root/radiance/src/common/spec_rgb.c
Revision: 2.12
Committed: Tue Feb 25 02:47:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.11: +1 -56 lines
5 * Convert colors and spectral ranges.
6 * Added von Kries white-balance calculations 10/01 (GW).
7 *
8 * Externals declared in color.h
9 */
10
11 #include "copyright.h"
12
13 #include "color.h"
14 #include <string.h>
15
16 #define CEPS 1e-4 /* color epsilon */
17
18 #define CEQ(v1,v2) ((v1) <= (v2)+CEPS && (v2) <= (v1)+CEPS)
19
20 #define XYEQ(c1,c2) (CEQ((c1)[CIEX],(c2)[CIEX]) && CEQ((c1)[CIEY],(c2)[CIEY]))
21
22
23 RGBPRIMS stdprims = STDPRIMS; /* standard primary chromaticities */
24
25 COLOR cblack = BLKCOLOR; /* global black color */
26 COLOR cwhite = WHTCOLOR; /* global white color */
27
28 float xyneu[2] = {1./3., 1./3.}; /* neutral xy chromaticities */
29
30 /*
31 * The following table contains the CIE tristimulus integrals
32 * for X, Y, and Z. The table is cumulative, so that
33 * each color coordinate integrates to 1.
34 */
35
36 #define STARTWL 380 /* starting wavelength (nanometers) */
37 #define INCWL 10 /* wavelength increment */
38 #define NINC 40 /* # of values */
39
40 static BYTE chroma[3][NINC] = {
41 { /* X */
42 0, 0, 0, 2, 6, 13, 22, 30, 36, 41,
43 42, 43, 43, 44, 46, 52, 60, 71, 87, 106,
44 128, 153, 178, 200, 219, 233, 243, 249, 252, 254,
45 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
46 }, { /* Y */
47 0, 0, 0, 0, 0, 1, 2, 4, 7, 11,
48 17, 24, 34, 48, 64, 84, 105, 127, 148, 169,
49 188, 205, 220, 232, 240, 246, 250, 253, 254, 255,
50 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
51 }, { /* Z */
52 0, 0, 2, 10, 32, 66, 118, 153, 191, 220,
53 237, 246, 251, 253, 254, 255, 255, 255, 255, 255,
54 255, 255, 255, 255, 255, 255, 255, 255, 255, 255,
55 255, 255, 255, 255, 255, 255, 255, 255, 255, 255
56 }
57 };
58
59 COLORMAT xyz2rgbmat = { /* XYZ to RGB (no white balance) */
60 {(CIE_y_g - CIE_y_b - CIE_x_b*CIE_y_g + CIE_y_b*CIE_x_g)/CIE_C_rD,
61 (CIE_x_b - CIE_x_g - CIE_x_b*CIE_y_g + CIE_x_g*CIE_y_b)/CIE_C_rD,
62 (CIE_x_g*CIE_y_b - CIE_x_b*CIE_y_g)/CIE_C_rD},
63 {(CIE_y_b - CIE_y_r - CIE_y_b*CIE_x_r + CIE_y_r*CIE_x_b)/CIE_C_gD,
64 (CIE_x_r - CIE_x_b - CIE_x_r*CIE_y_b + CIE_x_b*CIE_y_r)/CIE_C_gD,
65 (CIE_x_b*CIE_y_r - CIE_x_r*CIE_y_b)/CIE_C_gD},
66 {(CIE_y_r - CIE_y_g - CIE_y_r*CIE_x_g + CIE_y_g*CIE_x_r)/CIE_C_bD,
67 (CIE_x_g - CIE_x_r - CIE_x_g*CIE_y_r + CIE_x_r*CIE_y_g)/CIE_C_bD,
68 (CIE_x_r*CIE_y_g - CIE_x_g*CIE_y_r)/CIE_C_bD}
69 };
70
71 COLORMAT rgb2xyzmat = { /* RGB to XYZ (no white balance) */
72 {CIE_x_r*CIE_C_rD/CIE_D,CIE_x_g*CIE_C_gD/CIE_D,CIE_x_b*CIE_C_bD/CIE_D},
73 {CIE_y_r*CIE_C_rD/CIE_D,CIE_y_g*CIE_C_gD/CIE_D,CIE_y_b*CIE_C_bD/CIE_D},
74 {(1.-CIE_x_r-CIE_y_r)*CIE_C_rD/CIE_D,
75 (1.-CIE_x_g-CIE_y_g)*CIE_C_gD/CIE_D,
76 (1.-CIE_x_b-CIE_y_b)*CIE_C_bD/CIE_D}
77 };
78
79 COLORMAT vkmat = { /* Sharp primary matrix */
80 { 1.2694, -0.0988, -0.1706},
81 {-0.8364, 1.8006, 0.0357},
82 { 0.0297, -0.0315, 1.0018}
83 };
84
85 COLORMAT ivkmat = { /* inverse Sharp primary matrix */
86 { 0.8156, 0.0472, 0.1372},
87 { 0.3791, 0.5769, 0.0440},
88 {-0.0123, 0.0167, 0.9955}
89 };
90
91
92 void
93 spec_rgb(col, s, e) /* compute RGB color from spectral range */
94 COLOR col;
95 int s, e;
96 {
97 COLOR ciecolor;
98
99 spec_cie(ciecolor, s, e);
100 cie_rgb(col, ciecolor);
101 }
102
103
104 void
105 spec_cie(col, s, e) /* compute a color from a spectral range */
106 COLOR col; /* returned color */
107 int s, e; /* starting and ending wavelengths */
108 {
109 register int i, d, r;
110
111 s -= STARTWL;
112 if (s < 0)
113 s = 0;
114
115 e -= STARTWL;
116 if (e <= s) {
117 col[CIEX] = col[CIEY] = col[CIEZ] = 0.0;
118 return;
119 }
120 if (e >= INCWL*(NINC - 1))
121 e = INCWL*(NINC - 1) - 1;
122
123 d = e / INCWL; /* interpolate values */
124 r = e % INCWL;
125 for (i = 0; i < 3; i++)
126 col[i] = chroma[i][d]*(INCWL - r) + chroma[i][d + 1]*r;
127
128 d = s / INCWL;
129 r = s % INCWL;
130 for (i = 0; i < 3; i++)
131 col[i] -= chroma[i][d]*(INCWL - r) - chroma[i][d + 1]*r;
132
133 col[CIEX] = (col[CIEX] + 0.5) * (1./(256*INCWL));
134 col[CIEY] = (col[CIEY] + 0.5) * (1./(256*INCWL));
135 col[CIEZ] = (col[CIEZ] + 0.5) * (1./(256*INCWL));
136 }
137
138
139 void
140 cie_rgb(rgb, xyz) /* convert CIE color to standard RGB */
141 COLOR rgb;
142 COLOR xyz;
143 {
144 colortrans(rgb, xyz2rgbmat, xyz);
145 clipgamut(rgb, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite);
146 }
147
148
149 int
150 clipgamut(col, brt, gamut, lower, upper) /* clip to gamut cube */
151 COLOR col;
152 double brt;
153 int gamut;
154 COLOR lower, upper;
155 {
156 int rflags = 0;
157 double brtmin, brtmax, v, vv;
158 COLOR cgry;
159 register int i;
160 /* check for no check */
161 if (gamut == 0) return(0);
162 /* check brightness limits */
163 brtmin = 1./3.*(lower[0]+lower[1]+lower[2]);
164 if (gamut & CGAMUT_LOWER && brt < brtmin) {
165 copycolor(col, lower);
166 return(CGAMUT_LOWER);
167 }
168 brtmax = 1./3.*(upper[0]+upper[1]+upper[2]);
169 if (gamut & CGAMUT_UPPER && brt > brtmax) {
170 copycolor(col, upper);
171 return(CGAMUT_UPPER);
172 }
173 /* compute equivalent grey */
174 v = (brt - brtmin)/(brtmax - brtmin);
175 for (i = 0; i < 3; i++)
176 cgry[i] = v*upper[i] + (1.-v)*lower[i];
177 vv = 1.; /* check each limit */
178 for (i = 0; i < 3; i++)
179 if (gamut & CGAMUT_LOWER && col[i] < lower[i]) {
180 v = (lower[i]+CEPS - cgry[i])/(col[i] - cgry[i]);
181 if (v < vv) vv = v;
182 rflags |= CGAMUT_LOWER;
183 } else if (gamut & CGAMUT_UPPER && col[i] > upper[i]) {
184 v = (upper[i]-CEPS - cgry[i])/(col[i] - cgry[i]);
185 if (v < vv) vv = v;
186 rflags |= CGAMUT_UPPER;
187 }
188 if (rflags) /* desaturate to cube face */
189 for (i = 0; i < 3; i++)
190 col[i] = vv*col[i] + (1.-vv)*cgry[i];
191 return(rflags);
192 }
193
194
195 void
196 colortrans(c2, mat, c1) /* convert c1 by mat and put into c2 */
197 register COLOR c2;
198 register COLORMAT mat;
199 register COLOR c1;
200 {
201 COLOR cout;
202
203 cout[0] = mat[0][0]*c1[0] + mat[0][1]*c1[1] + mat[0][2]*c1[2];
204 cout[1] = mat[1][0]*c1[0] + mat[1][1]*c1[1] + mat[1][2]*c1[2];
205 cout[2] = mat[2][0]*c1[0] + mat[2][1]*c1[1] + mat[2][2]*c1[2];
206
207 copycolor(c2, cout);
208 }
209
210
211 void
212 multcolormat(m3, m2, m1) /* multiply m1 by m2 and put into m3 */
213 COLORMAT m3; /* m3 can be either m1 or m2 w/o harm */
214 COLORMAT m2, m1;
215 {
216 COLORMAT mt;
217 register int i, j;
218
219 for (i = 0; i < 3; i++)
220 for (j = 0; j < 3; j++)
221 mt[i][j] = m1[i][0]*m2[0][j] +
222 m1[i][1]*m2[1][j] +
223 m1[i][2]*m2[2][j] ;
224 cpcolormat(m3, mt);
225 }
226
227
228 void
229 compxyz2rgbmat(mat, pr) /* compute conversion from CIE to RGB space */
230 COLORMAT mat;
231 register RGBPRIMS pr;
232 {
233 double C_rD, C_gD, C_bD;
234
235 if (pr == stdprims) { /* can use xyz2rgbmat */
236 cpcolormat(mat, xyz2rgbmat);
237 return;
238 }
239 C_rD = (1./pr[WHT][CIEY]) *
240 ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) -
241 pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) +
242 pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ;
243 C_gD = (1./pr[WHT][CIEY]) *
244 ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) -
245 pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) -
246 pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ;
247 C_bD = (1./pr[WHT][CIEY]) *
248 ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) -
249 pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) +
250 pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ;
251
252 mat[0][0] = (pr[GRN][CIEY] - pr[BLU][CIEY] -
253 pr[BLU][CIEX]*pr[GRN][CIEY] +
254 pr[BLU][CIEY]*pr[GRN][CIEX])/C_rD ;
255 mat[0][1] = (pr[BLU][CIEX] - pr[GRN][CIEX] -
256 pr[BLU][CIEX]*pr[GRN][CIEY] +
257 pr[GRN][CIEX]*pr[BLU][CIEY])/C_rD ;
258 mat[0][2] = (pr[GRN][CIEX]*pr[BLU][CIEY] -
259 pr[BLU][CIEX]*pr[GRN][CIEY])/C_rD ;
260 mat[1][0] = (pr[BLU][CIEY] - pr[RED][CIEY] -
261 pr[BLU][CIEY]*pr[RED][CIEX] +
262 pr[RED][CIEY]*pr[BLU][CIEX])/C_gD ;
263 mat[1][1] = (pr[RED][CIEX] - pr[BLU][CIEX] -
264 pr[RED][CIEX]*pr[BLU][CIEY] +
265 pr[BLU][CIEX]*pr[RED][CIEY])/C_gD ;
266 mat[1][2] = (pr[BLU][CIEX]*pr[RED][CIEY] -
267 pr[RED][CIEX]*pr[BLU][CIEY])/C_gD ;
268 mat[2][0] = (pr[RED][CIEY] - pr[GRN][CIEY] -
269 pr[RED][CIEY]*pr[GRN][CIEX] +
270 pr[GRN][CIEY]*pr[RED][CIEX])/C_bD ;
271 mat[2][1] = (pr[GRN][CIEX] - pr[RED][CIEX] -
272 pr[GRN][CIEX]*pr[RED][CIEY] +
273 pr[RED][CIEX]*pr[GRN][CIEY])/C_bD ;
274 mat[2][2] = (pr[RED][CIEX]*pr[GRN][CIEY] -
275 pr[GRN][CIEX]*pr[RED][CIEY])/C_bD ;
276 }
277
278
279 void
280 comprgb2xyzmat(mat, pr) /* compute conversion from RGB to CIE space */
281 COLORMAT mat;
282 register RGBPRIMS pr;
283 {
284 double C_rD, C_gD, C_bD, D;
285
286 if (pr == stdprims) { /* can use rgb2xyzmat */
287 cpcolormat(mat, rgb2xyzmat);
288 return;
289 }
290 C_rD = (1./pr[WHT][CIEY]) *
291 ( pr[WHT][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) -
292 pr[WHT][CIEY]*(pr[GRN][CIEX] - pr[BLU][CIEX]) +
293 pr[GRN][CIEX]*pr[BLU][CIEY] - pr[BLU][CIEX]*pr[GRN][CIEY] ) ;
294 C_gD = (1./pr[WHT][CIEY]) *
295 ( pr[WHT][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) -
296 pr[WHT][CIEY]*(pr[BLU][CIEX] - pr[RED][CIEX]) -
297 pr[RED][CIEX]*pr[BLU][CIEY] + pr[BLU][CIEX]*pr[RED][CIEY] ) ;
298 C_bD = (1./pr[WHT][CIEY]) *
299 ( pr[WHT][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) -
300 pr[WHT][CIEY]*(pr[RED][CIEX] - pr[GRN][CIEX]) +
301 pr[RED][CIEX]*pr[GRN][CIEY] - pr[GRN][CIEX]*pr[RED][CIEY] ) ;
302 D = pr[RED][CIEX]*(pr[GRN][CIEY] - pr[BLU][CIEY]) +
303 pr[GRN][CIEX]*(pr[BLU][CIEY] - pr[RED][CIEY]) +
304 pr[BLU][CIEX]*(pr[RED][CIEY] - pr[GRN][CIEY]) ;
305 mat[0][0] = pr[RED][CIEX]*C_rD/D;
306 mat[0][1] = pr[GRN][CIEX]*C_gD/D;
307 mat[0][2] = pr[BLU][CIEX]*C_bD/D;
308 mat[1][0] = pr[RED][CIEY]*C_rD/D;
309 mat[1][1] = pr[GRN][CIEY]*C_gD/D;
310 mat[1][2] = pr[BLU][CIEY]*C_bD/D;
311 mat[2][0] = (1.-pr[RED][CIEX]-pr[RED][CIEY])*C_rD/D;
312 mat[2][1] = (1.-pr[GRN][CIEX]-pr[GRN][CIEY])*C_gD/D;
313 mat[2][2] = (1.-pr[BLU][CIEX]-pr[BLU][CIEY])*C_bD/D;
314 }
315
316
317 void
318 comprgb2rgbmat(mat, pr1, pr2) /* compute conversion from RGB1 to RGB2 */
319 COLORMAT mat;
320 RGBPRIMS pr1, pr2;
321 {
322 COLORMAT pr1toxyz, xyztopr2;
323
324 if (pr1 == pr2) {
325 mat[0][0] = mat[1][1] = mat[2][2] = 1.0;
326 mat[0][1] = mat[0][2] = mat[1][0] =
327 mat[1][2] = mat[2][0] = mat[2][1] = 0.0;
328 return;
329 }
330 comprgb2xyzmat(pr1toxyz, pr1);
331 compxyz2rgbmat(xyztopr2, pr2);
332 /* combine transforms */
333 multcolormat(mat, pr1toxyz, xyztopr2);
334 }
335
336
337 void
338 compxyzWBmat(mat, wht1, wht2) /* CIE von Kries transform from wht1 to wht2 */
339 COLORMAT mat;
340 float wht1[2], wht2[2];
341 {
342 COLOR cw1, cw2;
343 if (XYEQ(wht1,wht2)) {
344 mat[0][0] = mat[1][1] = mat[2][2] = 1.0;
345 mat[0][1] = mat[0][2] = mat[1][0] =
346 mat[1][2] = mat[2][0] = mat[2][1] = 0.0;
347 return;
348 }
349 cw1[RED] = wht1[CIEX]/wht1[CIEY];
350 cw1[GRN] = 1.;
351 cw1[BLU] = (1. - wht1[CIEX] - wht1[CIEY])/wht1[CIEY];
352 colortrans(cw1, vkmat, cw1);
353 cw2[RED] = wht2[CIEX]/wht2[CIEY];
354 cw2[GRN] = 1.;
355 cw2[BLU] = (1. - wht2[CIEX] - wht2[CIEY])/wht2[CIEY];
356 colortrans(cw2, vkmat, cw2);
357 mat[0][0] = cw2[RED]/cw1[RED];
358 mat[1][1] = cw2[GRN]/cw1[GRN];
359 mat[2][2] = cw2[BLU]/cw1[BLU];
360 mat[0][1] = mat[0][2] = mat[1][0] =
361 mat[1][2] = mat[2][0] = mat[2][1] = 0.0;
362 multcolormat(mat, vkmat, mat);
363 multcolormat(mat, mat, ivkmat);
364 }
365
366
367 void
368 compxyz2rgbWBmat(mat, pr) /* von Kries conversion from CIE to RGB space */
369 COLORMAT mat;
370 RGBPRIMS pr;
371 {
372 COLORMAT wbmat;
373
374 compxyz2rgbmat(mat, pr);
375 if (XYEQ(pr[WHT],xyneu))
376 return;
377 compxyzWBmat(wbmat, xyneu, pr[WHT]);
378 multcolormat(mat, wbmat, mat);
379 }
380
381 void
382 comprgb2xyzWBmat(mat, pr) /* von Kries conversion from RGB to CIE space */
383 COLORMAT mat;
384 RGBPRIMS pr;
385 {
386 COLORMAT wbmat;
387
388 comprgb2xyzmat(mat, pr);
389 if (XYEQ(pr[WHT],xyneu))
390 return;
391 compxyzWBmat(wbmat, pr[WHT], xyneu);
392 multcolormat(mat, mat, wbmat);
393 }
394
395 void
396 comprgb2rgbWBmat(mat, pr1, pr2) /* von Kries conversion from RGB1 to RGB2 */
397 COLORMAT mat;
398 RGBPRIMS pr1, pr2;
399 {
400 COLORMAT pr1toxyz, xyztopr2, wbmat;
401
402 if (pr1 == pr2) {
403 mat[0][0] = mat[1][1] = mat[2][2] = 1.0;
404 mat[0][1] = mat[0][2] = mat[1][0] =
405 mat[1][2] = mat[2][0] = mat[2][1] = 0.0;
406 return;
407 }
408 comprgb2xyzmat(pr1toxyz, pr1);
409 compxyzWBmat(wbmat, pr1[WHT], pr2[WHT]);
410 compxyz2rgbmat(xyztopr2, pr2);
411 /* combine transforms */
412 multcolormat(mat, pr1toxyz, wbmat);
413 multcolormat(mat, mat, xyztopr2);
414 }
