| 1 | /* Copyright (c) 1997 Regents of the University of California */ |
| 2 |  |
| 3 | #ifndef lint |
| 4 | static char SCCSid[] = "$SunId$ LBL"; |
| 5 | #endif |
| 6 |  |
| 7 | /* |
| 8 | * Routines for tone mapping on Radiance RGBE and XYZE pictures. |
| 9 | * See tonemap.h for detailed function descriptions. |
| 10 | */ |
| 11 |  |
| 12 | #include        <stdio.h> |
| 13 | #include        <math.h> |
| 14 | #include        "tmprivat.h" |
| 15 | #include        "resolu.h" |
| 16 |  |
| 17 |  |
| 18 | extern char     *tempbuffer(); |
| 19 |  |
| 20 | #define LOGISZ  260 |
| 21 | static TMbright logi[LOGISZ]; |
| 22 | static BYTE     photofact[BMESUPPER-BMESLOWER]; |
| 23 |  |
| 24 |  |
| 25 | int |
| 26 | tmCvColrs(ls, cs, scan, len)            /* tone map RGBE/XYZE colors */ |
| 27 | TMbright        *ls; |
| 28 | BYTE    *cs; |
| 29 | COLR    *scan; |
| 30 | int     len; |
| 31 | { |
| 32 | static char     funcName[] = "tmCvColrs"; |
| 33 | COLR    cmon; |
| 34 | register int    i, bi, li; |
| 35 |  |
| 36 | if (tmTop == NULL) |
| 37 | returnErr(TM_E_TMINVAL); |
| 38 | if (ls == NULL | scan == NULL | len <= 0) |
| 39 | returnErr(TM_E_ILLEGAL); |
| 40 | if (tmTop->flags & TM_F_NEEDMAT) {      /* need floating point */ |
| 41 | register COLOR  *newscan; |
| 42 | newscan = (COLOR *)tempbuffer(len*sizeof(COLOR)); |
| 43 | if (newscan == NULL) |
| 44 | returnErr(TM_E_NOMEM); |
| 45 | for (i = len; i--; ) |
| 46 | colr_color(newscan[i], scan[i]); |
| 47 | return(tmCvColors(ls, cs, newscan, len)); |
| 48 | } |
| 49 | if (logi[0] == 0) {                     /* build tables if necessary */ |
| 50 | for (i = 256; i--; ) |
| 51 | logi[i] = TM_BRTSCALE*log((i+.5)/256.) - .5; |
| 52 | for (i = 256; i < LOGISZ; i++) |
| 53 | logi[i] = logi[255]; |
| 54 | for (i = BMESLOWER; i < BMESUPPER; i++) |
| 55 | photofact[i-BMESLOWER] = 256. * |
| 56 | (tmLuminance(i) - LMESLOWER) / |
| 57 | (LMESUPPER - LMESLOWER); |
| 58 | } |
| 59 | for (i = len; i--; ) { |
| 60 | copycolr(cmon, scan[i]); |
| 61 | /* world luminance */ |
| 62 | li =  ( tmTop->clfb[RED]*cmon[RED] + |
| 63 | tmTop->clfb[GRN]*cmon[GRN] + |
| 64 | tmTop->clfb[BLU]*cmon[BLU] ) >> 8; |
| 65 | bi = BRT2SCALE*(cmon[EXP]-COLXS) + |
| 66 | logi[li] + tmTop->inpsfb; |
| 67 | if (bi < MINBRT) { |
| 68 | bi = MINBRT-1;                  /* bogus value */ |
| 69 | li++;                           /* avoid li==0 */ |
| 70 | } |
| 71 | ls[i] = bi; |
| 72 | if (cs == TM_NOCHROM)                   /* no color? */ |
| 73 | continue; |
| 74 | /* mesopic adj. */ |
| 75 | if (tmTop->flags & TM_F_MESOPIC && bi < BMESUPPER) { |
| 76 | register int    pf, sli = normscot(cmon); |
| 77 | if (bi < BMESLOWER) |
| 78 | cmon[RED] = cmon[GRN] = cmon[BLU] = sli; |
| 79 | else { |
| 80 | if (tmTop->flags & TM_F_BW) |
| 81 | cmon[RED] = cmon[GRN] = cmon[BLU] = li; |
| 82 | pf = photofact[bi-BMESLOWER]; |
| 83 | sli *= 256 - pf; |
| 84 | cmon[RED] = ( sli + pf*cmon[RED] ) >> 8; |
| 85 | cmon[GRN] = ( sli + pf*cmon[GRN] ) >> 8; |
| 86 | cmon[BLU] = ( sli + pf*cmon[BLU] ) >> 8; |
| 87 | } |
| 88 | } else if (tmTop->flags & TM_F_BW) { |
| 89 | cmon[RED] = cmon[GRN] = cmon[BLU] = li; |
| 90 | } |
| 91 | bi = ( (int4)TM_GAMTSZ*tmTop->clfb[RED]*cmon[RED]/li ) >> 8; |
| 92 | cs[3*i  ] = bi>=TM_GAMTSZ ? 255 : tmTop->gamb[bi]; |
| 93 | bi = ( (int4)TM_GAMTSZ*tmTop->clfb[GRN]*cmon[GRN]/li ) >> 8; |
| 94 | cs[3*i+1] = bi>=TM_GAMTSZ ? 255 : tmTop->gamb[bi]; |
| 95 | bi = ( (int4)TM_GAMTSZ*tmTop->clfb[BLU]*cmon[BLU]/li ) >> 8; |
| 96 | cs[3*i+2] = bi>=TM_GAMTSZ ? 255 : tmTop->gamb[bi]; |
| 97 | } |
| 98 | returnOK; |
| 99 | } |
| 100 |  |
| 101 |  |
| 102 | #define FMTRGB          1       /* Input is RGBE */ |
| 103 | #define FMTCIE          2       /* Input is CIE XYZE */ |
| 104 | #define FMTUNK          3       /* Input format is unspecified */ |
| 105 | #define FMTBAD          4       /* Input is not a recognized format */ |
| 106 |  |
| 107 | static struct radhead { |
| 108 | int     format;         /* FMTRGB, FMTCIE, FMTUNK, FMTBAD */ |
| 109 | double  expos;          /* input exposure value */ |
| 110 | RGBPRIMP        primp;  /* input primaries */ |
| 111 | RGBPRIMS        mypri;  /* custom primaries */ |
| 112 | } rhdefault = {FMTUNK, 1., stdprims, STDPRIMS}; |
| 113 |  |
| 114 |  |
| 115 | static int |
| 116 | headline(s, rh)                 /* grok a header line */ |
| 117 | register char   *s; |
| 118 | register struct radhead *rh; |
| 119 | { |
| 120 | char    fmt[32]; |
| 121 |  |
| 122 | if (formatval(fmt, s)) { |
| 123 | if (!strcmp(fmt, COLRFMT)) |
| 124 | rh->format = FMTRGB; |
| 125 | else if (!strcmp(fmt, CIEFMT)) |
| 126 | rh->format = FMTCIE; |
| 127 | else |
| 128 | rh->format = FMTBAD; |
| 129 | return; |
| 130 | } |
| 131 | if (isexpos(s)) { |
| 132 | rh->expos *= exposval(s); |
| 133 | return; |
| 134 | } |
| 135 | if (isprims(s)) { |
| 136 | primsval(rh->mypri, s); |
| 137 | rh->primp = rh->mypri; |
| 138 | return; |
| 139 | } |
| 140 | } |
| 141 |  |
| 142 |  |
| 143 | int |
| 144 | tmLoadPicture(lpp, cpp, xp, yp, fname, fp)      /* convert Radiance picture */ |
| 145 | TMbright        **lpp; |
| 146 | BYTE    **cpp; |
| 147 | int     *xp, *yp; |
| 148 | char    *fname; |
| 149 | FILE    *fp; |
| 150 | { |
| 151 | char    *funcName = fname==NULL ? "tmLoadPicture" : fname; |
| 152 | FILE    *inpf; |
| 153 | struct radhead  info; |
| 154 | int     err; |
| 155 | COLR    *scanin = NULL; |
| 156 | int     i; |
| 157 | /* check arguments */ |
| 158 | if (tmTop == NULL) |
| 159 | returnErr(TM_E_TMINVAL); |
| 160 | if (lpp == NULL | xp == NULL | yp == NULL | |
| 161 | (fname == NULL & fp == TM_GETFILE)) |
| 162 | returnErr(TM_E_ILLEGAL); |
| 163 | *xp = *yp = 0;                          /* error precaution */ |
| 164 | if ((inpf = fp) == TM_GETFILE && (inpf = fopen(fname, "r")) == NULL) |
| 165 | returnErr(TM_E_BADFILE); |
| 166 | info = rhdefault;                       /* get our header */ |
| 167 | getheader(inpf, headline, (char *)&info); |
| 168 | if (info.format == FMTBAD | info.expos <= 0. || |
| 169 | fgetresolu(xp, yp, inpf) < 0) { |
| 170 | err = TM_E_BADFILE; goto done; |
| 171 | } |
| 172 | if (info.format == FMTUNK)              /* assume RGBE format */ |
| 173 | info.format = FMTRGB; |
| 174 | if (info.format == FMTRGB) |
| 175 | info.expos /= WHTEFFICACY; |
| 176 | else if (info.format == FMTCIE) |
| 177 | info.primp = TM_XYZPRIM; |
| 178 | /* prepare library */ |
| 179 | if ((err = tmSetSpace(info.primp, 1./info.expos)) != TM_E_OK) |
| 180 | goto done; |
| 181 | err = TM_E_NOMEM;                       /* allocate arrays */ |
| 182 | *lpp = (TMbright *)malloc(sizeof(TMbright) * *xp * *yp); |
| 183 | if (*lpp == NULL) |
| 184 | goto done; |
| 185 | if (cpp != TM_NOCHROMP) { |
| 186 | *cpp = (BYTE *)malloc(3*sizeof(BYTE) * *xp * *yp); |
| 187 | if (*cpp == NULL) |
| 188 | goto done; |
| 189 | } |
| 190 | scanin = (COLR *)malloc(sizeof(COLR) * *xp); |
| 191 | if (scanin == NULL) |
| 192 | goto done; |
| 193 | err = TM_E_BADFILE;                     /* read & convert scanlines */ |
| 194 | for (i = 0; i < *yp; i++) { |
| 195 | if (freadcolrs(scanin, *xp, inpf) < 0) { |
| 196 | err = TM_E_BADFILE; break; |
| 197 | } |
| 198 | err = tmCvColrs(*lpp + (i * *xp), |
| 199 | cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp + (i * 3 * *xp), |
| 200 | scanin, *xp); |
| 201 | if (err != TM_E_OK) |
| 202 | break; |
| 203 | } |
| 204 | done:                                           /* clean up */ |
| 205 | if (fp == NULL) |
| 206 | fclose(inpf); |
| 207 | if (scanin != NULL) |
| 208 | free((char *)scanin); |
| 209 | if (err != TM_E_OK) |
| 210 | returnErr(err); |
| 211 | returnOK; |
| 212 | } |
| 213 |  |
| 214 |  |
| 215 | int                                     /* run pcond to map picture */ |
| 216 | dopcond(psp, xp, yp, flags, monpri, gamval, Lddyn, Ldmax, fname) |
| 217 | BYTE    **psp; |
| 218 | int     *xp, *yp; |
| 219 | int     flags; |
| 220 | RGBPRIMP        monpri; |
| 221 | double  gamval, Lddyn, Ldmax; |
| 222 | char    *fname; |
| 223 | { |
| 224 | char    *funcName = fname; |
| 225 | char    cmdbuf[512]; |
| 226 | FILE    *infp; |
| 227 | register COLR   *scan; |
| 228 | register BYTE   *rp; |
| 229 | int     y; |
| 230 | register int    x; |
| 231 | /* set up gamma correction */ |
| 232 | if (setcolrcor(pow, 1./gamval) < 0) |
| 233 | returnErr(TM_E_NOMEM); |
| 234 | /* create command */ |
| 235 | strcpy(cmdbuf, "pcond "); |
| 236 | if (flags & TM_F_HCONTR) |
| 237 | strcat(cmdbuf, "-s "); |
| 238 | if (flags & TM_F_MESOPIC) |
| 239 | strcat(cmdbuf, "-c "); |
| 240 | if (flags & TM_F_LINEAR) |
| 241 | strcat(cmdbuf, "-l "); |
| 242 | if (flags & TM_F_ACUITY) |
| 243 | strcat(cmdbuf, "-a "); |
| 244 | if (flags & TM_F_VEIL) |
| 245 | strcat(cmdbuf, "-v "); |
| 246 | if (flags & TM_F_CWEIGHT) |
| 247 | strcat(cmdbuf, "-w "); |
| 248 | sprintf(cmdbuf+strlen(cmdbuf), |
| 249 | "-p %f %f %f %f %f %f %f %f -d %f -u %f %s", |
| 250 | monpri[RED][CIEX], monpri[RED][CIEY], |
| 251 | monpri[GRN][CIEX], monpri[GRN][CIEY], |
| 252 | monpri[BLU][CIEX], monpri[BLU][CIEY], |
| 253 | monpri[WHT][CIEX], monpri[WHT][CIEY], |
| 254 | Lddyn, Ldmax, fname); |
| 255 | /* start pcond */ |
| 256 | if ((infp = popen(cmdbuf, "r")) == NULL) |
| 257 | returnErr(TM_E_BADFILE); |
| 258 | /* check picture format and size */ |
| 259 | if (checkheader(infp, COLRFMT, NULL) < 0 || |
| 260 | fgetresolu(xp, yp, infp) < 0) { |
| 261 | pclose(infp); |
| 262 | returnErr(TM_E_BADFILE); |
| 263 | } |
| 264 | /* allocate arrays */ |
| 265 | if (flags & TM_F_BW) |
| 266 | rp = (BYTE *)malloc(sizeof(BYTE) * *xp * *yp); |
| 267 | else |
| 268 | rp = (BYTE *)malloc(3*sizeof(BYTE) * *xp * *yp); |
| 269 | scan = (COLR *)malloc(sizeof(COLR) * *xp); |
| 270 | if ((*psp = rp) == NULL | scan == NULL) { |
| 271 | pclose(infp); |
| 272 | returnErr(TM_E_NOMEM); |
| 273 | } |
| 274 | /* read and gamma map file */ |
| 275 | for (y = 0; y < *yp; y++) { |
| 276 | if (freadcolrs(scan, *xp, infp) < 0) { |
| 277 | pclose(infp); |
| 278 | returnErr(TM_E_BADFILE); |
| 279 | } |
| 280 | colrs_gambs(scan, *xp); |
| 281 | if (flags & TM_F_BW) |
| 282 | for (x = 0; x < *xp; x++) |
| 283 | *rp++ = normbright(scan[x]); |
| 284 | else |
| 285 | for (x = 0; x < *xp; x++) { |
| 286 | *rp++ = scan[x][RED]; |
| 287 | *rp++ = scan[x][GRN]; |
| 288 | *rp++ = scan[x][BLU]; |
| 289 | } |
| 290 | } |
| 291 | free((char *)scan); |
| 292 | pclose(infp); |
| 293 | returnOK; |
| 294 | } |
| 295 |  |
| 296 |  |
| 297 | int                                     /* map a Radiance picture */ |
| 298 | tmMapPicture(psp, xp, yp, flags, monpri, gamval, Lddyn, Ldmax, fname, fp) |
| 299 | BYTE    **psp; |
| 300 | int     *xp, *yp; |
| 301 | int     flags; |
| 302 | RGBPRIMP        monpri; |
| 303 | double  gamval, Lddyn, Ldmax; |
| 304 | char    *fname; |
| 305 | FILE    *fp; |
| 306 | { |
| 307 | char    *funcName = fname==NULL ? "tmMapPicture" : fname; |
| 308 | FILE    *inpf; |
| 309 | BYTE    *cp; |
| 310 | TMbright        *lp; |
| 311 | int     err; |
| 312 | /* check arguments */ |
| 313 | if (psp == NULL | xp == NULL | yp == NULL | monpri == NULL | |
| 314 | (fname == NULL & fp == TM_GETFILE)) |
| 315 | returnErr(TM_E_ILLEGAL); |
| 316 | /* set defaults */ |
| 317 | if (gamval < MINGAM) gamval = DEFGAM; |
| 318 | if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN; |
| 319 | if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; |
| 320 | if (flags & TM_F_BW) monpri = stdprims; |
| 321 | /* check for pcond run */ |
| 322 | if (fp == TM_GETFILE && flags & TM_F_UNIMPL) |
| 323 | return( dopcond(psp, xp, yp, flags, |
| 324 | monpri, gamval, Lddyn, Ldmax, fname) ); |
| 325 | /* initialize tone mapping */ |
| 326 | if (tmInit(flags, monpri, gamval) == NULL) |
| 327 | returnErr(TM_E_NOMEM); |
| 328 | /* load & convert picture */ |
| 329 | err = tmLoadPicture(&lp, (flags&TM_F_BW) ? TM_NOCHROMP : &cp, |
| 330 | xp, yp, fname, fp); |
| 331 | if (err != TM_E_OK) { |
| 332 | tmDone(NULL); |
| 333 | return(err); |
| 334 | } |
| 335 | /* allocate space for result */ |
| 336 | if (flags & TM_F_BW) { |
| 337 | *psp = (BYTE *)malloc(sizeof(BYTE) * *xp * *yp); |
| 338 | if (*psp == NULL) |
| 339 | returnErr(TM_E_NOMEM); |
| 340 | cp = TM_NOCHROM; |
| 341 | } else |
| 342 | *psp = cp; |
| 343 | /* compute color mapping */ |
| 344 | err = tmAddHisto(lp, *xp * *yp, 1); |
| 345 | if (err != TM_E_OK) |
| 346 | goto done; |
| 347 | err = tmComputeMapping(gamval, Lddyn, Ldmax); |
| 348 | if (err != TM_E_OK) |
| 349 | goto done; |
| 350 | /* map colors */ |
| 351 | err = tmMapPixels(*psp, lp, cp, *xp * *yp); |
| 352 |  |
| 353 | done:                                           /* clean up */ |
| 354 | free((char *)lp); |
| 355 | tmDone(NULL); |
| 356 | if (err != TM_E_OK) {                   /* free memory on error */ |
| 357 | free((char *)*psp); |
| 358 | *psp = NULL; |
| 359 | returnErr(err); |
| 360 | } |
| 361 | returnOK; |
| 362 | } |
