| 1 |
/* Copyright (c) 1990 Regents of the University of California */
| 2 |
| 3 |
/* SCCSid "$SunId$ LBL" */
| 4 |
| 5 |
| 6 |
* Miscellaneous definitions required by many routines.
| 7 |
| 8 |
| 9 |
#include <stdio.h>
| 10 |
| 11 |
#include <math.h>
| 12 |
| 13 |
#include <errno.h>
| 14 |
| 15 |
#include "mat4.h"
| 16 |
/* regular transformation */
| 17 |
typedef struct {
| 18 |
MAT4 xfm; /* transform matrix */
| 19 |
FLOAT sca; /* scalefactor */
| 20 |
} XF;
| 21 |
/* complemetary tranformation */
| 22 |
typedef struct {
| 23 |
XF f; /* forward */
| 24 |
XF b; /* backward */
| 25 |
} FULLXF;
| 26 |
| 27 |
#ifdef M_PI
| 28 |
#define PI M_PI
| 29 |
#else
| 30 |
#define PI 3.14159265358979323846
| 31 |
#endif
| 32 |
| 33 |
#ifndef F_OK /* mode bits for access(2) call */
| 34 |
#define R_OK 4 /* readable */
| 35 |
#define W_OK 2 /* writable */
| 36 |
#define X_OK 1 /* executable */
| 37 |
#define F_OK 0 /* exists */
| 38 |
#endif
| 39 |
/* error codes */
| 40 |
#define WARNING 1 /* non-fatal error */
| 41 |
#define USER 2 /* fatal user-caused error */
| 42 |
#define SYSTEM 3 /* fatal system-related error */
| 43 |
#define INTERNAL 4 /* fatal program-related error */
| 44 |
#define CONSISTENCY 5 /* bad consistency check, abort */
| 45 |
#define COMMAND 6 /* interactive error */
| 46 |
| 47 |
extern char errmsg[]; /* global buffer for error messages */
| 48 |
| 49 |
extern int errno; /* system error number */
| 50 |
| 51 |
/* memory operations */
| 52 |
#ifdef NOSTRUCTASS
| 53 |
#define copystruct(d,s) bcopy((char *)(s),(char *)(d),sizeof(*(d)))
| 54 |
#else
| 55 |
#define copystruct(d,s) (*(d) = *(s))
| 56 |
#endif
| 57 |
| 58 |
#ifndef BSD
| 59 |
#define bcopy(s,d,n) (void)memcpy(d,s,n)
| 60 |
#define bzero(d,n) (void)memset(d,0,n)
| 61 |
#define bcmp(b1,b2,n) memcmp(b1,b2,n)
| 62 |
extern char *memcpy(), *memset();
| 63 |
#define index strchr
| 64 |
#define rindex strrchr
| 65 |
#endif
| 66 |
| 67 |
extern char *sskip();
| 68 |
extern char *getpath(), *getenv();
| 69 |
extern char *malloc(), *calloc(), *realloc();
| 70 |
extern char *bmalloc(), *savestr(), *savqstr();
