root/radiance/src/common/tonemap.c
Revision: 3.34
Committed: Mon Feb 9 20:48:08 2009 UTC (16 years, 8 months ago) by greg
Changes since 3.33: +2 -1 lines
Eliminated redefinition of malloc(3)
2 static const char RCSid[] = "$Id: tonemap.c,v 3.33 2009/02/09 20:23:51 greg Exp $";
5 * Tone mapping functions.
6 * See tonemap.h for detailed function descriptions.
7 * Added von Kries white-balance calculations 10/01 (GW).
8 *
9 * Externals declared in tonemap.h
10 */
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15 #include <stdlib.h>
16 #include <math.h>
17 #include "tmprivat.h"
18 #include "tmerrmsg.h"
19
20 #define exp10(x) exp(M_LN10*(x))
21
22 /* our list of conversion packages */
23 struct tmPackage *tmPkg[TM_MAXPKG];
24 int tmNumPkgs = 0; /* number of registered packages */
25
26 /* luminance->brightness lookup */
27 static TMbright *tmFloat2BrtLUT = NULL;
28
29 #define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15]
30
31
32 TMstruct *
33 tmInit( /* initialize new tone mapping */
34 int flags,
35 RGBPRIMP monpri,
36 double gamval
37 )
38 {
39 COLORMAT cmat;
40 TMstruct *tmnew;
41 int i;
42 /* allocate structure */
43 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
44 if (tmnew == NULL)
45 return(NULL);
46
47 tmnew->flags = flags & ~TM_F_UNIMPL;
48 if (tmnew->flags & TM_F_BW)
49 tmnew->flags &= ~TM_F_MESOPIC;
50 /* set monitor transform */
51 if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
52 tmnew->monpri = stdprims;
53 tmnew->clf[RED] = rgb2xyzmat[1][0];
54 tmnew->clf[GRN] = rgb2xyzmat[1][1];
55 tmnew->clf[BLU] = rgb2xyzmat[1][2];
56 } else {
57 comprgb2xyzmat(cmat, tmnew->monpri=monpri);
58 tmnew->clf[RED] = cmat[1][0];
59 tmnew->clf[GRN] = cmat[1][1];
60 tmnew->clf[BLU] = cmat[1][2];
61 }
62 /* set gamma value */
63 if (gamval < MINGAM)
64 tmnew->mongam = DEFGAM;
65 else
66 tmnew->mongam = gamval;
67 /* set color divisors */
68 for (i = 0; i < 3; i++)
69 tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam);
70
71 /* set input transform */
72 tmnew->inppri = tmnew->monpri;
73 tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
74 tmnew->inpsf = WHTEFFICACY;
75 tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
76 tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
77 tmnew->inpdat = NULL;
78 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
79 tmnew->histo = NULL;
80 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
81 tmnew->lumap = NULL;
82 /* zero private data */
83 for (i = TM_MAXPKG; i--; )
84 tmnew->pd[i] = NULL;
85 tmnew->lastError = TM_E_OK;
86 tmnew->lastFunc = "NoErr";
87 /* return new TMstruct */
88 return(tmnew);
89 }
90
91
92 int
93 tmSetSpace( /* set input color space for conversions */
94 TMstruct *tms,
95 RGBPRIMP pri,
96 double sf,
97 MEM_PTR dat
98 )
99 {
100 static const char funcName[] = "tmSetSpace";
101 int i, j;
102 /* error check */
103 if (tms == NULL)
104 returnErr(TM_E_TMINVAL);
105 if (sf <= 1e-12)
106 returnErr(TM_E_ILLEGAL);
107 /* check if no change */
108 if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat)
109 returnOK;
110 tms->inppri = pri; /* let's set it */
111 tms->inpsf = sf;
112 tms->inpdat = dat;
113
114 if (tms->flags & TM_F_BW) { /* color doesn't matter */
115 tms->monpri = tms->inppri; /* eliminate xform */
116 if (tms->inppri == TM_XYZPRIM) {
117 tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
118 tms->clf[CIEY] = 1.;
119 } else {
120 comprgb2xyzmat(tms->cmat, tms->monpri);
121 tms->clf[RED] = tms->cmat[1][0];
122 tms->clf[GRN] = tms->cmat[1][1];
123 tms->clf[BLU] = tms->cmat[1][2];
124 }
125 tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] =
126 tms->inpsf;
127 tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
128 tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
129
130 } else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */
131 compxyz2rgbWBmat(tms->cmat, tms->monpri);
132
133 else { /* input is RGB */
134 if (tms->inppri != tms->monpri &&
135 PRIMEQ(tms->inppri, tms->monpri))
136 tms->inppri = tms->monpri; /* no xform */
137 comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri);
138 }
139 for (i = 0; i < 3; i++)
140 for (j = 0; j < 3; j++)
141 tms->cmat[i][j] *= tms->inpsf;
142 /* set color divisors */
143 for (i = 0; i < 3; i++)
144 if (tms->clf[i] > .001)
145 tms->cdiv[i] =
146 256.*pow(tms->clf[i], 1./tms->mongam);
147 else
148 tms->cdiv[i] = 1;
149 /* notify packages */
150 for (i = tmNumPkgs; i--; )
151 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
152 (*tmPkg[i]->NewSpace)(tms);
153 returnOK;
154 }
155
156
157 void
158 tmClearHisto( /* clear current histogram */
159 TMstruct *tms
160 )
161 {
162 if (tms == NULL || tms->histo == NULL)
163 return;
164 free((MEM_PTR)tms->histo);
165 tms->histo = NULL;
166 }
167
168
169 TMbright
170 tmCvLuminance( /* convert a single luminance */
171 double lum
172 )
173 {
174 double d;
175
176 #ifdef isfinite
177 if (!isfinite(lum) || lum <= TM_NOLUM)
178 #else
179 if (lum <= TM_NOLUM)
180 #endif
181 return(TM_NOBRT);
182 d = TM_BRTSCALE*log(lum);
183 if (d > 0.)
184 return((TMbright)(d+.5));
185 return((TMbright)(d-.5));
186 }
187
188
189 int
190 tmCvLums( /* convert luminances using lookup */
191 TMbright *ls,
192 float *scan,
193 int len
194 )
195 {
196 if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */
197 int32 i;
198 tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000);
199 if (tmFloat2BrtLUT == NULL)
200 return(TM_E_NOMEM);
201 for (i = 0; i < 0x10000; i++) {
202 int32 l = (i<<1 | 1) << 14;
203 #ifndef isfinite
204 if ((l & 0x7f800000) == 0x7f800000)
205 tmFloat2BrtLUT[i] = TM_NOBRT;
206 else
207 #endif
208 tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l);
209 }
210 }
211 if (len <= 0)
212 return(TM_E_OK);
213 if ((ls == NULL) | (scan == NULL))
214 return(TM_E_ILLEGAL);
215 while (len--) {
216 if (*scan <= TM_NOLUM) {
217 *ls++ = TM_NOBRT;
218 ++scan;
219 continue;
220 }
221 *ls++ = tmCvLumLUfp(scan++);
222 }
223 return(TM_E_OK);
224 }
225
226
227 int
228 tmCvGrays( /* convert float gray values */
229 TMstruct *tms,
230 TMbright *ls,
231 float *scan,
232 int len
233 )
234 {
235 static const char funcName[] = "tmCvGrays";
236 int i;
237
238 if (tms == NULL)
239 returnErr(TM_E_TMINVAL);
240 if ((ls == NULL) | (scan == NULL) | (len < 0))
241 returnErr(TM_E_ILLEGAL);
242 if (tmFloat2BrtLUT == NULL) /* initialize */
243 tmCvLums(NULL, NULL, 0);
244 for (i = len; i--; ) {
245 float lum = tms->inpsf * scan[i];
246 if (lum <= TM_NOLUM)
247 ls[i] = TM_NOBRT;
248 else
249 ls[i] = tmCvLumLUfp(&lum);
250 }
251 returnOK;
252 }
253
254
255 int
256 tmCvColors( /* convert float colors */
257 TMstruct *tms,
258 TMbright *ls,
259 BYTE *cs,
260 COLOR *scan,
261 int len
262 )
263 {
264 static const char funcName[] = "tmCvColors";
265 static BYTE gamtab[1024];
266 static double curgam = .0;
267 COLOR cmon;
268 float lum, slum, d;
269 int i;
270
271 if (tms == NULL)
272 returnErr(TM_E_TMINVAL);
273 if ((ls == NULL) | (scan == NULL) | (len < 0))
274 returnErr(TM_E_ILLEGAL);
275 if (tmFloat2BrtLUT == NULL) /* initialize */
276 tmCvLums(NULL, NULL, 0);
277 if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) {
278 curgam = tms->mongam; /* (re)build table */
279 for (i = 1024; i--; )
280 gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
281 }
282 for (i = len; i--; ) {
283 if (tmNeedMatrix(tms)) { /* get monitor RGB */
284 colortrans(cmon, tms->cmat, scan[i]);
285 } else {
286 cmon[RED] = tms->inpsf*scan[i][RED];
287 cmon[GRN] = tms->inpsf*scan[i][GRN];
288 cmon[BLU] = tms->inpsf*scan[i][BLU];
289 }
290 #ifdef isfinite
291 if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f;
292 if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f;
293 if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f;
294 #else
295 if (cmon[RED] < .0f) cmon[RED] = .0f;
296 if (cmon[GRN] < .0f) cmon[GRN] = .0f;
297 if (cmon[BLU] < .0f) cmon[BLU] = .0f;
298 #endif
299 /* world luminance */
300 lum = tms->clf[RED]*cmon[RED] +
301 tms->clf[GRN]*cmon[GRN] +
302 tms->clf[BLU]*cmon[BLU] ;
303 if (lum <= TM_NOLUM) { /* convert brightness */
304 lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM;
305 ls[i] = TM_NOBRT;
306 } else
307 ls[i] = tmCvLumLUfp(&lum);
308 if (cs == TM_NOCHROM) /* no color? */
309 continue;
310 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
311 slum = scotlum(cmon); /* mesopic adj. */
312 if (lum < LMESLOWER) {
313 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
314 } else {
315 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
316 if (tms->flags & TM_F_BW)
317 cmon[RED] = cmon[GRN] =
318 cmon[BLU] = d*lum;
319 else
320 scalecolor(cmon, d);
321 d = (1.f-d)*slum;
322 cmon[RED] += d;
323 cmon[GRN] += d;
324 cmon[BLU] += d;
325 }
326 } else if (tms->flags & TM_F_BW) {
327 cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
328 }
329 d = tms->clf[RED]*cmon[RED]/lum;
330 cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
331 d = tms->clf[GRN]*cmon[GRN]/lum;
332 cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
333 d = tms->clf[BLU]*cmon[BLU]/lum;
334 cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
335 }
336 returnOK;
337 }
338
339
340 int
341 tmAddHisto( /* add values to histogram */
342 TMstruct *tms,
343 TMbright *ls,
344 int len,
345 int wt
346 )
347 {
348 static const char funcName[] = "tmAddHisto";
349 int oldorig=0, oldlen, horig, hlen;
350 int i, j;
351
352 if (tms == NULL)
353 returnErr(TM_E_TMINVAL);
354 if (len < 0)
355 returnErr(TM_E_ILLEGAL);
356 if (len == 0)
357 returnOK;
358 /* first, grow limits */
359 if (tms->histo == NULL) {
360 for (i = len; i-- && ls[i] < MINBRT; )
361 ;
362 if (i < 0)
363 returnOK;
364 tms->hbrmin = tms->hbrmax = ls[i];
365 oldlen = 0;
366 } else {
367 oldorig = HISTI(tms->hbrmin);
368 oldlen = HISTI(tms->hbrmax) + 1 - oldorig;
369 }
370 for (i = len; i--; ) {
371 if ((j = ls[i]) < MINBRT)
372 continue;
373 if (j < tms->hbrmin)
374 tms->hbrmin = j;
375 else if (j > tms->hbrmax)
376 tms->hbrmax = j;
377 }
378 horig = HISTI(tms->hbrmin);
379 hlen = HISTI(tms->hbrmax) + 1 - horig;
380 if (hlen > oldlen) { /* (re)allocate histogram */
381 int *newhist = (int *)calloc(hlen, sizeof(int));
382 if (newhist == NULL)
383 returnErr(TM_E_NOMEM);
384 if (oldlen) { /* copy and free old */
385 for (i = oldlen, j = i+oldorig-horig; i; )
386 newhist[--j] = tms->histo[--i];
387 free((MEM_PTR)tms->histo);
388 }
389 tms->histo = newhist;
390 }
391 if (wt == 0)
392 returnOK;
393 for (i = len; i--; ) /* add in new counts */
394 if (ls[i] >= MINBRT)
395 tms->histo[ HISTI(ls[i]) - horig ] += wt;
396 returnOK;
397 }
398
399
400 static double
401 htcontrs( /* human threshold contrast sensitivity, dL(La) */
402 double La
403 )
404 {
405 double l10La, l10dL;
406 /* formula taken from Ferwerda et al. [SG96] */
407 if (La < 1.148e-4)
408 return(1.38e-3);
409 l10La = log10(La);
410 if (l10La < -1.44) /* rod response regime */
411 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
412 else if (l10La < -.0184)
413 l10dL = l10La - .395;
414 else if (l10La < 1.9) /* cone response regime */
415 l10dL = pow(.249*l10La + .65, 2.7) - .72;
416 else
417 l10dL = l10La - 1.255;
418
419 return(exp10(l10dL));
420 }
421
422
423 int
424 tmFixedMapping( /* compute fixed, linear tone-mapping */
425 TMstruct *tms,
426 double expmult,
427 double gamval
428 )
429 {
430 static const char funcName[] = "tmFixedMapping";
431 double d;
432 int i;
433
434 if (!tmNewMap(tms))
435 returnErr(TM_E_NOMEM);
436 if (expmult <= .0)
437 expmult = 1.;
438 if (gamval < MINGAM)
439 gamval = tms->mongam;
440 d = log(expmult/tms->inpsf);
441 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
442 double val = 256. * exp(
443 ( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) )
444 / gamval);
445 tms->lumap[i] = val >= (double)0xffff ? 0xffff : (int)val;
446 }
447 returnOK;
448 }
449
450
451 int
452 tmComputeMapping( /* compute histogram tone-mapping */
453 TMstruct *tms,
454 double gamval,
455 double Lddyn,
456 double Ldmax
457 )
458 {
459 static const char funcName[] = "tmComputeMapping";
460 int *histo;
461 float *cumf;
462 int brt0, histlen, threshold, ceiling, trimmings;
463 double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld;
464 int32 histot;
465 double sum;
466 double d;
467 int i, j;
468
469 if (tms == NULL || tms->histo == NULL)
470 returnErr(TM_E_TMINVAL);
471 /* check arguments */
472 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
473 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
474 if (gamval < MINGAM) gamval = tms->mongam;
475 /* compute handy values */
476 Ldmin = Ldmax/Lddyn;
477 logLddyn = log(Lddyn);
478 Ldavg = sqrt(Ldmax*Ldmin);
479 i = HISTI(tms->hbrmin);
480 brt0 = HISTV(i);
481 histlen = HISTI(tms->hbrmax) + 1 - i;
482 /* histogram total and mean */
483 histot = 0; sum = 0;
484 j = brt0 + histlen*HISTEP;
485 for (i = histlen; i--; ) {
486 histot += tms->histo[i];
487 sum += (double)(j -= HISTEP) * tms->histo[i];
488 }
489 threshold = histot*0.005 + .5;
490 if (!histot)
491 returnErr(TM_E_TMFAIL);
492 Lwavg = tmLuminance( (double)sum / histot );
493 /* use linear tone mapping? */
494 if (tms->flags & TM_F_LINEAR || threshold < 4 ||
495 tms->hbrmax - tms->hbrmin < TM_BRTSCALE*logLddyn)
496 goto linearmap;
497 /* clamp histogram */
498 histo = (int *)malloc(histlen*sizeof(int));
499 cumf = (float *)malloc((histlen+2)*sizeof(float));
500 if ((histo == NULL) | (cumf == NULL))
501 returnErr(TM_E_NOMEM);
502 cumf[histlen+1] = 1.; /* guard for assignment code */
503 for (i = histlen; i--; ) /* make malleable copy */
504 histo[i] = tms->histo[i];
505 do { /* iterate to solution */
506 sum = 0; /* cumulative probability */
507 for (i = 0; i < histlen; i++) {
508 cumf[i] = (double)sum/histot;
509 sum += histo[i];
510 }
511 cumf[histlen] = 1.;
512 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
513 ((double)histlen*TM_BRTSCALE) / logLddyn;
514 ceiling = Tr + 1.;
515 trimmings = 0; /* clip to envelope */
516 for (i = histlen; i--; ) {
517 if (tms->flags & TM_F_HCONTR) {
518 Lw = tmLuminance(brt0 + i*HISTEP);
519 Ld = Ldmin * exp( logLddyn *
520 .5*(cumf[i]+cumf[i+1]) );
521 ceiling = Tr * (htcontrs(Ld) * Lw) /
522 (htcontrs(Lw) * Ld) + 1.;
523 }
524 if (histo[i] > ceiling) {
525 trimmings += histo[i] - ceiling;
526 histo[i] = ceiling;
527 }
528 }
529 /* check if we're out of data */
530 if ((histot -= trimmings) <= threshold) {
531 free((MEM_PTR)histo);
532 free((MEM_PTR)cumf);
533 goto linearmap;
534 }
535 } while (trimmings > threshold);
536 /* allocate space for mapping */
537 if (!tmNewMap(tms))
538 returnErr(TM_E_NOMEM);
539 /* assign tone-mapping */
540 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
541 j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
542 d -= (double)j;
543 Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
544 d = (Ld - Ldmin)/(Ldmax - Ldmin);
545 tms->lumap[i] = 256.*pow(d, 1./gamval);
546 }
547 free((MEM_PTR)histo); /* clean up and return */
548 free((MEM_PTR)cumf);
549 returnOK;
550 linearmap: /* linear tone-mapping */
551 if (tms->flags & TM_F_HCONTR)
552 d = htcontrs(Ldavg) / htcontrs(Lwavg);
553 else
554 d = Ldavg / Lwavg;
555 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval));
556 }
557
558
559 int
560 tmMapPixels( /* apply tone-mapping to pixel(s) */
561 TMstruct *tms,
562 BYTE *ps,
563 TMbright *ls,
564 BYTE *cs,
565 int len
566 )
567 {
568 static const char funcName[] = "tmMapPixels";
569 int32 li, pv;
570
571 if (tms == NULL || tms->lumap == NULL)
572 returnErr(TM_E_TMINVAL);
573 if ((ps == NULL) | (ls == NULL) | (len < 0))
574 returnErr(TM_E_ILLEGAL);
575 while (len--) {
576 if ((li = *ls++) < tms->mbrmin) {
577 li = 0;
578 } else {
579 if (li > tms->mbrmax)
580 li = tms->mbrmax;
581 li = tms->lumap[li - tms->mbrmin];
582 }
583 if (cs == TM_NOCHROM)
584 *ps++ = li>255 ? 255 : li;
585 else {
586 pv = *cs++ * li / tms->cdiv[RED];
587 *ps++ = pv>255 ? 255 : pv;
588 pv = *cs++ * li / tms->cdiv[GRN];
589 *ps++ = pv>255 ? 255 : pv;
590 pv = *cs++ * li / tms->cdiv[BLU];
591 *ps++ = pv>255 ? 255 : pv;
592 }
593 }
594 returnOK;
595 }
596
597
598 TMstruct *
599 tmDup( /* duplicate top tone mapping */
600 TMstruct *tms
601 )
602 {
603 int len;
604 int i;
605 TMstruct *tmnew;
606
607 if (tms == NULL) /* anything to duplicate? */
608 return(NULL);
609 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
610 if (tmnew == NULL)
611 return(NULL);
612 *tmnew = *tms; /* copy everything */
613 if (tmnew->histo != NULL) { /* duplicate histogram */
614 len = HISTI(tmnew->hbrmax) + 1 - HISTI(tmnew->hbrmin);
615 tmnew->histo = (int *)malloc(len*sizeof(int));
616 if (tmnew->histo != NULL)
617 for (i = len; i--; )
618 tmnew->histo[i] = tms->histo[i];
619 }
620 if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
621 len = tmnew->mbrmax-tmnew->mbrmin+1;
622 tmnew->lumap = (unsigned short *)malloc(
623 len*sizeof(unsigned short) );
624 if (tmnew->lumap != NULL)
625 for (i = len; i--; )
626 tmnew->lumap[i] = tms->lumap[i];
627 }
628 /* clear package data */
629 for (i = tmNumPkgs; i--; )
630 tmnew->pd[i] = NULL;
631 /* return copy */
632 return(tmnew);
633 }
634
635
636 void
637 tmDone(tms) /* done with tone mapping -- destroy it */
638 TMstruct *tms;
639 {
640 int i;
641 /* NULL arg. is equiv. to tms */
642 if (tms == NULL)
643 return;
644 /* free tables */
645 if (tms->histo != NULL)
646 free((MEM_PTR)tms->histo);
647 if (tms->lumap != NULL)
648 free((MEM_PTR)tms->lumap);
649 /* free private data */
650 for (i = tmNumPkgs; i--; )
651 if (tms->pd[i] != NULL)
652 (*tmPkg[i]->Free)(tms->pd[i]);
653 free((MEM_PTR)tms); /* free basic structure */
654 }
655
656 /******************** Shared but Private library routines *********************/
657
658 BYTE tmMesofact[BMESUPPER-BMESLOWER];
659
660 void
661 tmMkMesofact() /* build mesopic lookup factor table */
662 {
663 int i;
664
665 if (tmMesofact[BMESUPPER-BMESLOWER-1])
666 return;
667
668 for (i = BMESLOWER; i < BMESUPPER; i++)
669 tmMesofact[i-BMESLOWER] = 256. *
670 (tmLuminance(i) - LMESLOWER) /
671 (LMESUPPER - LMESLOWER);
672 }
673
674
675 int
676 tmNewMap( /* allocate new tone-mapping array */
677 TMstruct *tms
678 )
679 {
680 if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
681 (tms->hbrmax - tms->hbrmin)) {
682 free((MEM_PTR)tms->lumap);
683 tms->lumap = NULL;
684 }
685 tms->mbrmin = tms->hbrmin;
686 tms->mbrmax = tms->hbrmax;
687 if (tms->mbrmin > tms->mbrmax)
688 return 0;
689 if (tms->lumap == NULL)
690 tms->lumap = (unsigned short *)malloc(sizeof(unsigned short)*
691 (tms->mbrmax-tms->mbrmin+1));
692 return(tms->lumap != NULL);
693 }
694
695
696 int
697 tmErrorReturn( /* error return (with message) */
698 const char *func,
699 TMstruct *tms,
700 int err
701 )
702 {
703 if (tms != NULL) {
704 tms->lastFunc = func;
705 tms->lastError = err;
706 if (tms->flags & TM_F_NOSTDERR)
707 return(err);
708 }
709 fputs(func, stderr);
710 fputs(": ", stderr);
711 fputs(tmErrorMessage[err], stderr);
712 fputs("!\n", stderr);
713 return(err);
714 }
