root/radiance/src/common/vars.h
Revision: 2.3
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.2: +93 -8 lines
1 /* RCSid: $Id$ */
2 /*
3 * Header for programs that load variable files.
4 */
5
6 /* ====================================================================
7 * The Radiance Software License, Version 1.0
8 *
9 * Copyright (c) 1990 - 2002 The Regents of the University of California,
10 * through Lawrence Berkeley National Laboratory. All rights reserved.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 *
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 *
19 * 2. Redistributions in binary form must reproduce the above copyright
20 * notice, this list of conditions and the following disclaimer in
21 * the documentation and/or other materials provided with the
22 * distribution.
23 *
24 * 3. The end-user documentation included with the redistribution,
25 * if any, must include the following acknowledgment:
26 * "This product includes Radiance software
27 * (http://radsite.lbl.gov/)
28 * developed by the Lawrence Berkeley National Laboratory
29 * (http://www.lbl.gov/)."
30 * Alternately, this acknowledgment may appear in the software itself,
31 * if and wherever such third-party acknowledgments normally appear.
32 *
33 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
34 * and "The Regents of the University of California" must
35 * not be used to endorse or promote products derived from this
36 * software without prior written permission. For written
37 * permission, please contact [email protected].
38 *
39 * 5. Products derived from this software may not be called "Radiance",
40 * nor may "Radiance" appear in their name, without prior written
41 * permission of Lawrence Berkeley National Laboratory.
42 *
43 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
44 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
45 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
46 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
47 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
50 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
51 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
52 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
53 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
54 * SUCH DAMAGE.
55 * ====================================================================
56 *
57 * This software consists of voluntary contributions made by many
58 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
59 * information on Lawrence Berkeley National Laboratory, please see
60 * <http://www.lbl.gov/>.
61 */
62
63 typedef struct {
64 char *name; /* variable name */
65 short nick; /* # characters required for nickname */
66 short nass; /* # assignments made */
67 char *value; /* assigned value(s) */
68 void (*fixval)(); /* assignment checking function */
69 } VARIABLE; /* a variable-value pair */
70
71 /**** The following variables should be declared by calling program ****/
72
73 extern int NVARS; /* total number of variables */
74
75 extern VARIABLE vv[]; /* variable-value pairs */
76
77 extern char *progname; /* global argv[0] from main */
78
79 extern int nowarn; /* global boolean to turn warnings off */
80
81 /**** The rest is declared in loadvars.c ****/
82
83 extern VARIABLE *matchvar();
84 extern char *nvalue();
85
86 #define UPPER(c) ((c)&~0x20) /* ASCII trick */
87
88 #define vnam(vc) (vv[vc].name)
89 #define vdef(vc) (vv[vc].nass)
90 #define vval(vc) (vv[vc].value)
91 #define vint(vc) atoi(vval(vc))
92 #define vflt(vc) atof(vval(vc))
93 #define vlet(vc) UPPER(vval(vc)[0])
94 #define vscale vlet
95 #define vbool(vc) (vlet(vc)=='T')
96
97 #define HIGH 'H'
98 #define MEDIUM 'M'
99 #define LOW 'L'
100
101 #ifdef NOPROTO
102
103 extern void loadvars();
104 extern int setvariable();
105 extern VARIABLE *matchvar();
106 extern char *nvalue();
107 extern void checkvalues();
108 extern void onevalue();
109 extern void catvalues();
110 extern int badmatch();
111 extern void boolvalue();
112 extern void qualvalue();
113 extern void intvalue();
114 extern void fltvalue();
115 extern void printvars();
116
117 #else
118
119 extern void loadvars(char *rfname);
120 extern int setvariable(char *ass, VARIABLE *(*mv)());
121 extern VARIABLE *matchvar(char *nam);
122 extern char *nvalue(int vn, int n);
123 extern void checkvalues(void);
124 extern void onevalue(VARIABLE *vp);
125 extern void catvalues(VARIABLE *vp);
126 extern int badmatch(char *tv, char *cv);
127 extern void boolvalue(VARIABLE *vp);
128 extern void qualvalue(VARIABLE *vp);
129 extern void intvalue(VARIABLE *vp);
130 extern void fltvalue(VARIABLE *vp);
131 extern void printvars(FILE *fp);
132
133 #endif
