root/radiance/src/common/triangulate.c
Revision: 2.7
Committed: Mon Apr 19 20:37:04 2021 UTC (4 years, 5 months ago) by greg
CVS Tags: rad5R4, rad6R0, HEAD
fix: Repaired issue in last change with colinear vertices
2 static const char RCSid[] = "$Id: triangulate.c,v 2.6 2021/04/19 19:40:03 greg Exp $";
5 * triangulate.c
6 *
7 * Adapted by Greg Ward on 1/23/14.
8 * Fixes for polygons with seams/holes and co-linear vertices added
9 * by Nathaniel Jones on 12/21/16.
10 * Copyright 2016 Anyhere Software. All rights reserved.
11 *
12 */
13
14 /* COTD Entry submitted by John W. Ratcliff [[email protected]]
15
16 // ** THIS IS A CODE SNIPPET WHICH WILL EFFICIEINTLY TRIANGULATE ANY
17 // ** POLYGON/CONTOUR (without holes) AS A STATIC CLASS. THIS SNIPPET
18 // ** IS COMPRISED OF 3 FILES, TRIANGULATE.H, THE HEADER FILE FOR THE
19 // ** TRIANGULATE BASE CLASS, TRIANGULATE.CPP, THE IMPLEMENTATION OF
20 // ** THE TRIANGULATE BASE CLASS, AND TEST.CPP, A SMALL TEST PROGRAM
21 // ** DEMONSTRATING THE USAGE OF THE TRIANGULATOR. THE TRIANGULATE
22 // ** BASE CLASS ALSO PROVIDES TWO USEFUL HELPER METHODS, ONE WHICH
23 // ** COMPUTES THE AREA OF A POLYGON, AND ANOTHER WHICH DOES AN EFFICENT
24 // ** POINT IN A TRIANGLE TEST.
25 // ** SUBMITTED BY JOHN W. RATCLIFF ([email protected]) July 22, 2000
26 */
27
28 #include <stdio.h>
29 #include <stdlib.h>
30 #include "triangulate.h"
31
32 #ifndef true
33 #define true 1
34 #define false 0
35 #endif
36
37 #define EPSILON 0.0000000001
38
39 static int
40 polySnip(const Vert2_list *contour, int u, int v, int w, int n, int *V)
41 {
42 int p;
43 double Ax, Ay, Bx, By, Cx, Cy, Px, Py, cross;
44
45 Ax = contour->v[V[u]].mX;
46 Ay = contour->v[V[u]].mY;
47
48 Bx = contour->v[V[v]].mX;
49 By = contour->v[V[v]].mY;
50
51 Cx = contour->v[V[w]].mX;
52 Cy = contour->v[V[w]].mY;
53
54 cross = ((Bx - Ax)*(Cy - Ay)) - ((By - Ay)*(Cx - Ax));
55 if (cross < EPSILON)
56 return cross > -EPSILON ? -1 : false; /* Negative if colinear points */
57
58 for (p=0;p<n;p++)
59 {
60 if( (p == u) | (p == v) | (p == w) ) continue;
61 Px = contour->v[V[p]].mX;
62 Py = contour->v[V[p]].mY;
63 if ((Px == Ax) & (Py == Ay) || (Px == Bx) & (Py == By) ||
64 (Px == Cx) & (Py == Cy)) continue; /* Handle donuts */
65 if (insideTriangle(Ax,Ay,Bx,By,Cx,Cy,Px,Py)) return false;
66 }
67
68 return true;
69 }
70
71 Vert2_list *
72 polyAlloc(int nv)
73 {
74 Vert2_list *pnew;
75
76 if (nv < 3) return NULL;
77
78 pnew = (Vert2_list *)malloc(sizeof(Vert2_list) + sizeof(Vert2)*(nv-3));
79 if (pnew == NULL) return NULL;
80 pnew->nv = nv;
81 pnew->p = NULL;
82
83 return pnew;
84 }
85
86 /*
87 Area is positive if vertices listed counter-clockwise, negative if clockwise
88 */
89 double
90 polyArea(const Vert2_list *contour)
91 {
92 double A=0.0;
93 int p, q;
94
95 for(p = contour->nv-1, q = 0; q < contour->nv; p=q++)
96 {
97 A += contour->v[p].mX*contour->v[q].mY - contour->v[q].mX*contour->v[p].mY;
98 }
99 return A*0.5;
100 }
101
102 /*
103 InsideTriangle decides if a point P is Inside of the triangle
104 defined by A, B, C.
105 */
106 int
107 insideTriangle(double Ax, double Ay,
108 double Bx, double By,
109 double Cx, double Cy,
110 double Px, double Py)
111 {
112 double ax, ay, bx, by, cx, cy, apx, apy, bpx, bpy, cpx, cpy;
113 double cCROSSap, bCROSScp, aCROSSbp;
114
115 ax = Cx - Bx; ay = Cy - By;
116 bx = Ax - Cx; by = Ay - Cy;
117 cx = Bx - Ax; cy = By - Ay;
118 apx= Px - Ax; apy= Py - Ay;
119 bpx= Px - Bx; bpy= Py - By;
120 cpx= Px - Cx; cpy= Py - Cy;
121
122 aCROSSbp = ax*bpy - ay*bpx;
123 cCROSSap = cx*apy - cy*apx;
124 bCROSScp = bx*cpy - by*cpx;
125
126 return ((aCROSSbp >= 0.0) & (bCROSScp >= 0.0) & (cCROSSap >= 0.0));
127 };
128
129 int
130 polyTriangulate(const Vert2_list *contour, tri_out_t *cb)
131 {
132 /* allocate and initialize list of Vertices in polygon */
133
134 int nv, u, v, w, count, result;
135 int *V;
136
137 if ( contour->nv < 3 ) return false;
138
139 V = (int *)malloc(sizeof(int)*contour->nv);
140 if (V == NULL) return false;
141
142 /* we want a counter-clockwise polygon in V */
143
144 if ( polyArea(contour) > 0.0 )
145 for (v=0; v<contour->nv; v++) V[v] = v;
146 else
147 for (v=0; v<contour->nv; v++) V[v] = (contour->nv-1)-v;
148
149 nv = contour->nv;
150
151 /* remove nv-2 Vertices, creating 1 triangle every time */
152 count = 2*nv; /* error detection */
153
154 v = nv-1;
155 while (nv > 2)
156 {
157 /* if we loop, it is probably a non-simple polygon */
158 if (count-- <= 0)
159 {
160 /* Triangulate: ERROR - probable bad polygon */
161 free(V);
162 return false;
163 }
164
165 /* three consecutive vertices in current polygon, <u,v,w> */
166 u = v ; u *= (nv > u); /* previous */
167 v = u+1; v *= (nv > v); /* new v */
168 w = v+1; w *= (nv > w); /* next */
169
170 result = polySnip(contour, u, v, w, nv, V);
171 if (result > 0) /* successfully found a triangle */
172 {
173 /* output Triangle */
174 if (!(*cb)(contour, V[u], V[v], V[w])) {
175 free(V);
176 return false;
177 }
178 }
179 if (result) /* successfully found a triangle or three consecutive colinear points */
180 {
181 int s,t;
182
183 /* remove v from remaining polygon */
184 for(s=v,t=v+1;t<nv;s++,t++) V[s] = V[t]; nv--;
185
186 /* reset error detection counter */
187 count = 2*nv;
188 }
189 }
190
191 free(V);
192
193 return true;
194 }
