterp.o
116 $(CC) $(CFLAGS) -o bsdf2klems bsdf2klems.o bsdfrep.o bsdfinterp.o \
117 -lrtrad $(MLIB)
118
119 pkgBSDF: pkgBSDF.o
120 $(CC) $(CFLAGS) -o pkgBSDF pkgBSDF.o -lrtrad $(MLIB)
121
122 checkBSDF: checkBSDF.o
123 $(CC) $(CFLAGS) -o checkBSDF checkBSDF.o -lrtrad $(MLIB)
124
125 epw2wea: epw2wea.o
126 $(CC) $(CFLAGS) -o epw2wea epw2wea.o
127
128 robjutil: robjutil.o
129 $(CC) $(CFLAGS) -o robjutil robjutil.o \
130 -lwfobj -lrtrad $(MLIB)
131
132 mgf2rad.o: mgf2rad.c ../common/mgf_parser.h ../common/tmesh.h \
133 ../common/color.h
134 $(CC) $(CFLAGS) -c mgf2rad.c
135
136 mgf2meta.o: mgf2meta.c ../common/mgf_parser.h
137 $(CC) $(CFLAGS) $(METACFLAGS) -c mgf2meta.c
138
139 arch2rad.o trans.o: trans.h
140
141 ies2rad.o lampcolor.o: ../common/color.h
142
143 ies2rad.o: ../common/paths.h
144
145 obj2rad.o tmesh2rad.o: ../common/tmesh.h \
146 ../common/standard.h ../common/rtmisc.h ../common/rtio.h \
147 ../common/rtmath.h ../common/rterror.h ../common/mat4.h \
148 ../common/fvect.h
149
150 obj2rad.o: trans.h
151
152 rad2mgf.o: ../common/standard.h ../common/mat4.h ../common/fvect.h \
153 ../common/object.h ../common/color.h ../common/lookup.h
154
155 mgfilt.o: ../common/mgf_parser.h ../common/ccolor.h
156
157 mgf2inv.o: ../common/mgf_parser.h ../common/ccolor.h
158
159 3ds2mgf.o rayopt3ds.o: rayopt3ds.h
160
161 3ds2mgf.o rayopt3ds.o vect3ds.o: vect3ds.h
162
163 checkBSDF.o pkgBSDF.o: ../common/bsdf.h ../common/fvect.h \
164 ../common/ccolor.h ../common/paths.h
165
166 bsdf2ttree.o bsdfinterp.o bsdfmesh.o bsdfrbf.o bsdfrep.o bsdf2rad.o bsdftrans.o \
167 pabopto2bsdf.o: bsdfrep.h ../common/bsdf.h ../common/fvect.h ../common/ccolor.h
168
169 bsdf2ttree.o pabopto2bsdf.o: ../common/platform.h
170
171 bsdfrep.o: ../common/resolu.h ../common/rtio.h
172
173 pabopto2bsdf.o: ../common/resolu.h
174
175 bsdf2rad.o bsdf2ttree.o: ../common/rtprocess.h
176
177 bsdf2klems.o bsdf2ttree.o mgf2meta.o: ../common/random.h ../common/calcomp.h
178
179 bsdftrans.o: transportSimplex.h
180
181 bsdfquery.o: ../common/rtmath.h ../common/rtio.h bsdfrep.h
182
183 bsdfpeaks.o: bsdfrep.h
184
185 checkBSDF.o: ../common/rtio.h ../common/bsdf_m.h ../common/bsdf_t.h
186
187 robjutil.o: ../common/objutil.h
