root/radiance/src/common/tmapluv.c
Tue Nov 15 06:53:00 2005 UTC (19 years, 11 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.11: +4 -16 lines
Diff to previous 3.11
Added tmCvLuminance() call
Fri Jan 7 21:41:06 2005 UTC (20 years, 9 months ago) by greg
Changes since 3.10: +3 -3 lines
Diff to previous 3.10
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (20 years, 9 months ago) by greg
Changes since 3.9: +79 -73 lines
Diff to previous 3.9
Sun Jul 27 22:12:01 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 3.8: +4 -4 lines
Diff to previous 3.8
Tue Jul 15 07:28:09 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.7: +2 -2 lines
Diff to previous 3.7
Improved speed of 48-bit RGB pixel conversion in tmCvRGB48()
Tue Jul 1 16:20:04 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.6: +3 -2 lines
Diff to previous 3.6
Compile fixes related to Photosphere
Mon Jun 30 14:59:11 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 3.5: +2 -5 lines
Diff to previous 3.5
Tue Feb 25 02:47:22 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.4: +1 -56 lines
Diff to previous 3.4
Sat Feb 22 02:07:22 2003 UTC (22 years, 7 months ago) by greg
Changes since 3.3: +109 -88 lines
Diff to previous 3.3
Sun Dec 20 16:38:29 1998 UTC (26 years, 10 months ago) by gwlarson
Diff to previous 3.2
added TM_NOBRT macro for undefined brightnesses
Mon Oct 26 17:07:05 1998 UTC (26 years, 11 months ago) by gwlarson
Changes since 3.1: +19 -7 lines
implemented mesopic color shift
Thu Oct 22 13:53:06 1998 UTC (27 years ago) by gwlarson
