| 1 | /* Copyright (c) 1998 Silicon Graphics, Inc. */ |
| 2 |  |
| 3 | /* SCCSid "$SunId$ SGI" */ |
| 4 |  |
| 5 | /* |
| 6 | *      Miscellaneous definitions required by many routines. |
| 7 | */ |
| 8 |  |
| 9 | #include  <stdio.h> |
| 10 |  |
| 11 | #include  <sys/types.h> |
| 12 |  |
| 13 | #include  <fcntl.h> |
| 14 |  |
| 15 | #include  <math.h> |
| 16 |  |
| 17 | #include  <errno.h> |
| 18 |  |
| 19 | #include  "mat4.h" |
| 20 | /* regular transformation */ |
| 21 | typedef struct { |
| 22 | MAT4  xfm;                              /* transform matrix */ |
| 23 | FLOAT  sca;                             /* scalefactor */ |
| 24 | }  XF; |
| 25 | /* complemetary tranformation */ |
| 26 | typedef struct { |
| 27 | XF  f;                                  /* forward */ |
| 28 | XF  b;                                  /* backward */ |
| 29 | }  FULLXF; |
| 30 |  |
| 31 | #ifndef  PI |
| 32 | #ifdef  M_PI |
| 33 | #define  PI             ((double)M_PI) |
| 34 | #else |
| 35 | #define  PI             3.14159265358979323846 |
| 36 | #endif |
| 37 | #endif |
| 38 |  |
| 39 | #ifndef  F_OK                   /* mode bits for access(2) call */ |
| 40 | #define  R_OK           4               /* readable */ |
| 41 | #define  W_OK           2               /* writable */ |
| 42 | #define  X_OK           1               /* executable */ |
| 43 | #define  F_OK           0               /* exists */ |
| 44 | #endif |
| 45 |  |
| 46 | #ifndef  int2 |
| 47 | #define  int2           short           /* two-byte integer */ |
| 48 | #endif |
| 49 | #ifndef  int4 |
| 50 | #define  int4           int             /* four-byte integer */ |
| 51 | #endif |
| 52 |  |
| 53 | extern int  eputs(), wputs();   /* standard error output functions */ |
| 54 |  |
| 55 | /* error codes */ |
| 56 | #define  WARNING        0               /* non-fatal error */ |
| 57 | #define  USER           1               /* fatal user-caused error */ |
| 58 | #define  SYSTEM         2               /* fatal system-related error */ |
| 59 | #define  INTERNAL       3               /* fatal program-related error */ |
| 60 | #define  CONSISTENCY    4               /* bad consistency check, abort */ |
| 61 | #define  COMMAND        5               /* interactive error */ |
| 62 | #define  NERRS          6 |
| 63 | /* error struct */ |
| 64 | extern struct erract { |
| 65 | char    pre[16];                /* prefix message */ |
| 66 | int     (*pf)();                /* put function (resettable) */ |
| 67 | int     ec;                     /* exit code (0 means non-fatal) */ |
| 68 | } erract[NERRS];        /* list of error actions */ |
| 69 |  |
| 70 | #define  ERRACT_INIT    {       {"warning - ", wputs, 0}, \ |
| 71 | {"fatal - ", eputs, 1}, \ |
| 72 | {"system - ", eputs, 2}, \ |
| 73 | {"internal - ", eputs, 1}, \ |
| 74 | {"consistency - ", eputs, -1}, \ |
| 75 | {"", NULL, 0}   } |
| 76 |  |
| 77 | extern char  errmsg[];                  /* global buffer for error messages */ |
| 78 |  |
| 79 | /* memory operations */ |
| 80 | #ifdef  NOSTRUCTASS |
| 81 | #define  copystruct(d,s)        bcopy((char *)(s),(char *)(d),sizeof(*(d))) |
| 82 | #else |
| 83 | #define  copystruct(d,s)        (*(d) = *(s)) |
| 84 | #endif |
| 85 |  |
| 86 | #ifdef   BSD |
| 87 | extern long  lseek(); |
| 88 | #else |
| 89 | #define  bcopy(s,d,n)           (void)memcpy(d,s,n) |
| 90 | #define  bzero(d,n)             (void)memset(d,0,n) |
| 91 | #define  bcmp(b1,b2,n)          memcmp(b1,b2,n) |
| 92 | #define  index                  strchr |
| 93 | #define  rindex                 strrchr |
| 94 | extern off_t  lseek(); |
| 95 | #endif |
| 96 | extern long  ftell(); |
| 97 |  |
| 98 | extern char  *sskip(), *sskip2(); |
| 99 | extern char  *getpath(), *getenv(); |
| 100 | #ifndef malloc |
| 101 | extern char  *malloc(), *calloc(), *realloc(); |
| 102 | #endif |
| 103 | extern char  *bmalloc(), *savestr(), *savqstr(); |
| 104 |  |
| 105 | #ifdef  DCL_ATOF |
| 106 | extern double  atof(); |
| 107 | #endif |
| 108 |  |
| 109 | #ifdef MSDOS |
| 110 | #define NIX 1 |
| 111 | #endif |
| 112 | #ifdef AMIGA |
| 113 | #define NIX 1 |
| 114 | #endif |
| 115 |  |
