root/radiance/src/common/tonemap.h
Sat May 31 19:38:36 2008 UTC (17 years, 4 months ago) by greg
Diff to previous 3.22
Eliminated tifftypes.h in favor of tiff.h throughout
Wed May 10 15:21:58 2006 UTC (19 years, 5 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.21: +18 -6 lines
Diff to previous 3.21
Made COLOR conversion faster with lookup and fixed scale bug in tmCvGrays()
Tue Nov 15 06:53:00 2005 UTC (19 years, 11 months ago) by greg
Changes since 3.20: +6 -1 lines
Diff to previous 3.20
Added tmCvLuminance() call
Mon Nov 14 22:18:18 2005 UTC (19 years, 11 months ago) by greg
Changes since 3.19: +3 -3 lines
Diff to previous 3.19
Fri Jan 7 22:05:30 2005 UTC (20 years, 9 months ago) by greg
Changes since 3.18: +4 -2 lines
Diff to previous 3.18
Added client data pointer to tmSetSpace() call
Fri Jan 7 21:41:06 2005 UTC (20 years, 9 months ago) by greg
Changes since 3.17: +5 -3 lines
Diff to previous 3.17
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (20 years, 9 months ago) by greg
Changes since 3.16: +40 -59 lines
Diff to previous 3.16
Mon Jul 14 22:23:59 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.15: +4 -3 lines
Diff to previous 3.15
Mon Jul 14 04:56:54 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.14: +28 -1 lines
Diff to previous 3.14
Fri Jun 27 06:53:22 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.13: +1 -4 lines
Diff to previous 3.13
Fri Jun 6 16:38:47 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 3.12: +8 -24 lines
Diff to previous 3.12
*** empty log message ***
Tue Feb 25 02:47:22 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.11: +2 -57 lines
Diff to previous 3.11
Sat Feb 22 02:07:22 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.10: +173 -82 lines
Diff to previous 3.10
Sun Dec 20 16:38:29 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.9: +2 -0 lines
Diff to previous 3.9
added TM_NOBRT macro for undefined brightnesses
Mon Oct 5 16:49:52 1998 UTC (27 years ago) by gwlarson
Changes since 3.8: +2 -2 lines
Diff to previous 3.8
corrected comment about pixel ordering for tmLoadPicture and tmMapPicture
Mon Aug 17 17:58:47 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.7: +5 -4 lines
Diff to previous 3.7
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Mon Nov 17 13:54:35 1997 UTC (27 years, 11 months ago) by gregl
Changes since 3.6: +5 -2 lines
Diff to previous 3.6
changed behavior so that tmClearHisto() and tmAddHisto() do not
void computed tone mapping, even if brightness limits are exceeded
Tue Jul 29 11:54:45 1997 UTC (28 years, 2 months ago) by gregl
Changes since 3.5: +2 -0 lines
Diff to previous 3.5
added tmLastError and tmLastFunction globals (set by tmErrorReturn)
Mon Apr 21 15:23:42 1997 UTC (28 years, 6 months ago) by greg
Changes since 3.4: +5 -1 lines
Diff to previous 3.4
small comment changes
Fri Apr 18 13:59:48 1997 UTC (28 years, 6 months ago) by greg
Changes since 3.3: +48 -8 lines
Diff to previous 3.3
added notion of conversion packages with private data
Wed Apr 16 20:28:07 1997 UTC (28 years, 6 months ago) by greg
Changes since 3.2: +11 -2 lines
minor bug fixes and added tmDup()
Tue Apr 15 20:04:41 1997 UTC (28 years, 6 months ago) by greg
changed TM_F_NOERRS to TM_F_NOSTDERR
skipped histogram clipping for TM_F_LINEAR in tmComputeMapping()
Tue Apr 15 16:53:03 1997 UTC (28 years, 6 months ago) by greg
